90 страниц V < 1 2 3 4 5 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3874
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Stalker.mg
сообщение 11.10.2006, 10:57
Evil
Пользователь №: 57 954
Модель телефона: iPhone 5
CG3
http://www.webfile.ru/1145828
http://www.rapidshare.ru/67098
CG1
http://slil.ru/23235148
Сообщение отредактировал Stalker.mg - 11.10.2006, 14:27
Stalker.mg
сообщение 11.10.2006, 14:30
Evil
ORA,
Можно, но лучше еще и cg3 заменить
CG3
CG1
на всякий случай еще разок :)
Алекс75
сообщение 11.10.2006, 16:59
Мото-реаниматор
Из: Калининграда
Пользователь №: 30 882
Модель телефона: XT502
Прошивка: Android 2.2
elektro255,
At me one more question... It Is possible to put skins from a disk "b"??? It considerably will save an empty seat in CG2. For example on V635 the disk for loading java simply varied in all references with "a" on "b" but with skins such it is impossible :(
Bent
сообщение 12.10.2006, 8:25
MoTo Marvellous
Пользователь №: 63 874
SharkExE, Вот пожалуйста :) MV целиком и полностью.
Прикрепленный файл MV_electro_0.2b.rar   ( 213.62 килобайт ) Кол-во скачиваний: 673
abatsk
сообщение 12.10.2006, 8:44
Пользователь №: 77 083
Модель телефона: Samsung i9003
Прошивка: Android
Цитата(vip.sergey @ Четверг, 12 Октября 2006, 12:36)
Люди, помогите. Чем можно прошить CG1 и CG3?
Лично я сделал так: Взял монстр, разобрал. Заменил CG1 и CG3. собрал. Включил прогу FlashBackup 3.0. Поставил галочки на этих файлах. Что бы он только их прошил .И все.
ORA
сообщение 12.10.2006, 11:55
Из: Ижевск
Пользователь №: 91 715
Прошивка: R373_0.2b(49R)
Bezumniy,
Установи яву от электро и включи в ней Автоблок клавы, у меня так получилось.
Bezumniy,
Прикрепленный файл Synerj_by_Elektro255.rar   ( 8.94 килобайт ) Кол-во скачиваний: 381
Прикрепленный файл Synerj_by_Elektro255.rar   ( 8.94 килобайт ) Кол-во скачиваний: 310
Archy
сообщение 13.10.2006, 19:45
Пользователь №: 40 468
Модель телефона: E1-L6-L7e-U9, iPhone
Прошивка: M-S1.5RC3 L7e_01.0AR
Не ругаемся и стараемся быть повежливее друг с другом.
Автору по-любому респект!
Кому-то может нравится, кому-то нет, но следующий наехавший на автора получит бан на неделю минимум.
elektro255:
Thank a lot for your work, eager to see your next projects, and thanks for taking my Symba as source :)
elektro255
сообщение 15.10.2006, 8:00
Из: Poland, Siedlce
кто-нить знает, когда выйде доработанная версия?
Final version will be In his week ;) now i’m testing final version, making flex, website etc. ;)
So I also wanted to learn what exactly it is necessary to change in CG1 that worked automatic lock-out and a small lamp. I have checked up 20 % CG1 and have counted 23 changes in comparison with standard CG1....
For automatic lock-keyapad I’m found where is code of DisplayTimeot and then injected code what read feturestarte like java and if readed state is =1 then sending event to lock keypad (like senttoos in java)
btw, have you changed Tim2005's Synerj Plugin? As you have already said you have changed Low battery sound and auto keypad lock settings from 004a (or 004e - I do not remember) seem to 0032 seem. I think now Synerj plugin doesn't work properly in changing auto lock and low battery sound settings.
I’m not changed offsets to his features, but tchis plugin hale some bugs and i will make New plugin
This will be very dangerous, when you replaced TF phone will not start without skins
Я вот звук не могу заменить потому что видите ли места нет в CG1...так теперь ещё ко всему добавилось то что не могу картинку boot заменить статичную Hellomoto,суть в том что картинка стоит фирмачная автора,НО ни программа moto_boot_scrn_repl(правильно у меня смещения) ни в ручную(ISE208,SamsungFlashImager6.10) не меняет,а показывает там обычную hellomoto хотя должен показывать эту фирмачную картинку...кто что скажет по этому поводу?
We can’t replace boot splash screen and SW name, because I’m hard protected this , after replace phone will not power on (and if first protection not working, second will crash calls from phone), because this is my signature in SW :) we can make yours signatures in flex ;)
когда пишеш на разных языках (переключаешся с символов на анг и рус или числовой) быстро то включается этот "светильник"
there is a problem with flashlight while MV is working. When I press ## while some music is playing flashlight begins to blink. Since that moment I haven't any opportunity to do anything
I will change his In final version (maybe to *0 ? )
Elektro255 имхо, 10 октября кончилось ты где там? Релиз на 10е намечал и пропал, имхо!!!
Sometimes I don’t have time to reply on forum :)
P.S.Насчет поиска в ручную необходимых изменений....времени нет но на 20% прошивы имеется 23 изменения я бегло просмотрел во всей наберется более 50 что то меня не вдохновляет каждое изменение тестить в отдельности....А вдруг тот же автоблок активируется по нескольким смещениям возможно что пустая трата времени.Надо автора раскручивать пусть инфой делится!!!
Maybe later when i have some free time i will make website about asembler for ARM7TDMI, tell how to compile patches inject In exists code and i will give some offset wher we can inject his code
2. What asm/debugger(?)/emulator(?) are you use ? (I know DevKitARM for that, or smth from "gameboy" developing like HAM)
To disassemble SW – IDA PRO 5.0
To assemble my code – ADS 1.2 (ARM Developer Suite)
To inject code – Hex Workshop and my branch calculator elektro255.webpark.pl/Branch_calc.rar
4. Maybe you know addr of ringtone volume, or addr of current ring style - it will useful for regulate it from java apps. (For example, to make changig of volume/ring stlye in selected time)
To change ring stule in java use setfeaturestate(2038,xx) where xx=0 for loud xx=2 for vibra xx=4 for silent etc.
SORRY - не зная английского. Кому не лень, переведите мое сообщение для Elektro255.
я немного понимаю по-русски :) итак вы можете писать по-русски
P.S. Quote on this forum not working so i used code tags
elektro255
сообщение 19.10.2006, 7:45
Из: Poland, Siedlce
final version will be in next week because in this weekend i have bicycle race very far from home
v0.2 (not beta) will be at http://elektro255.ovh.org/
elektro255
сообщение 26.10.2006, 17:50
Из: Poland, Siedlce
21:09:16 BOOT verion: 8C5C (bad boot)
Thats mean your phone SW is broken or memory map is blank, first you must restore backup and then send flash
Sometimes flasher will not work if you don't have 7.D0 BOOT
22:23:03 Erasing flash. It can take 5 minutes.
то значит что тебе надо ждать 5 минуты
Текстовая версия Сейчас: 25.4.2024, 8:39
