Nik_Black_Diamond™Ver.2 Or Final, my updated fw
nikhill
сообщение 30.8.2009, 5:49
Из: India
Пользователь №: 204 325
Модель телефона: e8
Nik_Black_Diamond™ Ver.2 Or FiNal By Nikhil007™ (Nikhil Dhayatkar)
IPB Image
Hi guys here's my new update fw for the Rokr E8 !! Its based on Dragon_Hunter_13ER by xianyuhui .. Thanks to xianyuhui , Sandip_2u( For helping in some issues of the fw ) , ilove3d for Mpkgbox series , tulanix for providing excellent applications ,Xmifeng for 532 Mhz Script , are_ed for providing first.txt , all authors of mgx apps incuded in this flash And special thanks to MMUS.US & Itfunz.com !!
Cg31 is not present in this fw so its not a locked flash and no one will get any bootloader error !! You can flash this over Dragon_Hunter_13ER personally tested by me !!
Please perform format your phone memory as well as memory card after backing them up because master reset and master cleasr is not possible and doing this will help you have no errors with this fw as i havent faced any !!
Master Reset and Clear functions do not work at all !!
Please dont click on device status in shortcuts the phone might hang !! Please dont delete Preload,ezxlocal and linux folder on phone memory it might result in errors in the working of the fw .
Features :
1.Cpu Speed 339 Mhz by default because of that Battery life lasts for longer than 532Mhz + the phone is fast as well .. But i am providing the script made by my friend Xmifeng at moto.it168.com by which you can run Cpu Speed at 532Mhz by default !! The script is present in attachments of the post the readme is included in the attachment .
2.Samba present by default !
3.Sidebar hacked works for all networks http://www.mmus.us/forum/showthread.php?p=95822#post95822 .. Some network id's which were requested are added by default !! For some networks like Rogers it still might not work .
IPB Image
4.Azaan is also present !! It is turned on by default so when the phone loads up for the first time it wil show azaan first and then sidebar for those whose network id's are included in the hsa .. just turn azaan off in phone settings \ homescreen \ custom homescreen
5.Modified Onyx theme mixture of onyx,orange and cmcc theme by xianyuhui named as cmcc in the fw !!
6.Video high bitrate patch added by default !!
7.Some wallpapers,video and ringtones included !! In ringtones check Mum calling and Hanana !!
8.Java full Access enabled !
10.Animated picture included while opening browser !!
11.Turn Off Bluetooth present in Shortcuts ..it is shown when bluetooth is On !!
12.Copy and Paste skins to skins folder .. Even .mgs installation possible ..
13.Java heap size 4096 by default .
14.Message Alert Present By Default .
IPB Image
15.Video Slideshow present .. tHIS feature has been imported to the e8 from em30 .Thanks to Sandip_2u
IPB Image
16.Mpkgbox 2.0 Pro Free Version added !!
IPB Image
17.A new skin RedBlackRokr5 by bev and its HSA by Enigmatic !! Thanks to both of them at motofan.ru !! This skin is included in the preload folder on phone memory ..preload \skins\RBR just copy this RBR skin to your skins folder on phonememory ..
The preload folder also includes a folder named Awesome which has all animated grids and tabs.svg files !!
18.Rockbox added to Sidebar shortcuts . Go in sidebar options there are two options consumer and proffessional select any one of them it is present in one of them !! Shown in the sidebar screenshot above .
19.Startup and Shutdown screens from the previous black diamond fw .
20.The browser profile bug has been cleared by default ..No need to put up the devdetail.wbxml now .. Thanks to Huatz84 for this feature .
21.When you open a wallpaper and say Apply to it will give an option of silent mode wallpaper when you apply it as silent mode wallpaper it will be seen when you put your cellphone on silent !! This is a sidebar dependent feature .
22.FmRadio has a timeout feature enabled .
23.When the sidebar is on and if the music player is minimized it shows up as the left softkey and not on the screen ..just press the red button if you want to switch it off !!
Linux ( A new introduction )
Linux is a new icon and software introduced !! It has been set in Office tools by default !!
If you want you can bring it in the main menu !! More explained below !!
In this app you have :
1. Mpkgbox Switcher :
Mpkgbox 1 ( Open Source ) ; Mpkgbox 2.0 ( Registration Reqd . ) ; Mpkgbox 2.0 Pro Free version & Magicbox ( Registration Reqd.)
