23 страниц V « < 14 15 16 17 18 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
yurybol
сообщение 9.4.2007, 7:26
Из: Ростовская область.
Пользователь №: 12 235
Прошивка: Надеюсь поменять
У меня проблема такого плана:
Я использую телефон в связке блютус-gprs-комп. Через какое-то время после подключения связь автоматически обрывается. Этот эффект наблюдается и на 1 и на 2 альфе.
Как решить данную проблему?
Trentemoller
сообщение 9.4.2007, 8:20
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Цитата(Timik @ Сегодня, 8:14)
Добавлено позже (9.4.2007, 8:19):
Trentemoller, твои патчи точно подходят?
В каком смысле точно подходят? Я попросил elektro, чтобы он их портировал с 49r на 44r!
SharkExE
сообщение 9.4.2007, 8:22
Из: Пермь
Пользователь №: 46 933
Модель телефона: SE w810i
Прошивка: R4DB005
yurybol,
у всех такая проблема, хотя это даже не проблема, а фитча мотороловских телефонов. Через пять минут после последней активности сети GPRS тел обрывает связь.
AlexKooper
сообщение 9.4.2007, 8:46
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
SharkExE, так вроде в нетмониторе настройка есть gprsautodettach или как-то так...
Бес
сообщение 9.4.2007, 9:10
Оптимист
Из: Омск
Пользователь №: 92 409
Цитата(Trentemoller @ Сегодня, 3:24)
мультиструктура меню
это, наверное, то что обещал elektro255 - каждому скину свой файл мма_уцп!!!
V0.4a changes :
On develop are (maybe available on beta version):
multiple menu structures (you can add to each skin mma_ucp/dcp file, if file not exists skin will use original mma)
Timik
сообщение 9.4.2007, 9:13
Пользователь №: 100 902
Прошивка: даже не знаю теперь
А, ну тогда все нормально
волкOFF
сообщение 9.4.2007, 10:12
Из: Нижний Новгород
Пользователь №: 118 524
Модель телефона: E-398
Прошивка: Moto-Symbian RC3
а как поменять язык? когда захожу в настройки дальше в Lenguage телефон вылетает в меню!!! че делать? sad.gif
Timik
сообщение 9.4.2007, 10:13
кто-нибудь, скажите что нужно чтоб iTap был нормальный?
San3k
сообщение 9.4.2007, 10:25
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
elektro255, how I can change display timeout to 60 or 120 seconds? There is 1 min and 2 min in settings. If I select 1 min, display timeout will be 20 sec; if I select 2 min, timeout will be 40 sec.
sorry for my bad english
elektro255
сообщение 9.4.2007, 10:31
Из: Poland, Siedlce
San3k, SEEM 0032 byte 0x75 bit 5 set to 0 , 1min-20sek 2-40 5-60 10-120sek
Сообщение отредактировал elektro255 - 9.4.2007, 10:34
Trentemoller
сообщение 9.4.2007, 10:51
Из: Армавир
Все таки останусь я пока на 49r 0.2 моде, из-за нехватки патчей, разнообразных вышенаписанных глюков!
=BazOOka=
сообщение 9.4.2007, 11:18
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Для тех кто в танке. Насчет патчей:
Don't use Java plugins from old mods, and don't apply any patches, if you need any patch send e-mail.
"Не используйте ява-плагины со старых модов и не применяйте никаких патчей! Если вам нужен какой-либо патч, пошлите мне е-mail". Это вызвано тем, тчо это не 44R а MIX (смесь), названная так для совместимости с прогами)
"Мультиструктура меню" - у каждого скина - свой mma_ucp.
linxun
сообщение 9.4.2007, 11:39
Пользователь №: 108 892
Модель телефона: MOTO V3I
Прошивка: R47A_G_08_D9.3DR
[R373...4xR mod 3 Electro255]
Electro255=00843F50
Trentemoller
сообщение 9.4.2007, 11:45
Из: Армавир
=BazOOka=,
Я выложил в предыдущем своем посте самый нужный список патчей с 49r, их там штук 10 + самые последние. Выложил для того, чтобы elektro портировал их на свой mix, но ответа так и недождался!
linxun,
Вышла версия 0.4 от electro, половину патчей стоит, что выложил я! Впринципе неплохо, но для меня самый главный патч, это установка скинов на диск /a/. Народ, можно ли это реализовать на 0.4 моде?
