New FW 16r By loko_vr
PauloGSM
сообщение 20.5.2008, 16:53
Пользователь №: 172 796
Модель телефона: Motorola A1200 2Gb
Прошивка: 16r
Full specifications:
-- New feature of insersão automatic prefix of the long distance carrier.
-- Option to set the speed of the context menu.
-- Option of automatic adjustment of daylight saving.
-- RV works with flip closed.
-- Manage bluetooth with flip closed
-- Make and receive calls, viewing recent calls and contacts with flip closed.
-- 3 USB modes - Modem, USB Drive, USB Network.
-- Good battery life. (virtually the same as 24xps, 24xp30)
-- The "Phone speaker" read all messages in Portuguese.
-- Camera good with an option to automatically save and Silencio
-- Filming in the resolutions 176x144, 320x240 and 352x288
-- Pulp native "bin" reinstated with files as bash2 and VIM
-- It comes with the profiles of all network operators from Brazil
-- File "plmn.data" of 16R containing the insformações's network also live, so that's chip uses live no longer has that "problem" to appear 724-XX instead of the name of the operator in the home screen.
-- Java Heap Size changed from 4 to 5. This is get increased performance of 3D graphics in Java Apps.
-- Added support to the startup's two (startup.txt and startup1.txt)
-- Option "report delivery" enabled by default
-- Languages included: BR Portuguese, English, Spanish and French.
-- The gifs the boot and closure of the original 16R
-- Bootscreen tb was changed to the one 24xps.
-- Ringones default in the FW:
Mid
* Alert's 1, 3 and 4;
* Notification's 1, 2, 3, 4 and 5;
* Polyphonic_Alert's 1, 2 and 4;
* High_Capacity;
* Somewhat.
MP3
* Hyperactive;
* Passion.
AAC (These are new. Withdrew a monsterpack gringa, but I do not remember which!)
* Chat_alert
* E-mail 1 and 2;
* Message 1, 2 and 3.
-- All 4 of the home screen icons can be changed.
-- 3 themes of the original a1200e
-- In the file manager 3 of 7 default folders created the phone may be deleted.
-- Even in the file manager, the folders are no longer the names as "My Videos", "My Pictures", etc.. Now is "Videos", "Images", etc.. The vision was cleaner and easier viewing. Moreover, if you are on your phone, of course it is yours, do not even need to say! Rsrsrs!
-- Icons of folders and files changed. (Say goodbye to folders with flowers and hearts!)
-- New icons on the main menu.
-- The acronym GPRS "disappeared" from the Portuguese language in FW, replaced by the acronym EDGE
-- Picsel in Portuguese (New version: 1.0.16 Build 4183)
-- Opera in Portuguese (Version 8.00 Build 3172)
-- Source changed to the original FW 24xp30 that supports up to Chinese characters.
-- Font size decreased in the language en-in the following measures: (A visualiação tah better, beautiful +)
Small, 15 = p / 13
Average of 18 = p / 15
Much of 21 = p / 18
Note: flashear After your phone, you probably vai be getting a lot of messages from your carrier! If you do not know how to disable this, click here
Changes in sound:
-- New sound of initiation.
-- Sound of receiving files via bluetooth and USB connection "Device Conected.wav" was amended.
-- Sound of touch in "Tom" (Touch_Scr_Tone.wav) tb has changed.
-- Sound of closure "Hard_Key_Hold.wav" amended.
-- Sound the keyboard standard "Hard_Key_Default.wav" is silent (so the keyboard only makes noise at the time of shutdown, pq barulinho that the keyboard with time irritates !!!!)
-- Archive ezx_volumetable.cfg changed. The general volume of phone is very good, but the headphone out is great! (It is the same as the Elite)
Note: Qdo cn flashear your phone, the folders will be created tb "preload", "MyPrograms" and another now that I forgot the name, however, if you wish, you can delete them!
Applications Inclusos:
-- SmartAssistance in Portuguese.
-- Business Card reader.
-- Explorer (My Stuff, for viewing files of system)
-- Netcontrol (pra Samba, Telnet, access to the Internet by the PC, etc. ...)
-- EKonsole with native bash2
-- ILock (for blocking the "telcado" iPhone style)
Bugs:
-- Do not load the battery when plugged into the computer by USB
-- Some apps more complex as Opera Mini and MScreen, are presenting problems that FW.
