[modded]: V635_R474_G_08.48.6FR + ELFs, Motorola V635 custom firmware by fkcoder & EXL
сообщение 23.2.2025, 15:42
For English speaking members
21 years after the Motorola V635, the flagship of the P2K/GSM platform, was released, fkcoder and I, along with the guys from siepatchdb@c.j.r, decided to add support for running ELF applications to it! As a result, we have created a small modified firmware where I tried to preserve the stock and original design for nostalgic purposes. In essence, this is the first custom monsterpack for Motorola V635 with a full-fledged ElfPack.
The firmware is prepared and suitable for all V635 phones of the R474 platform on 07.D0, 07.E0, 08.20, 08.21 bootloaders with 8 MiB RAM and 32 MiB ROM flash memory. Warning!: If you have a 08.29 bootloader on your V635, you need to either downgrade it or rebuild the firmware with RSA bypass patches specifically for the 08.29 bootloader, you can ask for details in this thread. The custom firmware was not prepared for 08.29 due to its low prevalence.
S/W: R474_G_08.48.6FR
Flex: SE5163AXXU1106
Installation:
01. Charge the battery.
02. Enter Boot Loader mode by simultaneously pressing *, #, Red key when the phone is turned off.
03. Install Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Connect the phone to the PC.
05. Flash the SBF firmware file using RSD Lite 3.8 or Flash&Backup 3.09, you can flash it using a virtual machine, see for more details the topic:
Virtual machine images for Motorola, WinXP and Win2K phones for VirtualBox and VMware Player.
Changes:
01. CG1, CG18: RSA bypassed using method by Smart-Clip developers.
02. CG1: Changed Boot Screen.
03. CG1: All ELF patches have been added.
04. CG2, CG4: Mobile QQ menu item was activated and renamed to ELFs.
05. CG2: FEM activated.
06. CG2: JAL activated.
07. CG2: *#9999#
08. CG2: Opcode Hand-Test-Command (Menu + 048263*) activated.
09. CG2: Added various stock content.
10. CG2: Added ELFs, ElfLoader and necessary libraries.
11. CG15: Timings in DRM/CG15 have been reduced.
12. CG2: Added some Java-games and Java-applications: MP3 Player, Golf, JBenchmark, TopGun.
13. CG2: Funlight/Club Lights activated. Changes in funlight.pat by Prizr@k и gnome139.
14. CG2: Increased volume in sound drivers. Changes in gain_table.bin and param_table.bin by Prizr@k и gnome139.
15. CG1: MP3 bitrate limit increased to 320 kbps.
16. CG4: Fixed Cyrillic bold font in the Web browser.
17. CG4: Fixed ID3 tags in MP3 in Win-1251 encoding.
18. CG1: Added the ability to remove SIM-Lock.
A description of some ELFs can be found in the ELFs by EXL: Nostalgia of development for Motorola P2K thread.
Attention! Some ELF applications require a running and minimized any Java application.
(new!) CPU Overclock on Motorola E398, Motorola RAZR V3i, and similar phones, 52 MHz => 65 MHz, +20% Performance Boost!
Task List:
01. 🟩 Port the patch to increase the resolution of JPG (1280x1024), GIF (640x480) and PNG (640x480) images.
01. fkcoder | MotoFan.Ru: for huge work in finding functions which was needed for ElfPack port, debugging Elfs and ElfPack, for great help in testing.
02. dimonp25 | siepatchdb@c.j.r: for the idea of ​​creating custom V635 firmware with Elfs, finding functions which was needed for ElfPack port, help in testing.
03. Viktor89 | siepatchdb@c.j.r: for porting MP3 320kbps patch, for finding several functions which was needed for some Elfs. Genius, billionaire, playboy, philanthropist.
04. iLove3D | MotoFan.Ru: huge help in testing custom firmware, overclock, Elfs, and patches.
05. regenfaellt | siepatchdb@c.j.r: huge help in testing custom firmware, overclock, Elfs, and patches.
06. Prizr@k | MotoFan.Ru: for R474_G_08.48.6FR_by_Prizr@k_and_gnome139 project, some files of which I used.
07. gnome139 | MotoFan.Ru: for R474_G_08.48.6FR_by_Prizr@k_and_gnome139 project, some files of which I used.
08. Vilko | MotoFan.Ru: for bypassing RSA and the subsequent ability to create patches and Elfs.
09. Smart-Clip developers: for alternative RSA bypassing method and the subsequent ability to create patches and Elfs.
Mirrors:
01. V635_R474_G_08.48.6FR_modded_25-Feb-2025.zip on firmware.center
Спустя 21 год после выхода на рынок Motorola V635, который являлся флагманом платформы P2K/GSM, мы с fkcoder и ребятами из siepatchdb@c.j.r решили добавить в него поддержку исполнения ELF-приложений! По итогу у нас получилась небольшая модифицированная прошивка, в которой я постарался сохранить стоковое и оригинальное оформление в ностальгических целях. По сути это первый кастомный монстрпак для Motorola V635 с полноценным ElfPack'ом.
Прошивка подготовлена и подходит для всех телефонов V635 платформы R474 на бутах 07.D0, 07.E0, 08.20, 08.21 с количеством оперативной памяти 8 MiB RAM и размером Flash-памяти 32 MiB ROM.
Внимание: Если у вас на V635 используется бут 08.29, то его нужно либо понизить, либо пересобрать прошивку с патчами обхода RSA специально для бута 08.29, спросить подробности можно в этой теме. Прошивка не была подготовлена для 08.29 из-за его низкой распространённости.
