20 страниц V < 1 2 3 4 > »
Прошивка Basic Plus, V8
abelenki
сообщение 13.4.2009, 2:44 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
What is Basic Plus?
It is a basic unbranded NO_RSA firmware based on 80.46.1BR for 512MB V8 and 80.56.1BR for 2GB V8 with added 5 customization menus
(Change Bootlogo, Font Changer, Startup-/Shutdown Sound, Alarm Clock Timer and Reminder Sound), USB-Lan and Swap memory by default. That's it!
Now this space saving allowed to return to the old system of changing the language by flashing the CG46.
That is the Basic part!
The Plus part includes a Package Manager and you can install what you want and leave out what you don't want. There are 18 packages supplied, which would include the complete Evo 3 range, some have been upgraded, like zLauncher is version 2.1, pictureflow is upgraded and SlideShow is a development of pictureflow made by DeJe. You just have to copy the packages (*.tar.gz files) into /ezxlocal/download/mystuff/package. The Package Manager (you find it in the Package folder in the Main Menu) will install and uninstall packages. During installation you have to enter a menu name, for example you install zLauncher then you can call the menu whatever you want (e.g My Filesystem or Mein Dateienfresser), which is nice if you do not use english as your language. Secondly during installation you can associate file extentions, which most packages do not need. Also, because most Mods now come with a selection of languages and the packages are installed in /ezxlocal/download/mystuff/packages/apps, which is read/write filesystem, you can change the menus to your language. All packages menus will be installed in the Package folder below Package Manager, you either leave them there or you move them to somewhere else, your choice.
USB-Lan and Swap Memory are in the Settings menu, USB-Lan at the beginning and Swap Memory at the end, as you need to use Swap Memory only once to set up the swap file and activate it. After each reboot the swap file gets automatically activated. I have not included the Java HEAP Setting package as I have set the the default HEAP size to the maximum of 4096KB by default.
If you really MUST use Windows Explorer instead of FTP then shutdown the swap file first then change to USB Setting Memory Card and connect with USB cable to PC, the V8 will not hang itself.
MPlayer, because of its /mmc/mmca1/Programms path requirement has been not supplied as a package. However the MPlayer menu exists under Multimedia and all you have to do is copy the included MPlayer folder into /ezxlocal/download/mystuff/Programms on the 512MB V8 or into /mmc/mmca1/Programms on the 2GB V8, that's all.
Another change is that the ezx_flexbit.cfg is now under /ezxlocal/download/appwrite/flexbit, this allows to change the flexbit without the need to flash a CG43 every time you edited the ezx_flexbit.cfg. Just copy your new ezx_flexbit.cfg file into this folder and reboot.
I have tried to make this firmware as simple as possible, as from the comments about Evo 3 saw that a lot just could not get the hang of the different language system and how to handle it.
The need for a Package Manager was always high on the list, also the result of comments and requests like "we do not need this, but can we have that..." and then "we do not need that, but can we have this...", so now everybody can decide themselves what they want and what not.
There are already 2 package management system around (PEP and mpkg), so why creating a new one? Well, I was hoping that there would be a PEP for V8, but that project got put on hold and by request of the PEP creators I could not port it to V8, so that left only mpkg. Now mpkg might be fine for the Z6, but it is not good enough for the V8 and the reasons are that mpkg packages are installed from and onto the Z6 SD card (/mmc/mmca1) this path exists only on 2GB V8, but not on 512MB V8, secondly mpkg packages for Z6 do not work on V8, they need modification in order to work on the V8 (huge potential for future post " I installed mpkg package, but it does not work ."). Thirdly the icon management of mpkg produces only black exclamation marks on yellow background (mpkg uses one icon for std and ani icons, no small icon). which honestly does not look nice to have on your phone. Fourthly the AppID creation is rather simple and the V8 always has been quite fuzzy with "home made" AppID's. So, I either rewrite mpkg to fit V8 and change Z6 mpkg packages into V8 mpkg packages, which still leaves the door wide open for people to install Z6 mpkg packages on V8 and wonder why they do not work. So I decided against that option and created my own package management. Anyway Linux is all about choice, so there you go!
You might find that the Customize menu looks a bit different, this was done on purpose.
OK, I could not have done this without the help, inspiration and testing from DeJe (faq4mobiles.de) and DaRk_dOg (MMUS et al.), their work, ideas and contribution helped to shape this firmware. THANKS!
But a big thank you has to go out to all the other unnamed modders, who's work, modified or not, found their way also into this firmware. THANK YOU!
As with all my work, this firmware is also free for everybody to change, use parts of it or simply print out the code and wallpaper your room with it.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Описание:
1. Прошивка No RSA.
2. Лэнгпак шьётся по-старому, через RSDLite.
3. Теперь дополнительные программы устанавливаются пакетами, аналогично PEP, только они имеют свой формат. (т.е. теперь можно выборочно ставить то, что тебе нужно). Пакеты нужно копировать в /ezxlocal/download/mystuff/package, а потом инсталлировать или дизинсталлировать через Package Manager. В процессе инсталляции пакета, вы можете присвоить ему любое имя, а также ассоциировать с ним любые расширения (для большинства пакетов это не нужно).