NOTE: The QT apps (PKG's) that you already have installed on your memory card may not work in FW, to correct this, do the following:
-- Open the file in the folder that is CardRegistry / .system / Java with Wordpad or Metapad (not with the notebook)
-- Edit the QT apps one by one, moving the item "Attribute" from "4" (probably) to "2" and the item "Directory" which will probably have only the name of the app as a value, you have to add the full path of folder on app, ie / mmc/mmca1/.system/QTDownLoad/AppNameFolder
Link 4shared: http://www.4shared.com/account/file/482860...r_PT-BR_V1.html
FW This was based on the Portuguese language, it is necessary to implement the Russian LP!
Prior to FW on YouTube: http://www.youtube.com/watch?v=8993kYwwb9g
All rights reserved to GSMFans.com.br
____________________________________________________________________________
Sorry for the bad language, I used Google translator to translate this information.
tmp_do
сообщение 20.5.2008, 18:13
Пользователь №: 146 016
Модель телефона: HAINAN
Прошивка: hand made & custom
it is mod? do you have FULL original firmware?
Добавлено позже (20.5.2008, 22:15):
what's BP in your mod?
зы. без оригинальной бп это тухляк...
Lubomyr
сообщение 20.5.2008, 18:57
Из: Україна, Львів
Пользователь №: 49 683
Прошивка: Android 2.1
Цитата(leevgenij @ 20.5.2008, 21:39) *
А ей вообще шиться можно или будет гитлер капут. Язык интересно есть хотябы аглицкий или только португезе?
PauloGSM
сообщение 20.5.2008, 19:20
Прошивка: 16r
Цитата(KaleB87 @ 20.5.2008, 14:38) *
Эта прелесть, прошивка????
I do not have the Full version... I do not think anyone has... Ja tried everywhere but not found...
Добавлено позже (20.5.2008, 15:56):
I do not speak Russian, only translate the Google translator ...
Barbaro
сообщение 20.5.2008, 20:19
Пользователь №: 172 347
Модель телефона: A1200i
Прошивка: 1FR
O Sr é um fanfarrão Sr Paulo GSM hehehe
Até aqui o sr ta!
vou falar russo agora
Простите, я не говорю российские и бразильские также
Я использую переводчика pra писать.
Это микропрограммы было отредактировано loko_vr, бразильские членом форума. Они могут usala тихо, поскольку она работает прекрасно.
Поздравления российские друзья!
Barbaro
сообщение 20.5.2008, 21:37
Прошивка: 1FR
sorry BenLaden
I tried to write in Russian translator using google
but the message above I only recommended the firmware
can use because it is an excellent firmware
Мэн в наушниках
сообщение 21.5.2008, 10:09
Пользователь №: 64 390
Модель телефона: iPhone 3Gs
Прошивка: 3.0
Цитата(maximus2963 @ 20.5.2008, 22:49) *
белый
черный
атлантик
PauloGSM
сообщение 21.5.2008, 10:48
Прошивка: 16r
Até aqui o sr ta!
Pois é! Estou por toda parte rsrsrsrs!!!
Vamos ver se apartir dessa FW o pessoal faz umja edição perfeita!
Eu coloquei a fonte, será que eles vão nos visitar também?
Добавлено позже (21.5.2008, 7:23):
Цитата(maximus2963 @ 20.5.2008, 17:53) *
PauloGSM, Where I can download skins from your firmware?
I do not have the Skins separate ... But I will see if I ...
Добавлено позже (21.5.2008, 7:31):
The official link that FW is this:
http://www.gsmfans.com.br/index.php?topic=5702.0
leevgenij
сообщение 22.5.2008, 17:05
Из: Сальск
Пользователь №: 165 878
Модель телефона: a1200e
Прошивка: AMINS
Мужики так на каком она буте?
Silent_Bob
сообщение 12.6.2008, 15:19
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
Если я её прошью, я смогу откатиться обратно ???
CatSoup
сообщение 12.6.2008, 17:25
Из: г. Омск
Пользователь №: 144 759
Модель телефона: L7e+а1200е
Прошивка: NewStyle+Iris
Фиг бы их знал на каком. Эх, мож заглянут скажут. Thanks, this is а wery good mod, but we can't test it because we don't know loader's version. Please tell this one.