Установка:
01. Зарядите аккумулятор.
02. Зайдите в Boot Loader по одновременному нажатию *, #, Красная трубка, когда телефон выключен.
03. Установите драйвера Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Подключите телефон к PC.
05. Прошейте SBF-файл прошивки с помощью RSD Lite 3.8 или Flash&Backup 3.09, прошивать можно из-под виртуальной машины, см. подробнее тему:
Образы виртуальных машин для телефонов Motorola, WinXP и Win2K для VirtualBox и VMware Player.
Изменения:
01. CG1, CG18: Снят RSA по методике команды Smart-Clip.
02. CG1: Изменён Boot Screen.
03. CG1: Добавлены все необходимые ELF-пачти.
04. CG2, CG4: Активирован Mobile QQ и переименован в ELFs.
05. CG2: Активирован FEM.
06. CG2: Активирован JAL.
07. CG2: *#9999#
08. CG2: Активирован Opcode Hand-Test-Command (Menu + 048263*).
09. CG2: Добавлен различный стоковый контент.
10. CG2: Добавлены ELF'ы, ElfLoader и необходимые библиотеки.
11. CG15: Уменьшены тайминги в DRM/CG15.
12. CG2: Добавлены Java-игры и Java-приложения: MP3 Player, Golf, JBenchmark, TopGun.
13. CG2: Активирован Funlight/Club Lights. Авторство изменений в funlight.pat от Prizr@k и gnome139.
14. CG2: Увеличена громкость в драйверах звука. Авторство изменений в gain_table.bin и param_table.bin от Prizr@k и gnome139.
15. CG1: Увеличен битрейт MP3 до 320 kbps.
16. CG4: Исправлен жирный (bold) кириллический шрифт в Web-браузере.
17. CG4: Исправлены ID3-теги в MP3 в кодировке Win-1251.
18. CG1: Добавлена возможность снятия SIM-Lock.
Список патчей / List of Patches:
00_V635_R474_G_08.48.6FR_CG18_NoRSA.fpa
00_V635_R474_G_08.48.6FR_CG1_NoRSA.fpa
01_V635_R474_G_08.48.6FR_Custom_Bootsplash.fpa
01_V635_R474_G_08.48.6FR_Custom_Bootsplash_Vik89.fpa
02_V635_R474_G_08.48.6FR_EP1_Bootsplash.fpa
03_V635_R474_G_08.48.6FR_Deregister_Mobile_QQ.fpa
04_V635_R474_G_08.48.6FR_Unlock_PDS_SIM-Lock_SEEMs.fpa
05_V635_R474_G_08.48.6FR_MP3_320kbps.fpa
Список ELF'ов / List of ELFs:
2048-P2K
Ambilight
BadApple
Benchmark
Dumper
ElfBox
Neko
Overclock
Screenshot
Spout
Yeti3D Old
Yeti3D
Описание ELF'ов можно посмотреть в теме: ELFs by EXL: Ностальгия разработки под Motorola P2K.
Внимание! Некоторые ELF-приложения требуют запущенное (любое) и свёрнутое Java-приложение.
(new!) Разгон процессора в Motorola E398, Motorola RAZR V3i и подобных, 52 MHz => 65 MHz, +20% Performance Boost!
Список задач:
01. 🟩 Портировать патч на увеличение разрешения изображений формата JPG (1280x1024), GIF (640x480) и PNG (640x480).
Спасибо:
01. fkcoder | MotoFan.Ru: за огромную работу по нахождению функций и отладке Elf'ов и ElfPack'а. За громадную помощь в тестировании.
02. dimonp25 | siepatchdb@c.j.r: за идею создания прошивки для V635 с Elf'ами, нахождение функций для портирования ElfPack'а, помощь в тестировании.
03. Viktor89 | siepatchdb@c.j.r: За портирование патча MP3 320kbps, за нахождение нескольких функций для портирования Elf'ов. Гений, миллиардер, Playboy, филантроп.
04. iLove3D | MotoFan.Ru: огромная помощь в тестировании прошивки, разгона, Elf'ов и патчей.
05. regenfaellt | siepatchdb@c.j.r: огромная помощь в тестировании прошивки, разгона, Elf'ов и патчей.
06. Prizr@k | MotoFan.Ru: за проект R474_G_08.48.6FR_by_Prizr@k_and_gnome139, некоторые файлы которого я использовал.
07. gnome139 | MotoFan.Ru: за проект R474_G_08.48.6FR_by_Prizr@k_and_gnome139, некоторые файлы которого я использовал.
08. Vilko | MotoFan.Ru: за обход RSA и последующую возможность создания патчей и Elf'ов.
09. Smart-Clip команда: за альтернативный обход RSA и последующую возможность создания патчей и Elf'ов.
Зеркала:
01. V635_R474_G_08.48.6FR_modded_25-Feb-2025.zip на firmware.center
Прикреплённые файлы:
Прикрепленный файл V635_R474_G_08.48.6FR_modded_25-Feb-2025.7z   ( 15.86 мегабайт ) Кол-во скачиваний: 81
[modded]: V635_R474_G_08.48.6FR + ELFs, Motorola V635 custom firmware by fkcoder & EXL · Кастомные прошивки для Motorola V300, V500, V535, V547, V551, V600, V620, V635, V80, A630, RAZR V3 · Forum
Текстовая версия Сейчас: 27.3.2025, 6:13
