PP_Lrc1.5.4/PP_reader [23.09.2008update], new:pp_play_1.6 SRC&SDK
Campanula
сообщение 20.8.2008, 5:26
Пользователь №: 176 749
by:psjatqpgf[www.motoedy.cn]
pp-player plugin
This is a plug-in, with the use of motoCMD1.7.0.1
Fixed:
1: short music show little progress.
2: a blank screen and also standby to return.
Increase:
1: Allow the first from top to bottom, and the manual have the highest priority (regardless of what mode).
2: There are three modes: single, single loop, the whole cycle. # Switch
3: increase the number keys, 2 8 4 6 counterparts from top to bottom about 3 9 volume. * Or hidden.
Note:
* Just entering the end of the singles mode.
* Because the paper to find, access will be delayed.
* The MP3 will only join the list
SetWP.elf join extmgr.ini MotoCmd, choose BMP / PNG / JPG can see, but through the first set wallpaper, the screen view. And can not directly see
1. Merger documents, procedures for a merger deal with convenience.
2. Riga in the time display showing signal and electricity. And this is the same as the phone itself, not counting the voltage. Colors from red to green to the automatic transition, colors may be nausea point .......
3. Khao-screen function, improved, which may be in the normal operation of the border, but in the end and small paper did not test ....
4. Backlight control, in the text interface, the menu button is closed / open backlight. But as with the use of the Friends of the two patches under the menu ... that the use of careful, careful use of .....
5. Length of more than 20 amendments to the document can not be storage problems.
6. Can be used as a plug-in cmd.
7. In the use of the digital menu shortcuts, directly on the corresponding figure on it.
8. That opened less than 5 K's unicode format linked to the problem. (Two months ago saying this is a mistake ...)
9. Today saw the proposed zone of a message, think of a problem, Oh to be able to open the document in any format, of course, is the TXT format ~
10. That is less than 0 x21 due to the non-wrapped / Enter the text ASCII coding caused the loss (from WORD into the text in the copy of the frequent occurrence, from the pages of copy may also be a)
Interface resume ok
Do not open the file from that history disappear BUG ok
Separate document on the support ok
The final text is a single-byte coding do not show the restoration ok
Merger ok
Will be up into the main parameters of the function. ok
Time display of signals and electricity show. ok
Khao-screen problem. ok
Backlight control ok
Backlight adjustment
Jump on the document issue ok .....()
Long paper documents can not create a bookmark and history ok
The second open automatically withdraw from the ok
Bookmarks can not read the main ok
cmd link ok
Shortcuts ok
Khao screen in block border unexploded tank ok
Jump back up after the death cycle ok
Time display of signs location ok
Open less than 12 lines of text with the possibility of resuming ok
Small size of the end of documents do not show ok
Open any document ok
Patch Version:
Patch for R373_49R
Patch for L7_ACR
no Patch Version:
Прикрепленный файл ppreader_no_Patch_Version_.zip   ( 25.33 килобайт ) Кол-во скачиваний: 318
For example:
;comments
; app - elf path
; type - id|mid|uri
; id - FILE_ID as agrument to elf
; mid - Multiple FILE_ID as agrument to elf not supported
; uri - Path to file
; icon - not supported
[GIF]
app=/b/elf/MotoCmd/iv.elf
type=id
icon=0x120000CF
[ZIP]
app=/b/Elf/MotoCmd/UnZip.elf
type=id
icon=0x0
[PNG]
app=/b/elf/MotoCmd/SetWP.elf
type=id
[BMP]
type=id
[JPG]
type=id
[MP3]
app=/b/elf/MotoCmd/Music.elf
type=id
[M4A]
type=id
[AMR]
type=id
[JAR]
app=/b/elf/MotoCmd/MidTransfer.elf
type=id
[TXT]
app=/b/elf/MotoCmd/PPReader.elf
type=id
If friends want to the SRC, please PM to me!
Сообщение отредактировал Campanula - 23.9.2008, 2:20
Alemurillo·
сообщение 20.8.2008, 15:23
Пользователь №: 179 574
Модель телефона: Rokr E1
*Edit: To run ppp.elf edit extmgr.ini and eliminate or add ";" to:
;[MP3]
;app=/b/Elf/MotoCmd/Music.elf
;type=id
and
[MP3]
app=/b/Elf/MotoCmd/ppp.elf
type=id
now browser whit motocmd and listen...
