32 страниц V « < 30 31 32
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX]
OCM770
сообщение 10.7.2009, 7:33 Закрепленное сообщение!
Пользователь №: 196 171
By OCM770 in cooperation with Kidscracker and Skrilax_CZ
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes & Kernel
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, he is a great person and an awesome developer wink.gif
Second I would like to thank Skrilax_CZ for giving me great suggestions for this MP and of course patching the camera libs and mediaplayer lib. Also thanks to fldodger for fixing the Alkali skin and Skrilax for perfecting it.
Also thanks to Ant-ON for developing zTaskMan, AnarH and Tim_22R for making the main menu svg files
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys :D
Change log:
So I wasn’t satisfied with Freedom 7FR. I was convinced it was possible to run a custom kernel and have everything else working correctly. At last I figured out how to do so and took the opportunity to change more things, adding more features and some tweaks and bugfixes. So I present to you this MP which in my opinion excels over my previous one. As more mods come out and more developers obtain a ZN5 I will continue making more MP’s. I hope you like this MP wink.gif
Kernel Mods:
  • SWAP Support
  • Squashfs 3.4 Support. Now this is a real handy feature for developers. Using this kernel in another firmware you can use Squashfs 3.4 to squash the code groups using a block size of up to 1MB for a greater compression. It uses default block size of 128kb. Compared to Squashfs 2.2 with a max block size of 64kb.
  • EXT2, EXT3, NTFS Support
  • IPv6 support (needs to be tested)
CG36 Mods:
  • Bash (as a replacement for busybox ash)
  • busybox version 11.14.1 with many more features than standard busybox (as /bin/busybox_full)
  • EasyThemes by ilove3d (drop skin folders in /ezxlocal/download/mystuff/skins/) with SVG support.
  • Mediaplayer can play CIF videos.
  • zTaskMan included under Office Tools and Main Menu (in CG52)
  • Modification of some SVG files to edit softkey size in main menu and make main menu 15 icons
  • SWAP file gets turned off when connected in memory card mode and automatically re-enabled when disconnected from PC. This to avoid the phone crashing.
  • Mpkgbox (by kidscracker, original by ilove3d)
  • RAW and Binned RAW Pictures with fixed remaining picture estimate and red icons in iconres.ezx
  • CIF Recording 15FPS
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Optional Features (read below)
  • Custom Bootscreen
  • Custom Startup/Shutdown Animations
  • 15 icon main menu (animated with optional features)
  • Skins: Alkali (fixed), Kodak, Indium
Optional Features & SWAP
Right after flashing this firmware the phone will prompt to install Optional Features. What these do is install the medl and medld.conf folder along with some GUI tweaks (changed font, main menu animation, etc). You can chose to install these in Phone Memory or Memory Card (I HIGHLY recommend installing them to phone memory). Either choosing to install these or to not install them the phone will only prompt once. (To make the script run again delete /ezxlocal/medl or if you chose not to install them delete /ezxlocal/delete_to_run_initial_script).
Even if you chose not to install Optional Features the phone will still prompt if you want to install and enable SWAP. Once again, you can install this feature to phone memory or memory card ( I still recommend to install to phone memory). You can chose a swap file size of 32mb or 64mb ( I recommend 64mb for 062A users and 32mb for 062DP users). This part of the script will also only run once (to make it run again remove /ezxlocal/delete_to_run_initial_swap and /ezxlocal/download/mystuff/swapfile (for internal memory) or /mmc/mmca1/swapfile (for external memory))
Instructions
  1. Use RSD Lite 4.x for all flashing
  2. Download the version that corresponds to your bootloader (062DP is also for 062B users)
  3. Flash noRSA bootloader that corresponds to your bootloader
  4. Flash the version of Freedom Features Update that corresponds to your bootloader
  5. Follow Optional Features Instructions and wait for it to reboot (if by any chance it doesn’t reboot wait 3-5 minutes then remove/reinsert battery)
Download Link: Known Bugs:
  • Volume for mediaplayer can’t be modified from homescreen
ПЕРЕВОД:
От OCM770, совместно с Kidscracker и Skrilax_CZ
Основан на R6637_G_81.00.7FR + R6637_G_81.11.2CR Испрвлениях & Ядре
Благодарности
За этот монстрпак я должен особенно поблагодарить моего друга Kidscracker-а, за помощь мне в нескольких вещах, за то что вернул меня в этот проект и, конечно, за разработку Mpkgbox. Он великий человек и офигенный разработчик.
