This is another Phone Lock application inspired from qeiLock and based on SDL.
Created by - BRUCELEE
Features:
Attention:
Download:
Screenshots:
Сообщение отредактировал Kundan - 31.8.2011, 4:27
Features:
QUOTE
- uses the system current wallpaper and font
- 'slide to unlock' like qeiLock has
- show usb connection type
- bottom and top panel can be shown/hidden by dragging
- the clock can be dragged around and remembers the position
- screen slide between normal and settings state
- the settings option list can be scrolled by dragging it
- Vibrate when touching buttons
- If the SDL libraries are found in /mmc/mmca1/games/lib the bLock/data/lib folder is cleaned
Attention:
QUOTE
I don't recommend opening the settings window more than 16 times per application session.
Reason:
For faster startup I choosed to load the settings data only when entering settings as most of the time users won't open settings but block their phones.
So the settings data will load/unload each time you open/close settings.
For some reason something is not cleaned in memory. And so after about 16 loadings of the settings class loading it takes a lot.
I'll try to fix this...
Reason:
Download:
QUOTE
- bLock.v.1.1a.patch - Extract over the installed bLock.v.1.0
- bLock.v.1.0.mpkg - If you already have SDL libs in /mmc/mmca1/games/lib
- bLock.v.1.0-with-libs.mpkg - If you don't have SDL libs or you're not sure
- bLock.v1.1a+libs.mpkg.zip - If you don't have SDL libs or you're not sure
- bLock.v.1.0-src.zip - The source code.
Screenshots:
