[modded]: L6_R3511_G_0A.52.45R_A_Original_Mod_Pro_2.0, Монстр на базе чистой прошивки с оригинальным наполнением
сообщение 15.3.2024, 8:41 Закрепленное сообщение!
[modded]: L6_R3511_G_0A.52.45R_A_Original_Mod_Pro_2.0 + ELFs
Motorola SLVR L6 custom firmware by -=Smart=- & EXL
For English speaking members
I got inspired by -=Smart=-'s idea of creating custom nostalgic firmware with original stock content for Motorola SLVR L2, SLVR L6, SLVR L6i, SLVR L6g, and similar phones. I decided to update his firmware to version 2.0, with adding support for ELF applications.
The firmware is prepared on the R3511 platform and is suitable for many phones like L2, L6, L6i, L6g, V19x, and some others on Neptune LTE SoC with a screen resolution of 128x160 cSTN and 8 MiB RAM.
S/W: R3511_G_0A.52.45R_A
Flex: GSUL6T676MR0B0
Installation:
01. Charge the battery.
02. Enter Boot Loader mode by simultaneously pressing *, #, Red key when the phone is turned off.
03. Install Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Connect the phone to the PC.
05. Flash the SBF firmware file using RSD Lite 3.8, you can flash it from under a virtual machine, see for more details the topic: Virtual machine images for Motorola, WinXP and Win2K phones for VirtualBox and VMware Player.
Changes:
01. CG1, CG7, CG18: RSA bypassed.
02. CG1: Changed Boot Screen.
03. CG1: All ELF patches have been added.
04. CG2, CG4: MotoMixer menu item was activated and renamed to ELFs.
05. CG2: FEM activated.
06. CG2: JAL activated.
07. CG2: *#9999#
08. CG2: Added ELFs.
09. CG15: Timings in DRM/CG15 have been reduced.
10. CG2: Added various stock content.
11. CG1: Added the ability to remove SIM-Lock.
12. CG2: Funlight/Club Lights activated.
13. CG2: Increased volume in gain_table.bin and param_table.bin files, fixed file attributes.
14. CG1: MP3 bitrate limit increased to 320 kbps.
15. CG1: Removed message about "Invalid battery".
16. CG1: Added Java patches for access and signature bypass.
17. CG2: Updated Web sessions for local operators.
18. CG4: Fixed Cyrillic bold font in the Web browser.
19. CG4: Fixed ID3 tags in MP3 in Win-1251 encoding.
A description of some ELFs can be found in the ELFs by EXL: Nostalgia of development for Motorola P2K.
Attention! Some ELF applications require a running and minimized any Java application.
Task List:
01. CG1: Switch to the next track in audio player and video player.
02. CG1: Activate charging on "Invalid battery".
03. CG1: Port TFPG tasks.
04. CG1: Fix a bug with an additional item in FEM.
01. -=Smart=-: for the idea of ​​creating firmware with original content.
02. Andy51: for ElfPack v1.0 and PortKit!
03. baat: for testing on Motorola SLVR L6.
Mirrors:
01. https://firmware.center/projects/EXL/L6_R35...25-Mar-2024.zip
Проникся идеей -=Smart=-'а по созданию кастомной ностальгической прошивки с оригинальным наполнением для телефонов Motorola SLVR L2, SLVR L6, SLVR L6i, SLVR L6g и подобных и решил обновить его прошивку до версии 2.0, добавив в неё поддержку ELF'ов.
Изображение Изображение Изображение Изображение Изображение
Прошивка подготовлена на платформе R3511 и подходит для многих телефонов по типу L2, L6, L6i, L6g, V19x и некоторых других на Neptune LTE SoC с разрешением экрана 128x160 cSTN и количеством оперативной памяти 8 MiB RAM.
Установка:
01. Зарядить аккумулятор.
02. Зайти в Boot Loader по одновременному нажатию *, #, Красная трубка, когда телефон выключен.
03. Установить драйвера Motorola USB Driver v3.7.0: 32-bit | 64-bit.
04. Подключить телефон к PC.
05. Прошить SBF-файл прошивки с помощью RSD Lite 3.8, шить можно из-под виртуальной машины, см. подробнее тему: Образы виртуальных машин для телефонов Motorola, WinXP и Win2K для VirtualBox и VMware Player.
