Jffs2-r541_l7_g_11.10.11r
marcolnx
сообщение 29.5.2010, 14:50
Пользователь №: 201 733
Модель телефона: a1200e a1200i
Прошивка: jffs2
JFFS2-R541_L7_G_11.10.11R
I would like to give thanks especially Provodnik, I borrowed the theme Iris and animations.
Thanks Provodnik for the wonderful work.
Main features:
- widgets support (6 preinstalled)
- 3 skins: Iris - Red - White
- 2 java applications: Platinum Sudoku - ICQ Jimm
- Radio works without headset
- Realplayer with equalizer
- Run multiple apps
- Language: English - Russian
- English keyboard with Russian flag and Russian
- Fingerpad
- Screen3
- ext2 ext3 support with modules.dep
- bash3 busybox strace ldd etc.
- Telnet (completion commands-path and history) Samba Ftp (pure-ftpd)
- foxalarm (Russian with voice Russian)
- Preinstalled applications:
- Assistant (installer pkg, swap manager, screenshot, reboot, hide folder, java hacker, mystuff, uncompress most of archives tar - gz - zip - rar -7z, backup, etc.)
- eKonsole with history and completion path commands
- ZEditor
- PicselEdit
- Processor (underclock and overclock at 520)
- Skin Installer 2.4
- SysInfo
- Backup Restore Now
- Support autorun.txt startup.txt and startup1.txt -> SD (/mmc/mmca1/)
- Support startup2.txt -> Phone (/ezxlocal/download/mystuff/)
Preload folder it's My_FAVOR (you have to create -> Phone /ezxlocal/download/mystuff/ ).
Options (ezx_boot.cfg):
Start.wav (sound power)
myfont.ttf (for font)
command.spa and commandlist (voice)
Stop.wav (sound of the key "end" when it holds tight to turn off)
TouchT.wav (sound of the touch screen option in "Tone" )
TouchC.wav (sound of the touch screen option in "Click" )
Conect.wav (sound when loading / USB)
Alert.wav (sound low battery / missed call)
Key.wav (sound of the keys except those listed above)
Send.wav (sound of the green button )
End.wav (sound of the red button )
ezx_volumetable.cfg
Generally if something does not like (you can write in the whole) you can edit yourself.
To change modes ro - rw in the console execute:
rw (enter)
ro (enter)
SDHC support:
You must flash jffs2_kernel_sdhc.sbf
Format SDHC 1st partition Fat32 (use GParted for this and or for resize for swap partition)
When you will insert your SDHC with ekonsole or telnet session:
fdisk /dev/mmca (enter)
p (enter)
t (enter) and select first partition
6 (enter)
w (enter)
reboot
Link:
http://www.4shared.com/file/-4syXPiy/jffs2...1R_Iris_RU.html
(There are also two folders: VR and bcr (put both in SD for VR Russian and bcr)
To install programs rename pkg (install with Assistant)
To install widgets mpkg make click.
I thank you all for reporting any problems and if help with translation.
Прикрепленный файл DeviceStatusDashboard.zip   ( 187.4 килобайт ) Кол-во скачиваний: 321
dvrts
сообщение 29.5.2010, 18:00
Из: Lviv
Пользователь №: 162 099
Great work! I'm wondered of you, my dear friend :)
Caif
сообщение 29.5.2010, 18:39
Из: Набережные Челны
Пользователь №: 170 337
Модель телефона: A1200e
Прошивка: 16r
marcolnx
сообщение 29.5.2010, 21:02
Прошивка: jffs2
Hi dvrts,
I consider you a true friend and I would be honored to share with you this thread.
Your help and your experience are important to me.
Hi Caif,
In jffs2 you can directly edit what you want.
For me important busybox bash3 ldd strace ekonsole ...
No problems with battery.
You can directly change the theme, make symbolic links ...
I changed from Italian into Russian in no time (I do not speak Russian).
Easy to change directly to Ukrainian or whatever.
ElChino
сообщение 29.5.2010, 23:55
Из: JuventusMember
Пользователь №: 196 088
Модель телефона: ROKR E6 / X2 / Z3P WHITE
Прошивка: LightSPEED3 // 4.1.1
marcolnx,
It is possible please skin(theme) separately, it would not be desirable to assort insertion...
Сообщение отредактировал ElChino - 29.5.2010, 23:56
Myrik
сообщение 30.5.2010, 8:06
Пользователь №: 216 960
а можно перевод!
ElChino
сообщение 30.5.2010, 8:24
Из: JuventusMember
Вобщем, хотел чтобы марко скин вытащил и выложил)а то самому вытаскивать неохото,притом fx не может прога найти в прошивке.
dvrts
сообщение 30.5.2010, 9:19
Из: Lviv
а через usb-net вытащить?
