[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем.
Offset
сообщение 30.9.2009, 12:05 Закрепленное сообщение!
Leo
Пользователь №: 126 712
RockBox
Hello everybody, I hereby present the official version of the magnificent RockBox.
Some time ago and I adapted the Douglas RockBox Beta (version 3.3) of the Rokr Z6 developed by CepiPeres, was a great application but had some bugs and problems.
Well, then, was recently released on the website of RockBox version 3.4 of this fantastic multimedia center.
Team Motocaker Team took the opportunity to upgrade the family's RockBox MOTOMAGX.
I decided to adapt and adjust to this latest version to our dear ZN5 and the result was amazing. So I'm here to share with you the new version of RockBox.
What's new in this application compared to the Beta:
-Now the application no longer needs to be closed Plugin, just press the power button (red) to close the application.
-Now we can listen to music and continue stirring in the application, we can see photos, play games, use some mini-application, do whatever we want.
-Added the game Doom within the application to play while we hear that favorite song.
-Is it possible to play videos at 25fps in MPEG format.
-Is it possible to play ATRAC3 audio files.
-Is it possible to play audio files AC3.
-Is it possible to play AAC audio files.
-System stabilized and made some adjustments.
Keyboard Configuration:
- Volume Buttons: Controls the volume.
- Smart button: Main Menu.
- Directional Up and Down: Controls the volume and menu controls.
- Directs Right: Next and Select.
- Directional Left: Backwards and Back.
- Center Button: Selects functions.
- Left Softkey: Pause and Play in Playback mode.
- Right Softkey: Stop the music / Exit (when using a plugin or game that does not run correctly).
- Red Button: Close the application.
- Green Button: Capture screen images.
The application has 3 display modes: Portrait, Landscape and Landscape II.
Images of the application:
I recommend installing it on the Memory Card.
Works perfectly in Freedom Evolution Brazil 2.0 by Junior Passos, Evo2 and Evo3 by iLove3d.
Download:
http://www.4shared.com/file/136344685/6e89...Box_ZN5_EN.html
Sorry my English.
Credits:
Motocaker Team (RockBox)
Ant-ON (SDL)
Junior Passos (Ported for ZN5)
Оригинал топик
скачать с сервера mmus СКАЧАТЬ (необходима регистрация)
Скачать с ifolder.ru
Установка RockBox 3.4 (mgx): автор мануала: EXL
1.Скачиваем сам mgx-пакет RockBox, открываем его с помощью архиватора (Я пользуюсь WinRar). Извлекаем папку RockBox в любое доступное место на жестком диске.
2. (Внимание! Телофон должен быть прошит любым пользовательским модом с поддержкой MPKGBOX)!!!
Подключаем телефон в режиме КАРТЫ ПАМЯТИ и кидаем папку RockBox в папку mpkgbox на вашей флешке. Отключаем телефон, заходим в MPKGBOX, вибираем вкладку "карта памяти", запускаем RockBox. Установка завершена!
Общая настройка:
1. Создание главного плейлиста - заходим Playlists, Create Playlist (Создаётся плейлист каталога MMC/Music/).
Просмотр и воспроизведение песен плейлиста - Playlists, View Current Playlist
2. Плеер оснащен очень удобной Базой Данных, в которой музыка из каталога MMC/Music/ сортируется на множество категорий - начиная с Исполнителя, Альбома и заканчивая Годом, Номером трека и даже первой буквой различных категорий! Создать базу можно в меню Database.
3. В плеере есть встроенный Файл-Менеджер (меню - Files), чтобы вызвать контекстное меню в нём, нужно зажать центральную клавишу джойстика.
4. Plugins - здесь сосредоточены игры(присутствует даже Doom), небольшие програмки и визуализация/заставки для плеера. Стоит отметить, что не все плагины работают корректно.
5. System - информация о телефоне и RockBox'e, установка времени сна и др.
Пользовательская настройка: (Пункт Settings)
1. Sound Settings - Здесь можно настроить звучание под себя.
Основные пункты изменяющие звук:
1.1. Stereo Width - рекомендую поставить 250% (Расширение стереобазы)
1.2. Equalizer - Сначала включаем (Enable EQ, Yes), Затем либо настраиваем сами, либо воспользуемся
предустановками (Browse EQ Presets) которые действительно меняют звук!
Совет: 1. Самое качественное звучание - настройка Best Sound Quality (На мой взгляд)
2. Самое громкое Rock Clear + Sound Settings, Limiter Preamp нужно поставить в значение 8.0 db
1.3. Limiter Preamp - Если песня тихая, изменяем значение этого параметра на большее (Например 8.0 db)
2. Playback Settings - Здесь выставляете настройки проигрывания (Повтор, Случайное воспроизведение и др.)
3. General Settings - Общие настройки плеера. Здесь можно выставить русский язык (Language)!
ВНИМАНИЕ! Чтобы русский язык отображался, он должен поддерживаться текущим шрифтом!
