7 страниц V  1 2 3 > »
Gain Table, Дополнительные настройки
Gut4rt
сообщение 20.2.2006, 19:25
Пользователь №: 65 726
Народ кто неплохо английский знает помогите перевести а то не все понятно.
Maybe i'm not good enough...  And this topic is worthless
and also i could be wrong...
but here ... all i want to do is share....
i always make competitions with my friend
(crash overburn) in making gain table....
so after a few racing time... we found the secret
of the bass controller and treble controller
what control the bass is the master volume of speaker mp3/ringtone
in offfset 49 and the master control on offset 4C
please notice if you set one of them high..
so you have to reduce the other one...
notice in my baby's gaintable the offset 49 goes to 03 - standard
but the master in off. 4C is hacked to 0E (5 step)
this will increase the bass
and if you want to a clearer treble
this is what found by Crash Overburn...
set the vol on offset 49 to 07 then
lower the control on off. 4C to 03 (the logic reverse)
i have done so many experiments with this offset
and you should so ... to suit it your taste...
the other offset will make no difference on controlling
the bass and the treble...
only the 3D sound is controlled by offset 4E (the system tone)
set it to 01 for more surround
set it to 05 for 3D with big bass
set it to 07 to make it loud but crunchy/cracky
the other offset that interesting is the wiredheadset
on offset 145.... and the master control on offset 148
so if you want a great sound on your headset...
do this:
set volume low to 01 (offset 145) but,
hack the control to 0E (offset 148)
other interesting that you can try is
to set the keypad volume tone
on every part (the external and the wired)
you'll need a seem map by xlr8 to do this...
(thanks in advanced to xlr8 for the great map)
for you who have no experience in hex editing
search a hex editor (i recommend XVI32 which can be found on this site)
this is what you've been asking for...
now i reveal the secret..... (it's my experiment)
and if i'm wrong... please forgive me...
this is only an experiment... (but you proof it right?)
with my two gain table... you can compare the result...
E398 will never be beaten by any other phone in sound
i've tried to compete the w800i (SE)
and still my phone louder than that
Do this with original Vibexxx.wav file
good luck on tryin'
and happy modding always...
ZIE
Оригинал сдесь: http://www.motomodders.net/Default.aspx?ta...2183&view=topic
StrIk3r
сообщение 20.2.2006, 20:14
Из: Великий Новгород
Пользователь №: 53 936
Модель телефона: E398@ROKR_E1_iTunes
Прошивка: R373...49R
Пожалуйста кто нить перевидите по понятней
для тех чей бронепоезд на запасном пути
Кстати а где ты взял эту инфу ?
Madness
сообщение 21.2.2006, 9:46
Пользователь №: 42 480
Может я не настолько хорош....и эта тема ничего не значащая...и также я могу ошибаться
но сдесь...всё что я хочу сделать - поделиться...
я всегда соревнуюсь с моими друзьями (в частности с Крэшом Овербарном) в создании gain tabe...
так по истечению немногого времени .... мы нашли секрет bass контроллера и treble контроллера
настройки басов, отвечающие за громкость воспроизведения мп3 в offfset 49 и мастер управления в offset 4C
пожалуйста обратите внимание, если вы до этого правили их...
так вы снизили остальные...
в моём gaintable в offset 49 поставил значение 03 - стандарт, в offset 4C поставил значение 0E (5-й шаг)
это усилит басы
и если ты захочешь сделать звук чище, это было найдено Крэшом, поставь в offset 49 на 07 затем в offset 4C на 03 (логический переворот)
я сделал эти эксперименты, и вам тоже следует...на ваш вкус
следующий офсет не сделает никаких изменений в настройках басов и высоких...
только трёхмерный звук управляется офсетом 4E (системный tone)
поставь значение 01 для большего окружения
05 - трёхмерный с большими басами
07 - чтобы сделать громким, но с перегрузом
.....перевёл как знал, не до конца ... закончите....
Gut4rt
сообщение 21.2.2006, 10:31
Мне кажется если получить доступ из ява к gain_table то можно сделать неплохой эквалайзер!
grafmoto
сообщение 21.2.2006, 11:18
ЯваМотоКодер
Из: Северодвинск
Пользователь №: 16 752
Модель телефона: iPhone 3Gs
Прошивка: iOS 6.1.3
ну доступ то получить не сложно - в p2ktools поменять атрибуты у файла
Anton85
сообщение 21.2.2006, 13:04
Пользователь №: 55 377
Прошивка: Cyber Demon 1.6
пожалуйта дайте полный перевод и сделайте хорошенький мануал под анной теме
тема крутая!!