перевод будет готов сегодня-завтра, дайте только за комп сесть:)
I'll translate fw description in a few days - just i need to use my PC
Myrik
сообщение 30.5.2010, 10:41
отпишитесь кто прошивал есть баги и какие?
credoff
сообщение 30.5.2010, 12:44
Пользователь №: 15 146
Модель телефона: E1 & A1200
лично у меня багов не замечено... в целом прошивка очень хорошА.
Garm
сообщение 30.5.2010, 13:45
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
marcolnx, thank you very much for fw
Очень странно получается. Прошивка, как я понял умеет ставить в формате mpkg только виджеты... Моторола отказалась что ли от этого?
В принципе ничего страшного, кроме стартующих после каждого перезапуска виджетов.
Но замечу однозначно - прошивка с включенными виджетами работает на мой взгляд быстрее Linux Ming. И не мешает наличие
Как-нибудь можно использовать своп-раздел на карте памяти в единственном числе, а то у меня сейчас своп размером в 97 мб (67 в виде четырех файлов и 32 мб как раздел на карте) . Я так понял, это все суммируется? Или для виджетов 32 мб будет мало? Скажу, что у меня из 97 мб свободно 80 мб...
Somehow, I can use a swap partition on the memory card in the singular, but then I now swap size to 97 mb (67 in the form of four files and 32 MB as a partition of mmc). I understand it all is summed up? Or for widgets 32 MB will be not enough? I must say that I have the 97 MB, free 80 mb ...
Сообщение отредактировал Garm - 30.5.2010, 19:01
SanchoMutant
сообщение 30.5.2010, 15:48
Пользователь №: 202 933
Прошивка: 16R
а так alles gut
fluffy
сообщение 30.5.2010, 16:37
Из: Россия
Пользователь №: 213 570
Прошивка: R541L7_11R_Iris
Дорога возникает под шагами идущего
глюк с аккумулятором на этой прошивке все равно остался sorry.gif слезаю с неё...
Сообщение отредактировал fluffy - 30.5.2010, 16:38
Garm
сообщение 30.5.2010, 19:02
Из: Морозовск
Цитата(SanchoMutant @ Сегодня, 19:48)
ftp работает? у меня не получилось
FTP в пассивном режиме у меня заработал
marcolnx
сообщение 31.5.2010, 22:05
Прошивка: jffs2
Hi Garm,
firmware use swap (am), me too when I active widgets, system will turn on swap files (after I can turn off swap files from menu because I use a swap partition).
Yes mpkg only install widgets.
Standard mpkg you need rename pkg (me too asked Epinter and confirmed this).
So for me firmare stable and can install widgets.
Running fast without widgets.
This is for me the major difference from linuxming (also need keep pressed center buttom for flip closed menu player -> play, next song,)
Garm
сообщение 1.6.2010, 10:21
Из: Морозовск
marcolnx,
It's possible to make installation of mpkg-applications instead widgets?
fluffy
сообщение 1.6.2010, 10:30
Из: Россия
Hello Marco! I put your firmware JFFS2-R541_L7_G_11.10.11R and I have it not work the battery. When fully charged, the battery, it shows that little charge.
Сообщение отредактировал fluffy - 1.6.2010, 11:55
Garm
сообщение 1.6.2010, 11:27
Из: Морозовск
Ты с какой прошивки переходил на эту? Я перешел с Linux Ming и такой проблемы нет (сомневаюсь, что дело в этом, но возможность этого нельзя исключать для того чтобы понять что происходит)
Очень странно... И не ты один говоришь об этом...
В общем налицо такая же песня как и с Iris не-jffs2 - У кого нормально, А у кого наблюдаются глюки. И никто еще тогда не понял этого
fluffy
сообщение 1.6.2010, 11:58
Из: Россия
Привет Garm
у меня до этого стояла прошивка
jffs2-прошивка (релиз от 22.03.10 г.) Работает нормально после Iris, Микс 12r 13r и Amin's Extreme Elite от Marcolnx Версия от 8.05.10
credoff
сообщение 1.6.2010, 12:02
Я тоже перешёл именно с Linux Ming, и данной проблемы не заметил. Может попробывать последовательность действий повторить?
fluffy
сообщение 1.6.2010, 12:07
Из: Россия
Linux Ming (jffs2 11R - firmware) ты про это?
