Inferno_Green&Blue_MP 49R now boot 07.D0 and 0A.02, забавный монстр
Inf
сообщение 31.3.2008, 0:18
Пользователь №: 167 997
Прошивка: Е398+А1200е+V635
Представляю МП иностранного происхождения
Железо
- S/W : R373_G_0E.30.49R Original
- Flex: Inferno Green MP
- DSP : 6242A200
- Technology: Quad Band GSM
- BOOT 07.D0 and 0A.02
Языковой пакет
-R373_Eng_Lithu_BrPort_Esp_Russ_Serb
(English, Portugues, Espanol, Ruso, Serbio, Lituan)
Память:
- Всего: 6621KB, Использованно: 5713KB, Свободно: 907KB
DRM:
-Inferno DRM
-DRM Optimized in MotoSpeed 1.1
Corelets:
-Media Viewer by Valleo with plugins on Extras (iPhone green skin)
-Virtual Corelet
Скины:
-NoName II F3D
-PrisTine
-Black Angel 2 by maxto
тут переводить стало лень ) в принципе понятно всем
Features:
+Unlimited Dictaphone
+you can Volume Up/down videos/sounds in multimeda.. & volume up/down tone is disabled
+in msg outbox rightsoft button changed to details
+60 dialed/received calls
+store up to 178 messages
+ camera quality is improved with patch for Better photos (olympus quantization table)
+Blacklist
+date will be always shown even if you using GPRS
+no confirmation on delete
+video recording in *.mp4 format
+ Restart phone +Shortcuts (84)+
+Roam calls are using default ringtone from your ringstyle
+backgrounds in default audio player (walls are inside skins folders)
+switch to next track in audio player (sounds options Times: Meter to skip next track, Elapsed time
to skip to previous track)
+switch to next track in Video
+sms delievery reports (you can turn it on in message options & it will stay on, try it few times if u
have problems)
+no limits for playing mp3 files
+Edit next play with Free hands
+ Elf pack Compatible
+ No change ring style when charges connect.
+ Fast on cel
systemsounds:
-BGF.
Startup&Shutdown anim&sound:
- Inferno Gif’s and Sound’s
Мультимедия:
-wallpapers (16wps & new ems smiles)
-sounds (21mp3 & 2amr)
-video (Usb flash drive speedup.3gp)
Javas:
Gmail, GP editer, Irecorder,, MediaViewer, MP3 tools, Opera mini 4, Students calculator2, Synerj tools 49R, Windows Live Messnger, Mini commander, Virtual corelet, file changer, GP_PT_mma_ucp.
Shorcuts:
press 1x camera button it opens camera, press 2x it opens video camera
Menu + # changing style warning to the style of "Loud"
Menu + 0 to access opcode menu
Menu + Menu : go back to Main Menu from everywhere
0 + # quick access to "Sound"
0 + * quick access to "Pictures"
Red+Red flashlight
*#06# IMEI
Menu + 1 Media viewer
Menu + 2 virtual corelet
Menu + 3 mini comander
Menu + 4 Battery meter
Menu + 5 date book
Menu + 6 Usb Settings
Menu + 7 Storage divices
Menu + 8 Synerj Tools 49R
Menu + 9 Skins
Menu + 10 FuntLigh
Menu + 11Elf Pack´s
Menu + 84 Reset Cel
Patches:
2xmenu=enter menu everywhere
Access sounds by pressing 0+# and pictures by pressing 0+*
Added change ringstyle shortcut (Menu+#)
Added new symbols to type
Alarm 5m
Alarm (LeftSoftKey change to Edit)
Alarm_in_ss 49
auto video switch patch
Background in default music player
Battery
Better photos (Olympus quantization table)
Bluetooth availability time - 3 minutes
Camera button, press 1x camera 2x videocam
Change display activity (20 sc, 40 sc, 1 minute, 2 minutes)
Change menu opcode shortcut to Menu + 0
Change symbols order when entering text
Changes the size of number
Changed menu order in sounds, video and video camera
Change keypad lock(Menu+red) unlock (4+8)
Complete access to the phone file system (java, bluetooth, OBEX)
Corelet seem 4a access
Corelets are shown in java list
Default iTAP on corelet
Digital_and_Analog_Clock1.02
Do not delete calls when changing sim card
Don't check java signatures
Elf packs
Fifth group (black list)
Flashligh (red+red)
File wap
Green in call fix(press for a little time access to input call)
Hours into status to line 1.56 fix
Increase number of autoredial attempts
Increase Heap49
Increase java heap 1400K for E398_49r
icon_rc_inss_49R
Java black loading background
Java full access patch
Java with cable works
Left soft key - send in phonebook
Listen to Temporary audio
MMS limit - 300kB
Name and time in the alarm clocks list
menu_powerdown_49R
New keypadlock patch (allows you check imei).
new_recent_call_49R
No busy audio channels when battery low
NoJavaIcon_49
No MP3 bitrate limit
No vibe and sound when changing volume
Play next track instead of repeat
Reboot instead of chat (menu + 84)
Remove java protection
Remove P2K Write-protect from all locked seems
Remove system files limitations
RGF sytemsounds
Send file through BT devided into 5 groups with icons
SMS delivery report patch 1.18
Sort files in Animation
Store photos without menu
Time update 49R
Zoom is changed to 250% and 200%
Extras
+ iTunes_MOD_4.52Pro™
+ Skin media viewer
+ Imagen for TF
+ Extra gain tables
+ Elf pack
Ссылочки для скачивания:
на E398
на E1
Рефлеш на Е1
Ответов(1 - 29)
Rene
сообщение 31.3.2008, 4:18
Пользователь №: 73 537
Модель телефона: Z6+2G
Прошивка: PE2.0
Он кстати не новый...
Dim@
сообщение 31.3.2008, 6:28
Из: Харьков
Пользователь №: 141 597
Модель телефона: Rokr E1
Прошивка: часто меняю
Мне не очень понравился, ДРМ вообще не понравился (батарея не подходит ко всему дрм-му) Скины не совсем новые
MucTuk
сообщение 31.3.2008, 10:24
Из: Moscow
Пользователь №: 85 049
Модель телефона: v3x
Прошивка: 0.8.6.2
звук не оч чистый, хоть и достаточно громкий... скины - в аут... вообще не порадовал... не нашел ничего забавного в монстре ph34r.gif
Zhenek_
сообщение 31.3.2008, 10:28
Пользователь №: 128 350
Модель телефона: HS820
ничего нового как всегда.....
Mario7
сообщение 31.3.2008, 10:31
Пользователь №: 91 640
Модель телефона: С380&Е398
Прошивка: Volcanur & Deluxe
сорри но что в нём забавного?
AlexKooper
сообщение 31.3.2008, 11:34
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
Нижний скин как называется? Выложьте кому не жалко
tsesaleks
сообщение 31.3.2008, 11:54
Из: Тюмень
Пользователь №: 147 944
Модель телефона: E398,V3i,К1,Z10
Прошивка: R4441D_G_08.03.05R
Я его пробовал ставить, но вот такая ерунда, после прошивки экран мигает, вытаскиваю батарею, снова ставлю, перевожу в бут, старая прошивка на месте, тело не прошилось и так раза три и не только у меня, все кто прошивался этой прошивкой, такая же ерунда, что это могло значить?
knd
сообщение 31.3.2008, 13:33
Из: Оренбург
Пользователь №: 60 073
AlexKooper,
Нижний скин это black angel 2 by maxtor, его можно найти в теме с монстром black Angel 2, там есть ссылки.
tsesaleks
сообщение 31.3.2008, 14:53
Из: Тюмень
Да не кто его не ставил, потому что, он не ставится, Inf, а ты не выставляй на обозрения, когда сам не ставил, ты его хоть проверил? Вот то-то же.
MucTuk, молодец, как ты мог услышать звук, когда сам автор lusifer84 , писал, что прошивка глюкнутая и он доработает его и выставит, каже нестыдно врать? смотрите сами форум http://motohell.com/index.php?topic=2249.0 , после такого вранья у меня к вашим выссказываниям доверия нет. mad.gif
Dim@
сообщение 31.3.2008, 16:25
Из: Харьков
Его ставить даже не надо по скринам видно что ........
MucTuk
сообщение 31.3.2008, 18:40
Из: Moscow
Прошивка: 0.8.6.2
tsesaleks, я ставил не совсем его, а с ссылки моего немецкого знакомого переведенного с elektro.. ошибся, думал это тот же =)))
если честно, то мне на твои слова
с высокого моста...
1) не судите и не судимы будите
2) кто без единого греха...
есть монстр переложенный с elektro толька я не могу его найти + этот немецкий парень ща как раз летит домой от нас, так что "думайте сами, решайте сами"
да и ставить его я просто не советую, так что если даст тот парень сцылку - выложу, а так - хз
Добавлено позже (31.3.2008, 22:43):
+ read this, great englishman :
i use f&b3 and does not give me never problem check is for boot 07.D0
it means
я использую фб3 и у меня нет никаких проблем с бутом 07.Д0
Сообщение отредактировал MucTuk - 31.3.2008, 18:41
Orphen
сообщение 1.4.2008, 7:54
Пользователь №: 162 644
Модель телефона: E398, PSP Slim&Lite
Прошивка: Life II Gold xD
я ставил этого монстра. только качал с иностранного сайта. все нормально работает. не понравилось излишне мрачное оформление. зато мелодии которых нет ни у кого)
tsesaleks
сообщение 1.4.2008, 11:34
Из: Тюмень
Orphen, если не трудно, выложи мелодии.
