E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13)
smaylik
сообщение 15.11.2010, 18:37 Закрепленное сообщение!
Пользователь №: 173 531
E8_Silence-7
Autor: D-Boy
Based on: R6718_G_71.10.13R_E
Описание
Originally Posted by D-Boy
E8_Silence-7_Magicbox/ProcessMgr_13R_FW, I'm back...
Make sure that non-modded phones first be flashed with the correct version of noRSA bootloader!
When flashing is done, it's best to do master clear (Delete All Data) to achieve the best operating results!
Master Clear (Delete All Data):
Menu - Settings - Phone settings - Reset - Delete all data (Password: 000000)
Built-in input reason, the main clearance time is longer, about two minutes, please be patient!
I am the Lord because there is no clear result of the use of the obligation is not answered!!
I will begin by thanking those who contribute to the development of E8: ilove3D,龙 猪,泪,蜜蜂,maybeloveu,爱因,无印,Ro1ne, too many of them, endless lists, in short, thank you very much!
Thanks to ilove3D for the Magicbox, very powerful Task Manager, to 泪 for mgxInstaller, Rokr Mgr, Rokr tools and maybeloveu for the ProcessMgr.
Brush Pack is based on the ilove3D's Pro3 changes.
In accordance with their own ideas to add something.
I modified the package has always been the pursuit of speed and stability, unnecessary little things to add.
Divided into two versions, Magicbox version and ProcessMgr + Mpkgbox2.0 version.
Magicbox need to register, see the specific registration www.magxcn.com
for the free version, available to Friends of the machine is not up.
To maintain system stability, I do not like the built-in switch programs directly, so we only choose to forward to. CG36, CG46, CG52 components are used in cramfs format, improve system speed.
Brush Pack main features are as follows:
Both versions have built-in tears mgxInstaller, can choose to install into the menu or mpkgbox mgx or magicbox.
set which adds tears Rokr Mgr.
Built-in input methods. But need to manually import the theme and character input method.
After completion of the main brush clearance, the MarsInput folder into the phone memory unKnown can be.
\ MarsInput \ db may be replaced by your own font.
\ MarsInput \ theme can put themselves under the subject input method.
To keep the system speed at highest possible, sub-menu icons are disabled, you can enable them by yourself.
Sub.mgx
Also provides us with tears of gratitude to remove the installation tool in the menu mgx Mpkg Mgr, Thank you very much!
mpkg_mgr.mgx
For memory card partitioning you can use ilove3d's partitioner.
e8_parter_fixed.mgx
Other specific plug-it:
Note: This package in addition to built a music radar, but not built, or any other mgx java software, all software installed machine of their choice friends.
Set according to capture breath after running, choose to start automatically, after each boot can be automatically run.
If you press the music button after power is not exhaled, more like twice. After the first breath, after press time will be able to exhale.
the outgoing speed is fast.!
I thank those who have supported Friends of the machine, very grateful!
Скрины
E8_silence-7_Mod_ver_1.1
Перепакованная мной версия мода, пока тестовая.
Особенности:
- добавлен русский язык
- libezxappbase.so.1.0.0 заменена на патченую
- убраны китайские твики
- MagicBox заменен на MgxBox
- переработано меню
- авторан свапа на 3ий раздел флэш карты
- поддержка ext3 и ext2 разделов
- добавлен zCpuOverclock
- zTaskMan на зеленой кнопке
- Активировано HSA
- в файловом менеджере пункты ext и root
- EasyTheme как в zMod'e
- и по мелочам всякое
Если есть какие-либо пожелания или найдете баги пишите.
Известные БАГи сборки на данный момент( в следующей версии постараюсь устранить)
- не работает кнопка "нотка"
Установка
-Удалить все автораны с телефона и карты памяти, шрифты и прочую ерунду.
-переключиться на стандартный скин.
-Прошейте No_RSA_boot (если у вас его нет)
-Настройки\Настройки телефона\сброс\"Удалить все данные"
-прошейте монстр.
-если телефон не загружается, прошейте CG31 для своего бута.
