Значения битов во флексах EMMI, База из MotoWIN, EMMI_flexbits.txt
сообщение 21.11.2024, 6:40 Закрепленное сообщение!
Большое спасибо Bs0Dd за сборник.
Motorola EMMI phones
SEEM 14 ($0E) - FLEX Definition Table
The meanings of bits in the table.
List taken from MotoWin 9.7 by Daniel "Zulea" Henzulea.
Usage:
* If you have RoEMMI box, use PEMASTER to change these bits.
* If you have MotoKey dongle, you can use MotoWin for more comfortable editing.
* If you have TEST card only, you can use PPP commands when card inserted.
  P - pause (long-press *), displays as square.
  PPP<number>P<bit state 0/1>P [OK key]
  e.g. PPP331P1P - enable Games menu
       PPP334P0P - disable Baccarat game
--- Byte 72 ($48) ----------------------------
000 Allow MMI Field Test Flex Command
001 Dead Keypad / Enable keypad menu toggle possibility
002 Keylock (press # & * together)
003 MENU-PhoneBook(Personal Numbers) (add to top level)
004 MENU-Messages
005 Mute On/Off (MENU, during call)
006 Show complete menu of Call Related Features and Messages
007 MENU-"Arrows" (Bosch MMI)
--- Byte 73 ($49) ----------------------------
008 Phone Setup: Select Phone Line
009 Call Related Features: Last Ten Calls
010 Call Related Features: Restrict My Phone Number (CLIR)
011 Call Related Features: Call Diverting
012 Call Related Features: Call Diverting: Divert Voice Calls: Divert When Unavailable
013 Call Related Features: Call Diverting: Divert Voice Calls: Detailed Diverting
014 Call Related Features: Call Diverting: Divert Voice Calls
015 Call Related Features: Call Diverting: Divert Voice Calls: Divert All Voice Calls
--- Byte 74 ($4A) ----------------------------
016 Call Related Features: Call Diverting: Divert Voice Calls: Detailed Diverting: If Busy
017 Call Related Features: Call Diverting: Divert Voice Calls: Detailed Diverting: If No Answer
018 Call Related Features: Call Diverting: Divert Voice Calls: Detailed Diverting: If Not Reachable
019 Call Related Features: Call Diverting: Divert Fax Calls
020 Call Related Features: Call Diverting: Divert Data Calls
021 Call Related Features: Call Diverting: Cancel All Diverting
022 Call Related Features: Call Waiting
023 Call Related Features: Call Barring
--- Byte 75 ($4B) ----------------------------
024 Call Related Features: Call Barring: Bar Outgoing Calls
025 Call Related Features: Call Barring: Bar Incoming Calls
026 Call Related Features: Call Barring: Change Bar Password
027 Call Related Features: Call Restrictions
028 Call Related Features: Call Restrictions: Restrict Incoming Calls
029 Call Related Features: Call Restrictions: Phone Number Length
030 Call Related Features: Call Restrictions: Keypad Dialing
031 Messages: Call Voicemail
--- Byte 76 ($4C) ----------------------------
032 Messages: Received Messages
033 Messages: Cell Broadcast
034 Messages: Message Settings (completely)
035 Message Alert Tone (7500/8200 only)
036 Messages: Message Settings: Voicemail Number
037 Incoming Call Alert (7500/8200 or higher only)
038 No Alert (7500/8200 or higher only)
039 Vibrate Only (7500/8200 or higher only) or VibraCall On or Off (In Quick Access Menu, 2.75v w/VibraCall)
--- Byte 77 ($4D) ----------------------------
040 Phone Setup: Adjust Ring Volume
041 Phone Setup: Phone Lock: Lock Now
042 Phone Setup: Phone Lock: Automatic Lock
043 Phone Setup: Phone Lock: Change Unlock Code
044 Phone Setup: Require SIM Card PIN
045 Phone Setup: Change SIM PIN Code/Export PIN for Storage
046 Phone Setup: New Security Code
047 Phone Setup: Extended Menus
--- Byte 78 ($4E) ----------------------------
048 Phone Setup: Language Selection
049 Phone Setup: Language Selection: Automatic