IPB Image
IPB Image
A new trick if you open Mpkgbox 2.0 , register it and then open Magic box . Magic box automatically gets registered i.e becomes Magicbox Pro !! Or you can Mpkgbox 2.0 Pro free version !
2. Icon to Adjust :
By default the linux icon is present in the office tools !! This thing gives you an option if you want to switch Linux in the main menu in place of Mpkgbox !
IPB Image
3. Right icon
In the main screen for the right softkey a new icon is shown !! Looks brilliant you can set this On and Off from here !! For using a different icon and adding in the theme the icon name has to be youtube_simple.png ( 48*20 ) and youtube_big.png ( 125 * 24 ) the figures given in brackets are dimensions of the icon !
IPB Image
4.Networking Wizard
You can set the telnet,ftp and Samba enabled in the fw On and Off from here !!
IPB Image
Linux icon :
For adding the linux icon in different skins the name is certificate_mgr_big.png ( 96*96 ) ,certificate_mgr_std.png ( 49*49 ),certificate_mgr_simple ( 19*19 )
Mgx apps in Linux by Default in the fw are :[/COLOR]
IPB Image
IPB Image
1.Rockbox by tulanix with 21 themes + 98 equalizer presets
IPB Image
IPB Image IPB Image
[COLOR="Yellow"]2.Mplayer latest version by tulanix ( Without gain )
3.Picture Flow by crazysunh
4.Sms tracker by tulanix
5.Text Editor by Nestor M
6.E8 Terminal by tulanix
7.FileManger 2.0 by ilove3d
8.ImageMagic Beta by crazysunh
9.Pirate by Nikhil007
a compilation of 12 mgx apps ,
that are : Virtual Memory , Find Lost Java , Backup , Add Turn Off BT to Shortcuts , SysInfo 2.0 , Modify Shortcuts , Java Heap Sizer , Hide , Cpu Speed , Stop Keyboard Vibration , Java Rename , Snapper
Menu Editor removed from Pirate because there were some errors with it !!
In navigation key ( i.e. Up,Down,Right and Left ) you can add all the apps which are present in the linux directory !!
Abt Flashing and recommendations :
As Cg31 is not present all users can flash this !!
More abt it and flashing steps here :http://www.mmus.us/forum/showthread.php?t=9083
Imp : Flash after Flashing NO Rsa BL !!
Autorun Scripts can be added in locations :
/mmc/mmca1/first.txt
/mmc/movinand1/first.txt
/mmc/movinand1/unKnown/myfont.ttf
/mmc/movinand1/unKnown/mynum.ttf
/ezxlocal/autorun.txt
/mmc/mmca1/autorun/S??*
/mmc/movinand1/unKnown/S??*
Usefull paths:
mgx applications are installed:
/mmc/mmca1/mpkgbox
/mmc/movinand1/mpkgbox
mgs skins are installed:
/mmc/movinand1/skins
international language files:
/mmc/movinand1/.mpkgbox/
note: just write the file as xxx_${LANGUAGE_STRING}.lng
follow the ones which you get from ezx_system.cfg
the lang file is a shell script, you can understand it easily too.
FTP:
connect via USB tool or modem tools mode, access FTP in Filezilla,
through ftp://192.168.16.2, username is 'root', password not exist
TELNET:
telnet enabled
connect via USB tool or modem tools mode, access TELNET
through telnet 192.168.16.2, username is 'root', password not exist
Samba :
1.Connect the phone to your pc in usb & tools mode
2.In the address bar type \\192.168.16.2\ and hit enter
3.Bingo!...you have full access to file system ,without using filezilla
iF u r posting this monster pack anywhere on any site it is specified that you should mention my name as im the author .. and should mention the courtesy as MMUS !! Plz post this description as the original description when posting on any other site ..
It is needed to mention these things ..if u dont post you will be forbidden or plzz dont use the mp ..
Please give the phone a proper time to load up , dont hurry it will work fast !!
Thankyou ,
Nikhil Dhayatkar ( Nikhil007™ )
Moderator MMUS , Moderator E8 and Em30 English Station on Itfunz.com , nikhill on motofan.ru and nikhil007 on motofunvn.com,e8mod.pl & moto.it168.com
Special Thanks to MMUS.US,Moto.it168.com,Itfunz.com,Motofunvn.com,Motofan.ru and E8mod.pl !!
Thanking MMUS again for supporting me and all members who are using this flash !!
1 more thing plzz add the fw you are using to your signature ..This might help us moderators to solve ur problems !! Please report to me if any bugs are found i will surely try to solve them !! Thankyou !!
This can be said to be a final if the master clear or reset bug is solved the mp will be recompiled and made a final !! Im not able to upload any other download link because of some speed issues of my internet connection .. Please if anyone can upload it to 4shared or megaupload !! Thankyou !
You will get the download link + 532 Mhz script here : http://www.mmus.us/forum//showthread.php?t=10337
Сообщение отредактировал nikhill - 30.8.2009, 5:55
сообщение 30.8.2009, 6:27
вот..)) эту версию буду ставить.. отпишусь о багах (надеюсь их нет) smile.gif
alxey
сообщение 30.8.2009, 7:35
Из: Kiev
Пользователь №: 144 371
Прошивка: E8 EM30 V8
кто то знает как отсюда вытянуть правую софткнопочку?
klaraivanovna
сообщение 30.8.2009, 7:41
Пользователь №: 185 158
Модель телефона: Droid Maxx
alxey,
alxey
сообщение 30.8.2009, 7:43
Из: Kiev
тоесть если на гуд сток поставить софтину Блекдиамонд и скин из монстра то она у меня тоже появится?
Spitfire398
сообщение 30.8.2009, 12:34
Из: Ukraine
Пользователь №: 161 149
Модель телефона: E398, ROKR E8, DROID
Прошивка: Z-Mod E8
Уж больно неторопливая ета прошывка , даж при макс. частоте проца ... Вообщем чем больше "финтов" - тем больше "тормозов", насколько я понял smile.gif
Муха05
сообщение 30.8.2009, 16:20
Из: Махачкала
Пользователь №: 201 295
Модель телефона: E8 5530
нету никого кто переведет описание прошивки на русский? от гудстока отличия какие?
alxey
сообщение 30.8.2009, 16:35
Из: Kiev
отличия такие что работает медленее на много
сообщение 30.8.2009, 16:56
ну да медленнее.. только из-за того что тут сразу всё включенно..а если там всё тоже самое включить будет так же думать как и эта..
Муха05,
отличия что нет русского.. зато rockbox, mplayer, и pirate сразу встроенны в прошивку, так же файловый менеджер и текстовый редактор.. Активированна самба, фтп modem&tools и есть ,pkgbox (все версии)
я не понял, а почему нет скина RedBlackRokr5?
nikhill,
this fw don`t have skin RedBlackRokr5? I don`t see this skin for my phone (I have this fw)..
sorry for my bad english )
alxey, сделал.. молодец.., не многие могут позволить себе потратить время, на то что, бы всё это сделать.. А тут из коробки
Сообщение отредактировал metallsatanist - 30.8.2009, 17:07
alxey
сообщение 30.8.2009, 17:02
Из: Kiev
Я себе на гуд стоке сделал все тоже самое кроме 4 боксов. Скорость на много выше без разгона, чем тут с разгоном.
Сообщение отредактировал stigr - 31.8.2009, 6:20
demon-yo
сообщение 30.8.2009, 20:39
Пользователь №: 37 931
Модель телефона: E2,E8,A1200e
Прошивка: Maxx 4, 14.1ER, Iris
зеркало
http://www.mediafire.com/?xtl52iyudtm
Сообщение отредактировал demon-yo - 30.8.2009, 20:52
Messiv
сообщение 31.8.2009, 13:41
Пользователь №: 188 676
Модель телефона: E8
Прошивка: ...
Муха05,
nikhill,
preload папку глянь!
Dontsay
сообщение 2.9.2009, 7:22
Из: республика Адыгея, г. Майкоп
Пользователь №: 196 386
Модель телефона: MOTOROKR E8
Прошивка: Black Diamond
И все таки!Люди посоветуйте - у меня 1CR_A проша на буде 06.3А!Стоит ли переходить на этот монстр?И как его ускорить если говорите,что он тормозной?+ хотелось бы знать где взять русский ленг и как его прошить в этот монстрик?Инглиш меня не парит,но и русский ленг хотелось бы smile.gif)) СПС заранее!
_______
Русский ленг
Сообщение отредактировал stigr - 2.9.2009, 7:47
Pumba398
сообщение 2.9.2009, 9:13
Пользователь №: 119 961
Модель телефона: MotoROKR E8
Прошивка: Z-Mod 2.4.5 Final
Честно скажу не понимаю о каких тормозах все говорят. Может моя предыдущая проша MartiazFalz Eclipse была тормоз и я этого не понимал, но эта намного стабильнее и чуть быстрее (даже на скорости проца 399) хотя тут наворотов раза в два больше и сделано всё удобнее, даже не думал что эта прошивка будет настолько отличной после таких отзывов)) Возможно глюки у людей происходят из-за того что они не делают перед прошивкой мастер очистку карты и памяти телефона, я это сделал и теперь ненарадуюсь, особенно активированной HSA, удобная штука.
