5 страниц V  1 2 3 > »
C++ Develop App
croccio
сообщение 21.6.2010, 21:36
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
i' trying to develop app in c++. i downloaded E8GCC and E8SDK. i edit file env.sh then i try to compile showRadio but i've this error:
arm-linux-gnueabi-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -O3 -DNO_DEBUG -I/home/antonio/Scrivania/E8SDK//include -o showRadio.o showRadio.cpp
make: execvp: arm-linux-gnueabi-g++: Permesso negato
make: *** [showRadio.o] Errore 127
wht is??
can anyone do example for create "windows" and position object in the window???
EXL: Share full log of their actions, beginning with the launch environment
env.sh
#!/bin/bash
# -here you should put your own E8SDK path.
export QTDIR=/home/antonio/Scrivania/E8SDK/
export TMAKEPATH=/home/antonio/Scrivania/E8SDK/tmakelib/pwd/arm-linux-g++/
export PATH=/home/antonio/Scrivania:/e8-gcc/bin:/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
for compile app i do new sh file i called it make_app.sh
. /home/antonio/Scrivania/E8SDK/env.sh
cd /home/antonio/Scrivania/E8SDK/showRadio
progen -o showRadio.pro
tmake showRadio.pro -o Makefile
make
then from console i do
/home/antonio/Scrivania/E8SDK/make_app.sh
the it show this
make: *** [text.o] Errore 127
can u tell me what file i post??? or app that i can try??? and how can i create new form (window) where i put object, as textbox, label... and how can i control key pression??
in the foldere where there is the app code there isn't showRadio.o
EXL: Try to do so:
. env.sh
chmod +x /Path_to_progen/progen
chmod +x /Path_to_tmake/tmake
Coming Makefile fix thus the following strings:
CC    =    arm-linux-gcc
CXX    =    arm-linux-g++
Then execute:
make
And do check the correctness of all paths...
it do nothing
(22.6.2010, 13:43):
i get this
EXL: arm-linux-gnueabi-g++ in the Makefile should be replaced by on arm-linux-g++ !
i edit the make file in showRadio folder, it is or no??
EXL: Yeah!
when i run make_app.sh the make file in showRadio folder change automatically!
can u upload your E8SDK and e8-gcc folder so i use that?? can u tell me in what folder i copy them???
if u don't belive i post a video screen soon
EXL: From make_app.sh remove next line - make
New make_app.sh:
then correct Makefile
and run in console the following:
make
Сообщение отредактировал EXL - 23.6.2010, 1:21
croccio
сообщение 22.6.2010, 14:02
arm-linux-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -O3 -DNO_DEBUG -I/include -o showRadio.o showRadio.cpp
make: arm-linux-g++: comando non trovato
EXL: Give me a link to your E8 SDK
(22.6.2010, 14:06):
http://dc152.4shared.com/download/13376269...082755-79f8c8f3
i download them from mmus
(22.6.2010, 14:07):
env.sh file isn't edit with my path! it is original archive
(22.6.2010, 14:08):
can u help me with ftp connection on ubuntu 10.04 too?
EXL: arm-linux-gnueabi-g++ in the Makefile should be replaced by on g++
(22.6.2010, 14:23):
make: g++: comando non trovato
(22.6.2010, 14:28):
can u give me your folder for develop them???