Orphen
сообщение 7.4.2008, 8:10
могу выложить но только две песеник. остальные не понравились и брать не стал. если надо монстр могу выложить куда нить полностью. он оригинально сделан но оформление на любителя.
tsesaleks
сообщение 7.4.2008, 12:50
Из: Тюмень
Orphen, если не трудно, выложи здесь, в этой ветке, напиши, что первая ссылка с нерабочим монстром, а твоя с рабочим, скины те-же.
Orphen
сообщение 7.4.2008, 18:12
ссылка с оригинального сайта. сам от туда качал версия для е398 http://www.4shared.com/file/40106585/85ffb...rified=f18c18fc
для е1 http://www.4shared.com/file/42724860/f2c19...rified=f18c18fc
tsesaleks
сообщение 8.4.2008, 11:55
Из: Тюмень
Orphen, я эту ссылку знаю, вот он и не ставится.
Orphen
сообщение 8.4.2008, 12:46
хз. у меня вполне работал етот мп. на нем иностранный автор даже русский язык поставил. но шрифт не разборчивый сделан под иероглифы. да сдался тебе етот мп) все равно ничего революционного прямо)
tsesaleks
сообщение 8.4.2008, 13:12
Из: Тюмень
Orphen, просто хочется всё увидеть своими глазами, да что обьяснять, сам понимаешь, просто руки чешутся.
MucTuk
сообщение 9.4.2008, 8:22
Из: Moscow
Прошивка: 0.8.6.2
иностранные монстры не очень.. единственное что от туда можно брать это некоторые картинки и мелодии...
наши парни лучше делают... и оформление и патчи и сами МП в целом...
я обычно скачиваю монстры иностранные ради скинов и посмотреть как батарея держит... а так - сношу через 1-2 дня...
надо дождаться the Life 2 и поосмотреть что там намутили...
кстати... в этом МП дрм собран из четырех вроде... он налюбителя, мне ОЧ не понравился... не состыковываются цвета да и звук там не оч... добавили много низких частот...
Orphen
сообщение 9.4.2008, 21:16
Ну на счет иностранных монстров позволь не согласиться. сижу на мотохеле. поменял только скины эльфы и все путем работает. глюков нет совсем
djfox08
сообщение 10.4.2008, 12:33
Из: ~Г~УфА~РБ~
Пользователь №: 167 972
Модель телефона: ~Ёш398~
Прошивка: djfox&StarRap
чё т я тут посмотрел на всё...посчитал нужным поставить его...потом пожалел...фиговый монстр..отечественные лучше=)очередной раз убедился что тут большинство чел право!! smile.gif
Warped
сообщение 14.4.2008, 17:03
Пользователь №: 164 003
Модель телефона: C75, S75, RoverPC S2
Прошивка: sw22\sw52\WM 2003SE
Шрифты прикольные, только что с русским?
wallkman
сообщение 29.9.2009, 16:03
Пользователь №: 207 135
темы прикольные!по софту тож нечего))) а вот шрифт этот меня раздрожает
Красный
сообщение 30.9.2009, 11:53
Пользователь №: 197 555
Модель телефона: е398
Прошивка: Dream a Reality 1.3
seregagt1990
сообщение 16.10.2009, 14:03
Пользователь №: 207 646
Прошивка: R373_G_0E.30.79R
А дайте ссылку на скины из этого монстра плиз!?
ansemn
сообщение 14.1.2010, 6:30
Пользователь №: 204 311
Модель телефона: a1200е
Прошивка: DiamondRC4
Скажите как
блок\разблок клавы в этой прошивке???????
PItBuLL
сообщение 14.1.2010, 7:40
Из: Волгодонск
Пользователь №: 154 213
Модель телефона: Atrix 4G
как у Стаса!
ansemn, в первом посте вроде все написано.
сообщение 19.4.2010, 18:30
отстой а не проша, не в обиду автору и всем пользователям е398.
Inferno_Green&Blue_MP 49R now boot 07.D0 and 0A.02, забавный монстр · Кастомные прошивки для Motorola E398, E398B, E399, E375, E378i, C698p, E790, ROKR E1 · Forum
Текстовая версия Сейчас: 28.7.2025, 12:25