Изменения:
01. CG1, CG7, CG18: Снят RSA по методу LTE2 (хоть это и LTE телефон).
02. CG1: Изменён Boot Screen.
03. CG1: Добавлены все ELF-пачти в т.ч на увеличение System Heap.
04. CG2, CG4: Активирован MotoMixer и переименован в ELFs.
05. CG2: Активирован FEM.
06. CG2: Активирован JAL.
07. CG2: *#9999#
08. CG2: Добавлены ELF'ы.
09. CG15: Уменьшены тайминги в DRM/CG15.
10. CG2: Добавлен различный стоковый контент.
11. CG1: Добавлена возможность снятия SIM-Lock.
12. CG2: Активирован Funlight/Club Lights.
13. CG2: Увеличена громкость в файлах gain_table.bin и param_table.bin, исправлены атрибуты.
14. CG1: Увеличен битрейт MP3 до 320 kbps.
15. CG1: Удалено сообщение про "Недопустимую батарею".
16. CG1: Добавлены Java-патчи на доступ и обход подписи.
17. CG2: Обновлены Web-сессии для местных операторов.
18. CG4: Исправлен жирный (bold) кириллический шрифт в Web-браузере.
19. CG4: Исправлены ID3-теги в MP3 в кодировке Win-1251.
Список патчей / List of Patches:
R3511_45R_A_Canvas_All_Keys.fpa
R3511_45R_A_Canvas_Longkey_Timer.fpa
R3511_45R_A_ElfDirectory.fpa
R3511_45R_A_ElfPack_v1.0.fpa
R3511_45R_A_IncreaseHeap_1400KB.fpa
R3511_45R_A_Invalid_Battery_Fix.fpa
R3511_45R_A_itoa.fpa
R3511_45R_A_MP3_320_kbps.fpa
R3511_45R_A_Register_ElfPack_v1.0.fpa
R3511_45R_A_Write_Locked_PDS.fpa
Список ELF'ов / List of ELFs:
2048-P2K
Backuper
BadApple
Benchmark
Block
Dumper
ElfBox
FBrowser
FireEffect
Flex
HexEditor
MotoCMD
Neko
NumBasis
Overclock
Perlin
RedMenu
Screenshot
SeemEditor
Snake
Spout
TalkClock
Tunes
VibroHaptic
Y3D
Y3DO
Описание некоторых ELF'ов можно посмотреть в теме: ELFs by EXL: Ностальгия разработки под Motorola P2K.
Внимание! Некоторые ELF-приложения требуют запущенное (любое) и свёрнутое Java-приложение.
Список задач:
01. CG1: Переключение на следующий трек в аудиоплеере и видеоплеере.
02. CG1: Активация зарядки на "Недопустимой батареи".
03. CG1: Портировать TFPG-таски.
04. CG1: Исправить баг с дополнительным пунктом в FEM.
Спасибо:
01. -=Smart=-: за идею создания прошивки с оригинальным наполнением.
02. Andy51: за ElfPack v1.0 и PortKit!
03. baat: за тестирование на Motorola SLVR L6.
Зеркала:
Прикреплённые файлы:
Прикрепленный файл L6_R3511_G_0A.52.45R_A_Original_Mod_Pro_2.0_25-Mar-2024.zip   ( 20.62 мегабайт ) Кол-во скачиваний: 52
-=Smart=-
сообщение 14.8.2018, 10:04
Пользователь №: 133 943
Модель телефона: Motorola RAZR MAXX V6
Прошивка: R452J_G_08.22.05R
Представляю вашему вниманию монстр для Motorola L6/L2, основанный на чистой прошивке R3511_G_0A.52.45R. Данный монстр предназначен для тех, кто захотел усовершенствовать свой телефон дополнительными удобными функциями (о них ниже), но при этом сохранить оригинальность его заводского наполнения - всё мультимедийное наполнение, а также шрифты, иконки, звуки, картинки являются оригинальными. Теперь о монстре и изменениях:
1. Оригинальный DRM разогнан, увеличена скорость работы телефона, добавлены иконки российских операторов.
2. Добавлена ритм-подсветка, подсветка событий.
3. Активировано быстрое меню на джойстике с возможностью назначения любой функции.
4. Регулировка звука боковыми клавишами.
5. Добавлена автоматическая блокировка клавиатуры.
6. Добавлен режим в самолете.
7. Добавлен пункт включения/отключения зарядки по USB.
8. Улучшена эффективность работы батареи.
9. Увеличена громкость разговорного и мультимедийного динамиков, теперь вы услышите собеседника при любом шуме.
10. Блокировка/разблокировка клавиатуры по двойному нажатию кнопки "Меню".
11. Время и название будильника в одной строчке.
12. Убрана ID мелодия абонента в смс.
13. Изменение раскладки ввода. Было . ? ! , @ ' - _ : ; ( ) стало . , ? ! @ ( ) ' - _ : ;
14. Не удаляются звонки при смене симки.
15. Отправить SMS вместо выход в справочнике.
16. Ребут вместо версии PRL. Работает ТОЛЬКО через метку.
17. Автонабор через 5 секунд.
18. Черный список (пятая группа).
