Motorola Ситилинк
6 страниц V  1 2 3 > »
Прошивка Elysseum, V8
abelenki
сообщение 19.4.2009, 3:23 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
Support telnet, ssh, ftp (Connections modem&tools)
Support mpkg
bash version 4.0.0
kernel patch
unlock insmod
Applications installed:
MPKGLauncher by CepiPerez
Pictureflow by c_ro87
vAlarm by c_ro87
vBTTime by c_ro87
vWebLink by kleto
Konsole by tikva
vSYSInfo by c_ro87
vFM by rusiki
vTView by rusiki
vScreenshoter by c_ro87
mySkinDelete by kleto
vBackUp by kleto
vCleaner by c_ro87
Binaries show features:
readconfig
setconfig
showColorPicker
showTextContent
showDatePicker
showFilePicker
showlistbox
showMultiSelect
showNotify
showNumPicker
showProgress
showQ
showRadio
showTextEntry
showTimePicker
by Lasly, letterb, ilove3d, CepiPerez, flamefox.
Installer mpkg by kleto
Kernel:
my old kernel patch done
my kernel patch now made ext2, ext3, swap, no security
2 autorun:
autorun primary: /ezxlocal/startmount.conf
autorun secondary: /ezxlocal/download/mystuff/.Autorun/*
Supported extensions:
text: txt ini phm cpp h desktop cfg conf
packages: mpkg ins tar gz bz2 rar zip 7z iso cab ........
font: ttf
application: lin sh csh
skin: chm
Skin:
Alkali: Motorola inc.
CMCC: Motorola inc.
Luxury Mosaic: eisbar
Plush: Motorola inc.
Swap options:
1 activation by default compcache (You can turn off in /ezxlocal/download/mystuff/.Autorun/autorun)
2 used SwapMem to create swap file (not included)
3 partitioning /mmc/mmca1 (busybox fdisk /dev/mmca)
Skin: Use .chm edit the address
Font: just select it then you have to restart the new font
Flexbit: edit ezx_flexbit.cfg in "/ezxlocal/download/appwrite/setup" then reboot to see changes
Attention:
mpkg of z6 are not compatible (environment LinXtend not necessary now)
mpkg of z6 you want?
you delete mpkg
if [ "$LX_ENV" != "true" ]
then
. /ezxlocal/LinXtend/etc/initenv
fi
Автор:
kleto
Оригинальный топик:
modmymoto.com
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Elysseum (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Elysseum
2GB Elysseum
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Сообщение отредактировал abelenki - 14.7.2009, 8:32
ninja_vrn
сообщение 20.4.2009, 17:41
Из: Воронеж
Пользователь №: 108 427
Модель телефона: E398 => V8 2gg
Прошивка: V8 2G@Linuxmod
Бекапы от Линуксмода ослилит?
ХРОН
сообщение 20.4.2009, 21:52
Пользователь №: 148 368
Модель телефона: Z6, ZN5, Atrix HD
Прошивка: рабочая
vBackUp by kleto
если автор скрипта этот же, то точно осилит
abelenki
сообщение 21.4.2009, 2:35
Из: Russia, Perm
cam352x288.ins
мод для камеры, чтобы снимала в разрешении 352x288.
Сообщение отредактировал abelenki - 30.6.2009, 4:07
Прикрепленный файл cam352x288.zip   ( 239.46 килобайт ) Кол-во скачиваний: 333
любопытнный
сообщение 21.4.2009, 12:59
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
Как насчёт подключения со сторонним скином?
ravex
сообщение 24.4.2009, 19:34
Из: Питер
Пользователь №: 31 141
Модель телефона: L7, V8
Прошивка: LinuxMod 5 Pre-Final
abelenki,
ты ее уже ставил? понравилась?
что лучше? она или Linuxmod Fusion 2? не по количеству пакетов, а именно по производительности
ЗЫ если появиться версия для 512, дайте знать пожалуйста
Сообщение отредактировал ravex - 25.4.2009, 14:04
любопытнный
сообщение 29.4.2009, 5:32
Прошивка: ОЧЕРЕДНАЯ
Прошился после Linuxmod Fusion 2.Понравилась,FTP-соединение получил легко как на А1200е,меню Оранж очень порадовало,с пакетами от Linuxmod Fusion 2 пишет телефон,что не поддерживает,но это мелочи.Глубокоуважаемый куратор темы добавьте пожалуйста в первый пост -как вернуть душевное мотроловское кваканье при пропущеном вызове и разряде батареи имеенно для этой прошивки,тк способом описаным для последних распутинских не работает.Может конечно что-то делаю не так... помогите очень нужно,не хочется прошиваться назад на заводскую....
Добавлено позже (29.4.2009, 18:31):
Пропущенныее вызовы пиканье поставил,а на разряженную батарею никак.Мплеер тоже никак не заставлю работать-ставил MPRG.ставил через папку програмс на карте:всё равно не работает
Сообщение отредактировал abelenki - 30.4.2009, 2:44
abelenki
сообщение 30.4.2009, 2:42
Из: Russia, Perm
сначала надо стереть папку /mmc/mmca1/.Programms/Mplayer (если она была). а затем установить пакет Mplayer через MPKGLauncher.
Сообщение отредактировал abelenki - 30.6.2009, 4:41
любопытнный
сообщение 30.4.2009, 12:17
Прошивка: ОЧЕРЕДНАЯ
Стёр поставил-не работает.В Qtdaunload Мплеер у меня так и не появился.Что не так делаю? А одновременную работу ява-приложений нужно включать согласно инструкции на мотофане или должно сразу работать,всётаки NO RSA? Если да то у меня одновременно джимм и диабло не запускаются...
Сообщение отредактировал abelenki - 4.5.2009, 6:58
OlgaJah
сообщение 30.4.2009, 16:24
Пользователь №: 147 866
Модель телефона: RAZR2 Luxury Edition
Прошивка: MPKG Basic
Цитата(любопытнный @ 30.4.2009, 15:17) *
сначала надо стереть папку /mmc/mmca1/.Programms/Mplayer (если она была). а затем установить пакет Mplayer через MPKGLauncher. Стёр поставил-не работает.В Qtdaunload Мплеер у меня так м не появился .Что не так делаю? А одновременную работу ява-приложений нужно включать согласно инструкции на мотофане или должно сразу работать,всётаки NO RSA? Если да то у меня одновременно джимм и диабло не запускаются...
У меня точно также не работал,удалила,установила как нужно и результат-не работает(((
Прошивка Elysseum, V8 · Z6/V8 · Forum
Motorola Ситилинк
Текстовая версия Сейчас: 22.9.2019, 6:00
