18 страниц V < 1 2 3 4 5 > »
[MP] Freedom 7FR [MPKGBOX + QVGA], новый монстр!
OCM770
сообщение 9.6.2009, 16:16 Закрепленное сообщение!
Пользователь №: 196 171
Freedom 7FR
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, looking forward to working with you again Carlos wink.gif
Second I would like to thank tankrider, Skrilax_CZ and NestorM for clearing up some doubts I had and giving me suggestions for this MP.
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys biggrin.gif. Motofan as well for having awesome developers wink.gif
Благодарности:
За этот МодПак я особо рад сказать спасибо моему другу Kidscracker, за помощь мне с разными вещами, возвращение меня в проект, и конечно за разработку Mpkgbox. Расчитываю посотрудничать с тобой ещё, Карлос wink.gif
Второе: хочу поблагодарить tankrider, Skrilax_CZ и NestorM за то, что развеяли мои сомнения и за пожелания к моду.
Далее я хотел бы сказать спасибо сетевым сообществам моддеров Motorola, особенно ModMyMoto, которое меня взрастило, и MMUS, которое приняло меня в свои ряды. Оба сообщества очень дружелюбны и полезны, такими и будьте, ребята. Также и Motofan за выдающихся разработчиков.wink.gif
Change log:
This MP was originally based on R6637_G_81.11.2CR and it had a patched kernel that enabled swap, among some other features that are really only cosmetic. I decided to base this on R6637_G_81.00.7FR after it was discovered that it could record in QVGA. 7FR Camera libs won’t work on 2CR and while trying to make them work I ended up with a huge mess and other things started breaking. So I decided to base it on 7FR, unfortunately however, The custom kernel from 2CR will not run 100% well with 7FR, if it is flashed this way the wifi stops working. So I made a came to the conclusion QVGA was more important than a custom kernel with swap, therefore this firmware does NOT have SWAP capability. Im sure you guys will understand. If someone can get there hands on 7FR Source code please let me know so I can patch the kernel as this source is not available on Motorola’s site due to 7FR being a developers release.
История изменений:
МП изначально основывался на прошивке R6637_G_81.11.2CR с патченным ядром, включающим подкачку, а среди других изменений были в основном только косметические. Я решил перейти на R6637_G_81.00.7FR после того, как обнаружил, что в ней доступна запись видео в QVGA. Библиотеки (либы) камеры от 7FR не подходили для 2CR и в попытках заставить их работать я наломал немало дров, а точнее, работоспособного до того софта. Так что базовой стала 7FR, и, к сожалению, от самодельного ядра 2CR пришлось отказаться - на 100% с 7FR совместимым оно не было, после прошивки с ним отказывался работать wi-fi. Я решил, что запись видео в QVGA намного важнее, чем и ядро, и подкачка, поэтому эта прошивка БЕЗ функции СВОПА. Уверен, вы меня поймёте. А если у кого руки дойдут, и будут исходники 7FR, дайте мне знать - пропатчим ядро, а то так-то код недоступен на сайте Моторолы, ибо 7FR - релиз для разработчиков.
скрыть.
CG36 Mods:
  • MPKGBOX
  • QVGA Recording
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Custom Bootscreen
  • Skins: Alkali, Kodak, Indium, Tuscan (Alkali is not present in 062A version)
Instructions (инструкция как шить)
  1. Use RSD Lite 4.x for all flashing - используем RSD версии 4.x для прошивки
  2. Flash noRSA bootloader that corresponds to your bootloader - сначала прошиваем бут noRSA
  3. Flash the version of Freedom 7FR that corresponds to your bootloader - прошиваем сответствующую версию прошивки для вашего бута (для 062А -062A Version 1a и т.д.)
  4. Flash Update 1B corresponding to your bootloader - прошиваем обновление (для 062A бута - Update 1B 062A)
  5. Прошиваем русский ленг отсюда: ЛЕНГПАКИ ДЛЯ ZN5
Download Link:This MP does NOT have the lost calls after reboot bug
Это делает MP не имеют потерянных вызовов после перезагрузки ошибка
Сообщение отредактировал AstaRoth - 30.6.2009, 16:05
kidscracker
сообщение 11.6.2009, 3:01
Пользователь №: 189 546
Модель телефона: MotoZine ZN5
Прошивка: Symbiosis III 1.1
Хорошо то, что я забыл упомянуть о том, что время для этого, Mpkgbox только на английском языке, но мы исправим это в следующей версии. Я приношу извинения за это.
