17 страниц V < 1 2 3 4 > »
Штурм камеры Zn5, Iso, чувствительность и т.д.
Ralf555
сообщение 13.9.2010, 20:43
Пользователь №: 46 337
Модель телефона: ZN5,L9,E398,V3x etc
Прошивка: R6637_G_81.03.05R
Nuke142, night pictures in such dark scene in normal mode are useless. Use low light mode instead, much better. And Night II with the stronger brightness will brighten it up. Need a steady hand. And of course in better light basically you only need day patch/unmodded or Evening I. Evening I can vary between 1/30-1/50 shutter (Indoor mostly 1/30) ISO 64-400. Low Light mode can go above with shorter shutter time or below in bad light.
Сообщение отредактировал Ralf555 - 13.9.2010, 20:52
Black Dragon
сообщение 16.9.2010, 18:07
Shaman
Из: Тольятти
Пользователь №: 36 118
Модель телефона: S21FE
Прошивка: 10
Nuke142, чет с часами у тебя не то.. Судя по свойствам, самая светлая фотка имеет ISO 125.. И вообще по логике вещей, чем меньше iso тем темнее фото будет, при отсутствии хорошего света.
Ralf555
сообщение 16.9.2010, 18:33
QUOTE(Black Dragon @ 16.9.2010, 18:07) *
That's why changing the ISO isolated from shutter time would be useless. With lowered ISO sensitivity you have to modify the shutter time as well, otherwise in most cases no good result (too dark). The first example with the watch was made in medium light looks like. For medium light never use Night patch. The original was captured with ISO 320 and 1/60 shutter. With Evening I patch you would get in this case ISO 160 with shutter time 1/30 and Evening II ISO 64-125 with shutter time 1/15. This also means the night patches would be too much here and as prove you can see the Night patch is a lot overexposed. The night examples are not useful because they were made in normal mode.
Zorge.R
сообщение 17.9.2010, 6:42
Group Icon
Группа: System Administrators
Из: рук в руки
Пользователь №: 101 800
Прошивка: 1CR
Цитата(rokrzine @ 13.9.2010, 19:55)
дeн,нaшeл нeдостaток.при рeжимaх с iso 64-200 фотки выходят 'нe спeлыми','выцвeвшими'.тaк и должно быть?a в обычном рeжимe всe ок
хотел бы обратить внимание, на то что телефон не всегда правильно определяет точку белого, особенно когда белого в фокусе нет совсем. Поэтому часто в таких условиях, надо ставить "баланс белого" вручную. (режим автоматический приводить к выцветанию фотографии)
Zorge.R
сообщение 18.9.2010, 7:02
Group Icon
Из: рук в руки
Прошивка: 1CR
Тут кто то говорил про рисунки светом
на высокое художество не претендует, просто проверка.
Но если сделать выдержку еще больше (в несколько секунд если возможно), а ISO еще меньше, чтобы в кадре оставался только свет, то можно при помощи наложения, делать подобные снимки:
p.s.: плюс для "ночной съемки" можно использовать ISO 1600 и длинную выдержку, тогда можно делать снимки практически в полной темноте.
Добавлено позже (18.9.2010, 11:04):
lDeNl, sh код у тебя суровый, порезал половину прежде чем поставить. и почему не сделал вывод уведомления, после того как либа смонтирована успешно? юзер не экстрасен.
Сообщение отредактировал Zorge.R - 18.9.2010, 7:05
@Jenek
сообщение 18.9.2010, 7:30
Пользователь №: 126 392
Zorge.R Ето я говорил о рисунках светом. Да выдержку надо ещё больше. :(
Сообщение отредактировал @Jenek - 18.9.2010, 7:32
lDeNl
сообщение 18.9.2010, 7:35
Zine Master
Пользователь №: 189 506
Модель телефона: Nokia N8
Прошивка: Belle
Zorge.R,
Ну уж половину ты точно не порезал там и так по минимуму всего, если только сделал одну подпрограмму(или как там это называется) для всех пунктов. :)
Не сделал сообщения, т.к. по сути оно ни о чем, даже если либа криво встанет, то сообщение все равно появиться(типа все круто и т.д.), так что лишние надписи окна и т.д. только мешаются. Запустил - выбрал и открываешь камеру.
