z6 - монтирование, на Linux хосте
e-yes
сообщение 6.1.2008, 19:21
Пользователь №: 159 157
Модель телефона: MotoROKR z6
Прошивка: R60_G_80.33.44R
Радость от удачного приобретения немного омрачает невозможность смонтировать z6 на компьютере с Linux.
uname -a:
Linux chainsaw 2.6.22-gentoo-r9 #4 PREEMPT Fri Dec 14 23:41:12 MSK 2007 i686 Intel® Pentium® M processor 1.73GHz GenuineIntel GNU/Linux
dmesg:
[ 5944.460000] usb 1-6: new high speed USB device using ehci_hcd and address 3
[ 5944.610000] usb 1-6: configuration #1 chosen from 1 choice
[ 5944.630000] scsi0 : SCSI emulation for USB Mass Storage devices
[ 5944.630000] usb-storage: device found at 3
[ 5944.630000] usb-storage: waiting for device to settle before scanning
[ 5949.630000] scsi 0:0:0:0: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
[ 5949.630000] scsi 0:0:0:1: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
[ 5949.640000] usb-storage: device scan complete
[ 5949.730000] sd_mod: Unknown symbol scsi_logging_level
[ 5949.760000] sd_mod: Unknown symbol scsi_logging_level
[ 5949.780000] sd_mod: Unknown symbol scsi_logging_level
[ 5949.810000] sg: Unknown symbol scsi_logging_level
[ 5950.790000] sd_mod: Unknown symbol scsi_logging_level
[ 5950.810000] sg: Unknown symbol scsi_logging_level
/usr/sbin/lsusb -v | grep ручками:
Bus 001 Device 003: ID 22b8:6426 Motorola PCS
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x22b8 Motorola PCS
idProduct 0x6426
bcdDevice 1.01
iManufacturer 3 Motorola Inc.
iProduct 2 MS
iSerial 4 9073599825BA0B2A0D
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 7 msc
bmAttributes 0xc0
Self Powered
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk (Zip)
iInterface 8 Motorola Mass Storage - Bulk Only
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Как понимаете, в WinXP всё ок.
Получалось ли у кого, нет? uname -a?
Сообщение отредактировал e-yes - 6.1.2008, 19:22
Mayuka
сообщение 6.1.2008, 21:19
Пользователь №: 47 181
Модель телефона: MotoROKR Z6 + A1200e
Надо ядро патчить что бы нормально монтировалось.Вот линк http://www.mail-archive.com/linux-usb-user...t/msg19224.html
e-yes
сообщение 6.1.2008, 22:50
Ну а толку-то...
[ 103.760000] usb 1-4: new high speed USB device using ehci_hcd and address 2
[ 103.910000] usb 1-4: configuration #1 chosen from 1 choice
[ 103.910000] scsi0 : SCSI emulation for USB Mass Storage devices
[ 103.910000] usb-storage: device found at 2
[ 103.910000] usb-storage: waiting for device to settle before scanning
[ 108.910000] usb-storage: device scan complete
[ 108.910000] scsi 0:0:0:0: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
[ 109.030000] usb 1-4: reset high speed USB device using ehci_hcd and address 2
[ 109.190000] scsi 0:0:0:1: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
[ 109.320000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 109.440000] usb 1-4: reset high speed USB device using ehci_hcd and address 2
[ 109.590000] sd 0:0:0:1: [sdb] Attached SCSI removable disk
[ 109.750000] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 109.750000] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 163.320000] sd 0:0:0:0: [sda] 3931920 512-byte hardware sectors (2013 MB)
[ 163.320000] sd 0:0:0:0: [sda] Write Protect is off
[ 163.320000] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 163.320000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 163.320000] sda:
[ 175.050000] synaptics: using relaxed packet validation
[ 223.450000] usb 1-4: reset high speed USB device using ehci_hcd and address 2
[ 223.610000] sd 0:0:0:0: [sda] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK,SUGGEST_RETRY
[ 223.610000] end_request: I/O error, dev sda, sector 8
[ 223.610000] Buffer I/O error on device sda, logical block 1
[ 223.610000] Buffer I/O error on device sda, logical block 2
[ 223.610000] Buffer I/O error on device sda, logical block 3
[ 223.610000] Buffer I/O error on device sda, logical block 4
[ 223.610000] Buffer I/O error on device sda, logical block 5