Сообщение отредактировал Trentemoller - 9.4.2007, 12:08
kemre
сообщение 9.4.2007, 11:58
Пользователь №: 121 096
Прошивка: LP 49R
0.4 alpha 4 доступна с сайта электры!!!!
~Gangs2er~
сообщение 9.4.2007, 12:06
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Просьба: потестить, работает ли интернет в опере.
Side
сообщение 9.4.2007, 12:25
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
Этот патч на любой прошивке очень легко реализовать. Всего-то найти c/mobile/skins и заменить на a/mobile/skins. Прочитай тему про этот патч, там все очень подробно написано.
~Gangs2er~
сообщение 9.4.2007, 12:33
MotoSkinner
И еще вопрос, откуда беретсю mma ucp для каждого скина?
Electro255, возможно сделать чтобы mma брался из папки скина?
elektro255
сообщение 9.4.2007, 12:41
Из: Poland, Siedlce
no mma_ucp must be in /a/mobile/system
#нет mma_ucp будет вынужден быть в /a/mobile/system
nekr
сообщение 9.4.2007, 13:12
Пользователь №: 103 477
Прошивка: от всего по маленьку
язык меню не меняется, хотя может зависит от ленга? itap русский работает
браузер встроенный работает нормально
по скорости работы напоминает симбу
Сообщение отредактировал nekr - 9.4.2007, 13:12
X3MAL
сообщение 9.4.2007, 13:16
Из: Украина, Александрия
Пользователь №: 79 325
Модель телефона: MotoMing
Прошивка: Antarex Mod 14R
elektro255, что еще намереваешься исправить (добавить) в прошивку для Е398? И на счет мма_уцп подробнее можно, не понятно все-таки где они должны быть.
*DamneD*
сообщение 9.4.2007, 13:19
Из: Ставрополь
Пользователь №: 119 517
Модель телефона: Alcatel OT-990
А может кто нить сольет со своего тела бэкап после всех этих модификаций? а то чет качать сначала один потом другой, потом третий мод накладно. Заранее спасибо!
elektro255
сообщение 9.4.2007, 13:23
Из: Poland, Siedlce
*DamneD*, ты можешь сразу употребить updater.exe dal v0.4a4, на любом 4xR монстыре
X3MAL, пока что кончается мне перерыв праздничный smile.gif итак пока что то последняя версия, недолго я сделаю патчи для BT file send i lock/unlock keypad shortcut change, потом я сделаю программу к смене надписей в моём меню
Сообщение отредактировал elektro255 - 9.4.2007, 13:28
deadmoto
сообщение 9.4.2007, 13:24
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
elektro255, what do you think about:
-change 'repeat' function in std player when in backround to 'forward'
-change memory capacity for Java applets, like in L7e (1100kb heap)
Is it possible?
elektro255
сообщение 9.4.2007, 13:30
Из: Poland, Siedlce
Is it possible?
firs is possible maybe later i will add this, second is not possible e398 don't have more memory
spliter
сообщение 9.4.2007, 14:03
Пользователь №: 87 903
Прошивка: 49R
плз, люди выложите бэкап последней версии этой прошивки, а то там стоко файлов, а качать все проблема...