Сообщение отредактировал Pumba398 - 2.9.2009, 9:15
Dontsay
сообщение 2.9.2009, 9:21
Кстати,опишите пожалуйста порядок действий при прошивке этого монстра!!!!!!!
Тоесть повышать ли бут если стоит 06.А3,ставить ли патчи и тд!!!!
Pumba398
сообщение 2.9.2009, 12:01
Dontsay, да это не трудно, во многих темах пишут что сделать надо.
-Берёшь RSDlite 4.5.5
-Сначала прошиваем патч на бут NoRSA (его можно забрать тут в Мануале по E8 и EM30 стоит почти вначале, тебе нужен NoRSA для своего бута, если ты говоришь что у тебя 06.А3 то значит такой НоРСА и ставь.)
-Потом прошиваешся этим монстром (ждёшь пока на экране не будет написано что 100% а чуть позже после перезагрузки напишут PASS, типо удачно прошился)
-Потом если появятся глюки на экране со шрифтами и меню, то надо прошить CG31 для своей версии бута, я с этимм не сталкивался, 3 раза перепрошивал телефон и он мне ниразу не понадобился, так что где его достать это у кого-нить другого надо спросить.
-Потом шьёшь нужный ленг пак, так как в этом монстре тока китайский и английский (Ленг мона подобрать тут http://rapidshara.ru/112745 )
Вот и всё, больше ничего и настраивать не нужно, можно ещё панельку HSA активировать, типо как сайдбар в Висте, как это сделать пишут тут - HSA панель , там оказывается просто.
P.S: Лично я советую сделать полную очистку телефона (через телефон Мастер очистки) и карты памяти (форматнуть) и только потом уже начинать всё шить так как после перепрошивки на данный монстер пак, не работают эти функции из телефона, а их надо всегда делать после или перед прошивкой дабы не сыскать глюков лишних.
Сообщение отредактировал Pumba398 - 2.9.2009, 12:08
Witazzew
сообщение 2.9.2009, 12:25
Из: Ухта
Пользователь №: 180 655
Модель телефона: 910
человеки! можно русским языком что в этой прошиве есть?
DaER
сообщение 2.9.2009, 16:09
Пользователь №: 169 833
Модель телефона: ROKR E8
Прошивка: zMod E8
Никто не может пересобрать и выложить эту прошу с патченой либой для сохранения быстродействия с русским? А то турболенг на прошлую версию у меня не поставился, а качать и ставить линукс чтобы пересобрать прошу я не могу.
Pumba398
сообщение 2.9.2009, 17:42
Тут уже всё и так сделано и скорость на любом ленге быстрая, не нужен уже этот турболенг. Я русский поставил точно такая же скорость, что была и на англ.
demon-yo
сообщение 2.9.2009, 19:03
Важно!
Перед установкой делайте полную очистку телефона и карты памяти, иначе плеер не работает.
Монстр хороший, тормозов не ощущается, свап фаил и вперед.
Русский ленг нормально встает переводит почти все вот ссыла http://storage.e2mod.com/e8/lp/002EE-moto-e8.zip
HSA радует, все радует, кроме самой прошивки 13R имхо устарела она морально. А так все круто. Вот еще бы сделали чтонить подобное на CRA или 14ER ценыб небыло.
Boaz
сообщение 3.9.2009, 3:44
Из: Магнитогорск
Пользователь №: 197 485
Прошивка: Rokr Envy
так кто скажет эта быстрее аналогичной прошивки от ilove3d?
Добавлено позже (3.9.2009, 9:46):
и восклицательные знаки желтого цвета после прошивки могут быть? потому что до этого прошивая другой мод на основе 13R были у меня.
ViP)
сообщение 3.9.2009, 10:28
Пользователь №: 143 805
Модель телефона: E8
прошился....перезагружается он....кнопок ввода не видно, не горят вообще...все остальные жолтые восклицательные знаки(((.....прошил еще cg31.....тоже самое(((
что это может быть?....
поставил снова гудсток все норм!