У меня реальный косяк с автозагрузкой, через echo "" >> medld.conf, после каждого применения той или иной либы запись добавляется в medld.conf не супер критично, но костыль...
Так что это вот я скоро буду фиксить (завтра наверное ) Если есть предложения по коду, то предлагай я только за wink.gif
Я спрашивал у него на эту тему, говорит нельзя, 1/4 вроде как максимальное, цифру точную не помню, надо копаться в сообщениях, но те что стоят у него в ночной, в режиме слабого света - там вот максимальная выдержка.
Сообщение отредактировал lDeNl - 18.9.2010, 7:40
Zorge.R
сообщение 18.9.2010, 10:00
Group Icon
Из: рук в руки
Прошивка: 1CR
Цитата(lDeNl @ Сегодня, 13:56)
Ну и что в итоге? diff сравнивает 2 файла... у нас их 6, каждый с каждым сравнивать? В итоге 6 сравнений...
Все имхо проще:
Ты меня не понял, диффом сравнивать я ничего не предлогал. Перечитай пост внимательно.
Для чего дифф, будет ясно немного позже. когда я допишу пост.
Добавлено позже (18.9.2010, 14:04):
diff:
вечерняя | дневная
0x13CD4
______.|.E8
0x13CDC
5E______.|.F3
0x202A0
F2______.|.B4
вечерняя | вечерняя 2
0x202A0
F2______.|.F0
вечерняя | ночная
0x202A0
F2______.|.BF
вечерняя | ночная 2
0x13D00
64______.|.71
0x202A0
F2______.|.BF
0x2053c
4C______.|.4B
0x2147E
8B______.|.8D
0x21482
82______.|.80
hex:
offset____|дневная|вечерняя|вечерняя2|ночная|ночная2
0x202A0 - |B4|F2|F0|BF|BF|
0x2053c - |4C|4C|4C|4C|4B|
0x13CD4 - |E8|5C|5C|5C|5C|
0x13CDC - |F3|5E|5E|5E|5E|
0x13CDD - |AE|AE|AE|AE|AE|
0x13D00 - |64|64|64|64|71|
0x2147E - |8B|8B|8B|8B|8D|
0x21482 - |82|82|82|82|80|
Ralf555
сообщение 18.9.2010, 10:16
QUOTE(Zorge.R @ 18.9.2010, 8:00) *
diff либы вечерней и вечерней 2 показал отличие только в оффсете 0x202A0. Или diff сломался или все параметры пишутся в 1 байт.
Evening II is also different in brightness and I haven't changed the white balance because Night II is made for Outdoor night and Outdoor night isn't reddish looking.
0x202A0 - shutter time/ISO preset
0x2053c - shutter time/ISO preset
0x13CD4 - noise reduction
0x13CDD - noise reduction
0x13D00 -brightness
0x2147E - white balance red/green
0x21482 white balance red/green
There are so many more Offsets for noise reduction or brightness etc. but I didn't need it. As little as possible offsets to make sure it will be bug-free. By the way your idea with the ISO 1600 is not useful. You can be sure I have tried everything out. With ISO 1600 the colours are so unnatural, a lot noise in the picture and important the picture won't be brighter.
Zorge.R
сообщение 18.9.2010, 15:26
Group Icon
Из: рук в руки
Прошивка: 1CR
Спасибо, это именно то что было нужно
0x13D00 -brightness
Просто при съемке со стандартной библиотекой, при ISO1600, фотографии выходят светлей чем с night2. Поэтому хотелось попробовать ISO1600 и длинную выдержку. Большое количество шумов меня не смущает. Также думаю попробовать максимально длинную выдержку и как можно более низкое значение ISO, для получения фотографий рисованных светом.
Штурм камеры Zn5, Iso, чувствительность и т.д. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 26.4.2024, 18:09
