23 страниц V « < 10 11 12 13 14 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Ratmagor
сообщение 14.2.2007, 21:48
Из: Мск
Пользователь №: 59 289
Модель телефона: Motorola Moto Maxx
Прошивка: KitKat
San3k,
Лучше прошиться модом от Электро на 49Р, а потом прошить всё, кроме CG1 от mpx398...
Лично мне показалось, что скорость работы на 79 ниже (причем ощутимо) чем на 49.
Тестов не проводил, ориентируюсь только на собственные ощущения..
San3k
сообщение 15.2.2007, 11:24
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Скачал elektro255mod v0.3 49R как его поставить? Нужно откатиться на свой бекап и шиться или как? Напишите плиз подробно...
Ratmagor
сообщение 15.2.2007, 11:46
Из: Мск
Прошивка: KitKat
Делаешь бэкап. Если до этого ставил 42 for all, то прошивай родной и потом шейся по мануалу от Sanyok_ минуя 42 for all, чтоб сохранить настройки аккума..
Motofan_is_cool
сообщение 19.2.2007, 17:28
Пользователь №: 78 792
Поставил v0.3 for 49R а глюк в SMS .Пишеш SMS все норм а отправляются только цифры и знаки препинания русские буквы не отправляются.
Как лечить?
Moto_Chip
сообщение 20.2.2007, 0:08
Пользователь №: 70 398
Модель телефона: E398->E1
Прошивка: R_373_49r + ИМХО...
Motofan_is_cool,
Включи Юникод в СМС сообщениях ! С помощью нпример П2К тулс
ROMANI89
сообщение 25.2.2007, 2:12
Из: новосибирск
Пользователь №: 106 535
Модель телефона: MOTOROLA E398
Прошивка: MOTOSYMBYAN 1.5 RC3
здравствуйте, у меня такой глюк, когда загружается мв 0,35 , когда он в фоне, при нажатии клавиши меню тел перезагружается. у меня такие догадки почему это происходит, я помянял сим 005b_0001 он был настроен так: принажатии на клавишу гарнитуры срабатывало действие джойстик вверх, а при входящем вызове поднимал трубку. еще я поставил мв 0,35 .когда в мв не запущен плагин информаор все нормально.. так же заменил скины. вроде больше ничего не менял.что может быть? еслив это глюк сима, то выложите пожалуйста этот сим оригинальный .
OsVal
сообщение 28.2.2007, 7:31
Из: г. Орск
Пользователь №: 58 961
Модель телефона: Моторола E-398 -> E1
Прошивка: R373_G_0E.30.79R
Неделю с небольшим назад поставил монстра V0.3 79R Final mod. Шрифт для меня мелковат, поэтому прошил лэнг со стандартным шрифтом и соответственно заменил скины. Пока все работает нормально, по крайней мере те функции, что я использую: звонки, интернет, медиа, фото, видео. Стоит MV v. 1.0 с плагинами инструменты книги, SMS@sender, диктофон, funlight, читалка, погода, senergy, midletlist, filechanger, soundeditir. Все работают нормально. SMS не бэкапит, но возможно из-за названия телефона, вроде бы ему надо дать определенное имя, а какое, я забыл и искать лень. Минусов нашел пока только два: не видит из соответствующего меню и не ставит на звонок файлы аас (.m4a) - для меня несущественно, и батарея, которая на 49R держала 2-е суток, сейчас не тянет при той же нагрузке и одного дня - это напрягает. И после недельной дрессировки батареи пока не вижу существенных улучшений. Еще с недельку потерплю, если батарея так и будет держать меньше суток, откачусь обратно на v0.3 for 49R. Для меня двухдневная батарея предпочтительнее безлимитного видео, которое еще неизвестно, понадобится ли. rolleyes.gif
OsVal
сообщение 1.3.2007, 11:53
Из: г. Орск
01.03.07 Обнаружился еще один глюк - при соединении с компом по блютусу не хочет включаться служба FTP, хотя между телефонами файлы передаются без проблем. В то же время служба диал-ап работает нормально и с инетом вполне можно работать. У кого-нибудь еще есть такое.