050 Phone Setup: Change Greeting
051 Phone Setup: Battery Saving Mode (Voice Operated Transmission)
052 Phone Setup: Select Keypad Tones
053 Phone Setup: Phone Status
054 Phone Setup: Phone Status: Status Review
055 Phone Setup: Phone Status: Master Reset
--- Byte 79 ($4F) ----------------------------
056 Phone Setup: Phone Status: Master Clear
057 Network Selection: Available Networks
058 Network Selection: Network Search
059 Network Selection: Network Search: Registration Preferences
060 Network Selection: Network Search: Frequency Of Search
061 Network Selection: Preferred Networks
062 Network Selection: Preferred Networks: Add Network To List
063 Network Selection: Preferred Networks: Show List Of Networks
--- Byte 80 ($50) ----------------------------
064 Network Selection: Find New Network
065 Show Last Call (7500/8200 or higher only)
066 Resettable Call Meters (7500/8200 or higher only)
067 Call Meters: Set Audible Call Timers
068 Call Meters: Set Audible Call Timers: Single Alert Timer
069 Call Meters: Set Audible Call Timers: Repetitive Timer
070 ** 1 = Register write lock !!!! (no effect on newer phones)
071 Show Meter During Calls (7500/8200 or higher only)
--- Byte 81 ($51) ----------------------------
072 Set Meter Format (7500/8200 or higher only)
073 Set Call Cost Rates (7500/8200 or higher only)
074 Call Meters: Lifetime Meter
075 Accessory Setup: Mute Car Radio upon any keypress, disables 80 if entered thru keypad
076 Accessory Setup: Mute Car Radio while calling or receiving a call, disables 80 if entered thru keypad
077 Accessory Setup: Auto Answer
078 Accessory Setup: Automatic Handsfree
079 Accessory Setup: Safety Timer
--- Byte 82 ($52) ----------------------------
080 Accessory Setup: Aux Alert, disables 75&76 if entered thru keypad#82
081 Phone Book: Personal Numbers: Find Entry By Name
082 Phone Book: Personal Numbers: Find Entry By Location
083 Show Services (Phone Book: Personal Numbers)
084 Enter My Phone Number (7500/8200 or higher Only)
085 Show My Phone Number (7500/8200 or higher Only)
086 Phone Book: Personal Numbers: Add Entry
087 Phone Book: Personal Numbers: enable phone's phonebook
--- Byte 83 ($53) ----------------------------
088 Phone Book: Personal Numbers: Check Capacity (Phone / SIM)
089 Phone Book: Personal Numbers: Prevent Access
090 Phone Book: My Phone Number(s): Edit Name
091 Phone Book: My Phone Number(s): Edit Number
092 MENU-Call Related Features
093 MENU-Phone Setup
094 MENU-Network Selection
095 MENU-Call Meters
--- Byte 84 ($54) ----------------------------
096 MENU-Accessory Setup (only with PROPER headset or speakerphone)
097 Incoming Alert Timer
098 Voice Key Cancel Alert
099 Network Selection: Network Search: Frequency Of Search: Periodic Search (equivalent to Medium)
100 Network Selection: Network Search: Frequency Of Search: Continuous Search
101 Network Selection: Network Search: Frequency Of Search: Slow Search
102 Network Selection: Network Search: Frequency Of Search: Medium Search
103 Network Selection: Network Search: Frequency Of Search: Fast Search
--- Byte 85 ($55) ----------------------------
104 MENU-PhoneBook (on older phones?) / TON NPI Support
105 MENU-PhoneBook (Personal Numbers) (add to bottom level)
106 MENU-Messages (add to bottom level)
107 Divert All Calls
108 Phone Book: Personal Numbers: Copy SIM Memory
109 Call Related Features: Call Diverting - all submenus: Divert to Voicemail or Other Number
110 Phone Setup: Direct Dial Key: Edit Number
111 Phone Setup: Direct Dial Key: Edit Name
--- Byte 86 ($56) ----------------------------
112 Phone Setup: Direct Dial Key
113 MENU-Eng Field Options
114 Phone Setup: Ring Or Vibrate
