[Milestone] Cyanogenmod, Порт от Nadlabak'a
Ratmagor
сообщение 21.11.2010, 10:50 Закрепленное сообщение!
Куратор темы
Из: Мск
Пользователь №: 59 289
Cyanogenmod4Milestone.
Домашняя страница
Google Code
Багтрекер
Информация в шапке безнадежно устарела. Пинайте старших товарищей, дабы попросились в кураторы и поддерживали тему в актуальном состоянии
CM7 RC3 (ветка Android 2.3.3)
Update.zip брать на GitHub.
GoogleApps для CM7.
Установка ниже.
Сборка от 18 апреля от f_pasha с фиксами, русским и большим количеством свободной оперативки
Релиз CM7 от goodwin_c (19 апреля)
Благодарим artanto за быстрый хостинг
Текущая версия CM7: 10.04.2011-0.08 RC4
0.08-11.04.24 7.0.1
- fix: google maps freeze on launch after repeated gmaps launches (and system reboot after that in the end, sooner or later), lock happened at the time of reading of cached maps from sdcard, fixed by:
1. revert to not moving dalvik-cache to sd-ext (it causes also other performance issues, so I'd disable it anyway), only app and app-private are moved now
2. read_ahead_kb for sdcard set to 32 (yes, I don't care about sdcard speed benchmark results, I prefer stability)
- fix: webkit text wrapping (e.g. gmail text displayed too narrow)
- fix: displayed operator name (for some European networks), forced plmn display for spdi networks
other fixes and features (status bar additions etc.)
Changelog
0.08-11.04.18b 7.0.0
- mkdir fix! http://review.cyanogenmod.com/#change,4720
0.08-11.04.18 7.0.0
- workaround to avoid frequent Gallery3D resets (seg fault in SGX library - usually coming after orientation change)
- sys.keep_app_1 and sys.keep_app_2 properties can be defined (as process names) in build.prop, to allow user to specify up to two apps to be always kept in memory (use with caution, RAM is limited!)
- possible workaround for issue 498 (black screen) - http://code.google.com/p/cyanogenmod4miles...s/detail?id=498
- slight low memory killer parameters adjustment
- sync setting fix, TextView slow scroll fix, arabic keyboard and dictionary in LatinIME
0.08-11.04.10 RC4.1
fix: kernel modules sometimes installed too late (sd-ext not mounted, overclock not applied)
possible fix: locationproxy - ConnectionPending exception (hard to reproduce - needs confirmation)
update: overclock and cpufreq_stats modules - stats freq table automatically updated
kernel module nls_utf8 added and preloaded so that iocharset=utf8 option can be used for cifs mount
fix: 2 different possible NPEs in Settings.apk
VM heap size selection list expanded
10overclock: changed default frequency table (250/400/600/800/1000)
upstream: RTL lang fixes and other updates and fixes
0.08-11.04.05 RC4
kernel modules:
ext4 (finally proper, journalling works, preloaded) - supports also ext2 and ext3 partitions
ext3, ext2 - included, not preloaded
tun (for OpenVPN, preloaded)
cifs (not preloaded, but depends on slow-work that is preloaded), CifsManager app from market can insmod cifs.ko when needed (great for playback of avi files located on windows share via wlan wink.gif
nfs (not preloaded, depends on included but not preloaded auth_rpcgss, rpcsec_gss_krb5, sunrpc, lockd)
xt_multiport (to fix some iptables issues, preloaded)
overclock (+symsearch) reworked by Skrilax_CZ (preloaded)
- 5 frequency slots enabled
- greatly simplified setting of custom frequency/vsel pairs
see /system/etc/init.d/10overclock
- 07app2ext script included in /system/etc/init.d - works via bind mount but is compatible with symlink versions. (warning - do not put more than one app2ext script in init.d as it could result in loss of apps)
- auto boot OpenRecovery (when rebooting to recovery) script added
- SD card reading performance improved (read_ahead_kb set to 2048)
- Usb.apk is now built from source, thanks to Skrilax_CZ, very nice decompilation!