(22.6.2010, 14:41):
i install g++ with
apt-get install g++
then i start "make" from console and now i've this
g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -O3 -DNO_DEBUG -I/include -o showQ.o showQ.cpp
showQ.cpp:2:26: error: ZApplication.h: Nessun file o directory
showQ.cpp:3:25: error: ZMessageDlg.h: Nessun file o directory
showQ.cpp:7:24: error: qtextcodec.h: Nessun file o directory
showQ.cpp:9: error: expected constructor, destructor, or type conversion before ‘*’ token
showQ.cpp:10: error: ‘QString’ does not name a type
showQ.cpp: In function ‘int main(int, char**)’:
showQ.cpp:17: error: ‘QString’ was not declared in this scope
showQ.cpp:17: error: expected ‘;’ before ‘title’
showQ.cpp:18: error: expected ‘;’ before ‘text’
showQ.cpp:23: error: ‘title’ was not declared in this scope
showQ.cpp:23: error: ‘ChineseAndEnglish’ was not declared in this scope
showQ.cpp:24: error: ‘text’ was not declared in this scope
showQ.cpp:29: error: ‘title’ was not declared in this scope
showQ.cpp:29: error: ‘ChineseAndEnglish’ was not declared in this scope
showQ.cpp:30: error: ‘text’ was not declared in this scope
showQ.cpp:34: error: ‘text’ was not declared in this scope
showQ.cpp:34: error: ‘ChineseAndEnglish’ was not declared in this scope
showQ.cpp:37: error: ‘ZApplication’ was not declared in this scope
showQ.cpp:37: error: ‘a’ was not declared in this scope
showQ.cpp:37: error: expected type-specifier before ‘ZApplication’
showQ.cpp:37: error: expected ‘;’ before ‘ZApplication’
showQ.cpp:39: error: ‘ZMessageDlg’ was not declared in this scope
showQ.cpp:39: error: ‘showQDlg’ was not declared in this scope
showQ.cpp:39: error: expected type-specifier before ‘ZMessageDlg’
showQ.cpp:39: error: expected ‘;’ before ‘ZMessageDlg’
showQ.cpp:41: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
showQ.cpp:42: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
make: *** [showQ.o] Errore 1
EXL: This is not a full SDK for E8( http://dc152.4shared.com/download/13376269...082755-79f8c8f3
can u give me all file for develop app please???
EXL: I do not have moto e8 and E8SDK(
Сообщение отредактировал EXL - 23.6.2010, 0:04
croccio
сообщение 23.6.2010, 13:39
can anyone give me E8SDK please??
Сообщение отредактировал EXL - 23.6.2010, 13:51
Ant-ON
сообщение 24.6.2010, 14:58
Пользователь №: 49 304
Прошивка: CM12 / CM10 / PM2
I use this SDK.
Install on Linux:
1) Install subversion
For Debian/Ubuntu:
sudo apt-get install subversion
2) Download SDK + toolchain
For Debian/Ubuntu:
svn co https://ezx.darktech.org/svn/trunk/arm-eabi
3) Create a symlink to arm-eabi in the root directory
For Debian/Ubuntu:
sudo ln -s -d /home/anton/arm-eabi -t /
Now you can collect the application. To do this, open the makefile and replace the piece at the beginning (a piece of the file to "HEADERS ="):
# App can compile for platform:
#    PLATFORM=EZX-Z6
#    PLATFORM=EZX-Z6W
#    PLATFORM=EZX-U9
#    PLATFORM=EZX-ZN5
#    PLATFORM=EZX-V8
#    PLATFORM=EZX-E8 (default)
#    PLATFORM=EZX-VE66
#    PLATFORM=EZX-EM35
# For example - compile this source for Motorla ZN5:
# cd /PROJECT_FOLDER/
# make clean
# make PLATFORM=EZX-ZN5
######Config######
APPNAME    := zTextEdit
UPLOAD_PATH :=  /mmc/mmca1/bin/
TOOLPREFIX := /arm-eabi
ARMLIB     := $(TOOLPREFIX)/arm-linux-gnueabi/lib
ifeq ($(PLATFORM),)
PLATFORM = EZX-E8
endif
ifeq ($(PLATFORM),EZX-Z6)