115 Phone Setup: Set Ringer Tone
116 Phone Setup: Ring Or Vibrate: Vibrate Then Ring
117
118
119
--- Byte 87 ($57) ----------------------------
120 Unconditional Divert indicator 87
121 Divert Auto Cancel
122 Auto Clear Voicemail Indicator
123 Enable Clock / Phone Setup: Show Time and Date / Set Time and Date / Set Time Format
124 Call Related Features: Talk and Fax (TS61 ON/OFF Menu)
125 Call Related Features: Talk and Fax Next Call (TS61 Next Call menu)
126 Last Ten Calls: Erase All Numbers
127 MENU-PhoneBook (Phone Book new Main Menu)
--- Byte 88 ($58) ----------------------------
128 Phone Book: Personal Numbers
129 Phone Book: Show Services (8900 already uses this location)
130 Phone Book: Last Ten Calls
131 Phone Book: Personal Numbers: My Phone Number(s)
132 Phone Book: Fixed Dialling
133 Phone Book: One-Touch Dial Setting
134 Call Related Features: Closed User Group
135 Messages: Outgoing Messages
--- Byte 89 ($59) ----------------------------
136 Messages: Message Editor
137 Messages: Message Settings (w/o Voicemail Number)
138 Phone Setup: Change SIM PIN2 Code
139 Call Meters: Show Call Charges
140 Call Meters: Show Call Timers
141 Call Meters: Set In-Call Display
142 Call Meters: Call Charge Settings
143 Call Meters: Call Charge Settings: Set Total Charge Limit
--- Byte 90 ($5A) ----------------------------
144 Call Meters: Call Charge Settings: Set Charge Type
145 Disable change Phone Book Options menu to Personal Numbers (New Phonebook Menu with Hotkey)
146 Fixed Dialling Edit Number
147 Fixed Dialling Edit Name
148 Phone Setup: Ringer On or Off (No Vibrate phones)
149 Show Battery Meter
150 Operator Dialling
151 SMS Date Time Format
--- Byte 91 ($5B) ----------------------------
152 Phone Setup: Language Selection: Dansk
153 Phone Setup: Language Selection: Nederlands
154 Phone Setup: Language Selection: English
155 Phone Setup: Language Selection: Suomi
156 Phone Setup: Language Selection: French
157 Phone Setup: Language Selection: Deutsch
158 Phone Setup: Language Selection: Greek
159 Phone Setup: Language Selection: Magyar
--- Byte 92 ($5C) ----------------------------
160 Phone Setup: Language Selection: Italiano
161 Phone Setup: Language Selection: Norsk
162 Phone Setup: Language Selection: Portuguese
163 Phone Setup: Language Selection: Spanish
164 Phone Setup: Language Selection: Svenska
165 Phone Setup: Language Selection: Turkish
166 Phone Setup: Language Selection: Automatic
167 Quick Access Menu Entry: Show Battery Meter
--- Byte 93 ($5D) ----------------------------
168 Signal Strength Indicator
169 |A5.2; another source tells that 168 is A5.2 and 169 is A5.3
170 Call Related Features: Talk and Fax: Next Call Only (TS61 Next Call Only Option)
171 Phone Setup: Language Selection: Thai
172 Phone Setup: Language Selection: Tieng Viet
173 Phone Setup: Language Selection: Bahasa Malaysia
174 Phone Setup: Language Selection: Bahasa Indonesia
175 Phone Setup: Language Selection: Filipino (Tagalog)
--- Byte 94 ($5E) ----------------------------
176 Phone Setup: Language Selection: Simplified Chinese
177 Don't display menu name
178 Phone Book: Fixed Dialling: Setup Fixed Dialling: Erase Entry
179 Phone Setup: Keypad Guard (useful for handset only)
180 Call Related Features: Call Barring: Cancel All Barring
181 SMS Call Back Option Return
182 Hutchison Home Zone
183 MPC Home Zone
--- Byte 95 ($5F) ----------------------------
184 New Call Diverting Menu Structure
185 Enable Customization of Quick Access Menu
186 New Volume Adjust Menu Mode
187 Call Related Features: Key Answer Only (allow opening flip to check CLI)
188 |TS61 Fast Call Only (Quick Access Menu Entry)