ЗЫ. Вечером попробую соединить с другим компом для контроля.
OsVal
сообщение 2.3.2007, 8:26
Из: г. Орск
Проверил на другом компе, также по блютусу не хочет включаться служба FTP. Откатился на 49R, БТ заработал нормально.
DED_MOPO3
сообщение 3.3.2007, 10:16
Из: Земля-Россия-Воронеж--РОССОШЬ
Пользователь №: 115 566
Модель телефона: N73 me
Прошивка: V 4.0745.2.0.1RM 133
Дайте пожалуйста другую ссылку на скачку 79r , а то на сайте электро255 глюк какой - то!!! sad.gif
juk_jeka
сообщение 17.3.2007, 8:18
Из: украина
Пользователь №: 120 530
Прошивка: R373_G_OE.30.49R
как можна сделать на 398 моторе штоб играть по бт
deadmoto
сообщение 17.3.2007, 8:38
Главный Новостник
Из: Омск
Пользователь №: 49 284
Прошивка: Motorola Original
juk_jeka, НЕЛЬЗЯ, доступ к БТ из явы есть только на L7\V360
Сколько раз уже обсуждалось...
И вообще зайди сюда
X3MAL
сообщение 17.3.2007, 23:16
Из: Украина, Александрия
Пользователь №: 79 325
Модель телефона: MotoMing
Прошивка: Antarex Mod 14R
оффтоп:
смотреть на сайте электро.
Trentemoller
сообщение 17.3.2007, 23:24
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Переведите все описание 4 мода на Русский плз, с английским слабовато, да и через промт ничего конкретно непонятно!
Сообщение отредактировал Trentemoller - 17.3.2007, 23:26
Vadim Velikii
сообщение 18.3.2007, 1:11
Пользователь №: 102 604
Модель телефона: ROKR_E398, v360, v8
Прошивка: 49E.m.
По пожеланиям общественности перевёл, как смог, благо с английским у меня более-менее нормально:
Я вернулся после длительного перерыва smile.gif Новый мод будет завтра, сейчас я выложу лишь изменения и скриншоты.
Изменения мода 0,4альфа-версии:
- Мод сделан на 79й (но батарея держит столько же, сколько и 49я, и стоит ускоритель ядра(?) ОС(?) от Vilko).
- добавлены планировщик стилей звонка ( можно менять мелодии/фанлайт на выбранное время и день недели
- настройки мода и информация об ОС теперь доступны из меню(не нужно загружать для этого яву)
- работают стандартные комбинации клавиш(*#06# и *#9999#)
- новые ява-методы(SoftReset, PlayTone, StartFunlight, AudSetVolumeSetting, PlayAlert, GetRAMAddress).
- звук разряда батареи может находиться в зависимости от стиля звонка, может быть вибрацией, или отключён.
- теперь все настройки хранятся в файле ( \a\set.bin - файл настроек, \a\srs.bin файл планировщика[лёгкий доступ к PC, Java and phone menu])
- no more Java permissions(полномочия), corelet signs and certificates !
- автоматический вход в меню без сим-карты(экстренный вызов работает тоже)
- нет адреса в бутскрине
- и, конечно, автоблок клавы и фонарик
Перевод с английского - (с) Vadim Velikii
Английская версия:
I'm back after very long break smile.gif New mod will be tomorrow, for now I publish only changes list and some screenshots:
New mod V0.4a changes :
mod based on 79R (but battery life like 49R, and faster OS core by Vilko)
added Scheduled Ring Styles (can change ringtones/funlights on given time and week day [up to 36 changes per weak])
mod settings and some OS info now is accessible on menu (you don't need java app)
working original shortcuts (*#06# and *#9999#)
new Java methods (SoftReset, PlayTone, StartFunlight, AudSetVolumeSetting, PlayAlert, GetRAMAddress)
low batt sound can depend on ring style, can be vibe, beep or turned off
now all settings are stored on files ( \a\set.bin - settings file, \a\srs.bin schedule file [easy access from PC, Java and phone menu])
no more Java permissions, corelet signs and certificates !
automatic menu enter on key press if no sim card (emergency call working too)
of course keypad autolock and flashlight
Сообщение отредактировал Vadim Velikii - 18.3.2007, 15:17
Яуген
сообщение 18.3.2007, 6:35
Пользователь №: 101 871
Vadim Velikii, я ссылочка уже есть на этот мод?
elektro255
сообщение 18.3.2007, 9:37
Из: Poland, Siedlce
Trentemoller
сообщение 18.3.2007, 10:03
Из: Армавир
Я котегорически небуду переходить на нее с 49r v0.2 из-за тупости, качества звука, нехватки нужных мне патчей и т.д.