4. Theme Settings - Настройка тем.
4.1 Browse Theme Files - Здесь выбираем нужную Вам тему плеера.
4.2 Font - Установка шрифта плеера. (Русский язык отображается например в шрифте unifont)
4.3 While Playing Screen - Установка оболочки самого проигрывателя.
4.4 Show Icons -Настройка показа иконок
5. Manage Settings - Здесь можно сбросить все настройки плеера по дефолту, если вы где-то напортачили. (Reset Settings)
Клавиатура:
Вверх, вниз: громкость в плеере и вверх-вниз в меню.
Вправо: "Следующий трек", Удержание: "Перемотка вперед" - в плеере и выбор в меню.
Влево: "Предыдущий трек", Удержание: "Перемотка назад" - в плеере и назад в меню.
Качелька громкости: управляет громкостью в плеере. Для регулирования необходимо зажать (Длинная шкала)
Центральная кнопка джойстика: Выбор и контекстное меню при зажатии.
Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
Право софт-клавиша: Стоп/выход (при использовании плагина или игры, которая не работает должным образом).
Красная кнопка: Выход из плеера.
Зеленая кнопка: Скриншот экрана.
Шрифты, поддерживающие русский язык:
11-Nimbus
13-Nimbus
15-Adobe-Helvetica
16-GNU-Unifont
19-Nimbus
cfsj-12pt
Corbel_12
Epsy+asian-12
FZXSQJ-12pt
helvR12
kaiti-14pt
msyh-12pt
msyh-13pt
myfont-12pt
nimbus+uming-14
nimbus-12
nimbus-19
Segoe_UIB_12
shaonv-14pt
simsun_ok
st
STCAIYUN-14pt
unifont
Сменить язык интерфейса в RockBox можно, зайдя в Settings, потом Theme Setings, потом Font устанавливаем - жмем Unifont, возвращаемся назад к пункту General Settings, входим там папка Language.В ней выбираем язык какой хотим.
Еще раз пользуясь случаем благодарим этих камрадов:
Ant-ON (SDL)
Сообщение отредактировал Offset - 12.11.2010, 19:17
22 страниц V  1 2 3 > »
Ответов(1 - 9)
holyt
сообщение 30.9.2009, 14:53
Пользователь №: 193 712
Модель телефона: zn5
Все замечательно работает на симбиозе 2.1.
Ramiro
сообщение 30.9.2009, 14:57
Пользователь №: 118 051
Модель телефона: С650,E398,L7,L9,ZN5
Прошивка: Evolution-XXXBEST
Перевод Гугля!!! Немножко подкорректировал что понял, для лучшего восприятия!!
Привет всем, представляю вам официальную версию великолепного RockBox.
Некоторое время назад, и я адаптировал RockBox Бета (версия 3.3) ROKR Z6 разработана CepiPeres, было большое приложение, но были некоторые ошибки и проблемы.
Недавно на сайте RockBox была выпущена Версия 3.4 этого фантастического мультимедийного центра.
Команда Motocaker воспользовалась возможностью обновила RockBox семьи MOTOMAGX.
Я решила, чтобы адаптировать и приспособить эту последнею версии для наших дорогих ZN5 и результат был удивительный. Так что я нахожусь здесь, чтобы поделиться с вами новой версия RockBox.
Что нового по сравнению с Beta:
-Теперь приложение больше не нуждается в закрытии плагина, просто нажмите кнопку питания (красную), чтобы закрыть приложение.
-Теперь мы можем свернуть RockBox и продолжать перемешивание в применении, мы можем увидеть фотографии, играть в игры, использовать некоторые мини-приложения, делать все, что мы хотим.
-Добавлено игру Doom в приложении играть в то время как мы слышим, что любимой песней.
-Может играть в 25fps видео в формате MPEG.
-Может играть в ATRAC3 аудио файл.
-Может воспроизводить аудио AC3 файл.
-Может играть AAC аудио файл.
Система стабилизирована и сделаны некоторые корректировки.
Настройка клавиатуры:
- Клавиши регулировки громкости: управляет громкостью.
- Smart кнопки: Главное меню.
- Направленный вверх и вниз: управляет громкостью и меню управления.
- Поручает Справа: "Далее" и выберите.
- Направленные Слева: назад и Назад.
- Центральная кнопка: Выбор функции.
- Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
- Право софт-клавиша: Stop The Music / выезда (при использовании плагина или игру, которая не работает должным образом).
- Красная кнопка: Закрыть приложение.
- Зеленая кнопка: Захват изображения экрана.
Программа имеет 3 режима просмотра: Портрет, Пейзаж и ландшафт II.
Я рекомендую установить его на карту памяти.