Сообщение отредактировал Alemurillo· - 20.8.2008, 22:47
Campanula
сообщение 22.8.2008, 7:04
Last1Left
The SRC to you
Сообщение отредактировал Campanula - 22.8.2008, 7:06
Прикрепленный файл ppreader_T8__src.zip   ( 27.81 килобайт ) Кол-во скачиваний: 110
Campanula
сообщение 24.8.2008, 1:39
ppreader_t8
Fixed:
1: relevance to open a single file to the screen problem.
2: Amendments to the association after some unknown problem.
Patch Version:
Прикрепленный файл ppreader_Patch_Version_.zip   ( 25.18 килобайт ) Кол-во скачиваний: 179
No Patch Version:
Прикрепленный файл ppreader_no_Patch_Version_.zip   ( 25.34 килобайт ) Кол-во скачиваний: 178
pp_player v0.3
Fixed:
1: After the telephone or text message to stop the problem.
2: accidents may get stopped, I have not been stopped, can only be possible amendments.
for every friends SDK:
Сообщение отредактировал Campanula - 24.8.2008, 2:00
friend 1
сообщение 24.8.2008, 11:58
Пользователь №: 136 759
Модель телефона: L7e
Прошивка: 01.0AR NO RSA
Неотображает русский текст, или он его и не должен отображать?
RuslanchiK
сообщение 25.8.2008, 8:40
Из: Уфа
Пользователь №: 57 063
Модель телефона: E398, Zn5
Прошивка: E398-79R, Zn5-ZE0.9b
ИНЖЕНЕР!!!
И не должен.
Last1Left
сообщение 27.8.2008, 18:09
Из: Romania
Пользователь №: 161 862
Модель телефона: v360 ACR / Nokia N82
Прошивка: FallenAngel
PPReader in english( i'm not sure if the translation is 100% correct)
Сообщение отредактировал Last1Left - 27.8.2008, 18:11
RuslanchiK
сообщение 28.8.2008, 9:56
Из: Уфа
ИНЖЕНЕР!!!
Last1Left - Great Job! Thanx! 2all - when I enter to BOOKMARK and COPY SCREEN my phone Rebooting! Why? And WHAT NEW FUNCTIONS uses ppreader?
Campanula
сообщение 30.8.2008, 4:52
30.08.08
pp_player_1.5
+ + With pp_player, the # key player mode to switch the order: the order of play, repeat: repeat single, single: End of the song broadcast from ~ ~
+ + * Key is hidden, but there is a BUG, that is, if hidden on the desktop, then the only state column shows ~ ~ this is also pp_player the bug ~ ~ Why do not currently know ...
+ + 1,7 keys adjust the volume (personal habits such, Ha ha ~ ~), 2 4 6 8 counterparts from top to bottom at around ~ ~ suspended, the next stop, the left one, the right lower one, long left fast forward, often right quick Jin ~ ~
+ + Red button was launched ....
+ + Lyrics audio file on the lrc folder, that is the path to: file: / / b / mobile / audio / lrc /***. lrc
+ + The so-called non-patch and a patch is decoding documents, namely gb2uc.map ~ ~ ~ fight without this patch, would use non-patch version ~ ~
And gb2uc.map file path for: file: / / b/ELF/PPREADER/MAP/GB2UC.MAP
Сообщение отредактировал Campanula - 30.8.2008, 5:04
Прикрепленный файл PP_player1.5_no_patch_Version__.zip   ( 28.35 килобайт ) Кол-во скачиваний: 182
Прикрепленный файл PP_player1.5_patch_Version__.zip   ( 30.61 килобайт ) Кол-во скачиваний: 139
croccio
сообщение 30.8.2008, 7:54
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
everyone can port the patc of pplayer and ppreader for ACR_RB [L7]?
G-XaD
сообщение 30.8.2008, 8:03
Из: Donetsk City / Ukraine
Пользователь №: 153 083
Модель телефона: E1, k810
Прошивка: r373_g_0e.30.79r
this is not a plugins for MotoCMD!
Campanula
сообщение 30.8.2008, 8:19
QUOTE(G-XaD @ 30.8.2008, 8:03) *
Which ?
croccio
сообщение 31.8.2008, 12:07
with ppplayer i can't open *.mp3 files! with the first version yes. why?
friend 1
сообщение 31.8.2008, 18:56
А картинки в мотокмд должны открываться или посылать как фоновой рисунок на рабочий стол?