Сообщение отредактировал Trentemoller - 18.3.2007, 13:52
igorrius
сообщение 18.3.2007, 11:45
Пользователь №: 56 062
Прошивка: 49r
1 пытаюсьпоменять звуки в монстре на 49 электро 02...не получается, мне хотя б пиликанье убрать при
регулировке громкости, реально ли это сделать?
2 можно ли сделать так, чтобы не загоралась подсветка при изменения набора при наборе смс при нажатиях диеза?
Добавлено позже (18.3.2007, 15:46):
elektro255
сообщение 18.3.2007, 13:00
Из: Poland, Siedlce
Trentemoller, какое патчи ты нуждаешься ?
=BazOOka=
сообщение 18.3.2007, 13:07
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
electro255, I agree with Trentemoller about sound (and maybe about patches).
Please, make your new Mod on 49R.
Халдей
сообщение 18.3.2007, 18:02
Пользователь №: 42 573
Модель телефона: mpx220
Прошивка: 351 sp2
Хм, Электро написал вчера что выложит завтра, но пока не видать обновки
deadmoto
сообщение 18.3.2007, 18:09
Главный Новостник
Из: Омск
bazooka47, возможно мод на 49 и будет но позже))) а пока ещё мы это не увидели)))
Сообщение отредактировал deadmoto - 18.3.2007, 18:10
=BazOOka=
сообщение 18.3.2007, 18:10
Прошивка: 4AP
Vadim Velikii
сообщение 18.3.2007, 22:31
Прошивка: 49E.m.
Мод 0.4а выложен на сайте Электро.
Ссылка появилась только что!
Сообщение отредактировал Vadim Velikii - 18.3.2007, 22:46
ORA
сообщение 18.3.2007, 23:32
Из: Ижевск
Пользователь №: 91 715
Прошивка: R373_0.2b(49R)
Trentemoller
сообщение 19.3.2007, 10:17
Из: Армавир
Кто поставил отпишитесь плиз, какие изменения, что и как работает!?
ToJlcTblu
сообщение 19.3.2007, 10:28
Из: Краснодарский край г.Лабинск
Пользователь №: 105 576
Прошивка: R373_EM3_49R
Заметил пока одну штуку - при разрыве GPRS сессии телефон уходит в ребут.
А функция со сменой стилей по времени работает идеально
Сообщение отредактировал ToJlcTblu - 19.3.2007, 10:35
CrEa5eD
сообщение 19.3.2007, 10:39
Из: Беларусь, Минск
Пользователь №: 89 605
Модель телефона: W218,E398,E398
Прошивка: 0.5.79.K2, DAR 1.3
Ждёмс 49R!!!
Ктулху
сообщение 19.3.2007, 12:17
Moto К†улху
Из: Свердловская область
Пользователь №: 26 696
Модель телефона: Motorola Dyna-Tac
с разрешения semenigor сделал зеркала для тех кто нелюбит рапиду
elektro255,
please add this mirrors on your site, and after you may kill this post!
ifolder.ru slil.ru megaupload.com
ApxuBatop
сообщение 19.3.2007, 14:06
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
Trentemoller,
Звук на 79R такой же, как и на 49R, просто надо адаптировать param_table.bin и все. Патчи... хм, о каких патчах идет речь? Каких патчей нет для 79R? Уже давно все есть, даже больше, чем для 49R той же. tongue.gif
elektro255
сообщение 19.3.2007, 14:13
Из: Poland, Siedlce
не будет 49R, теперь только я буду заниматься 79R (звук дастся сделать)
Side
сообщение 19.3.2007, 15:10
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
Хотел узнать, удалось ли побороть в этом моде стандартные проблемы 79 прошивки, которые происходят при звуке клавиатуры установленном в 0, на любом стиле звонка:
1)В фотокамере не сразу появляется кнопка снять, надо что-нибуть нажать.