Прикрепленный файл L6_OriginalModPro_1.1.rar   ( 10.86 мегабайт ) Кол-во скачиваний: 302
Прикрепленный файл L2_OriginalModPro_1.1.rar   ( 10.79 мегабайт ) Кол-во скачиваний: 291
Сообщение отредактировал -=Smart=- - 15.8.2018, 9:25
Ответов(1 - 9)
сообщение 14.8.2018, 11:39
Это для L2 или L6?
Цитата(-=Smart=- @ Сегодня, 17:04)
Прошу модераторов добавить данный монстр в ветку "ЛЮБИТЕЛЬСКИЕ MONSTERPACK".
Залил на сайт: https://motofan.ru/firmware/?action=view&am...=2&phone=31
И добавил ссылку в эту тему: Ссылки на пользовательские монстерпаки
-=Smart=-
сообщение 14.8.2018, 12:04
Цитата(EXL @ 14.8.2018, 11:39) *
Это для L2 или L6?
для L6. Если будут желающие, могу адаптировать и под L2
MOROROSCHKA_SL.
сообщение 14.8.2018, 17:26
Пользователь №: 214 413
Прошивка: Android 13
Motorola my Love
Будто переместился на 12 лет назад))) Автору за старания + однозначно, но боюсь, что теперь монстр уже широкой аудитории не обретёт, к сожалению...
-=Smart=-
сообщение 15.8.2018, 9:27
Внёс кое-какие мелкие исправления и добавил монстр и для Motorola L2. Прошу модератора перезалить в файловый архив последнюю прикрепленную версию, а также добавить в файловый архив монстр для L2. Эти два монстра последние в истории человечества и в истории существования бренда Motorola, запомните этот исторический момент.
EXL: Добавил, см. линк.
Сообщение отредактировал EXL - 15.8.2018, 11:33
-=Smart=-
сообщение 12.4.2019, 11:44
Окончательная версия монстра. Исправлен баг, из-за которого при входящем смс не гас экран. Прошу модераторов перезалить ссылки.
EXL: Вот, держите:
https://motofan.ru/uploads/L6_OriginalModPro_1.2.rar
https://motofan.ru/uploads/L2_OriginalModPro_1.2.rar
Прикрепленный файл L2_OriginalModPro_1.2.rar   ( 10.79 мегабайт ) Кол-во скачиваний: 252
Прикрепленный файл L6_OriginalModPro_1.2.rar   ( 10.86 мегабайт ) Кол-во скачиваний: 566
-=Smart=-
сообщение 15.3.2024, 11:42
Приятно видеть, что результаты трудов не пропадают даром. Ребятам спасибо за старания и развитие темы. Кто-то скажет, что это уже всё старьё и не актуально, а я скажу следующее. У самого до сих пор лежат два телефона Motorola L6 и Motorola L2. Так вот, что я хочу сказать, периодически пользуюсь L2, как вторым телефоном. По эргономике, телефонов лучше, чем эти два аппарата никто еще не придумал. Тонкие, маленькие, громкие, а с кастомной прошивкой еще и мегаудобные. Так что тема, на данный момент, считаю еще как актуальна не только в ключе ностальгии, но и в практическом применении.
сообщение 15.3.2024, 12:36
-=Smart=-,
Да, классные телефоны, небольшие, тонкие. Вот только единственная проблемка - небольшая автономность от аккумулятора. Я наверное разбалован Philips Xenium'ами в плане идеальных звонилок, поскольку они держат месяцами.
Воха
сообщение 15.3.2024, 13:00
Сектант Xiaomi
Из: Дніпро 🇺🇦
Пользователь №: 145 492
Прошивка: Android 12-13
Норм
Я сам был владельцем L6 когда он только вышел, и тогда у меня возможности сменить телефон и не было, поэтому и пользовался, хотя любая Нокиа имела акккум х2, а у этих аппаратов как у Айфона и любого сверх дорого телефона современности - порезали батарею в угоду дизайну, и пусть юзер живёт у розетки, но тогда был глупый и не задумывался об этом. Сейчас смотришь, и время в режиме разговора 3.5 часов, против 50 часов у моего текущего сяоми.
Цитата(EXL @ Сегодня, 14:36)
* Philips Xenium'ами
Там же кажется технологии МТК и эти аппараты вышли сильно позже, когда уже и Филипса как такового не стало🤔. Если говорить об идеальной звонилке, то у неё должно быть минимум 2 микрофона, ведь даже самый слабый и старый Леново по качеству передачи голоса в шумных местах уделает все эти телефоны середины 2000ых, а кетайские кнопочники тем более.
Просто мне попадались ксениумы на Андроиде, и это такой радиоактивный кетай, что просто ужас
[modded]: L6_R3511_G_0A.52.45R_A_Original_Mod_Pro_2.0, Монстр на базе чистой прошивки с оригинальным наполнением · Кастомные прошивки для Motorola SLVR L2, L6, L6g, L6i, V19x, V235 · Forum
Текстовая версия Сейчас: 24.8.2025, 11:31