- ADWLauncher drawer scrolling (and zoom animation) optimized to be smoother even when "allow purging of assets" memory performance option is enabled
- finally implemented "no action on plug" (it's under CyanogenMod settings>Display)
- option to disable the dock observer fixed
- fixed gingerbread key event repeating bug affecting camera when using hardware buttons
- upstream: several new RTL fixes and features, 1 important EGL fix, 3 bluetooth fixes (cherry picked), various other fixes
0.08-11.03.16 RC3
- Allow purging of asset bitmaps performance option added - to allow the system to reclaim some more RAM when needed, enabled by default
- proprietary binaries update (one step ahead of )
- etc. (sorry, I could not resist, it's so tempting smile.gif )
0.07-11.03.12 RC3
- music volume steps doubling fixed (when volume button music control is enabled)
- gps not able to be re-enabled until reboot fixed
- etc.
0.07-11.03.09 RC3
- various fixes and enhancements (e.g. Autostarts issue when theme is used fixed, jpeg neon optimization added, various framework patches etc.)
0.07-11.03.04 RC3
- EGL fix (live wallpapers etc.)
- 854x480 mp4 video playback enabled
- volume key long press playback control fixed
- new feature: notification profiles
0.07-11.03.02 RC3
- media provider and other small fixes
- Android 2.3.3, etc.
0.07-11.02.23 RC2
- 2.3 AudioEffect API works now - DSP Manager fixed (by libaudiopolicy compiled from source)
- new battery percent status bar solution
- SMS timestamp options updated, character count can be displayed sooner
- lockscreen fixes
- new advanced camera options
- etc.
0.07-11.02.18 RC1
- low memory killer parameters tweaked: mainly to prevent killing of music player when playing
- CMParts and ADW launcher default changes - keep home/sms app in memory, disabled scrolling cache
- lockscreen updates
- wlan: EAP Phase 2 settings fix
- overlay clean up (Phone.apk)
- etc.
0.07-11.02.15
- wlan: EAP fix (802.1x enterprise)
0.07-11.02.14
- various wlan connectivity issues (some N routers, wpa2, 801.x enterprise etc.) seem to be fixed (for the first time since the GOT 2.2.1 leak). Thanks for the feedback to the wifi test version
- SMS TP-Data-Coding fix (kanged from 0.04-10.12.04)
- Toggle 2G removed (the memory is precious)
- other small things, upstream sync
0.07-11.02.12
wifi test - those who are experiencing wifi issues, please test this build made from alternative wpa_supplicant6 and ti wilink sources and report, thanks.
0.07-11.02.09
- reported lightsensor range fixed
- DSPManager temporarily replaced with proprietary AudioEffects
- little clean-ups and tweaks applied, etc...
0.07-11.02.07
- now playing/album art on lockscreen etc.
0.07-11.02.06
- the previous gps and rotation vector (compass) fixes included
- fixed the disabling of the light sensor when flashlight is on
- fixed 2g/3g toggle in the settings' Power Widget
- temporary battery percentage display included (will be changed)
CyanogenMod6 обновлен 11.03.2011
Текущая версия CM6: 11.03.2011-0.08
Последние изменения:
18.03.2011 0.08-11.03.18
- proprietary files update
- various wlan connectivity issues fixed (some N routers, wpa2, 801.x enterprise etc.), as in current CM7
28.01.2011 0.07-11.01.28
- апдейт проприетарных файлов (boot.img=>kernel, modules etc from SHOLS_U2_05.26.0)
- исправлен баг с СМС (версия ОС должна быть 2.2.2, было 2.2.1 там)
- поддержка греческого LatinIME 2.3 (включая словарь)
- ext4 модуль включен (может быть использован только для ext2 - запись в журналируемые ext3/4 пока работает не корректно)
- новый отдельный BPSW update.zip(такой же как в SHOLS_U2_05.26.0/SHLA_U2_05.0C.0)
Установка:
    После того, как установлен vulnerable recovery, нужно ЗАГРУЗИТЬСЯ В РЕКАВЕРИ МОД, если телефон до этого получал официальное обновление! Дело в том, что с оф. обновлением приходит скрипт, который при загрузке откатывает подозрительный апдейт, поэтому надо загрузиться в Open Update, там войти в терминал и rm -f /system/etc/install-recovery.sh (инфа отсюда: <a href="http://android.doshaska.net/rootable" target="_blank">http://android.doshaska.net/rootable</a>
    by TheZest.
