5 страниц V  1 2 3 > »
[Droid] Rom-ы для Droid (настоящие), Полноценные кастомные прошивки
XVilka
сообщение 16.3.2010, 20:23
Пользователь №: 109 689
Прошивка: CM10
CyanogenMod
Версия: 5.0.8
Скачать: тут
Версия: 6.0.0 RC3
Скачать: тут
Установка:
- В первый раз
1. Разблокируйте телефон и установите ROM Manager из Marketa
2. Сделайте Nandroid backup!
3. Скачайте ROM на телефон
4. Установите ROM (используйте DATA WIPE после этого)
- Апгрейд
1. Сделайте Nandroid Backup!
2. Установите ROM
История версий:
Version 5.0.8
* Common: Resync with Google as of 06/08/2010
* Common: Kernel 2.6.34 for DS
* Common: ADWLauncher 0.8.6 by Ander Webbs is now the default launcher (http://github.com/anderweb)
* Common: Complete music app overhaul (with gestures support) by Eliot Stocker (http://github.com/eliotstocker)
* Common: Customizable silent mode - Glenn Maynard (http://github.com/zewt)
* Common: More customizable colors for various parts of the system (in Spare Parts) - Wysie & Bcrook
* Common: Updated translations from Eug89, ThiasB, and Takuo Kitame
* Common: Wired headset hangup/mute control - Krazy Krivda (http://github.com/krazykrivda)
* Common: Updated USB tether and Bluetooth PAN tethering - Stefan Tomanek (http://github.com/wertarbyte)
* Common: Bluetooth DUN tether support (Omni-Tether) - Stefan Tomanek (http://github.com/wertarbyte)
* Common: Various minor bugfixes
* Common: Ability to load custom color theme xml - Wysie
* Common: Various code cleanups all throughout the source - Christian Mehlmauer
* Common: Fix issue where notifications would play thru the HW speaker even if a headset was connected - Glenn Maynard
* Common: Only load IPV6 if persist.net.ipv6 is set - Glenn Maynard
* Common: Enabled experimental Bluetooth voice dialing - copolii
* Common: Fix an NPE in AccountManagerService
* Common: Fix FLAC decoder lock contention - Glenn Maynard
* Common: Fix BlueZ logging - Glenn Maynard
* Common: Fix A2DP not connecting while asleep - Glenn Maynard
* Common: Fix BT control connection race condition (caused A2DP connection failures) - Glenn Maynard
* Common: Fix the "magic music" or "party-in-your-pocket" problem for good - Glenn Maynard
* Common: ADW Launcher settings and Spare Parts are now under the main Settings app - Mehdi ABAAKOUK (http://github.com/sileht)
* Common: Fix brightness going out of range - Glenn Maynard
* Common: Fix parsing of SMS messages from short numbers - Glenn Maynard
* Common: Improve BiDi text rendering - Dudy Kohen
* Common: Fix WindowManagerService issue that could cause apps to get OOM killed out of order
* Common: Busybox updated to 1.16.2 - Dylan Simon
* Droid: New kernel with Compcache support. (Bekit)
* D/S: Kernel tweaks to hopefully improve memory usage- enable TINY_RCU and deadline iosched (I can no longer reproduce the flash_image failures with this configuration)
* D/S: Multitouch and swipe added to legacy gallery app
* D/S: Long standing "disappearing icons" Launcher bug fixed - Glenn Maynard
* D/S: Fix acore crash when pressing hard call button - Glenn Maynard
* D/S: Fix issue where camera use kills all system audio
* D/S: Added antibanding to camera driver
* D/S: Fix bug where some wall chargers could disable the USB port
* D/S: Load the correct audio profile for the device to fix glitchy audio on Dream
* D/S: Default compcache size set to 12MB
* D/S: Offset the lowmemorykiller to allow for use of a fraction of swap (Dumfuq & Farmatito @XDA)
* D/S: Prevent allocation failure when enabling Compcache
Version 5.0.7.1
* Common: Color picker and reset-to-defaults option for new UI customizations (Wysie)
* N1/Droid: Fix blurry images in Gallery3D
Version 5.0.7
* Common: Resync with Google as of 05/20/2010
* Common: New ARM optimizations in Bionic from Jim Heruang @ 0xlab
* Common: Superuser 2.1 from ChainsDD
* Common: DeskClock style tweaks from Nathan Zachary
* Common: Email signature support from Jarrett Vance
* Common: Pin-lock and alternate lockscreen framework from _avatar
* Common: Updated Japanese locales from Takuo Kitame
* Common: Added Compcache and rzscontrol to the build
* Common: APN list updated by Paul Weiss, blunden, and PsychoI3oy.