QTDIR    :=    $(TOOLPREFIX)/lib/qt-2.3.8
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-z6
LINKLIB := -lm -lqte-mt -lezxpm -ljpeg -lezxappbase -lezxtapi-xscale-r -llog_util -llighting
DIRECTIV := -DEZX_Z6
TARGET    =       $(APPNAME)_Z6
endif
ifeq ($(PLATFORM),EZX-V8)
QTDIR    :=    $(TOOLPREFIX)/lib/qt-v8
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-v8
LINKLIB := -lm -lqte-mt -lezxpm -lezxappbase
DIRECTIV := -DEZX_V8
TARGET    =       $(APPNAME)_V8
ZNEWCHECKBOX = 1
endif
ifeq ($(PLATFORM),EZX-E8)
ARMLIB     := $(TOOLPREFIX)/arm-linux-gnueabi/lib_E8
QTDIR    :=    $(TOOLPREFIX)/lib/qt-e8
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-e8
LINKLIB := -lm -lqte-mt -lezxappbase
DIRECTIV := -DEZX_E8
TARGET    =       $(APPNAME)_E8
endif
ifeq ($(PLATFORM),EZX-EM30)
QTDIR    :=    $(TOOLPREFIX)/lib/qt-em30
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-em30
EZXDIR2    :=    $(TOOLPREFIX)/lib/ezx-e8
DIRECTIV := -DEZX_EM30
TARGET    =       $(APPNAME)_EM30
endif
ifeq ($(PLATFORM),EZX-U9)
QTDIR    :=    $(TOOLPREFIX)/lib/qt-zn5
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-u9
EZXDIR2    :=    $(TOOLPREFIX)/lib/ezx-zn5
DIRECTIV := -DEZX_U9
TARGET    =       $(APPNAME)_U9
endif
ifeq ($(PLATFORM),EZX-Z6W)
QTDIR    :=    $(TOOLPREFIX)/lib/qt-z6w
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-z6w
DIRECTIV := -DEZX_Z6W
TARGET    =       $(APPNAME)_Z6W
endif
ifeq ($(PLATFORM),EZX-ZN5)
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-zn5
DIRECTIV := -DEZX_ZN5
TARGET    =       $(APPNAME)_ZN5
endif
ifeq ($(PLATFORM),EZX-EM35)
QTDIR    :=    $(TOOLPREFIX)/lib/qt-em35
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-em35
DIRECTIV := -DEZX_EM35
TARGET    =       $(APPNAME)_EM35
endif
ifeq ($(PLATFORM),EZX-VE66)
EZXDIR    :=    $(TOOLPREFIX)/lib/ezx-ve66
DIRECTIV := -DEZX_VE66
TARGET    =       $(APPNAME)_VE66
endif
CC        =    $(TOOLPREFIX)/bin/arm-linux-gnueabi-gcc
CXX        =    $(TOOLPREFIX)/bin/arm-linux-gnueabi-g++
LD        =    $(TOOLPREFIX)/bin/arm-linux-gnueabi-g++
STRIP   =   $(TOOLPREFIX)/bin/arm-linux-strip
CFLAGS    =    -pipe -Wall -W -O2 -DNO_DEBUG $(INCPATH)
CXXFLAGS=    -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -O2 -DNO_DEBUG $(DIRECTIV) $(INCPATH)
INCPATH    =    -I$(QTDIR)/include -I$(EZXDIR)/include -I$(EZXDIR2)/include -I $(TOOLPREFIX)/arm-linux-gnueabi/include
LDFLAGS    =    -s
LINK    =    $(TOOLPREFIX)/bin/arm-linux-gnueabi-gcc
LFLAGS    =    -Wl,-rpath-link,$(EZXDIR)/lib
LIBS    =    $(SUBLIBS) -L$(EZXDIR)/lib -L$(EZXDIR2)/lib -L$(ARMLIB) -L$(QTDIR)/lib $(LINKLIB)
MOC        =    $(QTDIR)/bin/moc
UIC        =    $(QTDIR)/bin/uic
Do not forget to edit the name of the application.
Now cd to the folder and make (make PLATFORM=EZX-E8).
Сообщение отредактировал Ant-ON - 24.6.2010, 16:13
Nsolares
сообщение 25.6.2010, 4:33
Пользователь №: 163 256
hey croccio, how do you extract the e8 toolchain?
i recommend to you extract it with the ubuntu default extractor, i mean: right click (over your compressed file) then extract here.
do not use the terminal command line to extract it, to avoid permission troubles.
croccio
сообщение 26.6.2010, 13:35
thnk u! u're great! i'mdownlading it =) thank u to all =)
(26.6.2010, 14:54):
the download lock so
CODE
A    arm-eabi/arm-linux-gnueabi/bin
croccio
сообщение 26.6.2010, 22:07
bro why i can't reas src code of ztask 2???