Сообщение отредактировал CatSoup - 12.6.2008, 17:30
Silent_Bob
сообщение 13.6.2008, 1:24
Городской партизан
Прошивка: Готичная
Насколько я понял это прошивка "C2" серии ...
Сообщение отредактировал Silent_Bob - 13.6.2008, 2:04
Silent_Bob
сообщение 18.6.2008, 16:43
Городской партизан
Прошивка: Готичная
Народ вы мне скажите pls : можно с неё откатится будет или нет ???
Я б к ней клаву от Busterа прикрутил бы и всех-то делов (может пришлось бы шрифт менять) ...
Руссифицированный интерфейс мне не нужен ... английского хватит ... shuffle.gif
Добавлено позже (18.6.2008, 20:44):
Хотя и его добавить не сложно - я так полагаю ... (ну кроме клавы по умолчанию) ... ph34r.gif
Сообщение отредактировал Silent_Bob - 18.6.2008, 16:47
leevgenij
сообщение 19.6.2008, 13:36
Из: Сальск
Прошивка: AMINS
=Хотелось бы попробывать этто чудо, но боязно
Bonzic
сообщение 19.6.2008, 17:46
Из: Ташкент
Пользователь №: 85 978
Модель телефона: A1200,N95 8G
Прошивка: F5
прошил поверх F5 !! кнопка голоса работает при закрытом флипе !! английский присутствует !! на следующий день поставил F6 !! всё работает !!
Silent_Bob
сообщение 19.6.2008, 19:03
Городской партизан
Прошивка: Готичная
Есть новее версия http://www.4shared.com/file/51566155/4954d...r_PT-BR_v2.html
Оригинал обсуждения http://www.gsmfans.com.br/index.php?topic=6686.0
tmp_do
сообщение 19.6.2008, 19:42
нивкурю, BP там какой версии? какой флекс? кто поставил,отпишите пожалуйста
_Bolik_
сообщение 19.6.2008, 20:08
Motolancer
Из: UA Львів
Пользователь №: 111 986
Модель телефона: Razr XT910
Прошивка: 4.1.2 JB
разобрал EZXcodec`ом......
ap_version.txt
R532_G_11.00.16Rxps_Loko
base_version.txt
EZXBASE_N_00.42.A3I
modelnum.txt
A1200r
[ezx_timestamp]
ezx_timestamp = 20071121213101
ezx_setup_version.txt
GAS_ASIA_T675VA_E002
ezx_resource_version.txt
GAS_L4_T678PV_R532C2_G_11.30.24P_R002_Loko_vr
tmp_do
сообщение 20.6.2008, 3:43
спасибо. 532C2...нафиг надо...
Silent_Bob
сообщение 20.6.2008, 5:23
Городской партизан
Прошивка: Готичная
Silent_Bob
сообщение 20.6.2008, 12:51
Городской партизан
Прошивка: Готичная
Какая моторолла a1200e или a1200r(i) ???
Добавлено позже (20.6.2008, 17:26):
Прошился - пока всё пашет - щас клаву приделаю ...
Добавлено позже (20.6.2008, 17:38):
Когда дойдёт до 100% - надо включить телефон вручную и ждать надписи PASS ... thumbsup.gif
leevgenij
сообщение 20.6.2008, 14:31
Из: Сальск
Прошивка: AMINS
Ну и как ощущения на первый взгляд?
Silent_Bob
сообщение 20.6.2008, 14:46
Городской партизан
Прошивка: Готичная
Всё здорово но смски па русски не шлёт ... (((
В общем проша как 13-16_rc1 - тока не руссифицированна ...
Добавлено позже (20.6.2008, 18:47):
Есть еще интересная проша
http://www.gsmfans.com.br/index.php?topic=6646.0
http://www.4shared.com/file/51409639/f881d...Hibrida_V2.html
Добавлено позже (20.6.2008, 19:45):
Silent_Bob
сообщение 20.6.2008, 22:13
Городской партизан
Прошивка: Готичная
#!/bin/sh
if [ -f /ezx_user/autorun/icon/iconres.ezx ]; then
    /bin/mount --bind /ezx_user/autorun/icon/iconres.ezx /usr/data_resource/icon/iconres.ezx
fi
if [ -f /ezx_user/autorun/inputmethods/english_emea.kbd ]; then
    /bin/mount --bind /ezx_user/autorun/inputmethods/english_emea.kbd /usr/language/inputmethods/english_emea.kbd
fi
Добавлено позже (21.6.2008, 2:22):
Типа русская клава ... файлы рассувать ... скрипт - в авторан ...
