23 страниц V « < 9 10 11 12 13 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
_Тyшkан_
сообщение 11.1.2007, 16:11
Из: Орёл
Пользователь №: 81 333
Прошивка: CS_WITHIN_by_Тушкан
Keypad autoblock:
SEEM 004A_0001 adres 0x91 bit 1 (1-autolock enabled 0-autolock disabled)
Low Battery Sound:
SEEM 004A_0001 adres 0x91 bit 0 (1-sound enabled 0-sound disabled)
[OFF]Что-то не нашел я такого у себя. В аттачу мой 4а сим, тому кто мне активирует эти две фичи будет +.[/OFF]
Qwest,
посмотри в опциях, скорее всего у тебя смс на симкарте хранятся. Когда ты меняешь симку на другую, то смски остаются на старой. ИМХО
PATRON2002
сообщение 11.1.2007, 18:18
Из: Ростов-на-Дону
Пользователь №: 72 038
Модель телефона: Nokia 6120c
Прошивка: Symbian 9.2 3Dr
Люди дайте плиззз ссылку на 49ю...........
BackgaMan
сообщение 11.1.2007, 18:32
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
На предедущей странице смотри.
Qwest
сообщение 12.1.2007, 9:27
Из: Краснодар
Пользователь №: 47 049
Модель телефона: E798 (E398) 48R
_Тyшkан_
Нет, в том то и дело, когда ставлю на сим, все остается! я пробовал ставить сохранение в симах (в телефон) и через меню (в настройках сообщений) не помогает. Просто я не могу понять, это у всех так или только у меня!?
naykava
сообщение 12.1.2007, 12:12
Пользователь №: 74 301
Прошивка: 49R_em0.3_ns+my edit
В p2ktools 0.8.6 - скр.настр.- сообщения проверь следующие строки:
1. Хранить SMS только на SIM-карте - убери галочку
2. Удалять СМС при смене СИМ-карты - убери галочку
Если таких строк у тебя нет, тогда распакуй прикрепленный файл в корень p2ktools, заменив старый, и перезапусти прогу.
А также в телефоне: сообщ.-софт.клав.-настройка сообщ.-(автоочистка-нет)настройка сообщ.(изм.)-сохранить в: телефон.
Прикрепленный файл other_features__SnowArt_v1.7_.zip   ( 8.27 килобайт ) Кол-во скачиваний: 88
Qwest
сообщение 12.1.2007, 13:33
Из: Краснодар
naykava
Спасибки тебе, все получилось!!! =) Просто у меня было включено удаление при смене симки!!! Жаль что не могу поставить +, мало постов пока! =( Но большое человеческое СПАСИБО!!!
dsedelnikov
сообщение 13.1.2007, 20:39
Пользователь №: 70 385
Прошивка: elektro255_v0.2_49R
Может кто проверял: на прошивках от электро работают ли пункты меню "темы", IM и т.д.?
А то возиться напрасно нет желания
deadmoto
сообщение 14.1.2007, 9:16
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
dsedelnikov, зачем они тебе??? Если надо - включи, не надо выключи... 5 кнопок нажать...
Эти настройки есть в P2K Menu Editor'e...
dsedelnikov
сообщение 14.1.2007, 10:33
deadmoto,
спасибо, знаю.
Doktor Кот
сообщение 14.1.2007, 12:58
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Всем здрасте! А почему в проше от Электро в настройках настаивается интелект - клавиша для фотокамеры, а не которая с левой нижней стороны? Как это поправить? А еще как на этой проше дуалбут запустить? Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
deadmoto
сообщение 14.1.2007, 17:19
Главный Новостник
Из: Омск
Запускаем P2K Tools > Seem Editor > 005b_0001
Находим строку 010... По этой строке столбец 05 это кнопка слева, 06 - кнопка справа...
В архиве найдёшь значения клавиш... У меня 010х05 стоит 42, 010х06 стоит 3F...
Желаю удачи, пробуй...
После некоторых раздумий... Если всё же поставиш на инт.клавишу корелет(код 42), то он будет вызываться из любого места в телефонеsmile.gif Т.е. аналог такой же кнопки не Е1...
Я тебе сейчас -2 дам Запрещено выпрашивать рейтинг
Сообщение отредактировал deadmoto - 15.1.2007, 7:08
Bent
сообщение 15.1.2007, 5:17
MoTo Marvellous
Пользователь №: 63 874
Doktor Кот,
Зажимаешь "Зелёную кнопку" и буквально на секунду(отрывистым движением) нажимаешь "Красную"(Зелёную держишь всё время,не отпуская) Само собой проделывать это в выключенном состоянии.
На мой взгляд лучше 49R79R много заморочек(хотя,сейчас посмотрим что там за RC3 выйдет),НО на 79R безлимитное видео.
AgentSlash
сообщение 15.1.2007, 12:35
Из: Ukraine, Kyiv
Пользователь №: 46 621
Модель телефона: HTC Touch Diamond
Цитата(Doktor Кот @ Воскресенье, 14 Января 2007, 14:58)
.......Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
Всё таки 79 получше будет. Токо ставить тебе лучше не голую електровскую прошу, а какой нить настроеный и пропатченый монстрик. Советую подождать симбу от Арчи (RC3).
