2 страниц V  1 2 >
V8_EZX_SDK by yan0! hot, guys!
situr
сообщение 8.10.2009, 10:52
Пользователь №: 195 595
Модель телефона: V8 2G
Finally Finally and finally!
we v8 has our own SDK now!
It was by yan0, China.
NOw, here is the scrips by yan0:
QUOTE
V8 SDK released by yan0, 2009/10/7
V8 SDK (include files) are updated for V8 based on E8 SDK released by ilove3d.
yan0 have updated most files and can compile/run V8 program with UI.
http://www.magxcn.com
http://moto.it168.com
Use this SDK you need to open source, and need to release the include files with corrected.
To compile an application, please follow below steps as example:
1. Download E8 cross tool and extract to /e8-gcc
2. Extract V8SDK to /home
3. cd /home/V8SDK
4. . ./env.sh
5. cd ezxSample
6. progen -o ezxSample.pro
7. tmake ezxSample.pro -o Makefile
8. make
To compile your source code, rename above ezxSample to your file name.
check this original post:
http://magxcn.com/viewthread.php?tid=2501&extra=page%3D1
in this page you can download the sdk
http://magxcn.net/viewfile.php?file_id=265...le_key=Oxzanqfk
And now, ant-on and bez and all other z6 modders, please port your amazing apps of z6 to v8
thank you!!
Сообщение отредактировал situr - 8.10.2009, 11:21
ZORAN666
сообщение 8.10.2009, 19:27
Из: Запорожье
Пользователь №: 181 920
Модель телефона: Acer beTouch E101
Прошивка: WM 6.5
Sorry for the dumb question, but don't all the native apps work with V8?
I know the difference between MotoMAGX phones is only the keymap, cuz Z6 ScummVM works fine with ZN5 if you reconfigure the keyboard
situr
сообщение 9.10.2009, 2:16
Hi, I am a v8 user.
And I would say, Most apps can work on V8. But, most of them need Z6's lib to start which makes the apps so slow or so slow to start.For example, zScreenshoter , we would take more than 3 seconds or more to start it.And moreover , I am Chinese, you know in these apps,nearly all soft keys are English,Not Chinese.That is, if you didn't define soft keys in language files, they would appear to be english.
And some apps cannot work on v8, such as zMessager I think.
ZORAN666
сообщение 9.10.2009, 16:57
Из: Запорожье
Прошивка: WM 6.5
Цитата(situr @ 9.10.2009, 4:16) *
Hi, I am a v8 user.
I see...I didn't know...I know most of MotoCaker team projects have their source codes available, maybe you should try porting these apps yourself
Kefir.net
сообщение 12.10.2009, 16:15
Из: Беларусь, Могилёв
Пользователь №: 118 873
Модель телефона: L9 / RAZR² V8
Прошивка: .22.07R/LMFusion3
KoJIoBASS
сообщение 26.11.2009, 11:31
Пользователь №: 174 352
Модель телефона: RAZR 2 V8 2Gb
Прошивка: Fusion 3
Ещё бы скачать e8-gcc, было бы совсем здорово!
Сообщение отредактировал KoJIoBASS - 26.11.2009, 11:34
KoJIoBASS
сообщение 7.12.2009, 15:29
Прошивка: Fusion 3
В общем, e8-gcc(он же E8 cross tool) всё же разыскивается, кто поможет?
Добавлено позже (7.12.2009, 16:01):
Кому нужно: ссылка на оригинальный топик
Ant-ON
сообщение 8.12.2009, 4:36
Пользователь №: 49 304
Прошивка: CM12 / CM10 / PM2
С этим SDK zTaskMan не собирался работоспособно - он кривой. C каким-то по старее, запускался, но не всё работало...
KoJIoBASS
сообщение 8.12.2009, 6:22
Прошивка: Fusion 3
Kefir.net
сообщение 12.7.2011, 17:36
Где ещё можно взять SDK для V8?
V8_EZX_SDK by yan0! hot, guys! · Z6/V8 · Forum
2 страниц V  1 2 >
Текстовая версия Сейчас: 23.8.2019, 13:52
