Parse error: syntax error, unexpected '!', expecting T_VARIABLE or '$' in /home/admin/motofan/motofan.ru/board/sources/ipsclass.php(1485) : eval()'d code on line 51
MotoFan.Ru - все для моторола > Elfs by motoedy[China]
Уникальные сборники SMS-Приколов и SMS-Розыгрышей! Скачать бесплатно!
30 страниц V « < 8 9 10 11 12 > »            +   Facebook   Подписка   vkontakte   mail.ru
> Elfs by motoedy[China], new:more elfs 05.09.2009
Campanula
сообщение 15.8.2008, 1:58 Закрепленное сообщение!
Номер #91
Пользователь №: 176 749
< 0 ( 123.5 ) 20000 >
Welcome to China motoedy smile.gif www.motoedy.cn
http://translation2.paralink.com + http://translate.google.com/translate_t
newHITMOUSE by hantao
1,2,3,4,5,6,7,8,9
Exit: Red
Author: om2804 tim apple Editorer: 四夕 & 林子 L7E/L9: lpktool
Thanks to om2804 tim apple
new LRCPlayer_DesktopshowLRC_1.3
Прикрепленный файл   LRCPlayer_DesktopshowLRC_1.3.rar   ( 480.3 килобайт ) Кол-во скачиваний: 419
[Updated 09-08-01]
Lin LRCPlayer_ modified version V1.3
[+] Add lyrics contour, in BG_LRC.CFG color profile settings in the settings to add "show the outline of the lyrics" set;
[+] When did the lyrics, the screen does not display lyrics and other non-related tips;
[+] To remove the panel in the A site or C site settings, the program will automatically determine which disk;
[+] LRCPlayer.lng documents are updated, LRCPlayer.cfg document changes to the original part used to re-configure the settings (such as the use of IT to start, etc.);
[Updated 09-07-30]
Lin LRCPlayer_ modified version V1.2
[+] Amendment can not be deployed for panel icon panel issues;
[+] When a song did not amend the LRC, the desktop display lyrics on a problem;
[+] Icon shows a high degree determines the number of rows and a high of 20 for his party, would like to show you a few lines of lyrics
[+] Can call with the panel and different icons and configuration, will be on the panel BG_LRC.CFG and BG_LRC.GIF document under the folder DeskTopFile; not call the default program directory;
[+] In setting a "desktop display the lyrics" and "show-screen lyrics when Changliang" choice;
~ 12.06.2009 ~
[LRCPlayer 1.3]
Hard-won source ah
* Based on modifications made to Tunes3.9
* Play button changes the interface is as follows:
123, respectively, for the side and so on, flash, screen
5 for the current playlist
8 on
7 players on the grounds to the lyrics of the skin interface interface
9 on the grounds the lyrics to the player skin interface interface
* Reduce the volume
# Increase the volume
0 to mute
Other operations with Tunes3.9
still lrc.cfg address for GBK encoding, LRCPlayer.cfg the last 2 bytes in order to initiate a 16-band event code
new Memorandum_Simplify the locking version
Прикрепленный файл   Memorandum_Simplify_the_locking_version.zip   ( 9.92 килобайт ) Кол-во скачиваний: 251
new HDautoplay1.5
Прикрепленный файл   HDautoplay1.5.zip   ( 2.48 килобайт ) Кол-во скачиваний: 195
Its working principle: plug in your headphones to monitor the incident code, and monitor the core event code (0404, that is, start-up events LRCPLayer.elf/Tunes.elf, when you start the event of LRCPlayer/Tunes.elf code changes, so please direct HEX to 0404 start for your event LRCPlayer/Tunes.elf code), auto-play button to use the simulation
To work only on the desktop
Lock Application--->Headset
Locked--->autoplay
Unlocked---> unautoplay
maybe only for 79R
RamEdit :
Redmenu_mod (ELF&SRC)
gif:L"*.gif"
CODE
Ring Styles=0936
ZtxtEdit=file://a/MotoCmd/Ztxtedit.elf
CODE
For 79R:
Power off=17
Silent power off=0000
Reset=0001
Switch in BOOT=0003
Unload Java=1806
MachoSettings=0973
Tunes=1889
MotoCMD1.8=0985
OPcode=2011
Personalise=0942
Initial Setup=0943
Message=1025
Video Camera=1021
Camera=1019
Bluetooch=1789
USB Settings=1022
Alarm Clock=1001
Datebook=8378
Skins=3237
Shortcuts=0929
Ring Styles=0936
pp_lrc_1.7.1
Прикрепленный файл   ppplayerv1.7.zip   ( 135.61 килобайт ) Кол-во скачиваний: 509
* Revision of the map in support of GBK, shows in simplified and traditional Chinese \ Sun Wen \ text of the stick ..
