Прошивка MPKG Basic, V8
abelenki
сообщение 23.5.2009, 23:11 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
This is a Mixture of Kleto's Elysseum and Basic Plus.
Kleto gave me permission to use Elysseum as a base for this firmware.
It is a basic unbranded, unlocked, stock content orientated firmware.
Changes to Elysseum are:
no provider setting, email setting etc, unbranded
english menus
Picturflow got replaced by SlideShow (based on PictureFlow, but reedited and compiled by DeJe)
V8 Web Server is back to take screenshots from V8 on PC
You can give the installing mpkg packages your own menu name
You can uninstall MPKG packages
3 symlinked skin folder in /ezxlocal/download/mystuff/Skins, but you also can use the chm skin file installer to add more skins.
288x352 video recording build in
Because this is a basic firmware not all "preinstalled" menus of Elysseum are available, but I have packed those into mpkg packages and they are included with the firmware, as you will not find them as "Elysseum" mpkg's anywhere. I also included the NO_RSA A3.CF bootloader, just in case.
A big THANK YOU has to go to Kleto, c_ro87, CepiPerez, BeZ, Abram, sippey, rusiki, snizovtsev, DeJe and properly to a few more modders who's work has found their way into this firmware.
Автор:
rasputin007
Оригинальный топик:
mmus.us
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка MPKG Basic (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB MPKG Basic
2GB MPKG Basic
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
MPKG Basic Packages
V8 Modding Guide
Сообщение отредактировал XXX_S_B - 25.12.2012, 19:35
Ответов(1 - 37)
rasputin007
сообщение 24.5.2009, 21:38
Из: UK
Пользователь №: 184 705
Модель телефона: RAZR2 V8
Прошивка: Nothing for too long
The advantage is that you can install what apps you like and leave out what you don't like. Not like Evo 3 where you have NO choice at all.
Also it is very easy to translate the mpkg packages to any language you want.
If somebody can translate the few scripts in the CG36/usr/SYSQTapp/tweaks, CG36/usr/SYSQTapp/mpkg and CG36/usr/SYSQTapp/mpkgLauncher into russian you will have a pure russian menu firmware.
The Germans are doing it right now, they did that with Basic Plus as well.
The only problem you might have is that no text is displayed. The Germans had this problem with navtab in Basic Plus, but after recompiling the source code with UTF-8 support the text excepted german letters like ö, ä ,ü, and ß. I have already replaced the Tweaks (navtab) with this new compiled navtab version, not so sure about other mpkg packages.
However the Chinese have much bigger problems with the language as chinese characters are 16 bit unlike all european languages that have 8 bit characters.
Anyway nobody forces you to use this firmware.
Сообщение отредактировал rasputin007 - 24.5.2009, 21:46
Advokat_d
сообщение 24.5.2009, 21:59
Пользователь №: 155 462
Модель телефона: V3i,V8 2гига
Прошивка: R601_G_80.56.15R
Да Распутин на Высоте!!!! Особенно классно что не изменилась концепция установки скинов!!!!
К стати когда будете ставить MPKG пакеты не пишите название пакетов на русском!!!!!!!!!! Работать не будут
Сообщение отредактировал Advokat_d - 24.5.2009, 23:20
любопытнный
сообщение 25.5.2009, 13:53
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
Advokat_d, Лучше чем Элизиум? При подключении в режиме карты памяти всё равно телефон виснет? Можно чуть поподробнее о преимуществах этой прошивки,в частности:на Элизиум мне очень не нравится работа встроенного браузера-он вообще не работает,приходится работать в опера-мини.Для скинов меню Оранж есть?
БАZА
сообщение 25.5.2009, 14:09
Из: Заречный
Пользователь №: 125 911
Модель телефона: /Е8/V8/CLIQ
Прошивка: /Z-Mod/??/2.1
Сильно не бейте! В руках V8 только вот недавно! Прошие сие чудо, не могу понять как ставить MPlayer и почему то виснет при наборе смс, вебсессий и т.п. Подскажите как решить проблемы smile.gif Чем нагляднее тем лучше shuffle.gif
Advokat_d
сообщение 25.5.2009, 18:21
любопытнный,
Встроеным браузером не пользуюсь...а оренж есть! (При подключении в режиме карты памяти всё равно телефон виснет?) надо входить со стандартной прошивкой и выключать шнур с компа когда сделаеш безопасное удаление флеш на компе....