  1. Прошиваем уязвимое recovery(пункты 1-6 по ссылке).
  2. Ставим OpenRecovery. Отсюда. Или отсюда androidiani OR
  3. Скачиваем CyanogenMod.
  4. Закидываем файл с апдейтом в /sdcard/OpenRecovery/updates/
  5. Загружаемся в OpenRecovery.
    теперь желательно сделать nandroid backup.
  6. Делаем wipe.
  7. Выбираем пункт apply update.
  8. Делаем снова wipe.
После установки получаем ОС без маркета и прочих гугл-приложений, чтобы их установить идем на goo-inside.me, качаем Latest HDPI, закидываем к апдейту цианогена и применяем.
Если патча клавиатуры на текущую версию нет, то вместо него можно использовать ruKeyboard.
Для тех кто не ставил GOT 2.2.1, можно поставить последний доступный BPSW
Разгон
По-умолчанию, в этом моде для разгона используется файл /etc/init.d/10overclock.
Для изменения частоты нужно поменять две строчки
echo 60 > /proc/overclock/max_vsel
echo 750000 > /proc/overclock/max_rate
Первая строка отвечает за максимальное напряжение, вторая за частоту в килогерцах. Чтобы поэкспериментировать, найти оптимальное значение и при этом ничего не сломать эти строки можно вводить напрямую с консоли, при этом после перезагрузки параметры примут значения, которые записаны в файле.
Мнения по поводу данной темы, недочёты, исправления и дополнения мне в личку
Сообщение отредактировал Ratmagor - 7.6.2011, 20:17
iBarS
сообщение 17.9.2010, 15:27
Из: Кемерово
Пользователь №: 64 876
Прошивка: 2.2
Home page: http://android.doshaska.net/cm6
Статус: первый публичный альфа релиз CyanogenMod 6 for Milestone (nandroid backup)
Что работает: надеюсь все (GSM, WiFi, BlueTooth, GPS, camera & focus, video & audio recording & playback, app2sd, Adobe flash)
Custom additions to CM6: several additional dictionaries for keyboard
Update: 22.9.2010 0.01c
- includes the previously released hot fixes for APN/GPS (i5) and unwanted boot during charge only mode (i10)
- temporarily used usb_mass_storage_fix script (borrowed from Dext3r) is gone. Motorola's proprietary usbd is back accompanied with Usb.apk (re-engineered to reflect changes in 2.2 os classes and to disable the unavailable options). StorageNotifications.java (part of services.jar) adjusted to not duplicate the notifications from Usb.apk. Usb.apk together with usbd allows to suspend the usb kernel driver and the phone can enter the suspend mode now. Hopefully, the battery life will be better.
- several adjustments in init scripts (includes the check for fighting adbd sometimes launched from the first init instance)
- QuickOffice.apk included
- Street.apk removed, so you can download and install the updated version from the market
- audioflinger recompiled to not include one unnecessary static lib
Note: when adb is enabled and usb connected during boot, you will have to disconnect and reconnect the usb cable before you can mount the SD card to a computer. chmod 644 /system/etc/init.d/02adb_during_boot will disable the early adb mode and the mount will be possible immediately. Early adb is enabled by default (well, it's alpha, right?).
Only system.img has been changed and there should be no need to wipe data when you update from 0.01/0.01b, but I highly recommend to delete cache and dalvik-cache. Use OpenRecovery 1.37 or newer. Don't forget to backup your customized /system/etc/init.d/10overclock first .
Main obstacles encountered:
missing new 2.2 functions in the proprietary audio driver library libaudio taken from 2.1 system, solved by modifications to AudioFlinger.cpp (getInputFramesLost and getRenderPosition).