* Common: Downloader allows any file to download - thanks Eddie Ringle
* Common: Kernel updated to 2.6.33.4
* Common: Fix bug with where wrong organization is shown in-call (Boyd Bischke)
* Common: Several kernel patches from Christopher Lais (Zinx) to improve stability and support MT3G Fender/1.2
* Common: Low memory killer was pimped out by San Mehat @ Google. Big interactivity boost especially on D/S
* Common: Updated Phone patches from Cytown (v29)
* Common: Dim the deskclock screensaver colors
* Common: Fixed race conditions and notification bugs in MMS
* Common: Added quick uninstall "Delete Zone" to Launcher and Launcher2 (Ander Webbs)
* Common: Allow widgets in the Launcher default workspace (ported from Launcher2 by Lox)
* Common: Fix race conditions and bugs in MMS app
* Common: Compact drawer can be toggled for Launcher as well as Launcher2 now
* Common: Added squisher script for release builds
* Common: Another lowmemorykiller tweak from Zinx to take cache into account
* Common: Turned off battery percentage display by default
* Common: Added "omni-tether" from Wertarbyte for BT tether
* Common: System built using Zinx's resource-sorter patch for aapt- may provide perf boost
* Common: Patch from Zinx to have background processes holding wakelocks set to a higher OOM kill adjustment (push notify, mms are good examples)
* Common: Number of recent apps is configurable - Bcrook, Pershoot & Wysie
* Common: Ability to disable icons and paths on the lockscreen - Wysie
* Common: Add pand and hidd to the build
* Common: Fix OpenVPN- manifest was using the wrong mtpd
* Common: DeskClock: Add alarm timeout setting (Michael Webster)
* Common: OpenVPN: Select between TAP and TUN interface (Takuo Kitame)
* Common: Various UI element colors are selectable via Spare Parts (Wysie)
* Common: NEON-optimized libjpeg (CodeAurora/Qualcomm)
* Droid: Fix for 50% signal loss reporting bug on Motorola Droid (Boyd Bischke)
* Droid: Disable V8. It was breaking Epocrates and other applications
* Droid: Tweak the haptic feedback to better match stock (Adrynalyne)
* Droid: Enable Dialpad for OTA Activation (nuclear305)
Version 5.0.6.2
Add fstab to /system/etc
Remove Google Apps which accidentally ended up in the build.
Removed the usage of blur effects on some screens (like power off). It is too slow on the Droid.
Version 5.0.6.1
Fix wifi for those using the default kernel
Version 5.0.6
Fixed MMS Videos (PDR447, slayher, DroidMod all had a hand in this)
Fixups to 4/5 column launcher
Fixed ##program menu
Fix fstab bug (DroidMod)
Version 5.0.5.7
Исправлен Launcher2.
Version 5.0.5.6
Удален Launcher2 пока не решаться с ним проблемы.
Новые ESE81 драйвера and renderscript backport.
Version 5.0.5.4
Добавлены bash, irssi, nano, htop и другое...
Version 5.0.4.2
Ввиду больших проблем с работой отключен JIT
Version 5.0.4.1
Удален Stk,app, исправлены ошибки в работе подсветки клавиатуры
Version 5.0.4
Испарвлена ориентация экрана при установке на док-станцию
Используется версия 0.5 Launcher2.
Исправлена функция mute
Исправлена автонастройка подсветки от освещенности
Исправлены некоторые ошибки разгона
Возможности:
* Улучшенный код старта и выключения
* Убран APPS2SD для dalvik. Кэш сохраняется в /cache, что сохраняет около 40 мб в /data
* Встроенная поддержка USB Tether
* ARM NEON оптимизации по инструкциям 0xdroid и Qualcomm
* Включены BusyBox, htop, nano, powertop, bash и друугие полезные утилиты командной строки
* поддержка FLAC от Kenny Root
* Расширения функций звонилки от Cytown
* Расширения функций контактов от Wysie
* Подтверждение zipalign-on-install для приложений
* DeskClock улучшения - более долгая автопауза и "require unlock" опция
* Большая коллекция рингтонов и аудиофайлов для тем
* Включены все возможные локали (спасибо PsychoBoy)
* 360 автоориентация от Optedoblivion
* OpenVPN интеграция от James Bottomley
* Множество исправлений и улучшений от разрабочиков AOSP (собрано из последнего дерева AOSP)
Скрины:
Видеобзор тут
Все исходники могут быть скачаны из дерева GIT http://github.com/koush
Google Addon: EPF30
Download: EPF30-signed.zip
Bugless Beast
Последняя версия: 0.4
Скачать: тут
История версий:
*Version 0.4 (6/29/10)
-New Base (FRF84B)
+Clean Unyaffsed Image, NOT the leak
+Fully deodexed by Pete & Birdman
-Updated Bugless Beast Toolkit
-Renabled Setup Wizard by request
*Version 0.3 (6/28/10) STABLE!