2)Глюк при прослушивании мелодий (то играет то не играет).
Пишите о результах, как скорость, ToJlcTblu писал о проблемах при завершении GPRS сессии, у всех так? Стоит эту прошивку ставить или лучше подождать хотя-бы beta?
Вопрос к электро255: В будущем можно будет обновить этот мод до Beta и Final без полной перепрошивки (только reflash)
To elektro255: Do it possible to update this mod (in future) to Beta and Final without fullflash (only reflash)?
Nogay
сообщение 19.3.2007, 15:20
Из: Фёдоровка, Сургутский район
Пользователь №: 83 007
Прошивка: Mpx398 De Luxe
elektro255, сделай пожалуйста на 49R.
=BazOOka=
сообщение 19.3.2007, 15:22
Прошивка: 4AP
QUOTE(elektro255 @ 19.3.2007, 17:13) *
49R is using more people then 79R! Just look at this. It was the poll "Which firmware do you use?"
Please, do your Mod V0.4 on 49R. I ask it not for me only. I ask it for many people who have got e398/e1.
Сообщение отредактировал bazooka47 - 19.3.2007, 15:33
Trentemoller
сообщение 19.3.2007, 15:23
Из: Армавир
ApxuBatop,
Если допустим я выдерну свои gain и param table с 49r и залью их на 79r, останится ли звук прежним или изменится!? Патчи может быть и есть, но искать их опять же долго, дорабатывать самому. Еще очень нехочу ставить из-за глюков, перечисленные Side`ром.
Сообщение отредактировал Trentemoller - 19.3.2007, 15:25
=BazOOka=
сообщение 19.3.2007, 15:29
Прошивка: 4AP
Цитата(Trentemoller @ 19.3.2007, 18:23) *
ApxuBatop,
Могут быть и глюки, а может нормально влезть.
Nogay
Trentemoller, если ты поставишь gain и param от 49R на 79R, то звук будет не очень, т.е. не будет такого звука как на 49R.
ToJlcTblu
сообщение 19.3.2007, 15:57
Пробовал ставить патчи но ничего ощутимого не происходит. Все остается как и было! По-моему, этот мод вообще патчиться не хочет. Или я неправ?
Сообщение отредактировал ToJlcTblu - 19.3.2007, 21:42
ApxuBatop
сообщение 19.3.2007, 16:05
Мото-Художник
Прошивка: от Е398
Цитата(Trentemoller @ Сегодня, 18:23)
ApxuBatop,
Просто адаптируй param_table.bin с помощью Motosound : Звук На Любую Motorola =) а gain_table.bin не трогай.
elektro255,
It's great! Maybe interface is not so good, but firmware changes are excelent.
I advice you to look thought this topic: Переключаем Скоростя в Телефоне на Повышенные ! Motospeed , here Osta discovered, that in DRM is located timings table that allow us to speed our phone. smile.gif
I made patch for DRM for 0.4a...
Прикрепленный файл electro255_0.4a_optimum_speed_by_ApxuBatop.rar   ( 446 байт ) Кол-во скачиваний: 387
And i see, that video playback is rather faster, than in previous versions and firmwares... clap.gif
Короче, народ, вот патч для уменьшения таймингов телефона для ускорения передвижения по меню
и звуковой патч MegaBass...
Прикрепленный файл electro255_0.4a_MegaBass_by_ApxuBatop.rar   ( 33.5 килобайт ) Кол-во скачиваний: 355
Как включить wav звуковое оформление читаем тут: Все о телефоне Motorola E398 (6.1 Озвучка клавиш)
В этой прошивке видео воспроизводит гораздо быстрее и без тормозов идет Simple @L3 в скрипте ... Рекомендую! smile.gif
Сообщение отредактировал ApxuBatop - 19.3.2007, 17:47
Текстовая версия Сейчас: 20.7.2025, 16:35