для меня и для многих других это самая интересующая тема!!
несосчитать сколько по данному вопросу на форуме не находилось ответов
можно поставить звук как в 45 на 6FR или на 70 r,
да вообще можно подстроить под себя,
я бы добавил баса или осавил как на 45 со скоростью 70
ДАВАЙТЕ РАЗВИВАТЬ ДАННУЮ ТЕМУ ЭТО ПОЛЕЗНО
Ктати для того чтобы поменять значение офсета надо знать какой всётаки нужно редактировать сим. - люди добрые подскажите у кого что полчилось.
или может надо лазить в гаит тэйбл?
ОЧЕНЬ ХОЧУ ПОСТАВИТЬ 70R С КРУТЫМ ЗВУКОМ -например как на 45 - чу может чуть побасистее
StrIk3r
сообщение 21.2.2006, 13:20
А их труды и правда работают
Щас попробовал звук на 45р стал громкий и чистый я такого еще не слышал !!!
AlexKooper
сообщение 21.2.2006, 14:01
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
тема крутая!!
Сдается мне, ты еще не знаешь, что в ряд р2к программ встроен редактор гайн :) И многие монстры идут с собственными настройками этой штуки.
P.S. Но ребята похоже раскопали дополнительные настройки
StrIk3r
сообщение 21.2.2006, 14:05
Anton85, выкачиваешь у себя гайн тайбл и мучаешь его в хекс редакторе
офсеты я искал кнопочкой GOTO
Random
сообщение 21.2.2006, 17:05
Музыкант
Пользователь №: 36 054
Модель телефона: iPhone 4S
Постараюсь перевести по понятнее, и только то, что действительно интересно :)
Примечание:
По поводу смещений. Они даны в шестнадцатеричном виде, поэтому для правильностидописал букву h в конце.
Читается так. Например 4Ch
Ищем слева в редакторе 40, потом щелкаем по этой строчке, внизу слева увидите число, например 4F.
Перемещаете курсор пока не увидите "4C" Это и будет нужный параметр.
Уровень басов меняется громкостью внешних динамиков (по смещению 49h),
а также общей громкостью (смещение 4Ch).
Обратите внимание, если вы увеличили значение одного из этих параметров,
необходимо понизить значение другого.
В моем gaintable по смещению 49h стоит стандартное значение - "03"
но общая громкость (4Ch) изменена на "0E"
Это повышает уровень басов.
Если же вы хотите более чистых высоких частот,
установите громкость по смещению 49h на "07",
а по смещению 4Ch - "03"
Поэксперементировав с этими смещениямии,
вы можете настроить звучание на свой вкус.
Кроме этого, по смещению 4Eh (системные звуки)
регулируется 3D звук (Прим. от меня - что то не почуствовал я разницы, кроме громкости системных звуков.. Может быть это для др. телефона?)
Поставьте "01" для большего эффекта 3D звука
Поставьте "05" для 3D звука с сильными басами
Поставьте "07" для громкого звука, но с искажениями
Еще один интересный параметр -
громкость проводной гарнитуры (смещение 145h)
и общая громкость (смещение 148h)
Если вы хотите хорошего звука наушников,
Поставьте "01" по смещению 145h
И "0E" по смещению 148
Еще можете попробовать менять громкость
клавиатуры и на динамике, и в наушниках.
Для этого потребуется описание симов от xlr8
Для редактирования файла подойдет любой HEX-редактор, например XVI32
Если я где-то ошибся, извините меня.
E398 никогда не обойдут по громкости другие телефоны,
я пробовал SE w800i, и мой телефон все равно громче.
Делайте это с оригинальными файлами вибро Vibexxx.wav
Удачи!
Сообщение отредактировал Random - 21.2.2006, 20:16
StrIk3r
сообщение 21.2.2006, 17:09
Я так понял речь идет именно о е398
Anton85
сообщение 21.2.2006, 18:26
я открыл гайн тэйбл в хэкс редакторе но там нет никаких офсетов.