БАZА,
Ставь проигрыватель с MPKG MPlayer
Еще заметил в этой прошивке не работает vEncoder...он устанавливаеться но не работает
Моё мнение эта прошивка только хороша на счет скинов и все....лудше остаться на Elysseum там все приложения MPKG работают stink.gif
Сообщение отредактировал Advokat_d - 25.5.2009, 19:02
БАZА
сообщение 26.5.2009, 2:47
Из: Заречный
Сообщение отредактировал abelenki - 1.6.2009, 4:01
Offset
сообщение 26.5.2009, 7:22
Leo
Пользователь №: 126 712
Прошивка: 2BR
БАZА, решение проблемы зависания тела:
Цитата(simba4 @ 21.5.2009, 23:05)
download 2gb ellyseum and just extract the cg44 from it and flash it back to v8 512 cos there is a problem with the 512 mb cg44 ellyseum
По русски это звучит типа: Скачайте 2гб версию и извлеки только CG44 и прошей в V8 512.
БАZА
сообщение 26.5.2009, 7:35
Из: Заречный
"Скачайте 2гб версию и извлеки только CG44 и прошей в V8 512"
Может кто то провернуть это дельце? smile.gif Ну CG44 выдернуть и выложить smile.gif будет удобнее чем всю прошу качать заного smile.gif С меня +
любопытнный
сообщение 26.5.2009, 13:36
Прошивка: ОЧЕРЕДНАЯ
БАZА, На Элизиуме глюк похоже из-за скинов,посмотри в теме про Элизиум сообщение комрада ravex ,я изменил скин и путь к нему:за неделю ни разу не завис.Эту прошу ещё не шил-жду пока кто-нибудь отпишится как браузер встроенный работает.
Добавлено позже (26.5.2009, 16:40):
Скачайте 2гб версию и извлеки только CG44 и прошей в V8 512.Если у меня 2 Гига то шить CG44от 512?
rasputin007
сообщение 27.5.2009, 13:04
Из: UK
Sorry forgot to change 2 script links in the 512MB firmware, that's why Alarm Timer and BT Timer do not work. Have changed that now.
Сообщение отредактировал abelenki - 1.6.2009, 4:03
ravex
сообщение 27.5.2009, 23:23
Из: Питер
Пользователь №: 31 141
Модель телефона: L7, V8
Прошивка: LinuxMod 5 Pre-Final
Люди вы явно посты не читаете, любопытнный же написал, что у него на 2Гб была такая же проблема, соответственно проблема была в скине, путь решения этой проблемы я описывал, достаточно заменить все файлы скина в теле, на свой скин, перезагрузится. Будет вам счастье и ни каких зависаний =)
Добавлено позже (28.5.2009, 1:47):
БАZА
44 Группа отдельно
2GB_Elysseum
2GB_MPKG_Basic
Сообщение отредактировал ravex - 28.5.2009, 8:49
abelenki
сообщение 17.6.2009, 3:43
Из: Russia, Perm
вот метод, чтобы телефон не зависал в режиме memory-карты, если на ней есть скины:
http://modmymoto.com/forums/showthread.php?t=503131
(работает только для версии 2GB).
abelenki
сообщение 29.6.2009, 4:46
Из: Russia, Perm
в закреплённом сообщении обновлены прошивки 512MB MPKG Basic и 2GB MPKG Basic, а также V8 Modding Guide в соответствии со следующим заявлением rasputin007:
Yesterday I found out that the previously mksquashfs command line
mksquashfs /path to CG folder/* /path to where to put CG.smg -le
does NOT include any "hidden" folder like .backup (dot in front of folder name).
This missing of .backup folder in CG36 brings the Reset function to hang the V8.
The correct mksquashfs command line should be without the /*, like
mksquashfs /path to CG folder /path to where to put CG.smg -le
Now hidden folder are included.
Evo 3, Basic Plus and MPKG Basic have this faulty Reset function.
I have updated the V8 Modding Guide and MPKG Basic.
You can just make a CG36 reflash to keep your current setup.
I thought you should know about this and possibly pass this on as this could affect other Motomagx firmwares, when using the "old" style mksquashfs command.
