[Droid X2] CyanogenMod 9.0.0-бета 1, Прошивка Cyanogenmod 9 для Motorola Droidx2
сообщение 28.5.2012, 11:27
CyanogenMod 9.0.0-RC0-DROIDX2-ALPHA3
Оригинал темы на XDA
Ниже описание на английском и ссылка для скачивания.
Features:
For a list of features added to ICS please go to the Android website: http://www.android.com/about/ice-cream-sandwich/
As this is still relatively new to CyanogenMod, very few features have been added on top of this and I won't create a features list until CM9 is "CM9" and not a hacked up ROM.
Also, as this is still super alpha, some of the features listed are not fully functional on the X2 yet.
Working:
WIFI
Bluetooth
Data/3G (see known issues)
*Maybe* tethering, but I doubt it (turns on, but haven't tested)
HQ and LQ Youtube (used to be a problem)
And a lot of little things
Known Issues:
Besides a whole lot more of a lot of little things:
***NEW*** Google Play installs larger apps to the SD card on installation. After a reboot these no longer appear in the apps drawer. A workaround is to install the app, go to "Settings > Apps" and click on the app. Once there click "Move to phone" and you're app should remain persistent across reboots.
Camera doesn't work: there is a fix for this for Tegra devices, but it's not working for us yet
MMS rarely works: this probably has to do with how data works with the phone and how i had to "hack" the data to get it to work.
Graphics memory sometimes runs out: as we are on less RAM the memory management is a bit whack. Sometimes while rotating an app (noticeably the browser) it will "twitch" and crash. Also systemserver (the main background service) will crash and Android will restart (rarely).
Data usage doesn't work: this requires kernel mods which I haven't worked out yet (but started on as I have one of them in the build)
Chrome beta doesn't work: it also requires kernel mods which I haven't messed with yet.
Installation:
This can be installed over CM7 or BLUR but you MUST wipe data and cache. Also do NOT (I repeat) do NOT use TiBu to backup data from CM7/BLUR. I don't want to hear about how that doesn't work.
READ THE ENTIRE POST
Download the links provided below
Install the BSR (patched if on CM7)
Reboot into the BSR
NANDROID <--- you'll probably want to go back to this
Install the CM9 zip from the SD Card
Install the GAPPS from the SD Card
Wipe both DATA and CACHE (no need to wipe Dalvik if you wipe both of these)
Reboot your phone
Enjoy CM9
Downloads:
REQUIRED Google Apps (GAPPS): http://goo-inside.me/google-apps. Download the latest version of them for here and check the MD5 sums from there also.
CyanogenMod 9.0.0 RC0 Daytona Alpha 3: http://www.mediafire.com/?77iy4f7rlr0036m
MD5 sum: ce776352f481c8be67296ac3e09abe77
Also, if you would like (but not needed) to donate, see the donate button by my name. Gas/food money goes a long way
Changelog:
Alpha 3 (first public release):
Minor stability update
Few CM9 features added
Alpha 2:
More stability/features
Graphics capabilities updated
Added pictures to MMS.apk's notifications (now officially in CM9, AOKP, and Codenamed: Android) Yay me!
Alpha 1:
First boot into ICS/CM9
Прошивка пока не предназначена для повседневного использования. Имеется множество не доработок, не работает камера. При установке внимательно читайте инструкцию.
Сообщение отредактировал Claus398 - 14.8.2012, 21:52
Ответов(1 - 6)
сообщение 25.6.2012, 17:33
прошивка обновилась.
Alpha 4:
Very minor stability update (hardly noticeable)
Camera
Data usage
More CM9 features (themes, lockscreen enhancements, music app)
Diablo_kun
сообщение 25.6.2012, 17:37
Пользователь №: 228 282
Модель телефона: LG e970+L9+E398+A1200
Прошивка: 4.1.2 stock
Видимо надо было брать ZTE v975
Alpha 4:
Camera
Data usage
добавишь в шапку ?
сообщение 25.6.2012, 17:57
Diablo_kun,
да тут и сообщений то не так уж и много. да и это все равно пока не финальная версия.
из перевода примерно следует:
Очень незначительная модификация стабильности (едва достойный внимания)
камера
Использование данных
всякие плюшки и различные прибамбасы 4го андроида
сообщение 14.7.2012, 11:52
Цитата(Claus398 @ 25.6.2012, 20:57)
* всякие плюшки и различные прибамбасы 4го андроида
не 4 адроида а циана
Diablo_kun
сообщение 18.7.2012, 7:58
Сегодня обновилась до 5 alpha.
сообщение 14.8.2012, 21:52
Beta 1:
Updated to "stable" release of CM9 (though we're not 100% stable yet)
CM9 Features/Translations updated
[Droid X2] CyanogenMod 9.0.0-бета 1, Прошивка Cyanogenmod 9 для Motorola Droidx2 · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 30.7.2025, 23:50
