20 страниц V « < 5 6 7 8 9 > »
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр
sidr
сообщение 22.6.2014, 13:11 Закрепленное сообщение!
Из: Бреста
Пользователь №: 168 840
Moto E (XT1021, XT1022, XT1025)
Техническое описание
Operating system - Android™ 4.4, KitKat®
Processor - Qualcomm® Snapdragon™ 200 with 1.2GHz dual-core A7 CPU
Adreno 302 400MHz single-core GPU
Capacity - 4GB standard MicroSD slot supports up to 32GB expandable memory 1GB RAM
Dimensions and weight - Height: 124.8mm
Width: 64.8mm
Depth: 12.3mm
Weight: 142g
Display - 4.3 inches 540 x 960 qHD, 256ppi Features anti-smudge coating and Corning Gorilla Glass 3
Connectivity - MicroUSB, supports USB 2.0 3.5 mm headset jack Micro SIM
Battery - Built-in rechargeable lithium-ion, 1980mAh Mixed usage up to 24 hours
Rear camera - 5 MP
Networks - US GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
Requires a microSIM card (not included)
Global GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
CDMA Model Coming Soon!
CDMA/EVDO Rev A (850, 1900 MHz)
Bluetooth® Technology - Version 4.0 LE
Wi-Fi - 802.11 b/g/n, 2.4GHz
Фото MOTO E
Видео
[video]https://www.youtube.com/watch?v=Cs6tV1Di3-8[/video]
Видео Moto E vs Moto G
[video]https://www.youtube.com/watch?v=rVKQJp21r9Q[/video]
ОФ прошивки для MOTO E
Инструкция по прошивки с hda
a) Download and install Motorola Moto EDrivers
b) Download and extract the stock Firmware of your choosing
c) If the firmware file you downloaded is a .xml.zip file then download Motorola Fastboot Attachment 2427667 (attached to this post) and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files). If your firmware is a .tar.gz file then skip this step.
d) Get ADB (if you don't already have this, I suggest downloading and installing Minimal ADB and Fastboot by shimp208:
Direct Download
Disclaimer:
Follow these instructions at your own risk. If something goes wrong don't blame me!
These are the original stock signed image files from Motorola it should work on all Moto E Variants.
Steps to restore stock firmware:
1) Reboot the phone into bootloader mode. There are 2 ways to do this.
I) The 'hardware' way.
a) Unplug the USB cable and power off the phone.
b) Press and hold 'Volume down' then power on the phone.
c) Connect USB cable to your computer.
II) The 'software' way.
a) Enable developer mode on the Moto E (Settings-> 'About Phone'. Tap 7 times on 'Build Number')
b) Enable USB debugging. (Settings -> 'Developer options' -> 'USB Debugging' -> check)
c) Connect phone to computer via USB, you should see a new ADB device detected and drivers installed.
d) Open "Minimal ADB and Fastboot". Type:
Code:
adb reboot-bootloader
You should see the Moto E bootloader screen with the following options:
Code:
Normal Powerup
Recovery
Factory
Switch Console [NULL: null]
Barcodes
BP Tools
2) Open a command prompt / terminal (Start -> cmd.exe in Win7) and browse to the folder with the extracted firmware.
In my case:
Code:
cd c:\falcon_retgb_user_4.3_14.10.0Q3.X-76-LGG-8_54_release-keys-cid7-Retail_GB
3)
Flash each of the partitions in sequence using mfastboot, you need to enter the following commands one-by-one checking that each one returns an [OKAY]
Code:
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
Downgrading:
4) Wait, you should now be rebooted into a fully stock Moto E firmware.
Драйвера
Где купить:
EBAY
AMAZON
Фото разобранного телефона
Сообщение отредактировал Воха - 20.12.2015, 19:28
BeePlus
сообщение 20.7.2014, 7:57
Из: Харьков
Пользователь №: 168 992
VE66 :)
сообщение 20.7.2014, 15:42
BeePlus,
зачем ешку разбирал? Шото случилось или так спортивный интерес?
tuco
сообщение 20.7.2014, 16:05
Из: киров
Пользователь №: 220 793
Модель телефона: pixel 6a
30 баксов с телефона стоимостью 120? спасибо. в хендтеке он 4500 без доставки
сообщение 20.7.2014, 16:58
tuco,
ну на хендетке односимчный вариант, а тут двух.
BeePlus
сообщение 21.7.2014, 9:06
Из: Харьков
VE66 :)
Цитата(stigr @ 20.7.2014, 18:42) *
BeePlus,
Нет нигде фоток разобранного дуоса, вот и заполнил нишу.
Самому всегда интересно что и как (и тепер понимаю как его герметичным полностью сделать, хотя действительно он дождя защищен.
сообщение 21.7.2014, 9:56
BeePlus,
а случайно, фотки процесса разборки не делал?
Цитата(BeePlus @ Сегодня, 12:06)
* и тепер понимаю как его герметичным полностью сделать
ну и нам расскажи))
BeePlus
сообщение 22.7.2014, 21:10
Из: Харьков
VE66 :)
А что рассказывать ? Если крышка не люфтит, то можно вообще не париться. А так скотчем (наверное изолентой) залепить сзади прорези под аккум и вибрик ...
Со стороны 3.5 и USB стоит резина по периметру.
Сами панельки (верх и низ) с 2х бортиков и даже нет смысла между ними (было желание) прокладывать полоску резинки.
Короче, почти герметичен он. Уже столько раз пивом заливал, для демонстрации. grin.gif
captan2
сообщение 26.7.2014, 15:06
Из: Воронежская область
Пользователь №: 163 860
Модель телефона: z3 - xt5 - E - G3
Народ, выручайте. Сегодня прилетел в Рим, нашёл магазин с Моторолой. Там были 4 модели. Одна вылитая Е за которой я и пришёл, но на этикетке написано MOTO ME4K. в описании написано что это вообще MotoG. Спросил, весьма не приветливую продавщицу про Е. Она говорит вот Джи. А Е нету. Попробовал поиск в гугле. Пусто. Но по внешнему виду это Е, его двумя колонками. Что делать?
сообщение 26.7.2014, 15:31
captan2,
включи тел и посмотри название в настройках.
captan2
сообщение 26.7.2014, 15:53
Без знания языка и с приветливостью той мадам, я буду долго это делать))) поищу другой филиал этой сети, может там будет проще завтра)))
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр · Motorola на Android OS · Forum
Текстовая версия Сейчас: 26.4.2024, 10:02