VEX
сообщение 31.8.2008, 19:05
Из: Нижний Новгород
Пользователь №: 156 303
Модель телефона: e398,V3,T190,L7
Прошивка: R373_44R_v2.8
friend 1 посылать как фоновой рисунок на рабочий стол,кроме GIF картинок.
Last1Left
сообщение 1.9.2008, 18:49
Из: Romania
pp_player v1.5.4 in english:
-archives contain:
--pp_player.elf
--gb2uc.fpa
--example of .lrc file
Прикрепленный файл pp_player_v1.5.4_49R.zip   ( 32.67 килобайт ) Кол-во скачиваний: 149
Прикрепленный файл pp_player_v1.5.4_ACR.zip   ( 33.03 килобайт ) Кол-во скачиваний: 83
Прикрепленный файл pp_player_v1.5.4_ACR_RB.zip   ( 32.67 килобайт ) Кол-во скачиваний: 97
newbieholic
сообщение 4.9.2008, 3:01
Пользователь №: 180 492
Модель телефона: Motorola
Why after update libgen 4.0 for working iv.elf
my pp_player 1.5.4 eng can't work?
but pp_player 1.5 china work
R373_49R
Nixxell
сообщение 4.9.2008, 3:41
Пользователь №: 164 062
Модель телефона: L7
Прошивка: ACR_RB
Кто знает зачем патч gb2uc.fpa ???
DDA-E398
сообщение 4.9.2008, 5:09
Из: Нижегородская обл.
Пользователь №: 166 356
Модель телефона: E2, A910, Е398, ATRIX2
Прошивка: разные
Роботаю...
Может кто-нибудь по-русски объяснить как установить txtreader.
С меня +
Сообщение отредактировал DDA-E398 - 4.9.2008, 5:11
RuslanchiK
сообщение 4.9.2008, 7:07
Из: Уфа
ИНЖЕНЕР!!!
С меня +
DDA-E398,
1. Качаешь архив с читалкой (прикрепляю)
Эта сборка от Last1Left с английскими надписями.
2. Ставишь ее куда нить (например у меня есть папка plug-ins)
3. Пишешь в extmgr.ini
[TXT]
app=/b/elf/plug-ins/ppreader.elf
type=id
Ну и еще мона добавить RES, INI, RUN кроме TXT,
4. В Motorola Commandere 1.7.0 запускаешь этот файл
5. Радуешься)))))
Чтобы таблица gb2uc находилась в СГ1 - это и есть патч версия.
А если не_патч_версия, то эта таблица должна находиться в папке с эльфом в подпапке map
Сообщение отредактировал RuslanchiK - 4.9.2008, 7:11
Campanula
сообщение 4.9.2008, 7:15
Very Good!
blak_alex
сообщение 4.9.2008, 12:49
Пользователь №: 32 764
Модель телефона: L7
Прошивка: ACR_RB
при запуске PPReader постоянный ребут
либа новая 4.0
RuslanchiK
сообщение 4.9.2008, 13:03
Из: Уфа
ИНЖЕНЕР!!!
blak_alex,
Читать не судьба????
ЕГО НЕ НАДО ЗАПУСКАТЬ!!!!!
Читай двумя постами выше!!!!!!!!
По моему я нормальный ман написал.
Сообщение отредактировал RuslanchiK - 4.9.2008, 13:08
blak_alex
сообщение 4.9.2008, 13:24
Модель телефона: L7
Прошивка: ACR_RB
Цитата(RuslanchiK @ 4.9.2008, 13:03) *
blak_alex,
по твоему мануалу и делал
ребут
simba4
сообщение 4.9.2008, 13:27
Пользователь №: 122 706
Модель телефона: v3i
some functions needs to be added in the lib
__rt_memclr_w A E3A02000E92D4000E1A03002E1A0C002
0x00001180 A __rt_memclr_w
croccio
сообщение 4.9.2008, 14:39
i apply the patch and woth new version i can't listen the *.mp3 files, i've a L7 phone with R4513_ACR_RB
Мачо
сообщение 4.9.2008, 15:30
Из: Киров
Пользователь №: 8 569
Прошивка: Dream A Reality 2.0
Memclr не добавляйте тюнс глючить будет.. В теме кит эльфов я выкладывал автопатчер. Применить к эльфу. Ребутов больше не будет.
