18 страниц V < 1 2 3 4 > »
[MP] Freedom 7FR [MPKGBOX + QVGA], новый монстр!
OCM770
сообщение 9.6.2009, 16:16 Закрепленное сообщение!
Пользователь №: 196 171
Freedom 7FR
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, looking forward to working with you again Carlos wink.gif
Second I would like to thank tankrider, Skrilax_CZ and NestorM for clearing up some doubts I had and giving me suggestions for this MP.
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys biggrin.gif. Motofan as well for having awesome developers wink.gif
Благодарности:
За этот МодПак я особо рад сказать спасибо моему другу Kidscracker, за помощь мне с разными вещами, возвращение меня в проект, и конечно за разработку Mpkgbox. Расчитываю посотрудничать с тобой ещё, Карлос wink.gif
Второе: хочу поблагодарить tankrider, Skrilax_CZ и NestorM за то, что развеяли мои сомнения и за пожелания к моду.
Далее я хотел бы сказать спасибо сетевым сообществам моддеров Motorola, особенно ModMyMoto, которое меня взрастило, и MMUS, которое приняло меня в свои ряды. Оба сообщества очень дружелюбны и полезны, такими и будьте, ребята. Также и Motofan за выдающихся разработчиков.wink.gif
Change log:
This MP was originally based on R6637_G_81.11.2CR and it had a patched kernel that enabled swap, among some other features that are really only cosmetic. I decided to base this on R6637_G_81.00.7FR after it was discovered that it could record in QVGA. 7FR Camera libs won’t work on 2CR and while trying to make them work I ended up with a huge mess and other things started breaking. So I decided to base it on 7FR, unfortunately however, The custom kernel from 2CR will not run 100% well with 7FR, if it is flashed this way the wifi stops working. So I made a came to the conclusion QVGA was more important than a custom kernel with swap, therefore this firmware does NOT have SWAP capability. Im sure you guys will understand. If someone can get there hands on 7FR Source code please let me know so I can patch the kernel as this source is not available on Motorola’s site due to 7FR being a developers release.
История изменений:
МП изначально основывался на прошивке R6637_G_81.11.2CR с патченным ядром, включающим подкачку, а среди других изменений были в основном только косметические. Я решил перейти на R6637_G_81.00.7FR после того, как обнаружил, что в ней доступна запись видео в QVGA. Библиотеки (либы) камеры от 7FR не подходили для 2CR и в попытках заставить их работать я наломал немало дров, а точнее, работоспособного до того софта. Так что базовой стала 7FR, и, к сожалению, от самодельного ядра 2CR пришлось отказаться - на 100% с 7FR совместимым оно не было, после прошивки с ним отказывался работать wi-fi. Я решил, что запись видео в QVGA намного важнее, чем и ядро, и подкачка, поэтому эта прошивка БЕЗ функции СВОПА. Уверен, вы меня поймёте. А если у кого руки дойдут, и будут исходники 7FR, дайте мне знать - пропатчим ядро, а то так-то код недоступен на сайте Моторолы, ибо 7FR - релиз для разработчиков.
скрыть.
CG36 Mods:
  • MPKGBOX
  • QVGA Recording
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Custom Bootscreen
  • Skins: Alkali, Kodak, Indium, Tuscan (Alkali is not present in 062A version)
Instructions (инструкция как шить)
  1. Use RSD Lite 4.x for all flashing - используем RSD версии 4.x для прошивки
  2. Flash noRSA bootloader that corresponds to your bootloader - сначала прошиваем бут noRSA
  3. Flash the version of Freedom 7FR that corresponds to your bootloader - прошиваем сответствующую версию прошивки для вашего бута (для 062А -062A Version 1a и т.д.)
  4. Flash Update 1B corresponding to your bootloader - прошиваем обновление (для 062A бута - Update 1B 062A)
  5. Прошиваем русский ленг отсюда: ЛЕНГПАКИ ДЛЯ ZN5
Download Link:This MP does NOT have the lost calls after reboot bug
Это делает MP не имеют потерянных вызовов после перезагрузки ошибка
Сообщение отредактировал AstaRoth - 30.6.2009, 16:05
OCM770
сообщение 10.6.2009, 13:03
New version posted. Contains all bugfixes in one package and sync should work
[/quote]
Новая версия размещена. Содержит все исправления в один пакет и синхронизация должна работать[/quote]
Stray39
сообщение 10.6.2009, 16:15
Пользователь №: 198 407
Модель телефона: MOTOZINE ZN5
Прошивка: пока не определился
проставил обновление ... пример видео... про какие тормоза в плеере говорят не понятно.... кто там заикается.. видео по сравнению с тем что было ... небо и земля... синхронизация с Motorola Phone Tools работает отлично
Пару фоток для примера ... в режиме макро и авто... с фокусировкой проблем не наблюдаю
появился пункт экспозиция в фотоапарате
да с темой Tuscan проблема есть..
