7 страниц V  1 2 3 > »
Jffs2-r541_l7_g_11.10.11r
marcolnx
сообщение 29.5.2010, 14:50
Пользователь №: 201 733
Модель телефона: a1200e a1200i
Прошивка: jffs2
JFFS2-R541_L7_G_11.10.11R
I would like to give thanks especially Provodnik, I borrowed the theme Iris and animations.
Thanks Provodnik for the wonderful work.
Main features:
- widgets support (6 preinstalled)
- 3 skins: Iris - Red - White
- 2 java applications: Platinum Sudoku - ICQ Jimm
- Radio works without headset
- Realplayer with equalizer
- Run multiple apps
- Language: English - Russian
- English keyboard with Russian flag and Russian
- Fingerpad
- Screen3
- ext2 ext3 support with modules.dep
- bash3 busybox strace ldd etc.
- Telnet (completion commands-path and history) Samba Ftp (pure-ftpd)
- foxalarm (Russian with voice Russian)
- Preinstalled applications:
- Assistant (installer pkg, swap manager, screenshot, reboot, hide folder, java hacker, mystuff, uncompress most of archives tar - gz - zip - rar -7z, backup, etc.)
- eKonsole with history and completion path commands
- ZEditor
- PicselEdit
- Processor (underclock and overclock at 520)
- Skin Installer 2.4
- SysInfo
- Backup Restore Now
- Support autorun.txt startup.txt and startup1.txt -> SD (/mmc/mmca1/)
- Support startup2.txt -> Phone (/ezxlocal/download/mystuff/)
Preload folder it's My_FAVOR (you have to create -> Phone /ezxlocal/download/mystuff/ ).
Options (ezx_boot.cfg):
Start.wav (sound power)
myfont.ttf (for font)
command.spa and commandlist (voice)
Stop.wav (sound of the key "end" when it holds tight to turn off)
TouchT.wav (sound of the touch screen option in "Tone" )
TouchC.wav (sound of the touch screen option in "Click" )
Conect.wav (sound when loading / USB)
Alert.wav (sound low battery / missed call)
Key.wav (sound of the keys except those listed above)
Send.wav (sound of the green button )
End.wav (sound of the red button )
ezx_volumetable.cfg
Generally if something does not like (you can write in the whole) you can edit yourself.
To change modes ro - rw in the console execute:
rw (enter)
ro (enter)
SDHC support:
You must flash jffs2_kernel_sdhc.sbf
Format SDHC 1st partition Fat32 (use GParted for this and or for resize for swap partition)
When you will insert your SDHC with ekonsole or telnet session:
fdisk /dev/mmca (enter)
p (enter)
t (enter) and select first partition
6 (enter)
w (enter)
reboot
Link:
http://www.4shared.com/file/-4syXPiy/jffs2...1R_Iris_RU.html
(There are also two folders: VR and bcr (put both in SD for VR Russian and bcr)
To install programs rename pkg (install with Assistant)
To install widgets mpkg make click.
I thank you all for reporting any problems and if help with translation.
Прикрепленный файл DeviceStatusDashboard.zip   ( 187.4 килобайт ) Кол-во скачиваний: 203
dvrts
сообщение 29.5.2010, 18:00
Из: Lviv
Пользователь №: 162 099
Great work! I'm wondered of you, my dear friend :)
Caif
сообщение 29.5.2010, 18:39
Из: Набережные Челны
Пользователь №: 170 337
Модель телефона: A1200e
Прошивка: 16r
marcolnx
сообщение 29.5.2010, 21:02
Прошивка: jffs2
Hi dvrts,
I consider you a true friend and I would be honored to share with you this thread.
Your help and your experience are important to me.
Hi Caif,
In jffs2 you can directly edit what you want.
For me important busybox bash3 ldd strace ekonsole ...
No problems with battery.
You can directly change the theme, make symbolic links ...
I changed from Italian into Russian in no time (I do not speak Russian).
Easy to change directly to Ukrainian or whatever.
ElChino
сообщение 29.5.2010, 23:55
Из: JuventusMember
Пользователь №: 196 088
Модель телефона: ROKR E6 // RAZR M VRZ
Прошивка: LightSPEED3 // 4.1.1
marcolnx,
It is possible please skin(theme) separately, it would not be desirable to assort insertion...
Сообщение отредактировал ElChino - 29.5.2010, 23:56
Myrik
сообщение 30.5.2010, 8:06
Пользователь №: 216 960
а можно перевод!
ElChino
сообщение 30.5.2010, 8:24
Из: JuventusMember
Вобщем, хотел чтобы марко скин вытащил и выложил)а то самому вытаскивать неохото,притом fx не может прога найти в прошивке.
dvrts
сообщение 30.5.2010, 9:19
Из: Lviv
а через usb-net вытащить?
перевод будет готов сегодня-завтра, дайте только за комп сесть:)
I'll translate fw description in a few days - just i need to use my PC
Myrik
сообщение 30.5.2010, 10:41
отпишитесь кто прошивал есть баги и какие?
credoff
сообщение 30.5.2010, 12:44
Пользователь №: 15 146
Модель телефона: E1 & A1200
лично у меня багов не замечено... в целом прошивка очень хорошА.
Jffs2-r541_l7_g_11.10.11r · A1200/A1600/ROKR E6 · Forum
Текстовая версия Сейчас: 20.5.2019, 14:36