DDA-E398
сообщение 5.9.2008, 20:57
Прошивка: разные
Роботаю...
я применил автопатчер к эльфу и всёравно ребут
Last1Left
сообщение 8.9.2008, 10:19
Из: Romania
pp_player v1.5.4 black walkman mod by me, english version
Прикрепленный файл black_walkman_no_patch.zip   ( 15.73 килобайт ) Кол-во скачиваний: 112
Прикрепленный файл black_walkman_L7_09R.zip   ( 15.58 килобайт ) Кол-во скачиваний: 66
Прикрепленный файл black_walkman_ACR_RB.zip   ( 15.58 килобайт ) Кол-во скачиваний: 69
Прикрепленный файл black_walkman_ACR.zip   ( 15.58 килобайт ) Кол-во скачиваний: 71
Прикрепленный файл black_walkman_49R.zip   ( 15.58 килобайт ) Кол-во скачиваний: 98
RuslanchiK
сообщение 8.9.2008, 11:54
Из: Уфа
ИНЖЕНЕР!!!
Last1Left,
Campanula
сообщение 8.9.2008, 12:12
QUOTE(RuslanchiK @ 8.9.2008, 11:54) *
Last1Left,
GB2UC.MAP
newbieholic
сообщение 9.9.2008, 7:17
@campanula, Is there any program for edit or make lrc?
Can you share with us?
Thanks.
Last1Left
сообщение 9.9.2008, 11:45
Из: Romania
QUOTE(newbieholic @ 9.9.2008, 10:17) *
Thanks.
Hellscream
сообщение 10.9.2008, 3:52
Из: Кемерово
Пользователь №: 57 645
Модель телефона: N80
выложите кто-нибудь эти эльфы на сторонние хостинги, пожалуйста. Чего-то с мотофана не качает
Can you host all these elfs to www.slil.ru or other hosting???
Сообщение отредактировал Hellscream - 11.9.2008, 5:28
Campanula
сообщение 10.9.2008, 7:31
Цитата(Andy51 @ 9.9.2008, 17:08) *
Campanula, return the topic name please. I will close the thread if you want. I don't think it should be deleted.
well
Technology knows no borders! Only language differences!
Indeed smile.gif A51
Сообщение отредактировал Andy51 - 10.9.2008, 17:42
VEX
сообщение 21.9.2008, 8:36
Из: Нижний Новгород
Campanula you elf pp-player conflict with elf date (of Last1Left),at neglect pp-player telefone depended.
Campanula
сообщение 21.9.2008, 8:47
QUOTE(VEX @ 21.9.2008, 8:36) *
here you are!
pp_player_patch.elf
pp_player_patch_blue.elf
pp_player.elf
pp_player_blue.elf
With the patch are played E398map paper version of the patch, patch version of the other amendments to follow suit
English Version:
Сообщение отредактировал Campanula - 21.9.2008, 9:19
VEX
сообщение 22.9.2008, 12:59
Из: Нижний Новгород
Цитата(Campanula @ 21.9.2008, 12:47) *
English Version:
This is exactly the English version? I have for some reason, the text appears as follows:
Campanula
сообщение 23.9.2008, 2:17
QUOTE(VEX @ 22.9.2008, 12:59) *
IPB Image
here you are!
the SRC and SDK of pp_play_1.6
Sorry ,I'm busy!
so
Last1Left can make PP_play_1.6 with SRC for you!
Сообщение отредактировал Campanula - 23.9.2008, 2:22
Last1Left
сообщение 25.9.2008, 10:58
Из: Romania
pp_player v1.6 ENG walkman
Сообщение отредактировал Last1Left - 25.9.2008, 11:04
Прикрепленный файл EN_e398_49R.zip   ( 14.67 килобайт ) Кол-во скачиваний: 38
Прикрепленный файл EN_no_patch.zip   ( 14.79 килобайт ) Кол-во скачиваний: 56
Прикрепленный файл EN_v360_ACR.zip   ( 14.67 килобайт ) Кол-во скачиваний: 36
PP_Lrc1.5.4/PP_reader [23.09.2008update], new:pp_play_1.6 SRC&SDK · Эльфы, их разработка и портирование · Forum
Текстовая версия Сейчас: 20.7.2025, 0:56
Форум живёт: 8088 дней