Еще одно важное замечание, для тех лиц, которые имели проблемы с некоторыми MGX (CPU Speed, перезагрузка и т.д.) он, причиненный ошибкой в реестре в Mpkgbox. О Mgx, установленных в память телефона, которая не запускать, он был вызван medld.conf, что не хватает.
В новой модификации, которые мы в настоящее время испытания этого были исправлены, так что теперь без medld.conf вы запустите Mgx из Phonw памяти, а также Mp3 Мелодия устанавливается. Будьте терпеливы, и спасибо за отзыв.
С уважением
OCM770
сообщение 11.6.2009, 3:07
Версия 1a может запустить mpkgbox корни, которые требуют разрешенияsmile.gif
OCM770
сообщение 11.6.2009, 3:47
Im working on a second patch, now you can use ringtones fine but im looking for more bugs just in case wink.gif
Im работает над второй патч, теперь вы можете использовать рингтоны штрафом, но им искать более ошибок на всякий случайwink.gif
D-1c3
сообщение 11.6.2009, 7:18
Пользователь №: 150 086
Прошивка: свежая
Пожелания на будущее создателям монстра smile.gif :
1. Человеческий UserMenuTree. Я думаю MpkgBox нужно убрать из главного меню в органайзер или в мультимедию например
2. Чтоб при входе в меню курсор был на средней иконке
3. Бесконечное обнаружение бт
4. Увеличенные часы на рабочем столе (эт не обязательно канеш shuffle.gif ) хотяб в скине Kodak
Ну а про глюки уже все знают.. ждём их исправления
остальное всё просто замечательно) поэтому я акцентирую внимание на таких мелочах)
Сообщение отредактировал D-1c3 - 11.6.2009, 7:20
Ana®H
сообщение 11.6.2009, 7:25
Из: Украина, Черкасы
Пользователь №: 152 660
Модель телефона: ZN5, E8, K1, E770v
Прошивка: 0FR, 07R, 08R, 80R
Еще один баг нашел. На этой прошивке после включения wifi, использования и затем отключения иконка wifi мигает в статус строке, но не на главном экране а в главном меню и в подменю, не напрягает но все же.
I find out one more bug. It appear when after using wifi you turn it off, but in the main menu the wifi icon still blinking. Just in case smile.gif
P.S.: sorry for my bad english
Сообщение отредактировал Ana®H - 11.6.2009, 7:31
Chacha_Ivanov
сообщение 11.6.2009, 13:26
Куртуазный Маньерист
Из: Истра
Пользователь №: 56 473
Прошивка: Уникальная
помоги себе сам..
Цитата(earthshaker @ Сегодня, 15:13)
Почему то не могу сделать полную очистку и полный сброс
Неправильно наверно прошу пересобрали, проверьте папка .backup в корне фс есть? наверняка нету
r.o.m.a.N
сообщение 11.6.2009, 19:29
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Entom,
У меня вообще при окончании съемки тел "повис" (прошил мод полностью). На экране последний кадр, а звуки нажатия клавы есть, и тел выключается норомально. Если на ОЕ прошить Cg36, то такого нет
Добавлено позже (11.6.2009, 23:56):
Итог. Чтоб на 0Е работала и вафля, надо просто на 0Е прошить к Cg36 еще Cg35 от 07 (ядро)
Сообщение отредактировал r.o.m.a.N - 11.6.2009, 20:05
сообщение 12.6.2009, 22:24
Тему кардинально почистил - хотя в пору было закрывать.
Прошу более не флудить!
за посты типа: "каким ленгом прошить" "что такое бут" "как портировать либы на OE" и т.д. -не относящиеся к монстру - буду банить!
Сообщение отредактировал AstaRoth - 12.6.2009, 22:24
CjYoung
сообщение 13.6.2009, 10:32
Пользователь №: 14 233
Модель телефона: Milestone, ZN5, L7
r.o.m.a.N, тел виснет при окончании сьёмки и на этом монстре, но невсегда. позавчера 3 минуты отснял и повис =((
Я думаю, нужно сообщить об это баге афтору(а нука англичане...)))
ЗЫ: ещё раз прошу выложете пожалуйсто UserMenuTree оригинальный с мода.
vantus1995
сообщение 13.6.2009, 10:37
Пользователь №: 198 767
Прошивка: O5RMYMOD
вот, но mpkgbox в органайзере
Прикрепленный файл UserMenuTree.rar   ( 1.94 килобайт ) Кол-во скачиваний: 112
[MP] Freedom 7FR [MPKGBOX + QVGA], новый монстр! · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 26.4.2024, 11:13