croccio
сообщение 3.11.2010, 16:19
I tried again after quite a time trying to fill the showRadio, but does not work .. I followed the prcedimenti mentioned above but I get an error here goes
antonio@antonio:~/e8sdk/E8SDK/showRadio$ make PLATFORM=EZX-E8
/home/antonio/arm-eabi/bin/arm-linux-gnueabi-g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -O2 -DNO_DEBUG -DEZX_E8 -I/home/antonio/arm-eabi/lib/qt-e8/include -I/home/antonio/arm-eabi/lib/ezx-e8/include -I/include -I /home/antonio/arm-eabi/arm-linux-gnueabi/include -I/home/antonio/arm-eabi/lib/qt-e8/include -I/home/antonio/arm-eabi/lib/ezx-e8/include -I/include -I /home/antonio/arm-eabi/arm-linux-gnueabi/include -o showRadio.o showRadio.cpp
/home/antonio/arm-eabi/bin/arm-linux-gnueabi-gcc -Wl,-rpath-link,/home/antonio/arm-eabi/lib/ezx-e8/lib -o showRadio showRadio.o   -L/home/antonio/arm-eabi/lib/ezx-e8/lib -L/lib -L/home/antonio/arm-eabi/arm-linux-gnueabi/lib_E8 -L/home/antonio/arm-eabi/lib/qt-e8/lib -lm -lqte-mt -lezxappbase
/home/antonio/arm-eabi/bin/../lib/gcc/arm-linux-gnueabi/3.4.3/../../../../arm-linux-gnueabi/bin/ld: cannot find /arm-eabi/arm-linux-gnueabi/lib/libc.so.6
collect2: ld returned 1 exit status
make: *** [showRadio] Errore 1
makefile
CODE
# PLATFORM=EZX-Z6
# PLATFORM=EZX-Z6W
# PLATFORM=EZX-U9
# PLATFORM=EZX-ZN5
# PLATFORM=EZX-V8
# PLATFORM=EZX-VE66
# PLATFORM=EZX-EM35
# make clean
######Config######
TOOLPREFIX := /home/antonio/arm-eabi
ifeq ($(PLATFORM),)
PLATFORM = EZX-E8
endif
endif
ZNEWCHECKBOX = 1
endif
endif
endif
endif
endif
endif
endif
endif
LDFLAGS = -s
####### Files
HEADERS =
SOURCES = showRadio.cpp
OBJECTS = showRadio.o
INTERFACES =
UICDECLS =
UICIMPLS =
SRCMOC =
OBJMOC =
DIST =
TARGET = showRadio
INTERFACE_DECL_PATH = .
####### Implicit rules
.SUFFIXES: .cpp .cxx .cc .C .c
.cpp.o:
$(CXX) -c $(CXXFLAGS) $(INCPATH) -o $@ $<
.cxx.o:
.cc.o:
.C.o:
.c.o:
$(CC) -c $(CFLAGS) $(INCPATH) -o $@ $<
####### Build rules
all: $(TARGET)
$(TARGET): $(UICDECLS) $(OBJECTS) $(OBJMOC)
$(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJMOC) $(LIBS)
moc: $(SRCMOC)
tmake: Makefile
Makefile: showRadio.pro
dist:
$(TAR) showRadio.tar showRadio.pro $(SOURCES) $(HEADERS) $(INTERFACES) $(DIST)
$(GZIP) showRadio.tar
clean:
-rm -f $(OBJECTS) $(OBJMOC) $(SRCMOC) $(UICIMPLS) $(UICDECLS) $(TARGET)
-rm -f *~ core
####### Sub-libraries
###### Combined headers
####### Compile
showRadio.o: showRadio.cpp
Сообщение отредактировал EXL - 3.11.2010, 16:27
Ant-ON
сообщение 4.11.2010, 18:22
Check existing folder and library in it:
croccio
сообщение 4.11.2010, 18:54
i see it and exist
C++ Develop App · ROKR E8 & EM30 · Forum
Текстовая версия Сейчас: 23.5.2019, 17:04