Doktor Кот
сообщение 15.1.2007, 15:38
Из: Красноярск
Deadmoto, спасибо! Помог! лови + И за отзывы спасибо всем! Еще столкнулся с такой проблемой: изначально на проше от Электро стоит 2 скина: WindowsXp_olive и просто WindoаsXp. Заметил, что эти два скина - полные. WindowsXp_olive - это главный скин, мне он не нравится и я его удалил. И теперь когда я заливаю какой-нибудь другой скин, больший по размеру чем скин WindowsXp, этот скин (а он конечно же неполный) становится главным и пропадают пункты меню! А как сделать родной скин Windowsxp - главным?
BackgaMan
сообщение 15.1.2007, 17:29
Мотоумелец
ММА попробуй от этого скина закинь.
Bent
сообщение 16.1.2007, 4:51
MoTo Marvellous
Doktor Кот,
Открываешь через p2ktools папку со скином,выделяешь все файлы внутри папки Windowsxp,ставишь им атрибут - "Системный",перезагружаешься.
PATRON2002
сообщение 17.1.2007, 20:04
Из: Ростов-на-Дону
Дайте плиззз патч для передачи ЯВЫ по блютузу через папку видео....
deadmoto
сообщение 17.1.2007, 20:52
Главный Новостник
Из: Омск
PATRON2002, Держи...
PATRON2002
сообщение 18.1.2007, 18:03
Из: Ростов-на-Дону
Глюк с отправкой смс! Поставил более мелкий шрифт..........И почемуто когда отправляешь смс,то получателю приходят только знаки припинания.Да и на родном ленге смс не отправляются. А латинские буквы доходят нормально.
*НеХеR*
сообщение 18.1.2007, 20:58
Пользователь №: 74 787
Прошивка: 2.3.4
PATRON2002,
Ну уже не раз писали по всему мотофану, в п2к тулзе, в "скрытых настройках" включи "юникод в смс" и все.. если что не ясно, то поищи по форуму.
go-blin
сообщение 22.1.2007, 17:40
Из: Башкирия,Октябрьский
Пользователь №: 48 665
Модель телефона: i900
Прошивка: WM6.5.3
Мне кажется, что тема переходит во флуд. Дайте патч, дайте ленг. Все необходимое для доводки находится в соответствующих темах. Пора чистить!
Ты сам то не флуди,твоё сообщение по твоему информативное? Не волнуйся,когда нужно почистим.
Сообщение отредактировал Bent - 23.1.2007, 7:05
RXLexus
сообщение 23.1.2007, 18:53
Пользователь №: 115 240
Прошивка: electro v0.3
Подскажите, как фойти в меню опкодов? Просто хочу восстановить утерянные вх-исх вызовы.. через опеод прочитал на форуме делается. Вот что пишут...
"Делается через опкоды 47 - 421(422) - 1- 0 - 2 - 255255 - перегруз."
Bent
сообщение 24.1.2007, 5:55
MoTo Marvellous
RXLexus, Войти так: Меню + 048263 + * или Меню + 0
Maxval
сообщение 25.1.2007, 18:03
Из: Perm
Пользователь №: 67 892
Модель телефона: E 398
Прошивка: MotoWalkman49R EM
I just done reversing both 46R and 49R elektro's MP with manually applied RSA patch ... I found that elektro really did something to the firmware CG1 area. I hope these files works on ROKR as it did on E398.
NOTE : these files might brick your phone since it was fully patched from the original elektro's MP manually. Both files do not contain a language pack. Please make a backup before flashing. Flash these at your own risk.
1) elektro's v0.3 46R for E1 with RSA patch (46R fullflash excluding LP)
2)elektro's v0.3 49R for E1 with RSA patch и еще одна ссыла
3) elektro's v0.3 flexlash (extracted from v0.3 49R) -> if you just want the flex.
All files are in .shx format and can be flash using any flasher software you have.
If these files are worthless (bricking the phone,etc), I will remove them as soon as possible.
regards
note : all credits should go to the MP makers for their passion on making such wonderful MPs. I am just trying to help others enjoying their work.
цитата aze2learn с motomodders
gadzellist
сообщение 27.1.2007, 20:26
Из: ростов-на-дону
Пользователь №: 111 586
Модель телефона: e 1
Прошивка: New Standart
поставил прошивку,и на некоторых ява приложениях на карте памяти стало писать что 'приложение истекло.проверьте дату и время в исходныхнастройках' что нужно сделать,чтобы заработало????