-Added New "HotKeys" and changed existing ones
+Recovery (hold power & x button)
+Shutdown (hold power & s button)
+Reboot (hold power & r button)
+Testing Menu (hold left alt & menu button)
-Added Bugless Beast Toolkit App (developed by Mr.Blippy with some images by Frost)
-Updated scripts & added more (detailed info, restore options, etc)
+Type the name of any script to print its info
-Added transparent notification window (patch by Xeudoxus)
-Made adjustments to all tweaks/mods for a completely stable experience
-Added Motorola X bootanimation
-Added Motorola X ringtones & edited their names
-Updated Google Maps to latest version
-Fixed all issues/bugs with previous "Experimental" builds
Version 0.2.1 (6/16/10)
-Fixed Reboot/Shutdown issues
-Raised minumum cpu speed to 250Mhz (125Mhz was causing issues)
-Added information to /system/etc/sysctl.conf to help you fine tune Virtual Memory
and disabled my tweaks by default (I am still currently using my tweaks with no issues)
-Fixed Quick Office FC issues
Version 0.2 (6/15/10)
-Fixed Apps2SD on Froyo! Most apps will now install to the sdcard automatically
*Widgets and some other apps may not perform properly when installed on the sdcard;
simply use the option "move to phone" in Settings > Applications > Manage Applications*
-Updated Busybox to V1.16.1 (more commands)
-Fixed busybox wget command
-Readded automatic overclock to highest available slot
-Added full sysctl support
-Added Google DNS for a faster and safer online experience
-Removed google analytics from hosts for ROM Manager stats
-Made ADB Shell run as root by default (eliminates the need to type in su)
*TO REMOVE THESE OPTIONS DELETE /system/bin/shutdown*
-Added Reboot Recovery option (hold power & vol up button)
-Added Reboot option (hold power & vol down button)
-Added Shutdown option (hold power & half pressed camera button)
-Added Clean shutdown/startup from Cyanogenmod
-Added custom wallpapers (thanks Prash, HTC, Google, etc.)
-Added MANY new tweaks for added performance and battery life
-Bypassed setup wizard to save time after a data & cache wipe
-Disabled Location Services by default (saves battery life)
-Wifi Issues should be fixed (wipe data & cache if they still occur)
Version 0.1 6/09/10
Возможности:
-Основан на FRF57 (credit to Google)
-Полностью Zipaligned System (credit to Pete)
-Полностью Deodexed System (credit to Google)
-Автоматическое Apps2SD (credit to Pete for fixing)
-Автоматический разгон на максимально возможную частоту (credit to Pete)
-Полная поддержка sysctl (credit to Pete)
-Скрытые опции выключения используя горячие клавиши (credit to Pete):
Чтобы удалить эти возможности - удалите /system/bin/shutdown
*Shutdown: hold power & half pressed camera button
*Reboot: hold power & volume down button
*Reboot Recovery: hold power & volume up button
-Чистое завершение и старт(from CyanogenMod)
-Выборочные обои (thanks Prash, Google, & HTC)
-Автопрохождение Setup Wisard (credit to Pete)
-Геолокационные сервисы отключены по-умолчанию (credit to Pete)
-Тонны хаков и оптимизаций для увеличения производительности и времени жизни батареи (credit to Pete)
-Google DNS для увеличения быстроты и безопасности web-серфинга (credit to Pete)
-ADB Shell запускается под рутом по умолчанию *не нужен su* (credit to Pete)
-Встроен Chrome To Phone(credit to Google)
-Поддержка Adobe Flash Player
-Встроен видео плеер от Milestone (credit to Pete)
-Встроена запись звука (credit to Pete)
-Встроен Quick Office App (credit to Pete)
-Spare Parts App (modded by Pete)
-Neural Network Live Wallpaper with Google Colors (credit to Pete)
-Огромное количество стандартных мелодий (credit to Pete) *All 2.0, 2.1, & 2.2 Sounds*
-Longer Duration Between Wifi Scans Tweak *Battery Saver* (credit to Pete)
-Информация о версии в настройках > About Phone (credit to Pete)
-SuperUser App V2.1 w/ new UI (credit to ChainsDD)
-Блокировка рекламы в приложениях и броузере *не нужен AdFree* (credit to Pete)
-Отключен звук камеры *shutter & video recording* (credit to Pete)
-Nearly 100MB free at boot (credit to Pete)
-Over 50MB of free memory at all times *No need to use task killers* (credit to Pete)
-Автоматически установлены Busybox & Toolbox (thanks Koush)
-Scripts ready to run after ROM Installation (credit to Pete)
-Backup/Delete Apps Using Astro & godmode
-Процент заряда на иконке батареи (images by xeudoxus)
-Минимизировано использование процессора в LWPs (idea by ChevyNo1 & ReverendYo)
Утилиты:
-Flash Image
-Busybox 1.16.1
-Bash Shell
-Zipalign
-Toolbox
Удалено:
-Visual Voicemail (Market)
-Facebook (Market)
-Voice (Market)
-Goggles (Market)
-Twitter (Market)
-30 испорченных обоев .jpg которые остались в Launcher2.apk
Темы:
-Modified Stock Theme (credit to Pete)
-Удален логотип Google из виджета поиска
-Удален логотип Google из карт
-Удален логотип Weather Channel из News & Weather
-Удален фон из кнопок Launcher-а
Smoked Glass (by Adamz)
Последняя версия: 6.0.1
Скачать: тут
Simply Stunning (by Chevy No1)
Последняя версия: 4.3
Скачать: тут
Team Chaos Mod
Последняя версия: 1.0
Скачать: тут
Сообщение отредактировал Neko-mata - 13.7.2011, 5:46
OWNER
сообщение 17.3.2010, 13:12
Из: Odessa
Пользователь №: 1 969
Модель телефона: DROID RAZR MAXX
Прошивка: stok 4.1.2
многоуважаемый XVilka, а можно поподробней расписать как сделать бэкап всего, а затем как восстановить в случае чего. ну и самое главное как установить этот РОМ. по шагам если можно, ROM Manager из Marketa установлен. что дальше? хочу опробывать эту сборку...