189 My Phone Number(s)(Phone Book)
190 Caller ID Alpha Tag Lookup
191 Enable EFR on DSP 71.xx or higher. If set to 1, outgoing calls are not possible on older phones!
--- Byte 96 ($60) ----------------------------
192 Flex bit for bogus (If set to 1, outgoing calls are not possible on older phones!)
193 Phone Setup: Set Ringer Tone 2 (If set to 1, outgoing calls are not possible on older phones!)
194 Charging Prompts In Modulus (If set to 1, outgoing calls are not possible on older phones!)
195 Messages: Message Settings: Outgoing Message Type: Fax
196 Messages: Message Settings: Outgoing Message Type: X400
197 Messages: Message Settings: Outgoing Message Type: Paging
198 Messages: Message Settings: Outgoing Message Type: E-Mail
199 Messages: Message Settings: Outgoing Message Type: ERMES
--- Byte 97 ($61) ----------------------------
200 Messages: Message Settings: Outgoing Message Type: Voice
201 Charge Mode Timer
202 Phone Setup: Language Selection: Polski
203 Network Selection: Change Band (no function on 8900)
204 Network Selection: Change Band: Change to 900 (no function on 8900)
205 Network Selection: Change Band: Change to 1800 (no function on 8900)
206 Quick Access Menu Entry: Change Band (no function on 8900)
207 VoiceNotes (cd9xx and newer models only)
--- Byte 98 ($62) ----------------------------
208 Quick Access Zero (adds 4th row to Quick Access Key (only 0 useable), might not work on some phones)
209 Export PIN delete (in "Require SIM Card PIN")
210 Handsfree Toggle (MENU, during call)
211 Messages: VoiceNotes: Record VoiceNote
212 |Detailed Diverting (Voice) menu
213 Automatic Inactive Select Phone Line 1/2 on 900 MHz Band
214 |MenuMode For Divert VoiceCalls
215 Quick Access Menu Entry: Divert All Voice Calls
--- Byte 99 ($63) ----------------------------
216 Phone Setup: Language Selection: Cestina
217 Phone Setup: Language Selection: Complex Chinese
218 Input Method Selection(cd928+ S/W AB.50.03 Support CKE(Chinese Keypad Entry))
219 Chinese Keypad Entry Method: Pin-Yin
220 Chinese Keypad Entry Method: Stroke
221 Chinese Keypad Entry Method: Smart English
222 Chinese Keypad Entry Method: Multi-tap
223 Chinese Keypad Entry Method: Bo-po-mo-fo
--- Byte 100 ($64) ---------------------------
224 Phone Setup: Greeting Tone (MicroTAC 8700 and newer)0
225 Multiparty Calling Capable
226 Independent Ctrl ( Call Wait Line1 Line2)
227 Phone Setup: Language Selection: Romanian
228 Phone Setup: Language Selection: Lithuanian
229 Phone Setup: Language Selection: Russian
230 |Send Speech Teleservice Line1
231 Enable Flip function (keys disabled when Flip closed)
--- Byte 101 ($65) ---------------------------
232 LED indicate camped1
233 Voice Dialling
234 Quick Access Menu Entry: Add or Edit Voice Tag (if 233 enabled) (cd9x0 S/W AB.04.14 or higher)
235 Power On Delay
236 Power Off Delay (cd9x0 S/W AB.04.14 or higher)
237 Ability to Transfer Calls
238 Service Provider name in display row 2, read ROM SIM file 0x6f46; stays permanent even if no Line1/2 enabled