Сообщение отредактировал fluffy - 1.6.2010, 12:09
credoff
сообщение 1.6.2010, 12:29
Думаю можно попробывать. ;)
fluffy
сообщение 1.6.2010, 14:51
Из: Россия
berry.gif надо найти этот надоедливый файлик который отвечает за батарею(не симы)
Garm
сообщение 1.6.2010, 16:33
Из: Морозовск
А в какую категорию Assistent здесь ставит программы?
In which category Assistent to install programs?
marcolnx
сообщение 1.6.2010, 20:48
Прошивка: jffs2
Garm,
Assistant will install new programs under Games.
You cannot replace libezxam.so.1.0.0 for install mpkg
fluffy,
Battery problem started with flash Iris (widgets)?
The battery charge?
Only display problem?
Can you explain?
This firmware replaced:
/usr/lib/ezx/lib/
/usr/SYSqtapp/
/usr/SYStapi/
I'd like to understand...
I never had any problem with battery.
Only once in a version of WM2 showing red (I fixed by changing kernel)
fluffy
сообщение 2.6.2010, 6:41
Из: Россия
hello marcolnx! everything works well, I put the firmware back jffs2 12R.
Сообщение отредактировал fluffy - 2.6.2010, 7:31
bekendorf
сообщение 4.6.2010, 5:44
Пользователь №: 207 686
Пара вопросов:
1. Как убрать первую русскую клавиатуру?
2. Как сделать управление плеером при закрытом флипе как в Linux Ming (чтобы по средней кнопке открывалось меню а не просто ставилась пауза)?
credoff
сообщение 4.6.2010, 6:19
bekendorf,
1. Настройка-установка ввода
2. попробой зажать среднюю кнопку.
bekendorf
сообщение 4.6.2010, 7:50
А можно ли в этой прошивке как либо использовать только своп в виде блочного устройства?
Добавлено позже (4.6.2010, 8:51):
Спасибо кстати :)
Garm
сообщение 4.6.2010, 10:13
Из: Морозовск
Не использовать виджеты :)
Stalker 1988
сообщение 4.6.2010, 12:14
MotoArhangel
Из: Алтайский край
Пользователь №: 85 312
Прошивка: CM10 & MIUI
Ну вот и вернулся =)
Цитата(fluffy @ 1.6.2010, 15:58) *
Привет Garm
A ti slu4aem ne probival akum ljagushkoi zarjadit' a potom proshit'? Inogda pomogaet.
bekendorf
сообщение 4.6.2010, 12:17
А жаль...
Markus-vip
сообщение 14.6.2010, 16:45
Из: Донецк
Пользователь №: 214 845
Модель телефона: LEX L11N
Прошивка: PIE.L11_P_R30.21.30
не работает интернет
Grifon32
сообщение 14.6.2010, 20:51
Из: Россия, Самара
Пользователь №: 85 033
Модель телефона: E398;а1200е;Zn5 TM
Не понятно изза чего, но очень сильно притормаживает плеер. При открывании/закрывании флипа воспроизведение прекращается на 2-5 секунд, бывает просто по телефону шарюсь и тоже заметны притормаживание небольшие...
Как можно убрать голосовое озвучивание?
Garm
сообщение 15.6.2010, 4:44
Из: Морозовск
У меня работает. Ты его настроил хоть?
Порты убери если есть
Markus-vip
сообщение 15.6.2010, 5:13
Из: Донецк
Конечно!!!!
Просто идет безконечное подключение
Функция называеться Talking phone
runtime
сообщение 18.6.2010, 4:42
Из: Омск
Пользователь №: 168 421
Прошивка: JFFS2
Есть одна проблема: установленное Java приложение не отображается нигде в меню, соответственно не могу его запустить.
I've got one problem: Cannot find and run installed Java. Re-installation doesn't help. Installation goes without any errors, but icon doesn't appear.
dvrts
сообщение 19.6.2010, 15:08
Из: Lviv
попробуй поковырять свойства с помощью softmanager
bekendorf
сообщение 21.6.2010, 6:15
Русские теги в mp3 отображаются плохо - видимо проблемы с кодировками. У кого нибудь еще наблюдается?
Garm
сообщение 21.6.2010, 7:27
Из: Морозовск
Прошу помощи в связи с проблемой с функцией "Caller ID" (да, она работает"
Дело в том, что когда телефон говорит кто звонит, он говорит "Call from". Но в файле command.eng такого нет. Следовательно на русском он говорит это по буквам.
Кто-нибудь может подсказать как сделать чтобы он по-русски говорил "Вызов от"?
P.S. В файле command.eng есть фраза "Incoming call from", но телефон же говорит "Call form"... Замена не помогает
Текстовая версия Сейчас: 17.6.2025, 16:47