* Cancel version of the patch did not play ... GBK's patch map, garbled show ..
* Some small bug amendment ..
* Only version of the patch
This version of the six, to see the name of the folder you know the type:
If, desktop_walkman, on behalf of the desktop that shows the time, the interface for the walkman
The rest and so on (Note: iris for the past Xiaoyu's colorful interface)
Another: a patch version of the map for migration 0x10c3e800 (increase has been offset start-CG1), non-offset this, please make its own decisions
Revised: 16 hexeditor (such as UltraEdit32, etc.) to open elf, search 0x10c3e800, replace your address migration
PP_reader_1.1
Прикрепленный файл   ppreader_no_patch.zip   ( 26.93 килобайт ) Кол-во скачиваний: 264
Прикрепленный файл   pp_reader_v1.1.zip   ( 98.57 килобайт ) Кол-во скачиваний: 335
Increase:
1, to support the GBK code, that can display traditional.
2, in the setting / folder under map.set document offset patch, the hex address of the patch + CG1 address, I provided a patch for the use of 398. 398 can not use the default for 0x10C3E800.
3, at the right point in time to read software code to open the menu option to resolve the utf_8 file to open in the first few garbled.
1, the English word would be forcibly cut off, did not get
2, does not support L7E ...
3, to replace paper map, the size of 47k.
Patch file also changed, and 398 in place are adequate.
Other models to find your own! ! !
After the test, did not play in the system memory of the 398 patch can not run on non-patch version! ! !
Color Clock
1.6
Прикрепленный файл   Color_T_v1.6.zip   ( 9.53 килобайт ) Кол-во скачиваний: 296
Color_T v1.3
Прикрепленный файл   Color_T_v1.3.zip   ( 69.38 килобайт ) Кол-во скачиваний: 430
Author: Kalvinxp (bimonthly)
Source: EDY Прикрепленное изображение Прикрепленное изображение Прикрепленное изображение
0 1 2 3 4 5 ... F
0x00000000 XX XX XX bond packages
0x00000010 XX XX clock line coordinates of the clock ordinate
0x00000020 XX XX XX hours of high color
0x00000030 XX XX XX hours of low color
0x00000040 XX XX XX isolation: the color
0x00000050 XX XX XX high-minute color
0x00000060 XX XX XX low-minute color
0x00000070 XX XX XX XX XX XX this line of the first byte as a font type, 2 bytes for the border or shadow (0 without any results,Plus 1 frame, plus 2 after the shadow of the shadow of the former plus 3); the first 3-5 bytes for the effect of color ,No. 6 bytes for the digital space
PS: XX on behalf of a byte
ElfOpen2.4.1
Прикрепленный файл   ElfOpen_2.4.1.zip   ( 27.14 килобайт ) Кол-во скачиваний: 327
thanks for om2804!