4. USB-Lan и Swap Memory находятся в меню Settings. Swap Memory нужно запустить и настроить всего лишь один раз. Он активируется автоматически после ребута или включения телефона.
5. Если не активировать файл подкачки (Swap Memory), телефон теперь можно подключать в режиме мемори-карты, и при этом он зависать не будет.
6. Java HEAP автоматически установлен на максимальное значение - 4096KB.
7. MPlayer не включен в виде пакета, а устанавливается по-старому. Т.е. просто скопируйте его в /ezxlocal/download/mystuff/Programms на V8 512MB или в /mmc/mmca1/Programms на V8 2GB. Ярлык на него уже установлен в прошивке и находятся в Multimedia.
8. Файл ezx_flexbit.cfg теперь находится по этому пути - /ezxlocal/download/appwrite/flexbit. Теперь его можно спокойно редактировать, перезаливать в телефон и перезагружаться, чтобы изменения вступили в силу (разборка, редактирование, сборка и прошивка CG43 больше не требуется).
9. Видео-камера теперь снимает в разрешении 352x288.
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Basic Plus Update (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Basic Plus Update
2GB Basic Plus Update
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Basic Plus Update Packages
MPlayer
V8 Modding Guide
Сообщение отредактировал XXX_S_B - 20.2.2013, 16:09
OlgaJah
сообщение 18.4.2009, 11:43
Пользователь №: 147 866
Модель телефона: RAZR2 Luxury Edition
Прошивка: MPKG Basic
Ставила 2 раза прошивку на телефон и 2 раза телефон с ней работал не корректно.Бекап отказывается работать,как и MPlayer, вернулась на свою старую прошивку....это у всех так?или только мне не повезло?
Сообщение отредактировал OlgaJah - 18.4.2009, 12:21
KLON 3
сообщение 18.4.2009, 17:12
Из: Voronez
Пользователь №: 90 456
Модель телефона: v3i,V8 512M
Прошивка: Basic Plus
Advokat_d выложи плиз свой flexbit.С меня +
Advokat_d
сообщение 18.4.2009, 17:41
Пользователь №: 155 462
Модель телефона: V3i,V8 2гига
Прошивка: R601_G_80.56.15R
ДЕРЖИ
Сообщение отредактировал abelenki - 20.4.2009, 2:52
rasputin007
сообщение 18.4.2009, 18:22
Из: UK
Пользователь №: 184 705
Модель телефона: RAZR2 V8
Прошивка: Nothing for too long
Я нашел ошибку с 2GB версия, своп памяти не устанавливать. Если вы использовали Эво 3 до вы не замечаете этого.
Решение: скачать 2GB своп памяти, unrar и скопировать в / mmc/mmca1 и перезагрузитесь.
Сообщение отредактировал rasputin007 - 18.4.2009, 18:24
OlgaJah
сообщение 19.4.2009, 12:17
Thanks a lot for your reply and your reflashes.I have been using them for more than a year and I enjoy them very much.
Could you please repeat the original message in English?Thanks)
rasputin007
сообщение 19.4.2009, 19:08
Из: UK
UPDATE
I have updated Basic Plus with the package fix and the swap memory fix for the 2GB, other changes are:
352x288 video recording
packages on the 2GB are now placed on /mmc/mmca1 (2GB Memory) as the User memory with 48 MB rather small is.
All scripts are now located in /ezxlocal/download/appwrite/bin, which is read/write, so you can change the script menu texts from english to whatever language you like without the need to edit CG's or flashing, just copy the files to PC, and change texts with Linux, if you use Windows to do that the files will not work anymore as Windows does not know about executable file attributes as Linux does, alternative you can edit the scripts on the V8 using zLauncher, just highlight the script and pres and hold the 3 button and zTextViewer opens, which you can use to edit files.
Сообщение отредактировал abelenki - 21.4.2009, 2:37
OlgaJah
сообщение 20.4.2009, 6:49
Цитата(rasputin007 @ 19.4.2009, 22:08) *
UPDATE
Thank You
Добавлено позже (20.4.2009, 11:38):
Прошила новой версией для телефонов с 2гиг памятью.Сразу установила бекап и попыталась его залить,после этого телефон включился,но далее чем bootlogo загружаться не стал.Попытки перепрошить его в таком состоянии также не увенчались успехом,пришлось перевести телефон в бут и он успешно перепрошился.Так,что прошивка остается нестабильной(((.
rasputin007
сообщение 20.4.2009, 21:48
Из: UK
Цитата(OlgaJah @ 20.4.2009, 7:49) *
Thank You
Luckely there are other 2GB V8 firmwares, that might work better for you.
Linuxmod Fusion 2 and Elysseum 2GB.
Сообщение отредактировал abelenki - 21.4.2009, 2:27
abelenki
сообщение 21.4.2009, 2:39
Из: Russia, Perm
в закреплённом сообщении обновлена прошивка 512MB Basic Plus Update. исправлены проблемы с меню Customize.
OlgaJah
сообщение 21.4.2009, 8:06
I tried them but liked Evolution 3 more as it is more stable and I enjoy it.If you could prompt why the above mentioned bug(if you got it in Russian) shows up and give some directions how to avoid it, I would be very grateful)
Прошивка Basic Plus, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 19.4.2024, 22:30
