Люди свершилось MpkgBox2.0 от ilove3d
Link на форум
Link на скачку
Сейчас сам качаю.Как прошью-отпишусь.
ilove3d_magic_elba_pro
special thanks:
yan0, lasly, Koin, JayDD, dimichxp, Abram, motofan.ru, etc.
flashing steps:
1. confirm you have NO RSA bootloader(BL), if not, flash NO RSA BL first.
notes:
NO RSA BL should flash the same version as your current.
e.g. 06.A3 should flash 06.A3-NO-RSA
if you version is older than the NO-RSA-BL you found, upgrade
to the origian version first, like you have 06.A1, you can
upgrade to 06.A3 first, then flash 06.A3-NO-RSA
NO-RSA-BL version higher than 06.A9 may not works, note that.
2. flash this ilove3d_magic_elba_pro.sbf
3. do a master clear if you want.
more details of what's new? just flash it.
most new functions:
mpkgbox2.0: (shows in mainmenu, the MpkgBox2)
shows installed mgx programs in this application.
what's new to e8mpkgbox:
1. shows size in properties
2. no click bug
3. multi-selection (need register)
register please contact email fay2002hifi@163.com
sorry I have no paypal international account this moment
please contact me first.
4. faster
5. using mpkgbox2.conf to setup the paths
rokr2.0: (shows when you click the files it supports)
supports almost any type of archive file
supports mgx applications installation
supports mgs skins packages installation
what's new to rokr:
re-written using rork2.conf to setup the paths
textViewer2.0: (shows when you click the files it supports)
shows a plain-text file content.
what'snew to textViewer:
re-written using textViewer2.conf to setup the paths
easyThemes: (never shows, it works automaticly)
the assistant script for support easy skin format
what's new:
when you click theme setup, the script will prompt you
to delete useless theme files (if there is)
FTP:
bftpd from motofan.ru
connect via USB tool or modem tools mode, access FTP
through ftp://192.168.16.2, username is 'root', password not exist
TELNET:
telnet enabled
connect via USB tool or modem tools mode, access TELNET
through telnet 192.168.16.2, username is 'root', password not exist
usefull paths:
mgx applications are installed:
/mmc/mmca1/mpkgbox
/mmc/movinand1/mpkgbox
mgs skins are installed:
/mmc/movinand1/skins
international language files:
/mmc/movinand1/.mpkgbox/
note: just write the file as xxx_${LANGUAGE_STRING}.lng
follow the ones which you get from ezx_system.cfg
the lang file is a shell script, you can understand it easily too.
multi-media:
preloaded JayDD's M8_Style skin, one of the most beautiful E8 skins
preloaded some pictures and ringtone
You can delete them if you want.
mods:
compcache swap enabled, from Abram
bash4.0.24, as the default root shell
busybox1.13.4, shown as busybox_full in /bin
show* series , mostly the same usage as E2 ones, but you should still look at the help info
by typing them without any param
added deathDlg instead of showProgress
added showSlider instead of showNumPicker
sorry no showDatePicker and showTimePicker, showColorPicker
lib:
libezxappbase.so modded for java speed, from motofan.ru
kernel:
removed motorola_feature_security
enabled ext3
enabled swap
scripts:
/mmc/mmca1/first.txt
/mmc/movinand1/first.txt
/mmc/movinand1/unKnown/myfont.ttf
/mmc/movinand1/unKnown/mynum.ttf
/ezxlocal/autorun.txt
/mmc/mmca1/autorun/S??*
/mmc/movinand1/unKnown/S??*
Япапко http://ifolder.ru/12458370
MegaUpload http://www.megaupload.com/?d=N2NMLLPM
LetItBit http://letitbit.net/download/3121c9d3a3/il...ba_pro.zip.html
http://www.rayfile.com/en/files/392647bd-5...795f/-Финальная версия(исправлены все баги)
Сообщение отредактировал Льоша - 6.6.2009, 18:37
Link на форум
Link на скачку
special thanks:
flashing steps:
notes:
most new functions:
2. no click bug
4. faster
what's new to rokr:
what's new:
FTP:
TELNET:
telnet enabled
usefull paths:
/mmc/mmca1/mpkgbox
multi-media:
mods:
lib:
kernel:
enabled ext3
enabled swap
scripts:
