[Mgx] MutiPartition Tool By ilove3d, Translation By Nikhil007™
alxey
сообщение 4.10.2009, 16:13
Из: Kiev
Пользователь №: 144 371
Прошивка: E8 EM30 V8
MultiPartition Tool by ilove3d
Please backup your memory card Before using this application !!
2009-10-1
http://magxcn.com
All rights reserved, containing open-source script, leave the original author information!?????
Translation to English by Nikhil007™
Preface:
MOTOMAGX platform for the various models in the ilove3d's efforts have largely achieved MGX installation of software and MGS theme
Also achieved a very convenient for the font mounted
However, there has been very good to solve a problem, when using the font mounted or MGS theme, USB memory card mode then the computer will crash
Open MGX virtual memory is also true
This software can solve this problem
It is divided into three areas TF Card
1 District: still FAT32 format, and usually the same as
Zone 2: swap partition for virtual memory
Zone 3: EXT3 storage area, used to store themes, fonts, etc.
Set partition:
Within a certain range you can choose what you want size 2 and 3.
Transfer Subject:
Click on the theme of MGS after installation can be transferred to the EXT3 partition where
Ie / ezxlocal / download / mystuff / skins transferred to / mmc/ext3/skins
(Theme authors can continue to use the path in front of the transfer process will automatically replace the path)
Other mount:
Fonts
/ mmc/ext3/myfont.ttf
/ mmc/ext3/mynum.ttf
Switch machine animation
/ mmc/ext3/poweron.gif
/ mmc/ext3/poweroff.gif
Switching the sound
/ mmc/ext3/poweron.wav
/ mmc/ext3/poweroff.wav
Прикрепленный файл MultiPartition_Tool_By_ilove3d.rar   ( 132.45 килобайт ) Кол-во скачиваний: 916
Добавлено позже (4.10.2009, 19:26):
я себе этим форматнул флешку 128 свап и 384 етех3, но хотелось бы на оборот свап на 384 и етех3 на 128
Сообщение отредактировал alxey - 4.10.2009, 16:17
3 страниц V  1 2 3 >
Witazzew
сообщение 4.10.2009, 17:58
Из: Ухта
Пользователь №: 180 655
Модель телефона: 910
можно по русски?
Atei
сообщение 4.10.2009, 19:07
Пользователь №: 127 717
Модель телефона: ROKR EM30 + 8Gb King
Прошивка: Perfect мод
куда стоко свапа?
Добавлено позже (4.10.2009, 23:29):
Прикрепленный файл Multi_Partition.rar   ( 132.15 килобайт ) Кол-во скачиваний: 526
Zorge.R
сообщение 4.10.2009, 21:35
Group Icon
Группа: System Administrators
Из: рук в руки
Пользователь №: 101 800
Прошивка: 1CR
Цитата(Witazzew @ Вчера, 21:58)
можно по русски?
Для начала, рекомендуется сделать бекап флешки.
затем ставим прогу и юзаем.
приложение делит флешку, на 3 раздела.
1- обычный fat 32, то что мы видим как флешку, при подключении телефона к ПК в режиме карты памяти.
2- swap раздел.
3- ext3 раздел.
Фишка в том что 1-й раздел как обычно отмонтируется при подключении к ПК в режиме флешки, а другие 2 остаются монтированными в теле.
размеры раздела 2 и 3, можно менять в определенных пределах.
В общем доступ к ним остается всегда. Поэтому и свап не отвалиться, и шрифты\темы можно в любом количестве ставить, в котором они влезут на ext3 раздел.
За компанию, можно подменить звуки старта и выключения тела и анимацию.
p.s.: как бЭ так.
Сообщение отредактировал Zorge.R - 4.10.2009, 21:36
Sereg_K
сообщение 5.10.2009, 11:07
Мотоснайпер
Из: Жемчужина у моря
Пользователь №: 60 316
Модель телефона: ROKR E8
Прошивка: Z-Mod E8
Вопрос
Если свап уже включен, то надо ли его отключить сначала? Или свап файл сам переместится в нужное место после перезагрузки?
Что-то у меня на флешку приложение вообще не хочет становиться, а в телефон становится, но не запускается.
Щас попробую еще оригинальное (не переведенное) приложение скачать.
Сообщение отредактировал Sereg_K - 5.10.2009, 12:21
@SEM*
сообщение 5.10.2009, 15:31
(M)LuckyMan
Из: Earth
Пользователь №: 126 920
Прошивка: Android 11 & 14
Sereg_K насколько я понял он "отбивает" от fat32 определённый сектор флешки и создаёт ещё 2 раздела - один для swap файла, другой для ext3 системы ( стандартной для Linux smile.gif Поэтому и рекомендуют сделать бэкап - ведь могут удалится нужные данные при "отбивании" пространства". А программа врядле будет искать в системе swap файл и перемещать куда нужно. Поравте если не прав shuffle.gif
Zorge.R
сообщение 5.10.2009, 17:02
Group Icon
Из: рук в руки
Прошивка: 1CR
Сборка от ilove3d, заточена под его моды. Поэтому работать нормально на большинстве сторонних не будет.
решил пофиксить (на большинстве модов должна работать)
Прикрепленный файл E8_Partitioner_z_fix.mgx.7z   ( 122.23 килобайт ) Кол-во скачиваний: 487
в конце имени убрать 7z и установить через диспетчер файлов. (Только в телефон!!!)
Затем запустить и выбрать первый пункт, после этого выбрать желаемый размер свапа и ext3 раздела.
Ext3 раздел в этом приложении, в отличии от оригинала будет монтироваться на /ezxlocal/ext3
p.s.: у вас должна быть поддержка авторана из /phone/unKnown/S*, для работы автозапуска скрипта.
p.p.s.: после перезагрузки, зайдите в /ezxlocal/ext3/ если там есть папка lost_&_found, значит все работает.
Добавлено позже (5.10.2009, 21:54):
и еще, если Вы уже успели воспользоваться E8_Partion, а он у Вас не работал, то:
1) удалите его
2) удалите скрипт автозапуска (лежит по адресу /phone/unKnown/)
3) перезапустить телефон.
4) установите E8_Partitioner_z_fix.mgx
5) Запустите E8_Partitioner через mpkgbox, выберите Setting Up/FT_Restore, через пару минут перезапустить телефон.
6) Опять запустите E8_Partitioner через mpkgBox и выберить Setting Up/нужный размер свапа и ext3.
7) После того как он выдаст ОК, перезапустите телефон. Все должно работать.
Если не поможет, запустите info_restore.sh (phone/mpkgbox/e8_partion/) вручную, диспетчером файлов телефона. подождите 2 минуты, перезагрузитесь и проделайте пункты 4, 6, 7.
Сообщение отредактировал Zorge.R - 5.10.2009, 17:59
kale
сообщение 5.10.2009, 19:42
Пользователь №: 186 237
Модель телефона: e8,e398
Прошивка: black diamond 373
у меня незапускается((((
ставлю всё правильно вроде....но ничего не происходит....но флешку уже форматнуло....
Zorge.R
сообщение 5.10.2009, 21:14
Group Icon
Из: рук в руки
Прошивка: 1CR
вот свежая сборка, со встроенными шоу модулями (чтобы работало даже на тазике и тостере):
Прикрепленный файл E8_Partitioner_z_1.3_fix.mgx.7z   ( 122.7 килобайт ) Кол-во скачиваний: 543
так же исправил пути для шрифтов, скинов, звуков и анимации старта и отключения, на /ezxlocal/ext3/
p.s.: перед установкой, прочтите пост №7 ^, там написано про танцы с бубном, если Вы уже ставили прогу.
alxey
сообщение 6.10.2009, 5:01
Из: Kiev
смотрите, перенес скины на ехт3, потом зашел в темы показывает что все схм файлы с ошибкой и удалило их. как поставить скин чтоб работал с ехт3?
Добавлено позже (6.10.2009, 8:12):
все. сам разобрался. надо изменить путь в файле конфигурации скина на exectlocal/ext3/skins/
все пользовательские скины работабт норм в режиме карта памяти
Azick102
сообщение 6.10.2009, 6:39
Из: Уфа
Пользователь №: 186 615
Модель телефона: E398,EM30, Nokia e52
Прошивка: 49R, Perfect
Он флешку полностью форматирует или остаются файлы, при наличии свободного пространства для свап и ехт3
alxey
сообщение 6.10.2009, 7:10
Из: Kiev
полностью. все стирается
Zorge.R
сообщение 6.10.2009, 17:45
Group Icon
Из: рук в руки
Прошивка: 1CR
Вот, пофиксил. Теперь автоматом меняет путь в конфиге скина на /ezxlocal/ext3/skins:
Прикрепленный файл E8_Partitioner_z_1.4_fix.mgx.7z   ( 122.22 килобайт ) Кол-во скачиваний: 320
Перед установкой, удалите старую версию!
работаем так:
-кидаем нужные скины в /память/телефона/skins/
-запускаем прогу и выбираем Transfer theme. Прога перенесет все скины на раздел ext3.
-Заходим в настройки\темы\ и выбираем только что установленную тему.
p.s.: когда жмете transfer theme, надо чтобы ваш активный скин сам не лежал в /память/телефона/skins/, а то и его перенесет.
т.е. когда жмем первый раз, желательно выбрать к примеру родной скин телефона. потом можно смело юзать скины из ext3 и сколько угодно раз тыкать на Transfer theme.
Сообщение отредактировал Zorge.R - 6.10.2009, 17:49
Atei
сообщение 6.10.2009, 20:15
что за чудеса wacko.gif самая первая версия запускается только с флешки, а остальные вообще не запускаютсяsad.gif
kale
сообщение 6.10.2009, 20:22
супер программа.......запустил......всё сделал.....перезагрузил телефон.......у меня Е8, но сейчас постоянно выкидывает ошибку памяти и показывает что всего 9 метров на телефоне..((((
поражаюсь.....перезагрузил тел......вся память вернулась назад....и все файлы.....правда удалило бокс и всё что ставил поверх прошивки..(((
Zorge.R
сообщение 7.10.2009, 0:14
Group Icon
Из: рук в руки
Прошивка: 1CR
надо скрипт добавить в автозапуск, иначе будешь получать сообщение о нехватке памяти.
p.s.: для справки В именах папок со скинами, не должно быть пробелов.
kale
сообщение 7.10.2009, 13:05
как добавить в авторан??)
и после этой фигни у меня сбились часы......и назад поставить нельзя..(((
подскажете???
Zorge.R
сообщение 7.10.2009, 13:07
Group Icon
Из: рук в руки
Прошивка: 1CR
там кнопка есть add \ remove script. после этого надо перезагрузить телефон.
Если не работает, надо прошить монстр с поддержкой авторана ../../mystuff/unKnown/S*
kale
сообщение 7.10.2009, 13:19
а есть какие-то монстры на 1CR_A без NORSA???
тело на гарантии...
alxey
сообщение 7.10.2009, 13:45
Из: Kiev
есть. но это нельзя считать монстром.
kale
сообщение 7.10.2009, 17:59
Сообщение отредактировал PUSYA - 8.10.2009, 8:26
Atei
сообщение 7.10.2009, 18:06
Цитата(kale @ 7.10.2009, 21:59) *
очень мешает..(((
попробуй полную очистку
Добавлено позже (7.10.2009, 22:08):
прошил последний мод от Чачи, сделал полную очистку, а последняя версия проги всё равно не открывается mad.gif
Добавлено позже (7.10.2009, 23:14):
кажись вкурил... Zorge R. прописал брать шоумодули из определённой папки из этой:
/ezxlocal/download/mystuff/mpkgbox/e8_parter/
соответственно, если прога не в этой папке( а следовательно и шоумодули, хранящиеся с ней), то нийига не запустится
kale
сообщение 7.10.2009, 19:30
блин....полная очистка непомогла(((
ещё варианты будут как вернуть часы???
кстате теперь их вообще на главном экране нету..((
Atei
сообщение 7.10.2009, 20:06
Добавлено позже (8.10.2009, 2:03):
Немного подредактировал, а именно под мод Perfect:
1) теперь прога ориентируется на папку /ezxlocal/download/mystuff/.system/Programs/e8_parter/
2) автозапуск теперь происходит из папки /ezxlocal/autorun/
3) русификация
Сообщение отредактировал stigr - 7.10.2009, 23:39
Прикрепленный файл E8_Partitioner_z_1.4_fix_Perfect_Ru.mgx.7z   ( 137.93 килобайт ) Кол-во скачиваний: 268
Zorge.R
сообщение 8.10.2009, 22:09
Group Icon
Из: рук в руки
Прошивка: 1CR
а тем временем, версия 1.5
Прикрепленный файл E8_Partitioner_z_1.5.mgx.7z   ( 122.79 килобайт ) Кол-во скачиваний: 487
changelog:
-путь к шоу модулям, определяется в момент запуска, т.е. не важно где лежит запускаемый файл.
-при добавлении в авторан, swapon копируется в /ezxlocal/ , для того чтобы авторан сработал, при любом расположении папки e8_partion.
-авторан копируется как в /phone/unKnown/, так и в /ezxlocal/autorun/ (если эта папка есть), для совместимости с модом Perfect.
-при удалении, удаляется авторан из /phone/unKnown/ и /ezxlocal/autorun/ (если есть), а также /ezxlocal/swapon.
вроде все.
p.s.: язык английский.
p.p.s: должно работать на всех модах.
p.p.p.s: чтобы не создавать мусора у всех, те кто юзает /ezxlocal/autorun/ должны перед использованием создать эту папку, хотя если вы юзаете этот путь, папка у вас уже есть.
p.p.p.p.s.: интересно, у всех ли папка /ezxlocal/ примонтирована с exec. у кого не сработает авторан, видать явно noexec , если у вас есть авторан конечно.
Сообщение отредактировал Zorge.R - 8.10.2009, 22:23
mPhoneR
сообщение 10.10.2009, 5:44
Из: 42RUS
Пользователь №: 194 388
Модель телефона: E2\LG GT540
Прошивка: mUbuntu\2.2.2
Mood downloading...
Zorge.R,
так и не понял, зачем в памяти тела в ezxlocal папка ext3, в которой от ext3 имхо одно название?
Зачем замусоривать память телефона и чем не устраивает карта памяти?
    mkdir -p /ezxlocal/ext3
2)
        mkdir -p /ezxlocal/ext3/skins
и какая разница, в каком месте будут лежать в памяти телефона скины, в ezxlocal или в \usr\data_resource\skin (у меня на перфекте так)
Сообщение отредактировал mPhoneR - 10.10.2009, 5:58
alxey
сообщение 10.10.2009, 6:55
Из: Kiev
тем что етх3 это есть часть карты памяти подмонтированой в езхлокал. с нее скины не глючат когда как карту памяти подключаеш
mPhoneR
сообщение 10.10.2009, 7:22
Из: 42RUS
Mood downloading...
IMHO чушь. Вы сами то читали этот индусский код? Там как раз описано создание нового каталога
и перемещение туда скинов
            mv $i /ezxlocal/ext3/skins/
Поправьте, если не прав.
Сообщение отредактировал mPhoneR - 10.10.2009, 7:23
kale
сообщение 10.10.2009, 8:28
а неглючят темы потомучто папка с темами неоткрываеться после подключения к компу.....в этом и всё:)
mPhoneR
сообщение 10.10.2009, 11:48
Из: 42RUS
Mood downloading...
У меня она и так не открывается в режиме карты памяти. А вот у кого скины находятся здесь:
SKIN_PATH=/ezxlocal/download/mystuff/skins
тогда да, это правильно. Надо менять путь. Вот только что мешает сделать как автор программы первоначально, т.е. закидывать скины на карту памяти в раздел с файловой системой ext3 cool.gif
сообщение 10.10.2009, 15:08
Zorge.R
сообщение 10.10.2009, 17:08
Group Icon
Из: рук в руки
Прошивка: 1CR
папка ext3 и есть раздел ext3 с карты памяти. это очень трудно не понять, т.к. там текстовые файлы в которых прописан mount.
Браво clap.gif , там наверно не ext3 раздел а NTFS примонтирован. Хотя нет, ниче не примонтировано. Просто кидаем 360 метров в /ezxlocal/ и там все помещается. Безразмерная память у телефона.
Ты скрипт почитай до конца.
До конца читать терпения не хватило? там самое интересное, mount.
перемещаются они на раздел ext3 карты памяти, а не в память телефона. не надо людей в заблуждение вводить.
под линукс флешку примонтируй и посмотри. файлы туда не коперфильд запихал.
mPhoneR, вот хороший ответ на Твой вопрос, жалко Ты его не заметил.
Цитата(alxey @ Сегодня, 10:55)
ехt3 это есть часть карты памяти подмонтированой в езхлокал.
Для справки: \usr\data_resource\ - скваш, который кстати только RO.
Добавлено позже (10.10.2009, 21:51):
Цитата(metallsatanist @ Сегодня, 19:08)
а если у меня Ubuntu?
он нормально будет работать с ext3, только флешку подключай через кардридер.
или подключайся в режиме tools, через FTP. (под линем реализован также, как самба под виндой. это я про юзабилити)
Сообщение отредактировал Zorge.R - 10.10.2009, 18:04
Nikita83
сообщение 10.10.2009, 22:55
Из: Россия
Пользователь №: 198 249
Модель телефона: Rokr E8
Прошивка: X1_MOD_14_1cr
Слегка не в тему, но все же спрошу.
Если не затруднит, то немного по подробнее опиши про это.
mPhoneR
сообщение 11.10.2009, 0:51
Из: 42RUS
Mood downloading...
Zorge.R,
сообщение 11.10.2009, 4:44
Zorge.R,
ты не понял меня.. Я говорю о том, что если на телефоне будет выбран скин с флешки и я подключу телефон к компу, то скин на телефоне будет как обычно отображаться кусками? smile.gif
rock88
сообщение 11.10.2009, 6:15
Из: г. Омск
Пользователь №: 201 900
Модель телефона: L9 & EM30
Прошивка: 05R & 04.06R
что-то оно у меня не работает, ставил в память тела, жму установка, выбираю размер свапа и ext3, появляется надпиь FS_UNLOADING и все, все что было на флэшке остается, то есть она не форматируется, не создаются свап и ext3
dskiller
сообщение 11.10.2009, 6:37
Из: Пенза
Пользователь №: 195 433
Модель телефона: EM30, ех-300
Прошивка: мод бай Чача
Такая же фигня
mPhoneR
сообщение 11.10.2009, 8:43
Из: 42RUS
Mood downloading...
А если попробовать не через MPKG Box, а запустить скрипт loader.sh файловым менеджером? Тоже не выходит?
MKRIK
сообщение 11.10.2009, 17:01
Из: Псков, Санкт-Петербург
Пользователь №: 49 544
Модель телефона: Milestone, E8, Z6, E398
Zorge.R,
скачал твою послежднюю версию.
Прога стоит на теле. При попытке использование выдает ошибку "Try to umount /dev/mmca1 is finally umounted. rm autochk tag" =\
Что это значит?
Флефка абсолютно пустая(после форматирования, были проблемы,пришлось форматнуть)
Zorge.R
сообщение 11.10.2009, 18:38
Group Icon
Из: рук в руки
Прошивка: 1CR
вот тут есть уже.
Цитата(metallsatanist @ Сегодня, 8:44)
Zorge.R,
нет, все будет нормально. если скин с ext3 раздела, в режиме флешки ничего не отваливается.
нажми ОК и должен начаться процесс разбиения.
[Mgx] MutiPartition Tool By ilove3d, Translation By Nikhil007™ · Motorola ROKR E8, EM30 · Forum
3 страниц V  1 2 3 >
Текстовая версия Сейчас: 19.7.2025, 10:16
