12 страниц V  1 2 3 > »
[Mgx] MutiPartition Tool By ilove3d, Translation By Nikhil007™
alxey
сообщение 4.10.2009, 16:13
Из: Kiev
Пользователь №: 144 371
Прошивка: E8 EM30 V8
MultiPartition Tool by ilove3d
Please backup your memory card Before using this application !!
2009-10-1
http://magxcn.com
All rights reserved, containing open-source script, leave the original author information!?????
Translation to English by Nikhil007™
Preface:
MOTOMAGX platform for the various models in the ilove3d's efforts have largely achieved MGX installation of software and MGS theme
Also achieved a very convenient for the font mounted
However, there has been very good to solve a problem, when using the font mounted or MGS theme, USB memory card mode then the computer will crash
Open MGX virtual memory is also true
This software can solve this problem
It is divided into three areas TF Card
1 District: still FAT32 format, and usually the same as
Zone 2: swap partition for virtual memory
Zone 3: EXT3 storage area, used to store themes, fonts, etc.
Set partition:
Within a certain range you can choose what you want size 2 and 3.
Transfer Subject:
Click on the theme of MGS after installation can be transferred to the EXT3 partition where
Ie / ezxlocal / download / mystuff / skins transferred to / mmc/ext3/skins
(Theme authors can continue to use the path in front of the transfer process will automatically replace the path)
Other mount:
Fonts
/ mmc/ext3/myfont.ttf
/ mmc/ext3/mynum.ttf
Switch machine animation
/ mmc/ext3/poweron.gif
/ mmc/ext3/poweroff.gif
Switching the sound
/ mmc/ext3/poweron.wav
/ mmc/ext3/poweroff.wav
Прикрепленный файл MultiPartition_Tool_By_ilove3d.rar   ( 132.45 килобайт ) Кол-во скачиваний: 786
Добавлено позже (4.10.2009, 19:26):
я себе этим форматнул флешку 128 свап и 384 етех3, но хотелось бы на оборот свап на 384 и етех3 на 128
Сообщение отредактировал alxey - 4.10.2009, 16:17
Witazzew
сообщение 4.10.2009, 17:58
Из: Ухта
Пользователь №: 180 655
Модель телефона: 910
можно по русски?
Atei
сообщение 4.10.2009, 19:07
Пользователь №: 127 717
Модель телефона: ROKR EM30 + 8Gb King
Прошивка: Perfect мод
куда стоко свапа?
Добавлено позже (4.10.2009, 23:29):
Прикрепленный файл Multi_Partition.rar   ( 132.15 килобайт ) Кол-во скачиваний: 504
Zorge.R
сообщение 4.10.2009, 21:35
Group Icon
Группа: System Administrators
Из: рук в руки
Пользователь №: 101 800
Прошивка: 1CR
Цитата(Witazzew @ Вчера, 21:58)
можно по русски?
Для начала, рекомендуется сделать бекап флешки.
затем ставим прогу и юзаем.
приложение делит флешку, на 3 раздела.
1- обычный fat 32, то что мы видим как флешку, при подключении телефона к ПК в режиме карты памяти.
2- swap раздел.
3- ext3 раздел.
Фишка в том что 1-й раздел как обычно отмонтируется при подключении к ПК в режиме флешки, а другие 2 остаются монтированными в теле.
размеры раздела 2 и 3, можно менять в определенных пределах.
В общем доступ к ним остается всегда. Поэтому и свап не отвалиться, и шрифты\темы можно в любом количестве ставить, в котором они влезут на ext3 раздел.
За компанию, можно подменить звуки старта и выключения тела и анимацию.
p.s.: как бЭ так.
Сообщение отредактировал Zorge.R - 4.10.2009, 21:36
Sereg_K
сообщение 5.10.2009, 11:07
Мотоснайпер
Из: Жемчужина у моря
Пользователь №: 60 316
Модель телефона: ROKR E8
Прошивка: Z-Mod E8
Вопрос
Если свап уже включен, то надо ли его отключить сначала? Или свап файл сам переместится в нужное место после перезагрузки?
Что-то у меня на флешку приложение вообще не хочет становиться, а в телефон становится, но не запускается.