Ras
Сообщение отредактировал abelenki - 29.6.2009, 4:47
любопытнный
сообщение 30.6.2009, 7:44
Прошивка: ОЧЕРЕДНАЯ
Я правильно понял теперь при наборе текста зависать не будет?
Добавлено позже (30.6.2009, 10:47):
Т.е после обновления нет необходимости менять скин на свой?
Vermin
сообщение 14.7.2009, 0:49
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
Стандартный браузер так и не работает? Или нашли решение?
abelenki
сообщение 15.7.2009, 3:11
Из: Russia, Perm
потестировал несколько дней на V8 512MB. регулярно зависает при наборе текста. так что, ничего не изменилось. придётся прошивать Basic Plus...
Добавлено позже (15.7.2009, 9:13):
проверил, встроенная Opera не работает, даже при правильных настройках Web-сессии. другие приложения, использующие интернет, работают нормально.
Сообщение отредактировал abelenki - 16.7.2009, 9:50
OlgaJah
сообщение 15.7.2009, 5:52
Пользователь №: 147 866
Модель телефона: RAZR2 Luxury Edition
Прошивка: MPKG Basic
У меня работает встроенная Опера.
Но не работает MPlayer,может будут советы как его запустить...
Сообщение отредактировал abelenki - 15.7.2009, 5:55
A.C.
сообщение 15.7.2009, 6:39
Из: Moskau
Пользователь №: 141 223
Модель телефона: V8 2GB EXPRSO
Прошивка: Elysseum+ edition
при наборе текста зависает, на некоторые номера из записной книжки так и не звонит.
принципиальных отличий от Elysseum не заметил.
JC Denton
сообщение 15.7.2009, 16:03
Пользователь №: 183 547
Модель телефона: nomoto
Прошивка: nomoto
Подскажите, как поменять картинку, которая показывается на внешнем экране, когда телефон открыт? И где взять стандартную?
Можно ли как-то поменять картинки ярлыков в меню?
Please tell how to change a picture which is on the outer screen when phone is open. And where to download a pic from standart firmware?
Is it possible to change icons inb main menu?
abelenki
сообщение 16.7.2009, 6:47
Из: Russia, Perm
Guide: How to change cl.gif on V8
Guide to Changing the Outer Screen Picture on the MotoRazr2 V8
попробуй эту.
Сообщение отредактировал abelenki - 16.7.2009, 7:48
A.C.
сообщение 16.7.2009, 7:46
Из: Moskau
качаешь отсюда http://www.modmymoto.com/forums/downloads....le&id=17921 программу MotoLinux Iconres Composer , открываешь в ней файл iconres.ezx своего скина, находишь там картинку logo_motorola.g.gif, 2 клика на ней, Replace, выбираешь новую картинку (желательно 320х240 и с таким же названием "logo_motorola.g.gif"). Картинка заменяется, заходишь в File>Create iconres и выбираешь в какое место сохранить полученный iconres.ezx. После чего, новым файлом заменяешь аналогичный в списке файлов установленного скина на телефоне. (у меня скин располагается в ezxlocal/download/mystaff/other/skins/happygirl) где у тебя находится скин ты, навеное можешь посмотреть в файле /ezxlocal/download/appwrite/setup/ezx_theme.cfg
после замены файла перезагружаешь телефон.
любопытнный
сообщение 16.7.2009, 13:21
Прошивка: ОЧЕРЕДНАЯ
OlgaJah, Попроробуй удалить все файлы,связанные с MPleer в папке .system и в папке .Programms, а также в Регистри и поставить заново,через встроенный инсталер на телефоне.У меня как-то получилось раза с 10,но иногда всё равно слетает.
Let
сообщение 19.7.2009, 13:17
Из: г. Барнаул
Пользователь №: 5 459
Прошивка: >_<
Подскажите, А можно как-то сделать, чтобы avi и flv файлы открывались из диспетчера файлов сразу Mplayer-ом?
rasputin007
сообщение 19.7.2009, 20:40
Из: UK
I use this MPlayer.mpkg on 2GB V8 and 512MB V8 and it works perfect on both.
Just copy the MPlayer.mpkg onto V8 and click on that MPlayer.mpkg file, it then gets installed automatically.
