20 страниц V  1 2 3 > »
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр
sidr
сообщение 22.6.2014, 13:11 Закрепленное сообщение!
Из: Бреста
Пользователь №: 168 840
Moto E (XT1021, XT1022, XT1025)
Техническое описание
Operating system - Android™ 4.4, KitKat®
Processor - Qualcomm® Snapdragon™ 200 with 1.2GHz dual-core A7 CPU
Adreno 302 400MHz single-core GPU
Capacity - 4GB standard MicroSD slot supports up to 32GB expandable memory 1GB RAM
Dimensions and weight - Height: 124.8mm
Width: 64.8mm
Depth: 12.3mm
Weight: 142g
Display - 4.3 inches 540 x 960 qHD, 256ppi Features anti-smudge coating and Corning Gorilla Glass 3
Connectivity - MicroUSB, supports USB 2.0 3.5 mm headset jack Micro SIM
Battery - Built-in rechargeable lithium-ion, 1980mAh Mixed usage up to 24 hours
Rear camera - 5 MP
Networks - US GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
Requires a microSIM card (not included)
Global GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
CDMA Model Coming Soon!
CDMA/EVDO Rev A (850, 1900 MHz)
Bluetooth® Technology - Version 4.0 LE
Wi-Fi - 802.11 b/g/n, 2.4GHz
Фото MOTO E
Видео
[video]https://www.youtube.com/watch?v=Cs6tV1Di3-8[/video]
Видео Moto E vs Moto G
[video]https://www.youtube.com/watch?v=rVKQJp21r9Q[/video]
ОФ прошивки для MOTO E
Инструкция по прошивки с hda
a) Download and install Motorola Moto EDrivers
b) Download and extract the stock Firmware of your choosing
c) If the firmware file you downloaded is a .xml.zip file then download Motorola Fastboot Attachment 2427667 (attached to this post) and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files). If your firmware is a .tar.gz file then skip this step.
d) Get ADB (if you don't already have this, I suggest downloading and installing Minimal ADB and Fastboot by shimp208:
Direct Download
Disclaimer:
Follow these instructions at your own risk. If something goes wrong don't blame me!
These are the original stock signed image files from Motorola it should work on all Moto E Variants.
Steps to restore stock firmware:
1) Reboot the phone into bootloader mode. There are 2 ways to do this.
I) The 'hardware' way.
a) Unplug the USB cable and power off the phone.
b) Press and hold 'Volume down' then power on the phone.
c) Connect USB cable to your computer.
II) The 'software' way.
a) Enable developer mode on the Moto E (Settings-> 'About Phone'. Tap 7 times on 'Build Number')
b) Enable USB debugging. (Settings -> 'Developer options' -> 'USB Debugging' -> check)
c) Connect phone to computer via USB, you should see a new ADB device detected and drivers installed.
d) Open "Minimal ADB and Fastboot". Type:
Code:
adb reboot-bootloader
You should see the Moto E bootloader screen with the following options:
Code:
Normal Powerup
Recovery
Factory
Switch Console [NULL: null]
Barcodes
BP Tools
2) Open a command prompt / terminal (Start -> cmd.exe in Win7) and browse to the folder with the extracted firmware.
In my case:
Code:
cd c:\falcon_retgb_user_4.3_14.10.0Q3.X-76-LGG-8_54_release-keys-cid7-Retail_GB
3)
Flash each of the partitions in sequence using mfastboot, you need to enter the following commands one-by-one checking that each one returns an [OKAY]
Code:
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
Downgrading:
4) Wait, you should now be rebooted into a fully stock Moto E firmware.
Драйвера
Где купить:
EBAY
AMAZON
Фото разобранного телефона
Сообщение отредактировал Воха - 20.12.2015, 19:28
captan2
сообщение 29.5.2014, 15:01
Из: Воронежская область
Пользователь №: 163 860
Модель телефона: z3 - xt5 - E - G3
Так как моя нынешняя моторолка попрощалась со мной, то встал вопрос покупки новой. Через интернет присмотрел в Италии, куда поеду летом, модель Moto E. Но здесь на форуме совсем никак не могу найти темы с обсуждением данной модели. Тыкните мне, пожалуйста, если таковые есть что бы прочитать. Спасибо
сообщение 29.5.2014, 15:51
Группа: Администратор
Модель телефона: Moto X (4rd gen)
Прошивка: 29.69-37-3
captan2,
пока информации мало. Новость анонса можно прочесть тут
На мой взгляд достойный девайс, хотя не без минусов. Например как по мне минус это отсутствие фронтальной камеры для видео связи, ну и вспышки (хотя это и не столь важно).
Но и есть отличный плюс в виде наличия слота карты памяти. На моем джи его явно не хватает.
-RPG-
сообщение 29.5.2014, 15:53
Пользователь №: 126 829
Модель телефона: куча разных
Прошивка: нестандарт
captan2, телефон совсем новый, еще ни у кого на руках скорее всего нет.
сообщение 29.5.2014, 18:08
Группа: Разработчики сайта
Модель телефона: Motorola Rokr E1
Пишу обзоры за еду
по моему его даже в продаже пока нету. так что ждем появления в продаже.
сообщение 29.5.2014, 19:09
Claus398,
ошибаешься, в индии 120 000 ешек в онлайне распродали за пару часов.
сообщение 29.5.2014, 19:47
Пишу обзоры за еду
stigr,
а по чем продавали?
нашел вот http://www.ebay.com/itm/NEW-Motorola-Moto-...=item2ed24f787f 170 баксов, барыга продает, дороговато конечно. блин плохо что с офф сайта не отправляют по всему миру DHL'ом
captan2
сообщение 29.5.2014, 19:48
Claus398,
ну я практически наугад через официальный сайт вышел на региональный итальянский сайт и там есть ссылки на сайты магазинов типа Евроникс. И у них они стоят по 129 евро. Хотя немецкий сайт предлагает по 109, но под заказ. А доставка, как я прочитал здесь долгая и не дешёвая. Так что даже если так, то к концу июля уж они будут в продаже)) Иначе я без моторолки заскучаю совсем, хотя мой пенсионер Z3 сейчас выручает, но уже привык к смартфону(((
сообщение 29.5.2014, 20:01
Цитата(Claus398 @ Сегодня, 22:47)
* а по чем продавали?
129 баксов (но в рупиях). Так как мото и объявляла. Но я так и не понял продавалась двух симочная версия или простая. Новость видел в твиттере.
Добавлено позже (29.5.2014, 23:11):
Кст вот обзор от энгаджета. Будущим владельцам познавательно прочесть http://www.engadget.com/2014/05/26/moto-e-review/
captan2
сообщение 29.5.2014, 20:19
Я так понял продают односимочную http://www.euronics.it/acquistaonline/tele...=eProd142008979
За обзор спасибо, но с английским труба)))
сообщение 30.5.2014, 5:45
captan2,
в двух словах, они его хвалят. Минуса и плюсы они дают примерно теже. Плюс хвалят дисплей.
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр · Motorola на OS Android · Forum
Текстовая версия Сейчас: 21.8.2019, 4:43