подскажите поподробнее - ведь пригодится не только мне одному.
вам будет плюс
Gut4rt
сообщение 21.2.2006, 18:44
В редакторе XVI32 внизу слева пишится адрес (ето и есть офсет)
Anton85
сообщение 21.2.2006, 18:53
снизу в редакроре у меня пишется DEC и Hex
Hex - я так понел это и есть оффсет но допустим
4Ch, 4 ятак понимаю это HEX, тогда что такое Ch?
Gut4rt
сообщение 21.2.2006, 19:46
4C это hex и наверн так и пишется 4С(h-hex)
PCJ600
сообщение 21.2.2006, 19:56
Пользователь №: 66 753
Модель телефона: E 398
Прошивка: R373_G_0E.30.45R
нет у меня не работает - ур. басов не меняеться
Да и с чего
Если это в этих офсетах выставляеться просто ур. громкости.
Irus
сообщение 23.2.2006, 9:28
Пользователь №: 56 108
Модель телефона: E1 Rider
Прошивка: R373_G_OE.30.49R
У меня тоже нет изменений, правда когда залил GT от StrIk3r то уровень стояла на 7! А играл чуть громче, потом попробывал со своим GT на семь так он так орал! Вывод, что-то есть в их мануале, только вот что?
StrIk3r
сообщение 23.2.2006, 20:42
Народ а какое значение среднее между хекс значениями 05 и 06 ?
как записать значение 05,5 в хекс ?
GrAnd_
сообщение 23.2.2006, 21:05
Из: Королев/Москва
Пользователь №: 43 782
Модель телефона: Atrix
StrIk3r,
никак
StrIk3r
сообщение 23.2.2006, 21:26
Вот это давольно таки плохо
тат как когда ставлю на 06 в некоторых мелодиях телефон потрескивает от вибрации,
а когда на 05 как то недостаточно громко звучит..
Обидно
Досадно,
но Ладно
Irus
сообщение 24.2.2006, 17:21
Я ошибся! Чуваки! Реально рабочий мануал! Вибра стало намного сильнее (и в песнях и так просто)! Зацените два GT, GT1 вибра на минимуме, GT2 совсем на максимуме (аккруратнее!!!)! А ведь значения в P2K одно и тоже! Делаем вывод, 6FR не безнадёжна! Да кстати, всего навсего поменял смещение 4Ch в xVi32, вычислял через виндосовский калк. (инженер. вид) Ура!
StrIk3r в моем варианте, поставь на 0С смещение 4Ch и всё должно быть ОК.
Hirya
сообщение 24.2.2006, 17:53
Пользователь №: 52 005
Модель телефона: MPx220
Прошивка: MPx220Firm351SP3
Irus,
Круто! Только теперь что-нибудь "среднее" сделай.
И ещё, почему тему насчет эквалайзера на яве никто не развивает? Мне кажется это очень интересным!
Irus
сообщение 24.2.2006, 18:06
Hirya вот попробуй этот GT, а на счет эквал. это дело хорошее, только не нужное, я думаю скоро появится замена Itunes, так как уже научились расширять возможности Java, и вот там будет всё как в windows media rolleyes.gif :) да насчёт вибры если будут проблемы скажи, у меня всё настроено и подогнано под этот GT (сам его юзаю)
kokoc
сообщение 24.2.2006, 18:54
Пользователь №: 71 758
Модель телефона: R365
Господа! Не знаю в тему или нет! Возникла идея ипользования сотового телефона в качестве индикатора уровня ПЧ (950...2150 МГц) в кабеле снижения от конвертора СТВ к ресиверу для настройки тарелки на спутник. Каким образом это можно реализовать? Рабочая частота сотика в этом же диапазоне. Кто знает ответьте пожалуйста.
Gordon_Freeman
сообщение 25.2.2006, 8:30
Пользователь №: 56 511
Irus, а немного тише можешь сделать? :)
SharkExE
сообщение 25.2.2006, 9:40
Из: Пермь
Пользователь №: 46 933
Модель телефона: SE w810i
Прошивка: R4DB005
А вы думаете никто не заливал гейн тейбл от 42-45 на 6FR-70R ???