Прекрасно работает на прошивках свобода, эволюция, Бразилия 2,0 младшие Пассос, EVO2 и EVO3 по iLove3d.
Скачать:
извините за мой плохой английский.
Кредиты:
Ant-ON (SDL)
Junior Пассос (портирована на ZN5)
Сообщение отредактировал Offset - 2.10.2009, 13:47
D-1c3
сообщение 30.9.2009, 15:24
Пользователь №: 150 086
Модель телефона: L9/ZN5/E398/Z6/Dr2G/XT910
Прошивка: свежая
конвертируйте кто нить в .рер плс. не могу скачать прогу для этого самостоятельно в силу жопореза.
буду очень признателен
кстати вопрос про плейлисты остается открытым. неужели их никто не использует??
sim_emrom
сообщение 30.9.2009, 16:42
Из: Ханты-Мансийск
Пользователь №: 195 802
Модель телефона: Spica
Прошивка: a.v.2.1
Неужели ОНО настолько хорошо?
Кто ставил, скажите: как скорость запуска? Как там с обновлением базы и вообще сравнение со стандартным плейером. Если эта штука лучше, то возможно стоит отрубить стандартный плейер и его вечно обновляющуюся после работы с флешкой базу насовсем...
Скачиваю файл сейчас, проверю как будет возможность на своей чистой 0ER.
С возвращением на форум меня.
Всем привет! Я здесь постольку, поскольку хочу представить официальную версию великолепного RockBox.
Какое-то время назад я адаптировал Douglas RockBox Beta 3.3 с Rokr Z6, разработанный CepiPeres, это была прекрасная программа, но с долей багов и проблем.
Ну и вот, наконец недавно на сайте появился релиз RockBox 3.4 этого фантастического мультимедиа-центра.
У команды Motocaker Team появилась возможность обновить семейство RockBox на базе MOTOMAGX.
Я решил адаптировать и подточить последнюю версию на наш дорогой ZN5, и результат был потрясающий!
Итак, я здесь, чтобы поделиться с вами новой версией RockBox.
Что нового в программе по сравнению с beta-версией:
- Теперь программу не требуется закрывать плагином, просто нажмите красную кнопку, чтобы закрыть ее.
- Теперь мы можем слушать музыку и продолжать пользоваться приложением, мы можем смотреть фото, играть в игры, использовать какие-либо мини-программы, в общем, делать что хотим.
- Добавлена игра Doom в приложение, чтобы играть, пока слушаем любимую песню.
- Возможно проигрывать видео 25fps в формате MPEG.
- Возможно воспроизводить ATRAC3-аудиофайлы.
- Возможно воспроизводить файлы AC3.
- Возможно воспроизводить файлы AAC.
- Система стабилизирована и немного отрегулирована.
Рекомендуется установка на карту памяти.
D-1c3
сообщение 30.9.2009, 17:21
Прошивка: свежая
biggrin.gif ОНО не подлежит сравнению со стандартным плеером. это полноценная прошивка для многих моделей мп3 плееров, например айпода, с открытыми исходниками. просто представлена на наших телах в виде нативной проги. дабы не превращать телефон в мп3 плеер)))
больше всего мне нравится в нем гибкая настройка звука. можно под любые нужды настроить. и скорость переключения треков радует, если без эффектов плавного перехода)
базой можно и не пользоваться, а сразу воспроизводить нужное из файловой системы
в общем всё для людей) единственный недостаток для меня (был?)- невозможность создания плейлистов с желаемыми треками.
!Pavlik!
сообщение 30.9.2009, 18:00
Из: Нижний Новгород
Пользователь №: 160 141
Модель телефона: RAZR XT910
Залил на ifolder - http://motodev.ifolder.ru/14261408
holyt
сообщение 30.9.2009, 18:13
Плеер значительное шустрее родного. Быстро запускается. Обновление базы очень быстрое.
Из недостатков: Медленная навигация, именно медленная а не тормознутая. Трек ставиться на паузы при нажатие зажатие кнопки при навигации, но потом продолжает играть. Плагины достаточно медленные, при юзании некоторых плеер опять ставиться на паузу. Нет возможности свернуть, при сворачивании ztaskman-ом прорисоваеться поверх всех окон.
сообщение 30.9.2009, 18:26
Полет на Simbiosis 2.1 нормальный. Плеер отличный, отличное оформление, множество игр, скинов и приложений. Запуск достаточно быстрый
V!iT
сообщение 30.9.2009, 18:40
Из: Украина -> Мелитополь
Пользователь №: 196 457
Модель телефона: Motorola ZN5
Прошивка: Symbiosis OER
че то я не пойму,как может быть на симбиозе отлично ставится, если он не устанавливается! Пришлось разорхивировать самому в папку. или все так и ставили?
Я так понял,что русский не работает???
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 23.4.2024, 11:35