Сообщение отредактировал OWNER - 17.3.2010, 13:13
XVilka
сообщение 17.3.2010, 20:25
Прошивка: CM10
Ну вот собственно программа Nandroid Backup (ADBRecovery) ADBRecovery
Оригинал тут:
http://alldroid.org/threads/14716-ADBRecovery
порядок бэкапа
Как сделать бэкап с помощью только boot, bpsw, cust, recovery and system
* скопируйте ADBRecovery на карту памяти (по ссылке скачайте версию 6)
* Перезагрузитесь в рекавери режим и примените update.zip
* подсоединитесь с помошью ADB и наберите следующую команду
nandroid-mobile.sh --backup --nodata --nocache --nomisc
* Когда он спросит префикс - наберите что-нибудь
* Перезагрузитесь в андроид и скопируйте полученную папку на комп (by zipping the whole folder)
* Файл назван должен быть как nandroid каталог ("<prefix>-BbcRS-<date>-<time>") и иметь каталог "<prefix>-BbcRS-<date>-<time>" в корне архива
Добавлено позже (17.3.2010, 23:51):
Вот видео как это все делать http://alldroid.org/threads/15244-Video-Gu...ooting-Cust-ROM
Сообщение отредактировал XVilka - 17.3.2010, 20:40
OWNER
сообщение 18.3.2010, 10:25
Из: Odessa
с этого момента можно подробнее, как подсоединится? через что? каким образом?
данную команду где набирать ? на дроиде или с компа (каким образом)?
OWNER
сообщение 19.3.2010, 7:40
Из: Odessa
Все установил, все работает замечательно, доволен!
Вопрос, как отключить Launcher2. что бы остался стандартный рабочий стол? нигде не могу найти... помогите! crazy.gif
p.s. все, разобрался. вопрос отпал.
Сообщение отредактировал OWNER - 19.3.2010, 10:32
OWNER
сообщение 22.3.2010, 7:23
Из: Odessa
есть обин большой недостаток в этой сборке. т.к. он от HTC. то тут полная лажа с энергопотреблением. в течении дня со 100% заряд упал до 30% (это с 8.00 до 20.00) вот такие дела...
Сообщение отредактировал OWNER - 22.3.2010, 7:24
XVilka
сообщение 22.3.2010, 7:31
Прошивка: CM10
В 3 версии много багов связанных с этим исправлено
Но она пока в статусе экспериментальной
Вот последняя сборка powertop под Droid - посмотрите, что у вас больше всего ест в памяти
И напишите тут - мы им багрепорт составим
Сообщение отредактировал XVilka - 22.3.2010, 7:58
OWNER
сообщение 23.3.2010, 7:09
Из: Odessa
и как это установить на Droid ? или переименовать в *.apk ?
XVilka
сообщение 23.3.2010, 19:58
Прошивка: CM10
Разархивируйте на компе, копируете на телефон,
желательно в кпримеру в /data, поскольку с карты памяти нельзя запустить
и запускаете из консоли командой /data/powertop (под рутом)
И анализируете вывод - желательно смотреть в течение получаса - часа.
soneric750
сообщение 26.3.2010, 4:43
Группа: Начинающий
Пользователь №: 213 203
Модель телефона: zn5
Русский в этой прошивке есть?
[Droid] Rom-ы для Droid (настоящие), Полноценные кастомные прошивки · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 18.8.2019, 2:39