Slavasiv
сообщение 9.4.2007, 14:11
Пользователь №: 109 157
Прошивка: Elektro
elektro255 Gif Bug
Анимация на твоём последнем Mode сильно тормозит исправь пожалуйста
Добавлено позже (9.4.2007, 18:21):
Видео бесконесное не пишет на моде о.4 альфе4 максимум у меня 2,5 минуты
=BazOOka=
сообщение 9.4.2007, 14:48
Прошивка: 4AP
elektro255, on your Alpha4 0.4 animation is too slowly sad.gif Can you fix it?
And Slavasiv found bug with video-recording. He writes that it is limited by 2.5 minutes.
San3k
сообщение 9.4.2007, 15:02
elektro255 писал же, что можно скачать последнюю альфу и поставить ее на любой монстр 4xR
elektro255
сообщение 9.4.2007, 15:08
Из: Poland, Siedlce
on my phone video recording is unlimited try another flex or 004E SEEM and animation speed depend on DRM speed table smile.gif (use this tool: http://www.e398mod.com/content/view/482/28/ ), or wait for somebody who will made full monster on my software
Prometeius
сообщение 9.4.2007, 15:11
Пользователь №: 121 989
Модель телефона: V360
Прошивка: ACR
elektro255,
Whether it is possible to update(patch) 0,4a3 up to 0,4a4 without downloading of last version, and simply to replace a piece of a code?
~Gangs2er~
MotoSkinner
Electro255, ты не совсем понял меня, я имел ввиду не основной mma, а для каждого скина куда его ложить? В папку со скином?
и еще вопрос, в инет через оперу заходит?
=BazOOka=
сообщение 9.4.2007, 15:13
Прошивка: 4AP
QUOTE(elektro255 @ Today, 19:08)
Could you attach yor 004E SEEM, please?
San3k
сообщение 9.4.2007, 15:17
нужно положить mma_ucp0 в /a/mobile/system для скина который первый в настройках облочки
для второго в списке нужно положить туда же mma_ucp1 и т.д. Понял?
Trentemoller
Из: Армавир
elektro255,
Я так понял, первый будет патч для передачи ява через мультимедиа, а второй на автоматическую блокировку клавиатуры!? unsure.gif
I so have understood, 1 patch for transfer java through multimedia, and 2 on automatic blocking of the keyboard!?
И пожалуйста сделай что нибудь с анимацией, уж больно сильно она тормозит! smile.gif
And please make what that with анимацией, she is sick strongly brakes!:)
Сообщение отредактировал Trentemoller - 9.4.2007, 15:27
Jumperrr
сообщение 9.4.2007, 15:23
Пользователь №: 91 740
Модель телефона: E398 => Е1 iTunes
Прошивка: R373.....ххR
Супер!!! clap.gif У меня нету слов!!! Как хорошо что с нами electro smile.gif
yurybol
сообщение 9.4.2007, 15:26
SharkExE, я немного не понял. То есть разрыв идет если активности нет? Так?
А если подключен mIRC клиент и идет постоянная связь/активность то разрыв быть не должен?
У меня как раз-таки разрывается при АКТИВНОЙ связи. sad.gif Обидно
ЗЫ. На других прошивках такого нету, только на 1 и 2 альфах
Сообщение отредактировал yurybol - 9.4.2007, 15:29
Beaumont
сообщение 9.4.2007, 15:39
Миротворец
Из: г. Москва
Пользователь №: 39 110
Прошивка: R373_G_0E.30.79R
Вопрос: работает ли ритм-подсветка? И какие значения можно установить в выборе времени?
Да, и ещё, кто-нибудь ставил на флекс от 1.5 симбы?
Сообщение отредактировал Beaumont - 9.4.2007, 15:55
San3k
сообщение 9.4.2007, 15:42
У меня видео анлим...
=BazOOka=
сообщение 9.4.2007, 15:47
Прошивка: 4AP
Видео:elektro255 уже написал, что если анлимитное видео не работает, то пробуйте другой флекс или 004E SEEM!
Текстовая версия Сейчас: 20.7.2025, 0:36