Щас попробую еще оригинальное (не переведенное) приложение скачать.
Сообщение отредактировал Sereg_K - 5.10.2009, 12:21
@SEM*
сообщение 5.10.2009, 15:31
(M)LuckyMan
Из: Ukraine, Donetsk reg
Пользователь №: 126 920
Прошивка: Android 11 & 12
Sereg_K насколько я понял он "отбивает" от fat32 определённый сектор флешки и создаёт ещё 2 раздела - один для swap файла, другой для ext3 системы ( стандартной для Linux smile.gif Поэтому и рекомендуют сделать бэкап - ведь могут удалится нужные данные при "отбивании" пространства". А программа врядле будет искать в системе swap файл и перемещать куда нужно. Поравте если не прав shuffle.gif
Zorge.R
сообщение 5.10.2009, 17:02
Group Icon
Из: рук в руки
Прошивка: 1CR
Сборка от ilove3d, заточена под его моды. Поэтому работать нормально на большинстве сторонних не будет.
решил пофиксить (на большинстве модов должна работать)
Прикрепленный файл E8_Partitioner_z_fix.mgx.7z   ( 122.23 килобайт ) Кол-во скачиваний: 467
в конце имени убрать 7z и установить через диспетчер файлов. (Только в телефон!!!)
Затем запустить и выбрать первый пункт, после этого выбрать желаемый размер свапа и ext3 раздела.
Ext3 раздел в этом приложении, в отличии от оригинала будет монтироваться на /ezxlocal/ext3
p.s.: у вас должна быть поддержка авторана из /phone/unKnown/S*, для работы автозапуска скрипта.
p.p.s.: после перезагрузки, зайдите в /ezxlocal/ext3/ если там есть папка lost_&_found, значит все работает.
Добавлено позже (5.10.2009, 21:54):
и еще, если Вы уже успели воспользоваться E8_Partion, а он у Вас не работал, то:
1) удалите его
2) удалите скрипт автозапуска (лежит по адресу /phone/unKnown/)
3) перезапустить телефон.
4) установите E8_Partitioner_z_fix.mgx
5) Запустите E8_Partitioner через mpkgbox, выберите Setting Up/FT_Restore, через пару минут перезапустить телефон.
6) Опять запустите E8_Partitioner через mpkgBox и выберить Setting Up/нужный размер свапа и ext3.
7) После того как он выдаст ОК, перезапустите телефон. Все должно работать.
Если не поможет, запустите info_restore.sh (phone/mpkgbox/e8_partion/) вручную, диспетчером файлов телефона. подождите 2 минуты, перезагрузитесь и проделайте пункты 4, 6, 7.
Сообщение отредактировал Zorge.R - 5.10.2009, 17:59
kale
сообщение 5.10.2009, 19:42
Пользователь №: 186 237
Модель телефона: e8,e398
Прошивка: black diamond 373
у меня незапускается((((
ставлю всё правильно вроде....но ничего не происходит....но флешку уже форматнуло....
Zorge.R
сообщение 5.10.2009, 21:14
Group Icon
Из: рук в руки
Прошивка: 1CR
вот свежая сборка, со встроенными шоу модулями (чтобы работало даже на тазике и тостере):
Прикрепленный файл E8_Partitioner_z_1.3_fix.mgx.7z   ( 122.7 килобайт ) Кол-во скачиваний: 520
так же исправил пути для шрифтов, скинов, звуков и анимации старта и отключения, на /ezxlocal/ext3/
p.s.: перед установкой, прочтите пост №7 ^, там написано про танцы с бубном, если Вы уже ставили прогу.
alxey
сообщение 6.10.2009, 5:01
Из: Kiev
смотрите, перенес скины на ехт3, потом зашел в темы показывает что все схм файлы с ошибкой и удалило их. как поставить скин чтоб работал с ехт3?
Добавлено позже (6.10.2009, 8:12):
все. сам разобрался. надо изменить путь в файле конфигурации скина на exectlocal/ext3/skins/
все пользовательские скины работабт норм в режиме карта памяти
[Mgx] MutiPartition Tool By ilove3d, Translation By Nikhil007™ · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 19.4.2024, 3:20
