First No RSA 512 MB V8 LM5-SP1
aciddon
сообщение 8.1.2009, 11:22
Из: Украина, Донецк
Пользователь №: 130 096
Модель телефона: RAZR2 V8
Прошивка: Evolution 3
Вот что он пишет:
I have created a No_RSA firmware for the 512MB V8, it is based on the 80.46.1BR and the LP is LP0039A, LP0039B, LP0039C, LP0039D and LP0039E, so it is the LP0039, but with 6 different voice commands (english, german, italian, french, spanish and portuguese).
Other changes are, the Font Mod is the same as in LM5-SP1, but this time the selected font stays even after rebooting. There is still the alarmclock bug when you have change the font, but a quick reboot will cure this. There is no MPlayer, as this always a complete bugger on the 512MB V8, just have to wait until MPlayer has been recompiled for the 512MB V8.
Also missing are FBReader and SnesX as the purpose of them is unclear so far. Otherwise it is the same Linuxmod 5-SP1. Because I could move some of the Linuxmod from the CG52 into the CG36 I was able to increase the preloaded skins to 3 (Alkali, Indium and Golden).
This firmware consists of 4 parts, which you have to follow. There is also a ReadMe.txt file in the download. Please make sure you have a fully charged battery as you have to flash 3 times!
First part 1, then part , then part 3 and finally part 4. Only then is this firmware complete.
Part 1: is the no_rsa a3.cf bootloader, essential, but only flash this if you already have a a3.cf bootloader.
If you have not then flash a rsa signed a3.cf bootloader first and then this no_rsa a3.cf bootloader.
Part 2: is a complete firmware with signed, but edited codegroups.
Part 3: copy the content of the "language" folder into the "language" folder on your V8, which can be found
in the user memory (/ezxlocal/download/mystuff/language)
Part 4: this is a CG46 reflash, so this will then be linked to the folders and files you copied in part 3.
Finished.
Sit back and enjoy.
Скачать
Тестируем.
Сообщение отредактировал aciddon - 8.1.2009, 11:42
Ответов(1 - 1)
Abram
сообщение 8.1.2009, 11:51
Прелесть какая гадость
Из: .ru - рідна Україна
Пользователь №: 44 825
Прошивка: CyanogenMod
Ну вот почему Rasputin-у не ймется? Тем более, что делаю-то я на его телефоне... Подождал бы и сделал бы на основе моей... Ладно, всё равно заставлю переделывать biggrin.gif
Сообщение отредактировал Abram - 8.1.2009, 11:52
First No RSA 512 MB V8 LM5-SP1 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 29.7.2025, 9:35