[ 223.610000] Buffer I/O error on device sda, logical block 6
[ 223.610000] Buffer I/O error on device sda, logical block 7
[ 223.610000] Buffer I/O error on device sda, logical block 8
[ 223.610000] Buffer I/O error on device sda, logical block 9
[ 223.610000] Buffer I/O error on device sda, logical block 10
[ 223.620000] sd 0:0:0:0: [sda] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK,SUGGEST_RETRY
[ 223.620000] end_request: I/O error, dev sda, sector 8
[ 223.620000] end_request: I/O error, dev sda, sector 480
[ 223.630000] sd 0:0:0:0: [sda] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK,SUGGEST_RETRY
[ 223.630000] end_request: I/O error, dev sda, sector 488
[ 223.630000] end_request: I/O error, dev sda, sector 480
Mayuka
сообщение 6.1.2008, 23:17
Почти тот же эффект на ядре 2.6.23.12. dmesg выдает:
scsi1 : SCSI emulation for USB Mass Storage devices
scsi 1:0:0:0: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
scsi 1:0:0:1: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
sd 1:0:0:0: [sda] Attached SCSI removable disk
sd 1:0:0:1: [sdb] Attached SCSI removable disk
sd 1:0:0:1: [sdb] 128671 512-byte hardware sectors (66 MB)
sd 1:0:0:1: [sdb] Write Protect is off
sd 1:0:0:1: [sdb] Mode Sense: 03 00 00 00
sd 1:0:0:1: [sdb] Assuming drive cache: write through
sdb:
sd 1:0:0:0: [sda] 3931904 512-byte hardware sectors (2013 MB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 03 00 00 00
sd 1:0:0:0: [sda] Assuming drive cache: write through
sda: unknown partition table
Соответсвенно при выполнение команды :
debian:~# mount /dev/sda /mnt/
mount: you must specify the filesystem type
Стоит debian sid.
gabber@debian:~$ uname -a
Linux debian 2.6.23.12 #1 SMP Sun Jan 6 16:04:00 MSK 2008 i686 GNU/Linux.
У кого есть какие еще идеи?
e-yes
сообщение 6.1.2008, 23:34
А явно задать тип фс?
mount -t vfat /dev/sda /mnt/
Mayuka
сообщение 6.1.2008, 23:52
debian:~# mount -t vfat /dev/sda /mnt/
mount: Носитель не найден
хотя dmesg все видит :
usb 1-2: new full speed USB device using uhci_hcd and address 4
usb 1-2: configuration #1 chosen from 1 choice
scsi2 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 4
scsi 2:0:0:0: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
scsi 2:0:0:1: Direct-Access Motorola MSnc. PQ: 1 ANSI: 4 CCS
sd 2:0:0:0: [sda] Attached SCSI removable disk
sd 2:0:0:1: [sdb] Attached SCSI removable disk
sd 2:0:0:0: [sda] 3931904 512-byte hardware sectors (2013 MB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 03 00 00 00
sd 2:0:0:0: [sda] Assuming drive cache: write through
sd 2:0:0:1: [sdb] 128671 512-byte hardware sectors (66 MB)
usb 1-2: reset full speed USB device using uhci_hcd and address 4
sd 2:0:0:1: [sdb] Write Protect is off
sd 2:0:0:1: [sdb] Mode Sense: 03 00 00 00
sd 2:0:0:1: [sdb] Assuming drive cache: write through
Дальше :
debian:~# lsscsi
[2:0:0:0] disk Motorola MSnc. /dev/sda
[2:0:0:1] disk Motorola MSnc. /dev/sdb
Видят флеш.Дальше уже интерестно:
debian:~# scsiadd -s
could not add device 0 0 0 0 : No such device or address
could not add device 0 0 1 0 : No such device or address
could not add device 0 0 2 0 : No such device or address
could not add device 0 0 3 0 : No such device or address
could not add device 0 0 4 0 : No such device or address
could not add device 0 0 5 0 : No such device or address
could not add device 0 0 6 0 : No such device or address
could not add device 0 0 7 0 : No such device or address
could not add device 0 0 8 0 : No such device or address
could not add device 0 0 9 0 : No such device or address
could not add device 0 0 10 0 : No such device or address
could not add device 0 0 11 0 : No such device or address
could not add device 0 0 12 0 : No such device or address
could not add device 0 0 13 0 : No such device or address
could not add device 0 0 14 0 : No such device or address
Даже не знаю что делать. Каким надо обладать талантом что бы сделать телефон на linux который с linux не работает нормально (((
e-yes
сообщение 7.1.2008, 0:32
Они ж его в сотрудничестве с Майкрософт делали...