MPlayer menu under MPKG Launcher.
OlgaJah
сообщение 19.7.2009, 21:01
Thanks for your reply.MPlayer gets installed but does not launch under MPKG Launcher.What could be the prob?Probably,I should reflash it again?
We are going to UK now so I would like to get many moovies on board to kill the time during the travel.
Thanks.
Let
сообщение 20.7.2009, 16:42
Из: г. Барнаул
Прошивка: >_<
OlgaJah, у тебя Mplayer не устанавливается или просто не запускается? Если не запускается, закинь эту папку в /ezxlocal/download/mystuff/.Programs/, мне помогло.
OlgaJah
сообщение 20.7.2009, 18:28
Плейер устанавливается, в MPKG Launcher ярлык появляется,но не запускается.Я закинула его именно в эту папку,ваще много чего перепробовала,мне прошивка нравится,только напрягает тема с плейером(((
Let
сообщение 21.7.2009, 7:17
Из: г. Барнаул
Прошивка: >_<
OlgaJah, кого его закинула? Нужно закинуть не mpkg файл, а папку, которую я выложил, предварительно разархивировав. У меня с такими же симптомами всё заработало.
OlgaJah
сообщение 21.7.2009, 8:11
да,я кинула папку в указанную выше категорию,что дальше?
Charles Manson
сообщение 24.7.2009, 20:14
Пользователь №: 100 147
Модель телефона: Samsung i9190
CG44 менял (в V8 512 шил CG44 от V8 2Gb), скин тоже, зависания как были так и есть sad.gif покамест вернулся на родную 2BR. как быть?
Let
сообщение 25.7.2009, 6:53
Из: г. Барнаул
Прошивка: >_<
Charles Manson, от зависаний на этой прошивке пока никак не избавиться, шей Basic Plus, она не виснет.
любопытнный
сообщение 27.7.2009, 7:47
Прошивка: ОЧЕРЕДНАЯ
Charles Manson, Скин какой ставил? Попробуй Лавастик,у меня на нём нормально работал.там похоже что-то с иконрезом не так.Если бы кто-нибудь из умов пересобрал эту прошивкус другими скинами может и проблема отпала.
Charles Manson
сообщение 27.7.2009, 15:58
любопытнный, Скин ставил Alkali (из стандартной 2BR для 512Мб) и свой собственный на базе тогоже Alkali (ещё недоделанный правда).
любопытнный
сообщение 28.7.2009, 8:06
Прошивка: ОЧЕРЕДНАЯ
Charles Manson, Alkali хз...у меня он и на стандартной залипал,об этом писал Диом,в релизе своего Аспида.Пробуй Аспид или Лавастик,если не поможет-добро пожаловать в Бейсик плюс.
Acidag
сообщение 2.8.2009, 10:29
Пользователь №: 203 865
Модель телефона: V8
Поставил сабж.
Встроенная опера работает через профиль wap.
Через www - пока не заставил, пишет:
400 bad request
nginx/0.6.35
Оператор - МТС-Украина
Вот ломаю голову, это из-за прошивки, или оператор выделывается...
У кого как не работает Опера?
P.S. MPlayer жужит, правда требуемый flv не проглотил.
Добавлено позже (2.8.2009, 13:49):
Насчет зависаний - темы виноваты.
На Indium - фризов не заметил, поставил скин Leopard - при настройке браузера подвис.
Acidag
сообщение 5.8.2009, 19:34
Модель телефона: V8
ИМХО, встроенная Опера передает неправильно сформированный запрос, который http-серверы не могут нормально обработать.
Причем разные серваки ведут себя по-разному, но результат не положительный, только WAP работает нормально, что не есть гуд.
Сообщение отредактировал abelenki - 20.8.2009, 7:30
Charles Manson
сообщение 17.10.2009, 18:01
Кстати на MPKG Basic (наверное и на Elysseum тоже должно работать.) запускаются и норм работают все последние игры (Quake II, Duke Nukem 3D, Wolf 3D, etc...). Вот только хрен его знает как mpkg пакеты собрать дабы удобней было unsure.gif Если что пишите в лс.
Сообщение отредактировал Charles Manson - 17.10.2009, 18:02
Прошивка MPKG Basic, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 28.7.2025, 12:05