Известные проблемы:
- intermittent chaotic touch screen responses when connected to USB
- system will reboot when sh.bin used to run the second instance of init or the 2nd init instance itself is killed, because the original init instance will suddenly try continue the deliberately frozen init process on an already running system
To do:
- prepare and release the source for custom building (=> installation via update.zip in the future)
- clean up the mess in init scripts
- invent some better init hijack
- make some non polling usb fix (for now it's using the Dext3r's script - thanks)
- etc.
Примечания:
- the main init scripts are located in /system/etc/rootfs
- clocking options (frequency table, vsel table and governors) can be set in /system/etc/init.d/10overclock
- google apps are already included in this one, I will change that in the future releases
- included BPSW and boot are from the 2.36 RTEU release - radio will work on European frequencies
Установка:
- use OpenRecovery to restore the downloaded system image on your phone
- if you are using Motorola's 2.1-update1 fix update, you do not need to restore the boot and BPSW, restore only the system
- data wipe/factory reset is highly recommended
Ссылки:
http://rapidshare.com/files/419591971/MM1_...alpha_0.01b.zip
http://rapidshare.com/files/420601255/MM1_...alpha_0.01c.zip
Сообщение отредактировал iBarS - 23.9.2010, 13:36
10 страниц V  1 2 3 > »
Alex469
сообщение 17.9.2010, 15:54
Пользователь №: 217 413
Модель телефона: RAZR,XOOM,Photon Q
Добавлю от себя. Только что поставил. Это андроид 2.2. Куча языков поддерживает. Включая русский! Пока правда не разобрался как на хард клаве переключать язык. Вобщем презанятнейшая штучка :)
Пока альфа, но очень хочется надеятся что будет развиваться дальше. Автор - очень грамотный человек.
iBarS
сообщение 18.9.2010, 3:58
Из: Кемерово
Прошивка: 2.2
У меня почему-то на нем не работает тач, верх экрана( странные дела..
Ratmagor
сообщение 18.9.2010, 18:55
Куратор темы
Из: Мск
Обманули бутлоадер? Или оно работает на старом ядре?
Silent_Bob
сообщение 18.9.2010, 19:36
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
На старом ...
Vinndimon
сообщение 19.9.2010, 9:33
Из: Москау
Пользователь №: 192 549
Модель телефона: Photon, Milestone, EM30
Прошивка: CM10, CM7, RSP
А для русской клавы RU-keyboard используется? Прибавка в производительности риальне есть?
Илья Дорошенко
сообщение 19.9.2010, 12:33
Из: под славным Тольятти
Пользователь №: 149 988
Прошивка: Самопал
Fgfnbz
я делал так:
шьешь рекавери, он начинает загружаться, выдергиваешь батарею (не в коем случае нельзя чтобы он загрузился после прошивки рекавери, иначе оно восстановится!), потом спокойно запускаю рекавери и дальше делаю что хочу!
serzh44
сообщение 19.9.2010, 15:39
Пользователь №: 152 279
Прошивка: 79R
Цитата(Илья Дорошенко @ 19.9.2010, 12:33) *
я делал так:
Не совсем понятно...у меня ошибка происходит при попытке применить update.zip, который как я понимаю open recovery и содержит.
serzh44
сообщение 20.9.2010, 11:55
Прошивка: 79R
ruKeyboard разве предназначена для офф. русских аппаратов? она поддерживает запятую, переключение языка.по-моему она в транслите печатает.нет?
Silent_Bob
сообщение 20.9.2010, 14:18
Городской партизан
Прошивка: Готичная
Там всё настраивается ...
ps.gif Настройки под РСТ Milestone в проге уже заложены ...
DeshFXs
сообщение 20.9.2010, 15:45
Из: Жуковский, МО
Пользователь №: 137 130
Модель телефона: Moto X
Прошивка: LiquidSmooth
скажите лучше про быстродействе, есть тот самый прирост вдвое? если нет - в унитаз.