Mayuka
сообщение 7.1.2008, 0:42
Что могу сказать ужас....Вот понять что не хватает этому телефону или самим никсам что бы примонтироваться.
debian:~# scsiadd -p
Attached devices:
Host: scsi3 Channel: 00 Id: 00 Lun: 00
Vendor: Motorola Model: MSnc. Rev:
Type: Direct-Access ANSI SCSI revision: 02
Host: scsi3 Channel: 00 Id: 00 Lun: 01
debian:~# scsiadd -a disk
Сообщение отредактировал Mayuka - 7.1.2008, 0:45
Shadow_ru
сообщение 7.1.2008, 8:49
Пользователь №: 65 077
Модель телефона: L7
Нужен ПЕРВОЙ категории, т.е. 1PR в маркировке.
Ваши беды тут.
P.S. То что телефон на Линуксе не отменяет важности радиуса кривизны рук.
Mayuka
сообщение 7.1.2008, 9:27
Ваши беды тут.
Какая разница что стоит? Не люблю когда первым делом советуют сменить os . Провод использую родной.
P.S. Еще напишите : "И ещё тряпочкой экран протри"
Сообщение отредактировал Mayuka - 7.1.2008, 9:33
e-yes
сообщение 7.1.2008, 9:35
Shadow_ru, если бы вы, товарисчщ потрудились бы прогуляться по вышеуказанной ссылке, то этого бреда про кобеля-производителя кабеля не постили. Речь именно про кривую реализацию umass в мотороловских изделиях. Если всё-таки более-менее линуксоид (а не только человек, который читал про редхат в глянцевом журнале) - см. /usr/src/linux/drivers/usb/storage/unusual_devs.h
Но дабы не утруждать вас сильно поиском, зацитирую:
/* patch submitted by Davide Perini <perini.davide@dpsoftware.org>
* and Renato Perini <rperini@email.it>
UNUSUAL_DEV( 0x22b8, 0x3010, 0x0001, 0x0001,
"Motorola",
"RAZR V3x",
US_SC_DEVICE, US_PR_DEVICE, NULL,
US_FL_FIX_CAPACITY | US_FL_IGNORE_RESIDUE ),
* Patch by Pete Zaitcev <zaitcev@redhat.com>
* Report by Mark Patton. Red Hat bz#208928.
UNUSUAL_DEV( 0x22b8, 0x4810, 0x0001, 0x0001,
"Motorola",
"RAZR V3i",
US_FL_FIX_CAPACITY),
Ппц. То, что телефон на Линуксе... Произносить шепотом, с важностью. biggrin.gif
Дык на хосте тоже Линукс, при чём тут руки, они вообще ж без кабеля должны уметь коннектиццо. Иначе не юниксы biggrin.gif tomato.gif biggrin.gif
Shadow_ru
сообщение 7.1.2008, 11:19
Модель телефона: L7
Дык, я и говорю, поставить RedHat. Там уже оно есть.
Мне лично лень объяснять как там перекомпилять что надо и т.д.
Насчёт провода зря ржёте, можете ободрать экран с какого-нибудь кабеля и попробовать.
Mayuka
сообщение 7.1.2008, 13:54
Shadow_ru,если Вам нечего сказать то лучше помолчите.
Сообщение отредактировал Mayuka - 7.1.2008, 13:55
tishka
сообщение 7.1.2008, 16:43
Пользователь №: 159 274
Модель телефона: Z6
да, оч хочется, чтобы заработало ...
Но устройств никаких не появляется кроме
sg0-sg3 ... пишет что SCSI ... но монторивать особо нечего
Ось Kubuntu 7.10
Добавлено позже (7.1.2008, 18:58):
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usb 5-1: reset high speed USB device using ehci_hcd and address 2
scsi 2:0:0:0: Attached scsi generic sg2 type 0
scsi 2:0:0:1: Attached scsi generic sg3 type 0
вот что dmesg написал
asaw
сообщение 7.1.2008, 18:36
Пользователь №: 151 876
Модель телефона: Z6
dmesg написал, что носитель отсутствует. Т.е. телефон говорит, что в него де карточка не вставлена, когда она на самом деле вставлена. Вот в этом и есть кривость! Там ещё пара таких косяков есть. Ребят, ну вам же написали, что ядро нужно патчить на предмет отключения проверки наличия носителя, проверки реального размера ностителя и т.п., чтобы оно нормально с этим телефоном работало, а не игнорировало его как испорченный.