239 Power Off tone (cd9x0 S/W AB.04.14 or higher)
--- Byte 102 ($66) ---------------------------
240 Direct Dial As IP_Dedicated Key
241 Compressed (If set to 1 Phone will display poor greeting)
242 Display off when flip closed
243 Color/Contrast Adjust
244 US English/Can French (if set to 1 some phones will power on and off permanently. Dangerous!)
245 GSM 900 PLMN Display (display network names instead of shortcode)
246 DCS/PCN 1800 PLMN Display (display network names instead of shortcode)
247 PCS 1900 PLMN Display (display network names instead of shortcode)
--- Byte 103 ($67) ---------------------------
248 Multiparty with 2 parties
249 US Or European Supervisory Tones
250 Intro Messages For Quick Access Function
251 ROAMING or Operator Name Display
252 Enable SIM Toolkit Menu
253 Network Selection: Change Band: Change to 1900 (on Tri-Band phones)
254 Network Selection: Change Band: Change to 900/1800
255 Change Mode (Auto Select/Digital Only/Analog Only) (On Non-GSM phones)
--- Byte 104 ($68) ---------------------------
256 Quick Access Menu Entry: Change Mode (On Non-GSM phones) (Feature not available)
257 Viag Home Zone
258 CLIR Recognition Restriction
259 Phone Setup: Language Selection: Bulgarian
260 Phone Setup: Language Selection: Hrvatski (Croatian)
261 Phone Setup: Language Selection: Eesti (Estonian)
262 Phone Setup: Language Selection: Latviski (Latvian)
263 Phone Setup: Language Selection: Srpski (Serbian)
--- Byte 105 ($69) ---------------------------
264 Phone Setup: Language Selection: Slovensky (Slovakian)
265 Phone Setup: Language Selection: Slovensko (Slovenian)
266 Phone Setup: Language Selection: Ukrainian
267 Scanning Preferences On/Off
268 SID Display On/Off
269 Analog PIN code On/Off
270 Transfer All CBS On/Off
271 Receive Only Mode On/Off
--- Byte 106 ($6A) ---------------------------
272 Send Message: Enter Number/Find Entry By Name/Find Entry By Location (Phone Book Lookup)
273 Eng Field Options: Memory Monitor (S/W A0.06.18 or higher?)
274 Analog Emergency Call On/Off
275 Place Analog Emergency Call
276 Phone Setup: Set Message Alert Tone (cd9xx and newer models only) (S/W A0.06.18 or higher?)
277 SmartCard SIM Select / Notification
278 Phone Setup: Enable "Edit Music ringtone" (newer models) | disable Backlight on M-Series
279 Phone Setup: Activate IR port
--- Byte 107 ($6B) ---------------------------
280 Quick Access Menu Entry: Activate IR Port
281 Activate One2One SIM Band Control
282 Call Divert To EEPROM
283 Animated Wakeup Graphics
284 Messages: Cell Broadcast: Language List
285 Send SMS-RP ACK before SIM stores
286 Enable Receipt of Unicode SMS
287 Disable Roaming Icon
--- Byte 108 ($6C) ---------------------------
288 Phone Setup: Language Selection: Hebrew
289 Phone Setup: Language Selection: Arabic
290 Static Wakeup Graphics
291 Cell Broadcast Backlight Off
292 Credit Remaining on Idle Display
293 enable FM radio on V2288 (problem with VoiceNotes on T260 ???)