Boaz
сообщение 3.9.2009, 11:27
Из: Магнитогорск
Прошивка: Rokr Envy
вот...если такое появляется...что делать? кто блин может подсказать....дело в RAMDLD или как?
Zorge.R
сообщение 3.9.2009, 12:08
Group Icon
Группа: System Administrators
Из: рук в руки
Пользователь №: 101 800
Прошивка: 1CR
Прошей сначало чистую 1CR, а поверх неё этот мод.
ViP)
сообщение 3.9.2009, 15:18
Модель телефона: E8
спс, помогло....прошил сразу 1CR потом поверх прошивку...все работает!!!
VirusX74
сообщение 3.9.2009, 15:24
Пользователь №: 196 203
Модель телефона: E8
https://motofan.ru/firmware/?action=view&am...nt=1&phone=
ты вот эту сначала прошивал?
Сообщение отредактировал stigr - 3.9.2009, 15:53
Witazzew
сообщение 3.9.2009, 16:19
Из: Ухта
надо прошивать рамлодер от той прошивки которая до этого стояла и не будет глюков с !!! знаками если до этого стояла R6713_G_71.14.1CR_A то шейте для своего бута -
ViP)
сообщение 3.9.2009, 17:31
Модель телефона: E8
ага, её
Boaz
сообщение 4.9.2009, 3:01
Из: Магнитогорск
Прошивка: Rokr Envy
я прошивал со своим RAMDLD, не помогало
Dontsay
сообщение 4.9.2009, 5:49
Прошился clap.gif Все норм!Вот тока вопросик у меня! ph34r.gif Каким образом можно свернуть РОКБОКС во время проигрывания и восстановить его потом???? sad.gif
ViP)
сообщение 4.9.2009, 7:48
Модель телефона: E8
да меня эт тоже интересует....свернуть можна а вот назад он никак не хочет(((((....сварачивать левой кнопкой....
на гудстоке он у меня еще и розварачивался))))
Pumba398
сообщение 4.9.2009, 8:24
Только сейчас понял чего не хватает этой прошивке) Не убран этот идиотский звук (ну или вибра) при проверке баланса счёта) его не разбирая прошивки програмно можно как то вырубить или нет?
И второе - только у меня не работает ни в какую синхронизация WMP ? именно синхронизация, а то заливаю треки а телефон их не видит в плеере, не обновляет списки. Приходится заливать музыку, потом ставить английский, перегружатся, чуть ждать пока списки обновяться и потом снова ставить русский...это конечно не то чтоб час делать, просто как то странно почему стандартная заливка не работает так как надо..
В остальном мне кажется прошивка идеальная, глюков 0 , скорость самая быстрая даже на скорости проца в 399 и без свапа smile.gif
Dontsay
сообщение 4.9.2009, 8:59
А в целом отл. проша!!!!! Респект!!!!
ЗЫ:А что будет если с активированным свапом подключить трубу к компу в режиме флешки????
Сообщение отредактировал stigr - 4.9.2009, 9:48
matreks
сообщение 4.9.2009, 17:28
Пользователь №: 76 733
Модель телефона: V980 => А1200
Прошивка: Silent_Bob's FW
Это первый раз за десятки раз прошивания своего тела, когда не получается довести до ума...
Pumba398
сообщение 4.9.2009, 19:11
Dontsay, точно нельзя включать свап и потом юзать режим карты памяти, надо вырубать свап перед этим.
Boaz
сообщение 7.9.2009, 7:48
Из: Магнитогорск
Прошивка: Rokr Envy
блин, мне кто нибудь здраво может объяснить как прошить это чудо, сколько я не пытался ни с заменой RAMDLD, ни с заменой cg31...прошить прошлые наработки этого автора у меня не получалось...
SHERIF
сообщение 7.9.2009, 13:44
Из: Новомосковск
Пользователь №: 199 033
Модель телефона: E1, E8 xt912
Прошивка: Z-Mod,Test 16
На гудсток поставил.стала отлично все работает thumbsup.gif попробуй гудсток потом блека
Witazzew
сообщение 7.9.2009, 15:03
Из: Ухта
люди выложите пожалуйста папку linux с этой прошивки smile.gif + дам
SHERIF
сообщение 7.9.2009, 15:28
Из: Новомосковск
linux лови
alxey
сообщение 7.9.2009, 16:34
Из: Kiev
кто может выдернуть отсюда компку на рабочем экране рокр?
Nik_Black_Diamond™Ver.2 Or Final, my updated fw · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 11.8.2025, 4:56
Форум живёт: 8110 дней