Илья Дорошенко
сообщение 20.9.2010, 16:57
Прошивка: Самопал
Fgfnbz
по меню анимация подтормаживает. но игры заходили быстрее, списки крутятся быстрее, 3д галерея от нексуса почти моментально грузит фото... проц 550 мгц
Ratmagor
сообщение 20.9.2010, 17:02
Куратор темы
Из: Мск
Спасибо за помощь. Поставил - настроил - работает нормально. Скорость в играх заметно выше, раньше Angry Birds иногда притормаживали, а сейчас все летает. Меню подтормаживает только в AWD.Launcher, Launcher Pro разворачивает нормально.
serzh44
сообщение 20.9.2010, 21:09
Прошивка: 79R
Я прироста в скорости не заметил. Может только слегка. Что заметил:
1. Ввод с аппаратной улавиатуры стал жутко тормозить в браузере.
2. Таск киллер не может убить сам себя-зависает.
3. Батарея держит очень плохо.
4. Рукейбоард действительно корректно работает на рст.правда не работает запятая по двойному нажатию на точку
5. Флеш работает, но например, вконтакте не все видео работает, как-то через раз.
6. Реальный прирост в скорости замечен в rock base плеере, что не удивительно в теории так и должно было быть.
Вобщем тестить и тестить, но в целом серьезных проблем замечено не было, хотя и ожидал большего от 2.2.
Ratmagor
сообщение 21.9.2010, 5:23
Куратор темы
Из: Мск
По 4му пункту: запятая ставится через alt+.
Кстати, по непонятным причинам app2sd заработал со второго раза. В первый раз он тупо стер приложения, которые я просил перенести. Батарейка правда держит неважно. 4 часа музыки через бт-гарнитуру, несколько часов серфинга в нете по wifi, чтение около 4 часов, час разговоров -- умерла около 8 часов вечера.
Alex469
сообщение 21.9.2010, 5:42
Это зависит от версии ruKeyboard. В r49 запятая уже ставится по двойному нажатию на точку.
В предыдущих версиях дейтвительно alt+.
Сообщение отредактировал Alex469 - 21.9.2010, 8:35
Прикрепленный файл ruKeyboard_v1.5.3_r49.apk   ( 270.83 килобайт ) Кол-во скачиваний: 162
Илья Дорошенко
сообщение 21.9.2010, 18:06
Прошивка: Самопал
Fgfnbz
1) не заметил (рукиборд р49)
2) не пользуюсь и не пользовался никогда
3) как и на русской прошивке
4) все работает (р49)
5) сегодня вышел новый флеш (сборка 95) так все пашет и в стоковом браузере и в дельфине хд
6) даааа!!! это точно!!!
iBarS
сообщение 23.9.2010, 13:37
Из: Кемерово
Прошивка: 2.2
Обновился мод. Обновил 1й пост..
64kbiT
сообщение 24.9.2010, 17:07
Пользователь №: 204 007
Модель телефона: Milestone PCT 1ghz
Прошивка: Cyanogenmod latest
вообще perfect. но с батареей и правда беда, и заметил что он чтоли греться даже больше стал...
Илья Дорошенко
сообщение 25.9.2010, 3:28
Прошивка: Самопал
Fgfnbz
хм... в новой версии батарейку скушал за ночь на 10%... в старой жрал до 30.
64kbiT
сообщение 25.9.2010, 8:25
хм... пользуюсь сим модом 2 день, перестали ставиться приложения вообще, даже с маркета.
при установке файлменеджерами пишет "Приложение не установлено". через маркет - же, в статус строке - установка не удалась. Памяти вагон, чегото я не понимаю
з.ы : И да, в рекавери меню после разгона уходит в вечный ребут.
з.ы.ы Решил проблему с невозможностью установки приложения. Но так и не понял с чем было связано. Вообщем у кого будет такая проблема, в настройках самого цианогенмода переключить в автоматический режим путь установки приложений.
Сообщение отредактировал 64kbiT - 25.9.2010, 12:00
sals999
сообщение 25.9.2010, 14:20
Из: Россия_МО_Пушкино
Пользователь №: 192 983
Модель телефона: ZN5
Прошивка: Symbiosis X
app2sd не хочет работать на С версии, у кого ещё или тока у меня?