mma_ucp:
Phone book
Dialling services ---- Quick dial, voice dial, and attribution for (Fixed dial), Incall setup, RecentCall, Call Forward
Message
Security
ELF & JAVA procedures ---- JAVA procedures, MOTO Manager (AIM), ELF (mixing machine), FELX procedures (WEB shortcut), SEEM editor (Mobile QQ), HEX editor (themes)
Access to the network ---- browser, StoredPages,WebHistory,GotoURL,BRWSetup,WebSessions
Multimedia---- Sounds,Pictures,Video,ITUNES,Camera,VideoCamera
Tools ---- alarm clock, DateBook, calculator, voice record, data backup tools (IM), SIM APP
settings----Personalize,IntlSetup,JAVAtools,CarSetting,PhoneStatus,FEM
MMRingStyle
Shortcuts
Connection ---- Bluetooth, USBSetting, sync, network, airpin mode, headset
03FC instant messaging (IM)
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
039A (fixed dial-up)
Please use P2KTOOL hidden settings
The more open, and then put mma_ucp
The MMA for the E398. Other models, a separate production ~
new
Backupsms
Прикрепленный файл   backupsms__09_08_31.zip   ( 14.28 килобайт ) Кол-во скачиваний: 222
CODE
IN1=0x04E6
IN2=0x04E7
OUT1=0x07CD
OUT2=
PATH=file://b/backups/
CODE
[SMST]
app=/b/Elf/MotoCmd/smsv.elf
type=id
09-08-31
Amendments to the multi-page copies of reading support. (Known Bug: Unable to get part of the recipient)
Skin.elf
CODE
[SKI]
app=/b/Elf/MotoCmd/Skin.elf
type=id
new
Auto change skin when you startup your phone
Skins in dick a
Skins in dick c
Please add to AutoRun
PP_DnpEditor:
Прикрепленный файл   PP_DnpEditor.elf   ( 19.44 килобайт ) Кол-во скачиваний: 277
UnRAR/Un7z:
CODE
[RAR]
app=/b/Elf/MotoCmd/unrar.elf
CODE
[7z]
app=/b/Elf/MotoCmd/un7z.elf
6Elfs only for 79R
Gomeno(Lock Application --> JAVA APPS)
flashlight on VOICE + VOICE :
Lockvideo(Lock Application --> Headset)
Screener picture:
newPlug-in for MotoCMD: ConfigEditor oт 林子 English Verson by Last1left
Прикрепленный файл   ConfigEditor_eng.zip   ( 8.35 килобайт ) Кол-во скачиваний: 232
для редактирования файлов: .res .ini .menu .lng.run
CODE
[INI]
app=/a/Elf/MotoCmd/ConfigEditor.elf
[MENU]
[RES]
[LNG]
[RUN]
new DEC HEX BIN Converter oт 林子 English Verson by Last1left
Прикрепленный файл   NumBasis_eng.zip   ( 6.38 килобайт ) Кол-во скачиваний: 176
new Motocmd2.0
QUOTE(Fenja @ 1.9.2009, 17:43) *
Campanula, in what of difference between MotoCmd.elf, MotoCmd-DDRM.elf, MotoCmd-DXDRM.elf?
CODE
MotoCmd.elf don't need Icons
MotoCmd-DDRM.elf is old Verson
Please use MotoCmd-DXDRM.elf
Icons for MotoCmd
Please add in your DRM!(CG15)
695                 mp3.amr .m4a .mid
696                 device
697                 dir
698                 txt .umd .doc .lng .lrc .smst
699                 elf
700                 exe
701                 html
703                 jad
704                 jar
705                 main
706                 null
707                 rar
708                 sys
709                 video.3gp .mp4
710                 zip
711                 ini .cfg .set .run .lib .rlt .rm .pat
712                 mei .jc
713                  Waiting..
CODE
Register=0x03DC
Map=110F0824
Sytem=0;Hidden system files: 0/no 1/yes
ReadLast=1;Read last open Folder: 0/no 1/yes
ChangeType=1;Scroll Display file names : 0/no 1/yes
UseZipBrowser=1;ZIP Browser Switch:1 use MotoCmdZIP, 0 use MotoCmd Plug-in(UnZip.elf)
BookDir=/a/Elf/MotoCmd/bmk/Ebook.txt;file of BookDir
AutoDir=/a/Elf/MotoCmd/AutoRun.elf;file of AutoRUN
DrmDir=/a/Elf/MotoCmd/Adddrm.elf;file of Adddrm
HexDir=/a/Elf/MotoCmd/HexEditor.elf;file of HexDir
TxtDir=/a/Elf/MotoCmd/Ztxtedit.elf;file of TXTEdit
[MEI]
app=/a/Elf/MotoCmd/ElfInstaller.elf
[JC]
app=/a/Elf/MotoCmd/Jc.elf
[GIF]
app=/a/Elf/MotoCmd/Iv.elf
AutoRun for MotoCmd2.0, No AutoRun
Adddrm for MotoCmd2.0,Plaese Add to AutoRun
Example:b/Moto/Drm/Green/329-336.gif
Open MotoCmd2.0,You can Long press 0,Then Press Menu,Update battery pack.
QUOTE
map is our Chinese Transcoding
For example:
Map=110F0824 ,This is a patch of gb2uc. It's used to gbk to uc
UnZip.elf PP_lrc.elf LRCPlayer.elf MotoCmd.elf ....must to use this patch (Map=10C3E800)
ZtxtEdit.elf use 3 maps
1:patch (Map=110F0824) :gbk to uc
2:gb2big5.map : gb to big5
3:uc2gbk.map : :uc to gbk ,This is used to edit txt.