-mak-
сообщение 28.1.2007, 6:08
Из: Город-герой Волгоград
Пользователь №: 56 604
Модель телефона: qtek s200
regards
Сделана CG1 от электро портирована для оригинального РОКР Е1, написано, что тестовая версия, кто не боится - пусть пробует, шьется чем угодно. Прошивка не содержит лэнга
Если работает - сообщите
РАБОТАЕТ. Протестировано Don Omar. С неё можно слезть обратно стандартным монстром для Е1 (полным)
Сообщение отредактировал AlexKooper - 2.2.2007, 11:23
Neo31337
сообщение 1.2.2007, 19:20
Из: Зеон
Пользователь №: 115 765
Модель телефона: RokR E1 без ТП
Прошивка: Elektro 255 49R
Ждем тестов очень!!! На всяк случай скачайте ато вдруг им взбредет файл удалить...
czShaDoW
сообщение 7.2.2007, 21:29
Пользователь №: 117 034
Прошивка: Mpx_e398[Final]_49R
Помогите сделать с помощью опкодов на рокр е1 60 исх и вхд, заранее спасибо!
Valeo
сообщение 7.2.2007, 21:31
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Включение отображения 60 входящих/исходящих вызовов через опкод
60 Входящих
Bxoдим в мeню "Opcode"
жмем
Meню
затем 048263*
Bвoдим знaчeния:
Opcode "47" "OK"
Field 1 "80" "OK"
Field 2 "1" "OK"
Field 3 "143" "OK"
Field 4 "1" "OK"
Field 5 (D) "060" "OK" (понятно, что 060 - это 60 вызовов, можно 020 - будет 20 вызовов)
->Oтkaт: Field 5 (D) "010" "OK"
Results
F1 : 0 перезагрузка телефона
60 Исходящих
Opcode "47" "OK"
Field 1 "80" "OK"
Field 2 "1" "OK"
Field 3 "147" "OK"
Field 4 "1" "OK"
Results
Neo31337
сообщение 8.2.2007, 8:56
Из: Зеон
Все я поставил! все отлично работает даже СИГ ЭРРОР не дало! Смею заметить что у меня РокР Е1 без ТП! фонарик потестил. Скины мне не нравятся но я их заменю ДРМ тоже так себе надо бует доделать вид отправки сообщений тид итп. Мне лично нравяться с 2Pac Революшн Мода. Ждите постов от меня как потестю выдам результаты. Шиться мона без проблем, не забывая о бекапе.
Doktor Кот
сообщение 8.2.2007, 10:18
Из: Красноярск
Чет от Электро ничего не слышно и не видно! Кто нить знает, когда что нибудь новенькое Электро выдаст?
deadmoto
сообщение 8.2.2007, 13:35
Главный Новостник
Из: Омск
Doktor Кот, следующее скорее всего будет в т.ц. на V360.
X3MAL
сообщение 8.2.2007, 16:52
Из: Украина, Александрия
Пользователь №: 79 325
Модель телефона: MotoMing
Прошивка: Antarex Mod 14R
А при прошивке Е1 на него также можна будет патчи ставить?
Яуген
сообщение 8.2.2007, 17:04
Пользователь №: 101 871
X3MAL, он только для е398:)
Maxval
сообщение 8.2.2007, 19:06
Из: Perm
X3MAL,
можно, только скачай версию для е1
=BazOOka=
сообщение 9.2.2007, 21:21
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Кто-нить, дайте ссылки на 49r for rokr e1 без ленга, которые не с рапиды! Пожалста!
Наглый флуд.Ещё раз увижу подряд 8 сообщений об одном и том же, получишь моментальный БАН.
Bent, извиняюсь. Просто форум у меня вчера после отправки постов глючил, выкидывал куда-то. Вот я возвращался и отправлял опять. Просто не думал, что они отправились.
Сообщение отредактировал bazooka47 - 10.2.2007, 11:34
SANYO_K
сообщение 11.2.2007, 2:05
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
А на прошу для E1 со снятым RSA пробовали ставить DualBoot ??
Neo31337
сообщение 11.2.2007, 12:54
Из: Зеон
Так, потестил я этот мод для Е1. Вот те минусы что я заметил:
1. ДРМ не ахти можно было и получше
2. при поиске по справочнику постоянно включен Айтап и нет функции его вырубить
3. даже при входе джаву реклама сайта ЭЛЕКТРО
4. скины под оригинал виндовс ХР
5. значки при наведении на них курсора сильно терябют в качестве
6. гейн тейбл не хороший
7. синердж не пашет (ни тебе клавблока, ни контроля компресии фоток)
8. на клавишу камеры теперь монанастраивать что угодно а вот на реальную интелеектуальную клавишу настроенн голосовой набор и диктафон
Если кто знает как с этим всем разобраться пишите буду ждать!
Bent
сообщение 12.2.2007, 5:11
MoTo Marvellous
Neo31337,
2. Faq - Все Вопросы И Ответы По Шрифтам И Лэнгу
3. Убирается в DRM картинка №18
San3k
сообщение 14.2.2007, 7:01
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Подскажите что лучше сделать:
прошиться на електоромод 79р? (с сайта электро не качает FullSW with 1-click flasher, где еще можно скачать?)
или поставить рефлеш на мпх398 49р финал?
Текстовая версия Сейчас: 20.7.2025, 20:16