Сообщение отредактировал Silent_Bob - 20.6.2008, 22:18
Silent_Bob
сообщение 21.6.2008, 1:42
Городской партизан
Прошивка: Готичная
Щас прошился Perfectron_Amin_16R_Híbrida ...
Долго шилось - думал телефонЪ здох ...
Вот переделал под русскую клаву ...
Сообщение отредактировал Silent_Bob - 21.6.2008, 1:47
leevgenij
сообщение 21.6.2008, 12:17
Из: Сальск
Прошивка: AMINS
А где саму прошу взять?
Silent_Bob
сообщение 21.6.2008, 12:29
Городской партизан
Прошивка: Готичная
Тут
А тут обсуждение
leevgenij
сообщение 21.6.2008, 16:33
Из: Сальск
Прошивка: AMINS
Подскажи куда iconrez сувать чтоб клава русиш была
Silent_Bob
сообщение 21.6.2008, 16:40
Городской партизан
Прошивка: Готичная
#!/bin/sh
fi
fi
Cобсна отсюда должно быть всё понятно
ps.gif Меня терзают смутные сомнения, что BP:541_G_11.52.13R - вобще не менялся от прошлой проши (13-16_rc1)
leevgenij
сообщение 21.6.2008, 16:44
Из: Сальск
Прошивка: AMINS
Спасибо за разяснение а вообще стоит попробывать или и время не тратить
Silent_Bob
сообщение 21.6.2008, 17:56
Городской партизан
Прошивка: Готичная
Еслиб смски по русски отправляло - былоб шикарно - а так - то же самое что и 13-16_rc1 ...
(Кстати никто не знает как это исправить ???)
ps.gif Вот поправил, а то вводимые символы с нарисованными не совпадали ...
Сообщение отредактировал Silent_Bob - 21.6.2008, 17:58
leevgenij
сообщение 21.6.2008, 18:24
Из: Сальск
Прошивка: AMINS
Бобыч скинь пожалуйста свой авторан а что то не хочет русская клава вязаться И подскажи в какую папку иконрез засунуть
Silent_Bob
сообщение 21.6.2008, 18:46
Городской партизан
Прошивка: Готичная
Уже два раза выкладывал ...
Тут...
Сообщение отредактировал Silent_Bob - 21.6.2008, 18:50
Cent
сообщение 23.6.2008, 2:33
Пользователь №: 172 848
А как насчет тупняка при входящем звонке?? есть такое? спасибо
leevgenij
сообщение 25.6.2008, 13:44
Из: Сальск
Прошивка: AMINS
Практически нет
Бобыч что то буквы печатаются русские а на клавиатуре какието крякозябры
Сообщение отредактировал leevgenij - 25.6.2008, 14:34
Silent_Bob
сообщение 25.6.2008, 15:58
Городской партизан
Прошивка: Готичная
iconres.ezx - это подмонтировал ???
iconres.ezx.gz
Сообщение отредактировал Silent_Bob - 25.6.2008, 16:05
leevgenij
сообщение 25.6.2008, 16:05
Из: Сальск
Прошивка: AMINS
Подмонтировал А вообще прошивка прикольная если б не выподали периодически фразы на португальском был бы идеал
Silent_Bob
сообщение 25.6.2008, 16:06
Городской партизан
Прошивка: Готичная
Kлава как выглядит (screenshot) ???
Добавлено позже (25.6.2008, 20:14):
Видимо неподмонтированно ...
Добавлено позже (25.6.2008, 20:18):
ThemeIconDir = /итд/итп/
Сообщение отредактировал Silent_Bob - 25.6.2008, 16:15
leevgenij
сообщение 25.6.2008, 16:21
Из: Сальск
Прошивка: AMINS
Добавлено позже (25.6.2008, 20:27):
Во как Прикрепленное изображение
Сообщение отредактировал leevgenij - 25.6.2008, 17:05
Silent_Bob
сообщение 25.6.2008, 17:18
Городской партизан
Прошивка: Готичная
Не отображается картинка - но судя по описанию - косяк )))
Добавлено позже (25.6.2008, 21:20):
Тему менял ???
Текстовая версия Сейчас: 13.9.2025, 13:15