Russian friends, British friends ,Do not need to use maps....
give you the src of ZtxtEdit , MotoCmd2.0.0.1 and LRCPlayer1.4
Прикрепленный файл   motocmd2.0_scr.rar   ( 165.03 килобайт ) Кол-во скачиваний: 185
Спасибо всем разработчикам эльфпака и эльфов!
Сообщение отредактировал Campanula - 6.9.2009, 6:55
Прикрепленные файлы
Прикрепленный файл   ElfOpen_2.3.1.zip   ( 33.39 килобайт ) Кол-во скачиваний: 325
Прикрепленный файл   ElfOpen_2.3.zip   ( 32.16 килобайт ) Кол-во скачиваний: 158
Прикрепленный файл   LRCplayer_1.1.zip   ( 179.46 килобайт ) Кол-во скачиваний: 264
Прикрепленный файл   Color_T_1.1.zip   ( 81.69 килобайт ) Кол-во скачиваний: 550
Прикрепленный файл   Color_T_v1.2.zip   ( 68.73 килобайт ) Кол-во скачиваний: 322
Прикрепленный файл   LRCplayer_1.2.1.zip   ( 363.82 килобайт ) Кол-во скачиваний: 632
Прикрепленный файл   LRCplayer_1.2.zip   ( 189.02 килобайт ) Кол-во скачиваний: 755
Прикрепленный файл   LRCPlayer_1.3.zip   ( 440.51 килобайт ) Кол-во скачиваний: 235
Прикрепленный файл   backupsms__09_6_20.zip   ( 13.7 килобайт ) Кол-во скачиваний: 204
Прикрепленный файл   Memorandum_V1.0.zip   ( 18.46 килобайт ) Кол-во скачиваний: 250
Прикрепленный файл   backupsms__09_6_23.zip   ( 15.07 килобайт ) Кол-во скачиваний: 214
Прикрепленный файл   Memorandum_V1.1.zip   ( 176 килобайт ) Кол-во скачиваний: 293
В друзья
Юзер вышелВизиткаП/Я
+Цитировать сообщение
Z.d.u.n.e.X
сообщение 13.4.2009, 10:04
Номер #92
Из: Poland
Пользователь №: 186 451
Модель телефона: e398/k770i
Прошивка: R373_49R [EP1+EP2]
< 0 ( 185.5 ) 20000 >
QUOTE
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
A кто может сказать мне CommendID для Меню-Персонализация-Cкины?
http://cid-1f3becbc4444c6df.skydrive.live....o/commandid.PNG
@Campanula: Could you change language Flex.elf to Polish?
Flex number = Numer flex
Change model = Zmien model
Sent event = Wyslij zdarzenie
Security = Zabezpieczenia
Backup PDS = Backup PDS
ToneDb killer = ToneDb killer
Backup shourtcut = Backup skrotow
Сообщение отредактировал Z.d.u.n.e.X - 13.4.2009, 16:13
В друзья
Campanula
сообщение 13.4.2009, 12:38
Номер #93
QUOTE(Z.d.u.n.e.X @ 13.4.2009, 18:04) *
Here you are :Flex
BackUps is here:/B/Elf/BackUps/
Сообщение отредактировал Campanula - 13.4.2009, 13:02
Прикрепленные файлы
В друзья
Прикольные футболки!
сообщение 1239626313
Номер #
Толстовки Прикольные надписи Прикольные рисунки Интернет приколы Админские Вконтакте, Одноклассники Я Русский! Студенческие RnB Клубные Космос Спорт Игры Девушкам Детские Кино Антибренд Туристические Праздники Пиво-водочные Офис и работа Политические Матершинные Эмо Спецслужбы Секс и любовь Автомобильные Знаки зодиака Кошки
Ф И Ш К А сезона 2010 ! Быть оригинальным ПРОСТО ! читай текст ..
Здесь можно купить очень Оригинальные Футболки, Майки, Толстовки, Кепки, Трусы, ..
Крутые футболки! Крутые футболки! Крутые футболки! Крутые футболки!
Распродажа по 200 рублей !!!
обновить себя  )-->>
Как купить? Просто нажимаете на кнопку Заказать , указывате свой email или телефон , по ним подтверждаете заказ
и через время идёте на почту, оплачиваете и возвращаетесь в стильных Обновках! Статус заказа доступен всегда.