Во-вторых я хочу поблагодарить Skrilax_CZ за большие предложения для этого MP и, конечно, за патчинг либ камеры и медиаплеера. Также спасибо fldodger-у за исправления скина Alkali и Skrilax за доведение его до ума.
Также спасибо Ant-ON-у за разработку zTaskMan-а, AnarH-у and Tim_22R за переделку svg файлов для главного меню.
Далее я хочу поблагодарить сообщества моддеров телефонов Motorola в сети, особенно ModMyMoto, где я вырос, и MMUS за то что взяли меня как часть своей команды. Оба этих сообщества очень дружелюбны и готовы помочь, будьте такими всегда, ребята.
Изменения:
Итак, я не удовлетворился Freedom 7FR. Я был убежден, что возможно запустить свое ядро и все будет работать правильно. Наконец, я понял как это можно сделать и воспользовался этой возможностью, чтобы изменить больше вещей, добавить больше возможностей и некоторое количество фишек и исправлений ошибок. Итак, я представляю вам этот MP, который, по моему мнению превосходит предыдущий. По мере появления новых модов и новых разработчиков, имеющих ZN5 я продолжу делать больше монстрепаков. Я надеюсь вам понравится этот MP.
Моды ядра:
  • Поддержка swap.
  • Поддержка Squashfs 3.4. Это действительно удобная функция для разработчиков. Используя это ядро в других прошивках вы можете использовать Squashfs 3.4 для сборки кодовых групп с размером блока до 1 мегабайта для большего сжатия. По умолчанию используется размер блока 128 килобайт. По сравнению с Squashfs 2.2 с максимальным размером блока 64 килобайта.
  • Поддержка EXT2, EXT3, NTFS
  • Поддержка Ipv6 (необходимо тестирование)
Моды в CG36:
  • Bash (как замена для busybox ash)
  • busybox версии 11.14.1 с намного большим количеством функций чем стандартный busybox (как /bin/busybox_full)
  • EasyThemes от ilove3d (кидайте скины в папку skin в /ezxlocal/download/mystuff/skins/) с поддержкой SVG.
  • Mediaplayer теперь может проигрывать CIF видео.
  • ZtaskMan, включенный в меню Органайзер и Главное меню (в CG52)
  • Модификация нескольких SVG файлов для изменения размера подписей к софт-клавишам и 15 иконок в галвном меню
  • Swap файл выключается, когда телефон подключается в режиме карты памяти и автоматически включается при отключении от ПК. Это позволяет избежать зависание телефона.
  • Mpkgbox (от kidscracker-а, изначально от ilove3d)
  • RAW и Binned RAW режимы фото с исправленными рамкой и иконками в iconres.ezx
  • CIF запись видео 15FPS
  • Запуск скриптов из файл-менеджера
  • Распаковка rar и zip из файл-менеджера
  • Show* модули
  • Удалены определенные модули для увеличения скорости работы прошивки
Дополнительно:
  • Дополнительные возможности (читайте ниже)
  • Измененная загрузочная картинка
  • Измененная анимация на включение/выключение
  • Главное меню с 15 иконками (анимированное с дополнительными возможностями)
  • Скины: Alkali (исправленный), Kodak, Indium
Дополнительные возможности & SWAP
Сразу после прошивки телефон спросит, устанавливать ли дополнительные возможности. Что при этом делается — устанавливается папка medl и medld.conf вместе с несколькими настройками GUI (измененный шрифт, главное меню, анимация и т.д.). Вы можете выбрать куда устанавливать, в память телефона или на карту памяти (я НАСТОЙЧИВО рекомендую устанавливать мод в память телефона). Неважно, выберите вы установку или отмену установки, телефон больше об этом не спросит. (Чтобы запустить скрипт снова удалите /ezxlocal/medl или, если вы выбрали не устанавливать, удалите файл /ezxlocal/delete_to_run_initial_script). Даже если вы выбрали не устанавливать дополнительные возможности телефон спросит, хотите ли вы установить и включить Swap. И снова, вы можете установить его в память телефона или на карту памяти ( я снова рекомендую устанавливать в память телефона). Вы можете выбрать размер swap-файла, 32 или 64 мегабайта (я рекомендую 64 мегабайта для пользователей с бутом 062A и 32 для пользователей с бутом 062DP). Эта часть скрипта также запускается только один раз (чтобы запустить его снова удалите /ezxlocal/delete_to_run_initial_swap и /ezxlocal/download/mystuff/swapfile (для памяти телефона) или /mmc/mmca1/swapfile (для карты памяти)).
