20 страниц V < 1 2 3 4 5 > »
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр
sidr
сообщение 22.6.2014, 13:11 Закрепленное сообщение!
Из: Бреста
Пользователь №: 168 840
Moto E (XT1021, XT1022, XT1025)
Техническое описание
Operating system - Android™ 4.4, KitKat®
Processor - Qualcomm® Snapdragon™ 200 with 1.2GHz dual-core A7 CPU
Adreno 302 400MHz single-core GPU
Capacity - 4GB standard MicroSD slot supports up to 32GB expandable memory 1GB RAM
Dimensions and weight - Height: 124.8mm
Width: 64.8mm
Depth: 12.3mm
Weight: 142g
Display - 4.3 inches 540 x 960 qHD, 256ppi Features anti-smudge coating and Corning Gorilla Glass 3
Connectivity - MicroUSB, supports USB 2.0 3.5 mm headset jack Micro SIM
Battery - Built-in rechargeable lithium-ion, 1980mAh Mixed usage up to 24 hours
Rear camera - 5 MP
Networks - US GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
Requires a microSIM card (not included)
Global GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
CDMA Model Coming Soon!
CDMA/EVDO Rev A (850, 1900 MHz)
Bluetooth® Technology - Version 4.0 LE
Wi-Fi - 802.11 b/g/n, 2.4GHz
Фото MOTO E
Видео
[video]https://www.youtube.com/watch?v=Cs6tV1Di3-8[/video]
Видео Moto E vs Moto G
[video]https://www.youtube.com/watch?v=rVKQJp21r9Q[/video]
ОФ прошивки для MOTO E
Инструкция по прошивки с hda
a) Download and install Motorola Moto EDrivers
b) Download and extract the stock Firmware of your choosing
c) If the firmware file you downloaded is a .xml.zip file then download Motorola Fastboot Attachment 2427667 (attached to this post) and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files). If your firmware is a .tar.gz file then skip this step.
d) Get ADB (if you don't already have this, I suggest downloading and installing Minimal ADB and Fastboot by shimp208:
Direct Download
Disclaimer:
Follow these instructions at your own risk. If something goes wrong don't blame me!
These are the original stock signed image files from Motorola it should work on all Moto E Variants.
Steps to restore stock firmware:
1) Reboot the phone into bootloader mode. There are 2 ways to do this.
I) The 'hardware' way.
a) Unplug the USB cable and power off the phone.
b) Press and hold 'Volume down' then power on the phone.
c) Connect USB cable to your computer.
II) The 'software' way.
a) Enable developer mode on the Moto E (Settings-> 'About Phone'. Tap 7 times on 'Build Number')
b) Enable USB debugging. (Settings -> 'Developer options' -> 'USB Debugging' -> check)
c) Connect phone to computer via USB, you should see a new ADB device detected and drivers installed.
d) Open "Minimal ADB and Fastboot". Type:
Code:
adb reboot-bootloader
You should see the Moto E bootloader screen with the following options:
Code:
Normal Powerup
Recovery
Factory
Switch Console [NULL: null]
Barcodes
BP Tools
2) Open a command prompt / terminal (Start -> cmd.exe in Win7) and browse to the folder with the extracted firmware.
In my case:
Code:
cd c:\falcon_retgb_user_4.3_14.10.0Q3.X-76-LGG-8_54_release-keys-cid7-Retail_GB
3)
Flash each of the partitions in sequence using mfastboot, you need to enter the following commands one-by-one checking that each one returns an [OKAY]
Code:
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
Downgrading:
4) Wait, you should now be rebooted into a fully stock Moto E firmware.
Драйвера
Где купить:
EBAY
AMAZON
Фото разобранного телефона
Сообщение отредактировал Воха - 20.12.2015, 19:28
Voxa
сообщение 22.6.2014, 11:39
(M)otoVoxa
Из: г.Ставрополь
Пользователь №: 20 908
Модель телефона: Apple iPhone 6s 32Gb
Я написал одному продавцу с ибея который продаёт moto E, он сказал что русского языка нету.
сообщение 27.6.2014, 7:09
На странице Motorola Германия в социальной сети Facebook появилось объявление об обновлении смартфонов Moto G и X до Android L. Что касается самого дешёвого смартфона компании, Moto E, то представитель Motorola дал крайне неоднозначный ответ: "Мы в настоящее время по-прежнему не знаем, имеет ли апдейт до Android 5.0 смысл, если его не будет, смартфон определённо получит обновление до Android One OS для маломощных устройств" (представитель Motorola говорил именно "Android 5.0" и "Android One OS").
Сайт
Volchik777
сообщение 28.6.2014, 14:10
Пользователь №: 114 628
Модель телефона: MG
Прошивка: -
Русский язык интерфейса присутствует на данном девайсе?
sidr
сообщение 28.6.2014, 14:58
Из: Бреста
Volchik777,
Русского нет это ответили в техпотдержке моторолы
BeePlus
сообщение 3.7.2014, 23:21
Из: Харьков
Пользователь №: 168 992
VE66 :)
Юзаю Moto e XT1022 (dual) русский с коробки. (4.4.2)
BeePlus
сообщение 4.7.2014, 8:19
Из: Харьков
VE66 :)
Цитата(stigr @ 30.5.2014, 10:27) *
Цитата(captan2 @ Сегодня, 9:49)
* Главное потом разобраться с языком))
если с разлочкой бута не будет траблов, то и с русским не должно быть проблем. Ну если будут то прейдется ждать рут когда взломают.
Анлочится через сайт Моторолы, далее через фастбут подкидываем кастом рекавери (TWRP) и с флешки устанавливаем SuperSU.
Пол часа делов и можно накатывать 11 циан (или остальные кастомы)
Мото как всегда мото, камера отстой и задняя крышка люфтит.
сообщение 4.7.2014, 9:14
Цитата(BeePlus @ Сегодня, 11:19)
* камера отстой
сама камера не ахти или её работа на 4.4?
BeePlus
сообщение 4.7.2014, 10:23
Из: Харьков
VE66 :)
* камера отстой
Сам модуль конечно.
нет автофокуса.
программно даже hdr есть, а снимки ...
Девайс супер, ожидал худшего (особенно видя какое железо), а так, нереально доволен.
Экран ... разрешение возможно не ахти, но картинка и качество .
Связь ... да что тут говорить.
И микрофон и динамики , а в наушниках звук
батарейка!!! (охотно верю что хватит на 24 часа)
киткат с коробки и есть апдейт на новые версии ...
Дорого правда для такого железа, но последняя истинная моторолка, можно и купить blind.gif
Кстати, обновилось бутлого , теперь все в символике чемпионата по футболу в Бразилии laugh.gif
Сообщение отредактировал BeePlus - 4.7.2014, 15:13
сообщение 4.7.2014, 17:24
Цитата(BeePlus @ Сегодня, 13:23)
* Девайс супер, ожидал худшего (особенно видя какое железо)
я електрофай 2 немного использовал, то на старом омапе 4 довольно таки и нормально. такого железа вполне хватит, если не игроман конечно.
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр · Motorola на Android OS · Forum
Текстовая версия Сейчас: 25.4.2024, 16:03