звук то не меняется, он в проше такой басистый, так что имхо на 6FR-70R все безнадежно
Irus
сообщение 25.2.2006, 12:02
SharkExE конечно ты прав заливали и не раз! Тока дело в том, что GT от 45R усиливает, т. к. в самой проше вибра меньше, а для 6FR всё наоборот ИМХО! Попробуй из архива с двумя GT залить GT1 на 6FR.
PS Дайте GT от 6FR, посмотрим что можно сделать. Да а ты пробывал архив с вибрами?
Gordon_Freeman Могу, тока попозже, а то в школе достали :(
Hirya
сообщение 25.2.2006, 13:24
Irus,
clap;applo Круто, всё работает! Только бы ещё вибру выложил бы свою, а то моя трещит.
Irus
сообщение 26.2.2006, 14:37
Hirya на вот попробуй
Кто-нибудь даст мне GT от 6FR для экспериментов?
ROMEO E1
сообщение 27.2.2006, 12:03
Пользователь №: 71 426
Модель телефона: MING
Прошивка: 12.F4
Парни напешите манул или еще что нибудь как зделать вибру при прослушивание по больше ( но конечно чтоб и не хрепело а то на моей проше я вибру почти не ащущаю) я пытался сам сделать но получилось плохо сильный хрип Да я заметил что и param_table тоже отвечает за звук вот только что там крутить я не понял ( У меня gain_table от моей проши установлен а param_table от 95 на 7 репят а вот на 6 даже ничего кто нибудь по эксперементируйте с этима файлами)
ROMEO E1
сообщение 28.2.2006, 9:27
Прошивка: 12.F4
вот выкладываю свои настройки на звук ( если кто то сделает чечше на основе моих то выкладывайте )
заливать одновременно так получилось вообшем и не плохо попробуйте
Maks-E
сообщение 28.2.2006, 11:20
Пользователь №: 42 849
Модель телефона: V3
Прошивка: R374_G_0E.42.08R
А от 6BR для экспериментов пойдёт?
МИХА2006
сообщение 28.2.2006, 13:15
Пользователь №: 64 714
Прошивка: MotoSymbian1.4
Было бы круто скумекать прогу для редактирования GT ( типа как в П2Ктоолсе)! Мож кто из спецов возьмётся?
ROMEO E1
сообщение 28.2.2006, 15:29
Прошивка: 12.F4
НЕ зобывайте что и param_table то же за звук отвечает в часность за работу резонатора
Я заметил что он и еше за работу акб отвечает тоже ( но как и что там ковырять я так и не понял)
grafmoto
сообщение 1.3.2006, 5:43
ЯваМотоКодер
Из: Северодвинск
Прошивка: iOS 6.1.3
для начала нужно все окончательно систематизировать. подробно описать какой байт за что отвечает. как говорится у нас, у программеров, написать тех.задание :-)))
Irus
сообщение 2.3.2006, 16:05
Maks-E Не знаю, должно подойти, попробую
grafmoto Эт конечно надо, тока я вот заметил, всё таки увеличивается вибра в песнях за счёт громкости, найти бы способ увеличить не трогая громкость,
Roman Dagger
сообщение 3.3.2006, 8:36
Пользователь №: 62 614
Модель телефона: Galaxy Tab 7.7 3G
Прошивка: P6800DXMD3
Нашел я эти описания. Тока разобраться там с трудом смог. Может, кто распишет то, шо там написано по-человечески? Полезные штуки есть.
_Kostik_
сообщение 3.3.2006, 14:46
Пользователь №: 60 912
Прошивка: R373_G_OE.30.6FR
А вот и GT от 6fr если сделаете прикольный звук буду очень багодарен
StrIk3r
сообщение 3.3.2006, 15:13
ROMEO E1,
а ты прав у меня с твоим парам тейблом трещало страшно... а залил свой и оставил твой гейн тейбл трещать перестал так что не все так безнадежно как кажется будем искать дальше
Приду вечерком и гляну что разного в двух исходниках
StrIk3r
сообщение 3.3.2006, 18:44
Посмотрел через хекс редактор два парам тейбла:
один мой от 48r
другой ROMEO E1, от 95r
Местами они полностью идентичны но есть очень много различий
Предлагаю создать отдельную тему по этому вопросу
Gain Table, Дополнительные настройки · Ломаем и строим! · Forum
Текстовая версия Сейчас: 4.8.2025, 16:28