Патч для 2.6.23 прилагаю.
Mayuka
сообщение 7.1.2008, 20:18
Ядро 2.6.23.12 пропатчил но толку ноль.
tishka
сообщение 7.1.2008, 20:30
Модель телефона: Z6
в таком случае он бы видел внутренний диск ... наверное
Mayuka
сообщение 7.1.2008, 20:51
Он видет оба диска но не может их прочитать.
Удалось только добиться :
Attached devices:
Host: scsi2 Channel: 00 Id: 00 Lun: 00
Vendor: ATA Model: ST3808110AS Rev: 3.AA
Type: Direct-Access ANSI SCSI revision: 05
И гном пытается автоматом примонтировать флешку телефона но у него ни чего не получается )) и ручками тоже не монтируется.
Сообщение отредактировал Mayuka - 7.1.2008, 22:02
tishka
сообщение 7.1.2008, 21:11
Модель телефона: Z6
Интересно, а что производитель на это скажет?
"Купите винду и не морочьте нам голову!!!"?
e-yes
сообщение 8.1.2008, 0:38
Отправил запрос в саппорт с сайта. Вообще, как у моторолы с техподдержкой? У меня такое ощущение, что не очень гуд - тикета на мыло не пришлоsad.gif
Mayuka
сообщение 8.1.2008, 0:42
Заметил что флешки все таки определяются. Появляются записи в /proc/partitions и соответсвенно при попытке монтирования или fstab -l флеш телефона или карты отваливаются полностью.
Abram
сообщение 8.1.2008, 11:57
Прелесть какая гадость
Из: .ru - рідна Україна
Пользователь №: 44 825
Прошивка: CyanogenMod
Бред, бред, бред!!! Тянем по вышеуказаному линку 3 патча, кроме того я выложивал их на мотофане. Патчим ядро. У меня работает. После пересборки ядра Gnome сам увидел флешку и усе пошло ОК. Если у кого-то нет - проверяйте радиус кривизны рук.
Добавлено позже (8.1.2008, 13:59):
Кстати, Мото о баге знает. Я и не только я уже неоднократно им писали.
Сообщение отредактировал Abram - 8.1.2008, 11:58
Mayuka
сообщение 8.1.2008, 12:01
Все перепроверил но не хочет работать (( Отваливается при первом монтировании.
Abram
сообщение 8.1.2008, 12:04
Проверяй кривость рук и/или дистрибутива. smile.gif Де-то через неделю-две смогу выложить уже готовое патченое ядро под Убунту.
Добавлено позже (8.1.2008, 14:07):
А вот этого не надо! Если нормально пропатчено - то должно пойти все само. Ищи патчи в мейл-листе, должны быть 3 патча. Тогда работает. Баг в том, что Мотор неправильно выдает компу инфу о своем юсб.
tishka
сообщение 8.1.2008, 12:20
Модель телефона: Z6
Ну если бы они свою прошивку поправили было бы намного лучше ... чем при каждом апгрейде системы пересобирать ядро только для подключения мобильника sad.gif
Хотя конечно фиг кому что докажешь, а тело еще на гарантии ...
Ujeen
сообщение 9.1.2008, 1:45
Из: эта планета
Пользователь №: 23 025
Модель телефона: V180 -> ROKR Z6
Я из-за этого бага был в бешенстве,когда телефон купил. Предвкушал, как я сейчас начну мобилу под себя настраивать и т.д. и этот баг как фанерой по ягодицам.
Сейчас я в двойном бешенстве из-за того что Моторола просто игнорирует проблему.
я не хочу патчить ядро этими патчами, потому что это не патчи, а наоборот дырки в ядре, потому что когда мне попадется реально порченный аппарат и я его подключу по юзб, то из-за этого "патча" последствия будут непредсказуемы ! И от осознания этого мне хочется сильно и громко ругаться матом...
У меня винды нет и я в длительной командировке и музыку в телефон я, как заумнейший перемудак, заливаю в 2 этапа сначала на старенький palm, который прекрасно монтируется, а затем блютусом по одной песенке на мобилку - рррр
Сообщение отредактировал Ujeen - 9.1.2008, 1:48
tishka
сообщение 9.1.2008, 15:08
Модель телефона: Z6
пока буду юзать картридер
Mayuka
сообщение 9.1.2008, 18:18
Плюс на последнем ядре патчи работают через одно место...