64kbiT
сообщение 25.9.2010, 15:50
sals999,
в вечный ребут уходит? тут же 2.2 можно вручную перемещать. и ещё можно в цианоген меню сделать чтобы они на карту ставились
sals999
сообщение 25.9.2010, 17:38
64kbiT,
не, не уходит, просто тел загружается а на ext раздел ничего не переносится
Ratmagor
сообщение 25.9.2010, 18:11
Куратор темы
Из: Мск
У меня сегодня тоже ничего не ставилось. Помогло в консоли:
su
rm /mnt/secure/asec/smdl2tmp1.asec
Кто-нибудь нашел как вернуть обратно мотороловскую русскую хардварную клавиатуру? ruKeyboard - это, конечно, хорошо, но экранная клава там уродская, а поставить ее только на аппаратную нельзя. =(
Сообщение отредактировал Ratmagor - 25.9.2010, 21:18
64kbiT
сообщение 25.9.2010, 18:25
Кто-нибудь нашел как вернуть обратно мотороловскую русскую хардварную клавиатуру клавиатуру? ruKeyboard - это, конечно, хорошо, но экранная клава там уродская, а поставить ее только на аппаратную нельзя. =(
Поддерживаю. свайп с рукейбордом не дружит ниразу :(
Сообщение отредактировал 64kbiT - 25.9.2010, 18:35
iBarS
сообщение 30.9.2010, 14:47
Из: Кемерово
Прошивка: 2.2
Update: 29.9.2010 0.02
This release is not much about bug fixing, more about the way it is built - the process has been finally automated. Built from the latest CM sources.
Anyone can build a nightly from the current repositories, see http://android.doshaska.net/cm6build
There might be new issues, please report them using the bug tracker.
Now in the form of update.zip - put it to /sdcard/OpenRecovery/updates and use the Apply Update menu.
Google apps have to be installed separately, also in the form of update.zip, applied after CM6.
64kbiT
сообщение 30.9.2010, 16:07
понял только то, что не особо фиксит баги. так собсна ктонить растолкует мне по Русски чейнжлог?
Ratmagor
сообщение 1.10.2010, 8:01
Куратор темы
Из: Мск
Этот релиз не столько о фиксе багов, сколько о том, как он сделан - процесс наконец-то автоматизирован. Собрано из последних исходников CM. Теперь каждый может собрать себе "ночную" сборку из текущих репозиториев - инструкция http://android.doshaska.net/cm6build. Там могут быть новые баги, пожалуйста, сообщайте о них используя багтрекер. Теперь CM в форме update.zip - положите на карту и используйте апдейт меню. Приложения гугл устанавливаются отдельно, тоже через update.zip, после CM6.
John-1994
сообщение 1.10.2010, 9:08
the cake is a lie
Из: Киев , Украина .
Пользователь №: 218 960
Модель телефона: Milestone , Bitch !
Прошивка: Froyomod 2.9.3
Извиняюсь , сколько я раз уже видел эту тему , но так и не понял о чем она , никаких упоминаний о так называемом Cyanogenmod при поиске практически не встречаются , на Youtube тоже ничего нет , а судя по данной теме это какая-то разновидность ANDROID 2.2 на старом ядре для нашего Milestone ...
Ratmagor
сообщение 1.10.2010, 9:46
Куратор темы
Из: Мск
Это просто одна из популярнейших сборок Android. В данном случае да, это йогурт на старом ядре, который работает полностью, более-менее стабильно и функционально не урезан.
XVilka
сообщение 1.10.2010, 22:13
Пользователь №: 109 689
Прошивка: CM10
Да, кстати добавлю, что cyanogen и koush отказались принимать эту сборку в официал.
Ну что ж, это их проблемы. Мы скоро добавим подробное описание что и как собирать, для ночных сборок, скрины, и все такое
John-1994
сообщение 2.10.2010, 10:48
the cake is a lie
Ratmagor , спасибо за ответ .
Однако после него у меня появились ещё пара вопросов :
1. В чем минус старого ядра ?
2. Более-менее стабильно - это насколько ?
3. Прошивка поддерживает нашу ЙЦУКЕН-клавиатуру ?