294
295
--- Byte 109 ($6D) ---------------------------
296 Phone Setup: Set Animation (v8088, v51, v50, T250)
297
298 Eng Field Options: EFEM Options
299
300 MENU-Access Internet
301
302
303
--- Byte 110 ($6E) ---------------------------
304 Access Internet: Browser Menu: Setup
305 Access Internet: Browser Menu: MyMotorola
306
307
308
309
310
311
--- Byte 111 ($6F) ---------------------------
312
313 Phone Setup: Visual Alert (v8088 aka v51, useless on phones without the 2nd LED)
314
315 MENU-Alarm Clock
316
317
318
319 Phone Setup: Set Alarm Ringer Tone (On/Off)
--- Byte 112 ($70) ---------------------------
320 |Calculator ??
321 Disables Access Internet: Browser Menu: Advanced: Show URL
322 Access Internet: Browser Menu: Setup: Profile 1:Data Bearer: GPRS
323 Access Internet: Browser Menu: Setup: Editable Profile 1
324 Access Internet: Browser Menu: Setup: Editable Profile 2
325 Access Internet: Browser Menu: Setup: Editable Profile 3
326 Disables internet main menu when set to 1, combined with 306 function as switch for activation of WAP
327 Phone Setup: Setup Internet
--- Byte 113 ($71) ---------------------------
328 Phone Setup: Setup Internet: (Entries)
329
330
331 MENU-Games
332 Games: Bricks
333 Games: Tower of Hanoi
334 Games: Baccarat
335
--- Byte 114 ($72) ---------------------------
336
337 Enables big chars on menus (only T250, V51, V8088)
338 Phone Setup: Internet: Phone # (first profile)
339 Phone Setup: Internet: Line Type (Modem/ISDN) (first profile)
340 Phone Setup: Internet: User (first profile)
341 Phone Setup: Internet: Password (first profile)
342
343
--- Byte 115 ($73) ---------------------------
344 When set to 1, special characters are not displayed correctly in the WAP browser
345 Access Internet: Browser Menu: Advanced: Set Homepage
346
347 Eng Field Options: Phone Debug Features
348 Access Internet: Browser Menu: Mark Site
349 Changes menu text to large font (there is a separate setting for the phone book large font somewhere)
350 Access Internet: Browser Menu: Go
351
--- Byte 116 ($74) ---------------------------
352
353
354
355
356
357
358 Instead of showing "Access Internet" in the main menu, a bitmap is drawn. (T250 ?)
359 Enable bit 328 (Phone Setup: Setup Internet: (Entries)), override! (only T260?)
--- Byte 117 ($75) ---------------------------
360 Access Internet: Browser Menu: Setup: Profile 2:Data Bearer: GPRS
361 Access Internet: Browser Menu: Setup: Profile 3:Data Bearer: GPRS
362 Access Internet: Browser Menu: Web Favourites
363
364
365
366
367 MENU-Calculator
--- Byte 118 ($76) ---------------------------
368
369
370
371
372
373
374
375
--- Byte 119 ($77) ---------------------------
376
377
378 Phone Setup: Backlight (T260 AF.7C.CB)
379 Enable animated icon on SMS display (T260 AF.7C.CB)
380
381 Phone Setup: Message Popup Alert (T260 AF.7C.CB)
382
383
--- Byte 120 ($78) ---------------------------
384
385
386
387
388
389
390
391
--- Byte 121 ($79) ---------------------------
392
393
394
395
396
397
398
399
Прикреплённые файлы:
Прикрепленный файл EMMI_flexbits.txt   ( 19.98 килобайт ) Кол-во скачиваний: 236
Значения битов во флексах EMMI, База из MotoWIN, EMMI_flexbits.txt · Motorola EMMI: M3x88, T180, T192, T250, T260, x2288, V50, V51, StarTAC, CDxxx, V36xx · Forum
> Быстрый ответ
Текстовая версия Сейчас: 20.7.2025, 16:16