Abram
сообщение 10.1.2008, 5:44
Rusher
сообщение 10.1.2008, 11:57
Из: Украина, г. Бровары
Пользователь №: 40 146
Модель телефона: Motorola DROID
Прошивка: Cyanogen Mod 5.0.4.2
Abram, подтверждаю, всё работает отлично.
Патчил три файла следующим образом:
I. В файле drivers/scsi/scsi_sysfs.c редактируем static int scsi_bus_match таким макаром:
static int scsi_bus_match(struct device *dev, struct device_driver *gendrv)
struct scsi_device *sdp = to_scsi_device(dev);
if (sdp->no_uld_attach)
return 0;
return 1;
// return (sdp->inq_periph_qual == SCSI_INQ_PQ_CON)? 1: 0;
II. Добавляем в конец файла drivers/usb/storage/unusual_devs.h следующее:
/* Reported by Andreas Koenecke <[EMAIL PROTECTED]> */
UNUSUAL_DEV( 0x22b8, 0x6426, 0x0101, 0x0101,
"Motorola",
"MSnc Z6",
III. Находим в drivers/usb/storage/transport.c слудующюю строку:
if (bcs->Tag != us->tag || bcs->Status > US_BULK_STAT_PHASE) {
меняем на:
if (bcs->Status > US_BULK_STAT_PHASE) {
Вот и всё. Компилим и устанавливаем ядро.
После этого всё монтируется автоматически.
P.S. Патчил на Ubuntu 7.10, ядро 2.6.23.13.
Сообщение отредактировал Rusher - 10.1.2008, 12:05
Mayuka
сообщение 11.1.2008, 20:14
Так и делал ))) Система Debian sid. Плюнул поставил PoL и заливаю все что нужно по ftp благо usbnet работает стабильно ))).
Shadow_ru
сообщение 12.1.2008, 21:11
Модель телефона: L7
Debian есть зло от непонятных майнтайнеров. Юзайте RedHat, как я вам и предлагал.
Mayuka
сообщение 13.1.2008, 15:57
Проблема оказалась не в кривизне рук и даже не в системе,а в флешке Kingston microSD 2 gb. C родной флешкой и без флешки все монтируется на ура.
P.S. Shadow_ru а не пошли бы вы с своими предложениями что использовать куда подальше.
Rusher
сообщение 14.1.2008, 7:29
ПРисоединяюсь к этому...эээ...грубому замечанию...
Shadow_ru, рекламируйте Red Hat, где-нибудь в другом месте.
e-yes
сообщение 14.1.2008, 9:55
Интересно, что на рабочем компьютере, монтирование заработало... чудеса да и только.
e-yes@zion ~ $ uname -a
Linux zion 2.6.23-gentoo-r3 #2 SMP Wed Jan 9 17:55:34 MSK 2008 x86_64 AMD Athlon™ 64 X2 Dual Core Processor 5600+ AuthenticAMD GNU/Linux
Mailik
сообщение 24.5.2008, 15:31
Пользователь №: 133 755
Модель телефона: ROKRZ6
Прошивка: 44R+PoL
Патчил ядро 2.6.23 полёт был нормальный. Пересел на генту, пропатчил 2.6.24 результат нулевой. Заметил что разработчики переписали немного tranport.c. Кто нибудь сталкивался с таким?
Сообщение отредактировал Mailik - 24.5.2008, 15:36
nsk_qwerty
сообщение 24.5.2008, 15:42
Из: Новодвинск
Пользователь №: 40 788
Модель телефона: HTC Desire
Прошивка: Stock Froyo
Mailik, в генте патчи для мото есть в патчсете r4
Mayuka
сообщение 24.5.2008, 15:46
в ядре 2.6.25 появилась поддержка телефона : USB: add support for Motorola ROKR Z6 cellphone in mass storage mode
Abram
сообщение 24.5.2008, 16:54
aSh.
сообщение 14.6.2008, 0:16
Из: Odessa, ua
Пользователь №: 174 469
Модель телефона: Z6, E398, V600, C155
не только появилась, а и реально работает. монтируется по команде #mount -t vfat /dev/sda(sdb) /mnt/usb проверено лично smile.gif
z6 - монтирование, на Linux хосте · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 29.7.2025, 18:32