Сообщение отредактировал Stray39 - 10.6.2009, 16:45
alexа
сообщение 10.6.2009, 16:20
Из: Пушкин (Царское Село)
Пользователь №: 189 845
Модель телефона: Зина 5
Прошивка: 0ER
Ты тему Tuscan поставь и в плеер зайди.
Про видео я всё таки думаю что это не предел для Зины. С таким то процом smile.gif
Добавлено позже (10.6.2009, 16:23):
Ипапка
062A Version 1a
062DP Version 1a
Сообщение отредактировал alexа - 10.6.2009, 16:23
GandjaFuzz
сообщение 10.6.2009, 16:35
Motofuzzer
Пользователь №: 26 583
Модель телефона: ZN5 T-Mobile
Прошивка: 2CR_128
вы посмотрите на версию прошивки. 00!!!.7FR одна из самых первых версий прошивка. проще перетащить камеру на более новую прошивку. чем шить первую - глючную. проблема состоит в том что при переносу всех либ. ругается на версию qt но это не так и трудно поправить. а то что видео плохо записывает. думаю просто нужно повысить битрейт и все.
Сообщение отредактировал GandjaFuzz - 10.6.2009, 16:39
alexа
сообщение 10.6.2009, 16:59
Прошивка: 0ER
Ещё к радио прикрутили типа РДС
trace2343
сообщение 10.6.2009, 17:01
Из: UA
Пользователь №: 199 910
Модель телефона: zn5
Прошивка: R6637_G_81.05ER
УРАААА!!! после прошивки ЗАРАБОТАЛО авто обновление времени! рекомендую всем у кого были проблемы clap.gif
Tobias37
сообщение 10.6.2009, 17:43
Пользователь №: 175 317
Цитата(uzHeR @ 10.6.2009, 20:23) *
звонки не звонят. вызов идет, но мелодии нет
В режиме звонок+вибрация один раз вибрирует, звонка нет.
В режиме вибрации все нормально вибрирует.
В режиме звонка как будто на безшумном, звонка нет.
garic
сообщение 10.6.2009, 19:47
Из: Ростов на Дону
Пользователь №: 104 131
Модель телефона: Galaxy s 2
Прошивка: motofan
позитив )
Тоже ставил вчерашний мод+turbo lang. Звонок входящий звучит, камера в режиме видео сегодня повесила тело, пришлось батарейку доставать .Пока нравиться ,шустрый мод по сравнению с oer.
Добавлено позже (10.6.2009, 23:54):
Karaban,шас сливаю подожди
Добавлено позже (11.6.2009, 0:20):
Вот http://ifolder.ru/12587044
OCM770
сообщение 10.6.2009, 20:32
I know about the bug where you can not hear the ringtone, please understand that this firmware is based on 81.00 series which is very buggy, i am trying to correct as many bugs as possible, i have already corrected this ringtone bug and will upload the patch as soon as im certain no more obvious bugs are present
Я знаю об ошибке, когда вы не можете услышать мелодию, пожалуйста поймите, что этот микропрограммой основывается на 81.00 серий, которые очень плохо, я пытаюсь исправить столько ошибок, как это возможно, я уже исправила эту ошибку рингтон и загрузить Патч, как только им определенную не более очевидные ошибки присутствуют
r.o.m.a.N
сообщение 10.6.2009, 23:30
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Интересно узнать, действительно ли этот мод шустрее 0Е, или нет. Прошил на 0Е ток Cg36 от 07, прогнал тесты (при тестах тел быть подключен к компу для снятия скриншотов)
http://www.jbenchmark.com/download.jsp?benchmark=3d
1, 2 и 3D
Результаты
1:
2:
3D:
Asta: Рома, я через тесты не прогонял-но чисто субъективно - этот монстр шустрее 0Е, причем это заметно невооруженным глазом.
Сообщение отредактировал AstaRoth - 11.6.2009, 5:22
[MP] Freedom 7FR [MPKGBOX + QVGA], новый монстр! · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 19.4.2024, 10:03