Инструкции.
  1. Используйте RSD Lite 4.x для всех прошиваний
  2. Скачайте версию, которая соответсвует вашему бутлоадеру (062DP также подходит и для пользователей с 062B)
  3. Прошейте noRSA бут, который соответствует вашему буту.
  4. Прошейте версию Freedom Features Update, которая соответствует вашему буту.
  5. Следуйте инструкции установки дополнительных возможностей и ждите, пока телефон перезагрузится (если он не перезагрузится, подождите 3-5 минут и вытащите/вставьте батарею)
Ссылка для скачивания:Известные проблемы:
Громкость в медиаплеере нельзя изменить пока плеер свернут на главном экране.
Senx Lukas K. and Neomoto for translate on Russian
перевод на РУССКИЙ
Сообщение отредактировал EXL - 25.11.2010, 7:47
сообщение 30.12.2010, 7:51
да я тоже катанулся на прошу зорга. Но эта проша меня порадовала скоростью. Видео неплохо пишется. Но фото немного страдает но не так плачевно. Совместить пару фишек от других прош и будет супер.
mus13
сообщение 30.12.2010, 8:10
Из: РД
Пользователь №: 44 644
Модель телефона: Mpx220+Zn5
Прошивка: outlaw1313 v1.0 FFE
вот эта совместимость и была реализована у неомото
Neomoto
сообщение 30.12.2010, 22:32
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
если кому еще интересно, вот тот мой пост - ВОПРОС-ОТВЕТ
эх, как давно это было..
Сообщение отредактировал Neomoto - 30.12.2010, 22:33
sidno
сообщение 31.12.2010, 9:50
Из: Томск
Пользователь №: 204 629
Модель телефона: ZN5
Прошивка: Symbiosis X.1Final
Эх, Neomoto, взял бы да замутил монстра.. нам всем на радость clapping.gif Тем более что Ден отошел от проекта..
FdasweL
сообщение 2.1.2011, 18:18
Пользователь №: 214 903
Neomoto
Залил я в exlocal твой архив, но Pemanager не установился, иконка его в меню видна, но не запускается. Можешь объяснить как его установить? Или ссылку дать, где рассказано как это делается.
mus13
сообщение 7.1.2011, 6:23
Из: РД
FdasweL не знаю, что ты и как устанавливал, у меня все работает, правда есть несколько косяков:
1. с блокировки выходит медленно.
2. на блокировке может пропадать индикатор времени.
3. аккум держит меньше, чем на других прошах.
4. во время съемки видео, если отсчет времени остановился - снимать аккум.
dimonka_pavlov
сообщение 21.4.2011, 14:29
Пользователь №: 192 535
Модель телефона: ZN 5
плиз зелейте кто-нибудь...все ссылки умерли..хочетсья попробывать...для 0.62A
сообщение 22.4.2011, 10:42
Freedom Features Update 062A - ДЛЯ ПРОСТЫХ ЗН5 64 МЕТРОВЫХ.
https://mega.nz/#!XgJEGawL!-UK0091N...DJcM1oNQthtrv8I
Freedom Features Update 062DP-ДЛЯ T-MOBILE, 128 МЕТРОВЫХ ЗН5.
https://mega.nz/#!ntBWjKzK!7wyo-O1e...HaP6DgD9hE1QPRU
Сообщение отредактировал Claus398 - 13.12.2018, 7:23
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX] · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 25.4.2024, 10:38
