where it will store programme after install
zPart, Rev.1.2.zpk |
are_ed |
29.4.2010, 11:17
Опытный Группа: Пользователи Сообщений: 133 Регистрация: 24.2.2008 Пользователь №: 164 538 Модель телефона: e398 Рейтинг: 12.5 |
Zorge.R |
29.4.2010, 11:20
Ветеран Группа: System Administrators Сообщений: 1 915 Регистрация: 4.10.2006 Из: рук в руки Пользователь №: 101 800 Модель телефона: Note 9 Copper 512Gb Прошивка: 1CR Рейтинг: 2510 |
are_ed |
29.4.2010, 11:28
Zorge.R |
29.4.2010, 11:35
are_ed, Just run zPart 1.2 from file manager, wait "install complete" message, push OK and You will se zPart Menu. Do everything you want in that.
are_ed |
29.4.2010, 13:32
N!kola |
30.4.2010, 17:05
Опытный Группа: Пользователи Сообщений: 126 Регистрация: 11.8.2007 Из: Сербия Пользователь №: 144 136 Модель телефона: E398(x2) | ROKR E8 Прошивка: Anarchy48R | Z-Mod Рейтинг: 22 |
I've got problems. I have 4gb microSDHC card and Z-Mod 2.4.5 original.
I've tried making vfat|ext|swap (3643mb | 128mb | all the rest) two times, both times I've got 3450mb vfat, 310mb swap (which wouldn't mount after restart) and ext in which the lost+found folder would disappear after restart. That's two times. Third time I've tried vfat|swap|ext (3650mb | 128mb | all the rest) and I've got 3474mb vfat, 113.5mb swap and 289mb ext... I will use it that way, it's not a problem, but I thought I should tell you about this... I don't know if it's a bug. Thanks for another cool app, Zorge! |
Zorge.R |
30.4.2010, 17:18
N!kola, in the first post you can read about "vfat|ext|swap" , this is for ZN5. On zMod you need |vfat| or |vfat|swap| or |vfat|swap|ext|
then, you write 3650mb, it will be approximated to 3474mb (it's same) then, you write 128mb swap, and see 113.5mb. zTaskManager show You FREE swap size. (~12.5 Mb are occupied) then, 289mb it's all rest EXT=MicroSDsize-(vfat+swap) |
N!kola |
1.5.2010, 8:08
N!kola, in the first post you can read about "vfat|ext|swap" , this is for ZN5. On zMod you need |vfat| or |vfat|swap| or |vfat|swap|ext| then, you write 3650mb, it will be approximated to 3474mb (it's same) then, you write 128mb swap, and see 113.5mb. zTaskManager show You FREE swap size. (~12.5 Mb are occupied) then, 289mb it's all rest EXT=MicroSDsize-(vfat+swap) Silly me Yeah, I remembered later that it shows only free Thank you, again, for this fine app! |
MATRICE |
2.5.2010, 22:11
Новичок Группа: Пользователи Сообщений: 23 Регистрация: 30.8.2008 Пользователь №: 180 207 Модель телефона: E1 Рейтинг: 0 |
Can it download manually?i had some problem to download it.i dont have internet connection.just us edge.
ObScEnE |
8.5.2010, 15:18
Интересующийся Группа: Пользователи Сообщений: 48 Регистрация: 14.5.2007 Из: Лобня Пользователь №: 134 816 Модель телефона: Moto L7e;EM30;C380 Рейтинг: 0 |
огромное спасибо всё работает на ура!!
Текстовая версия | Сейчас: 23.4.2024, 8:56 |