Средняя цена классной футболки всего 400 руб : ) Множество размеров и цветов!
Сейчас есть распродажа по 200 руб за футболку !
Оплата заказа осуществляется с помощью платежной системы WebMoney (можно через автомат приема платежей),
Яндекс.Деньги, кредитной картой системы VISA/VISA Electron, Mastercard/Maestro, Банковским переводом
или Наложенным платежом (Тоесть оплата заказа на почте в момент его получения).
Если вы оплачиваете НЕ наложенным платежом , то получаете ещё и 10% СКИДКУ на ВЕСЬ заказ!
Кстати, есть конструктор футболок, на футболке можно сделать ваш рисунок, надпись, фото..
Например, Футболка с вашей фотографией размера А4 всего 400 рублей . Стильный подарок !
В друзья
Z.d.u.n.e.X
сообщение 13.4.2009, 16:10
Номер #94
Из: Poland
Fix Polish lang:
Flex number = Zmień flex
Change model = Zmień model
Sent event = Wyślij zdarzenie
-Security code = Kod zabezpieczający
-Unlock code = Kod odblokowujący
Backup PDS = Kopia PDS
ToneDb killer = ToneDB Killer
Backup shourtcut = Kopia skrotуw
-Backup shourtcut = Kopiuj skroty
-Restore shourtcut = Przywrуć skroty
Menu title:
www.motoedy.cn = Ustawiania Flexu
Security Unlock = Kody
ShourtCut = Skroty
Сообщение отредактировал Z.d.u.n.e.X - 14.4.2009, 8:03
Прикрепленные файлы
В друзья
MaratMD
сообщение 14.4.2009, 20:33
Номер #95
Пользователь №: 180 950
Прошивка: DAR 2.x Test15
< 0 ( 47 ) 20000 >
У кого нить ваще работает Unrar,Un7z.Всё куда надо прописал...
В друзья
VEX
сообщение 14.4.2009, 21:19
Номер #96
Из: Нижний Новгород
Пользователь №: 156 303
Модель телефона: e398,V3,T190,L7
Прошивка: R373_44R_v2.8
< 0 ( 126 ) 20000 >
MaratMD, у меня работает,но только Unrar,извлекает небольшие файлы по 50-80кб(если бльше то тел виснет и перезагружается),тестировал в основном на тексте(имя файла должно быть латинскими буквами),а Un7z почему-то не работает.
В друзья
BiLaZ
сообщение 14.4.2009, 21:33
Номер #97
Из: Украина, Киев
Пользователь №: 145 012
Прошивка: R373_G_0E.30.49R
< 0 ( 7.5 ) 20000 >
оперативки что-ли не хватает...
В друзья
MaratMD
сообщение 15.4.2009, 12:48
Номер #98
< 0 ( 47 ) 20000 >
Чё то странно...У мя даже Unrar не работает!Un7z тоже.Пробовал извлечь патч.Ноль реакций.
В друзья
Сержант л7е
сообщение 16.4.2009, 17:38
Номер #99
Из: Н. Новгород
Пользователь №: 140 784
Модель телефона: L7e & i900 & ем30
Прошивка: 0AR & wm6.5 & Vac1.6
< 0 ( 9 ) 20000 >
Телефон Л7е. Unrar - reboot, 7z - полёт нормальный!
В друзья
Campanula
сообщение 20.4.2009, 6:18
Номер #100
PP_DnpEditor
auther:psjatqpgf(www.motoedy.cn)
Can someone tell me:Why i cann't edit this post Elf's by motoedy[China]
and cann't edit this : look at the picture
Сообщение отредактировал Campanula - 20.4.2009, 6:29
Прикрепленные файлы
Прикрепленный файл   PP_DnpEditor.elf   ( 19.2 килобайт ) Кол-во скачиваний: 130
В друзья
Campanula
сообщение 21.4.2009, 7:25
Номер #101
PP_DnpEditor.elf
fix
Прикрепленные файлы
Прикрепленный файл   PP_DnpEditor.elf   ( 19.44 килобайт ) Кол-во скачиваний: 58
В друзья
> Быстрый ответ
> Для прикрепления файлов используйте форму полного ответа (кнопка "ОТВЕТИТЬ" или "Расширенная форма ")
Текстовая версия Сейчас: 2.9.2010, 22:51