Добавлено позже (2.10.2010, 15:24):
За последнее время на Youtube появилось множество видео , пересмотрев , сразу потекли слюни установить эту прошивку , но ... после подробного прочтения темы стало понятно , что багает эта прошивка подобно стандартной WM 6.0 для G900 . uzhas2.gif
P.S.
Вопросы 2 и 3 отзываю , зато появился вопрос #4 :
Насколько сильнее эта прошивка сжирает заряд аккумулатора ?
Сообщение отредактировал John-1994 - 2.10.2010, 11:03
64kbiT
сообщение 2.10.2010, 13:49
лично я цианоген поставил только ради переноса приложений ( и прямой установки на ЕХТ ), и флешпреера smile.gif
вот такой вопрос, перешился сегодня в который раз, при импорте контактов, даже при создании, они якобы создаются, но при заходе в контакты он говорит что номеров нет. как-то я лечил это чудо костылем , но вот чегото сам уже забыл как grin.gif
John-1994
сообщение 2.10.2010, 14:23
the cake is a lie
64kbit , на SIM-карте можно хранить контакты , по моему вполне подходящий для этой ситуации костыль , и хватит дурачится , читается Cyanogen примерно как Сайонджен . crazy.gif
P.S.
Ладно , так уж и быть , придется поставить , на свои вопросы найти решение можешь только ты один . yesyes.gif
P.P.S.
Сегодня вышла новая версия .
Сообщение отредактировал John-1994 - 2.10.2010, 14:30
64kbiT
сообщение 2.10.2010, 16:39
John-1994,
читай внимательнее.
импортирую с симки, а они вроде как есть, а вроде как и нет. в контактах нет, а при наборе номера имя контакта отображается
John-1994
сообщение 2.10.2010, 16:57
the cake is a lie
В общем установил я этот "Цианогенмод!!!" , ожидал увидеть нечто прекрасное , но увидел кошмар , через 20 минут который с ругательствами снес по следующим причинам , они же проблемы этой прошивки :
2. Прошивка хоть и летает , но время от времени подтормаживает .
3. Приложения очень часто валятся .
4. Я не знаю , какое ПО для камеры установлено в 2.2 , но здешнее ну очень похоже на 1.6 .
5. Отсутствует Маркет .
6. не смог присоединится к своему Wi-Fi роутеру , система его попросту не видит , зато нашло вдоволь соседских точек . crazy.gif
7. Встречаются изображения явно меньшего разрешения , нежели поддерживает наш дисплей .
8. Аппарат начал перезагружаться , причем довольно часто .
9. Аппарат начал греться как будто процессор разогнан до 1.2 GHz , что кстати возможно , так как здесь кто-то жаловался на то , что если через OpenRecovery увеличить частоту процессора , аппарат переходит в вечный ребут , это неизбежно , если уже был встроен модуль увеличения частоты , к примеру от Milestone Overclock .
Может я что-то упустил , но этих 9-ти причин мне предостаточно , чтобы держать в урне для мусора этот мод , пока по крайней мере статус Alpha не изменится на RC . rtfm.gif
P.S.
Пол часа жизни было потрачено на то , чтобы ну очень сильно обломаться . sorry.gif
64kbiT
сообщение 2.10.2010, 17:28
1. Flash в браузере у меня не заработал абсолютно .
Каким местом ты ставил мод?
John-1994
сообщение 2.10.2010, 17:32
the cake is a lie
По моему правильным , закидывал в папку Update , перед обновлением делал Wipe , все по инструкции разработчика , устанавливал кстати версию не отсюда , а свежую , сегодняшнего выпуска , возможно сам автор накосячил ... wink.gif
64kbiT
сообщение 2.10.2010, 17:35
в названии "update" случайно не было?
ставь 0.01с , потом этой догоняй
и я не понимаю как можно перейти на мод который хоть и на старом ядре, но всё же 2.2 НЕ через андроид рестор. полный бред, насколько я понимаю, апдейт есть апдейт, а рестор с удалением система это уже другое дело. не?
Сообщение отредактировал 64kbiT - 2.10.2010, 17:37
[Milestone] Cyanogenmod, Порт от Nadlabak'a · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 9.8.2025, 23:01