-подождали 10 минут, после включения телефона и Настройки\Настройки телефона\сброс\"Удалить все данные" (Может показаться,что тел завис, это не так)
-после включения ждите 10 минут... перезагрузите телефон вручную.
-после включения ждите 10 минут. Телефон готов к использованию.
Скачать
E8_Silence-7_ProcessMgr_13R_FW.rar - http://u.115.com/file/t1bd5b56a9
E8_Silence-7_MagicBox_13R_FW.rar - http://u.115.com/file/t166a2a594
E8_Silence-7_Mod_ver_1.1 - http://depositfiles.com/files/x6mbu9djz
Версия 1.3.1 от J()KER'a
Описание
Скачать
Сообщение отредактировал Sereg_K - 4.3.2013, 8:47
3 страниц V  1 2 3 >
CurtizZ
сообщение 17.11.2010, 12:13
Пользователь №: 219 228
Модель телефона: Moto G3 1\8
Какие плюсы имеются?
smaylik
сообщение 17.11.2010, 13:49
Сообщение отредактировал smaylik - 17.11.2010, 13:52
CurtizZ
сообщение 17.11.2010, 16:41
Поставлю,отпишусь,Спасибо!
Helix
сообщение 17.11.2010, 18:11
Из: Украина г.Сумы
Пользователь №: 214 233
Можно было бы и лучше.
Ну что появились уже потребители этой прошивки, жду коментарий.
UnrealT
сообщение 17.11.2010, 18:33
Пользователь №: 175 369
Модель телефона: E8/Q9H
Прошивка: а фиг его знает...
MOTOUNREAL
smaylik, libezxappbase.so.1.0.0 заменена на патченую - эт хорошо)
я ее месяц назад ставил, но из-за замены ленга скорость стала как на все остальных) сейчас попробую твою версию)
N!kola
сообщение 18.11.2010, 11:31
Из: Сербия
Пользователь №: 144 136
Модель телефона: E398(x2) | ROKR E8
Прошивка: Anarchy48R | Z-Mod
Please fix that music button bug soon :D And, there are some parts of the menu that aren't translated to English, if you get the time, please fix that, too? But it's not necessary!
CurtizZ
сообщение 18.11.2010, 13:17
N!kola,
I'm going to try it now. By the way, I heard that each phone has its own Firmware LIMIT? Is that's true or it's just another rumor?
N!kola
сообщение 18.11.2010, 21:18
Из: Сербия
QUOTE(CurtizZ @ 18.11.2010, 15:17) *
N!kola,
What do you mean by "firmware limit"?
Probably same thing I knew about on E398 smile.gif It's just that the flash ROM can't survive countless rewrites! I remember there were people that killed their E398's by flashing them too many times, like Shoey... (oh, the good days!! sorry.gif )
So...the "limit" on E398 people talked about was somewhere between 500 and 1000 times, so don't worry about your E8, just enjoy modding smile.gif
@smaylik There are a lot of places in menu that are not translated :D
pes992
сообщение 19.11.2010, 7:05
Из: Кемерово
Пользователь №: 184 606
Модель телефона: V80,Е398,XT5
Прошивка: Android 2.2
Прошил...
обратно на зМод не могу откатиться
K()t
сообщение 19.11.2010, 7:39
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
pes992, Попробуй сток, а потом З-Мод
pes992
сообщение 19.11.2010, 8:04
Из: Кемерово
K()t,
В Рдс почему то кнопка старт не жметься
N!kola
сообщение 19.11.2010, 8:27
Из: Сербия
Temporary solution for the music button!! Use RokrToolsPro smile.gif set feature "Set keyboard shortcut" ON! Now when you press the music button RokrTools will open and when you hold it the MusicPlayer will open smile.gif
Cheers!
K()t
сообщение 19.11.2010, 9:34
Прошивка: CM
pes992, переименуй прошивку 1.sbf, кинь её в корень диска С.
pes992
сообщение 19.11.2010, 9:49
Из: Кемерово
Прошился,но только с другого компа,не знаю в чем дело
Сообщение отредактировал pes992 - 19.11.2010, 9:50
K()t
сообщение 19.11.2010, 9:52
Прошивка: CM
pes992, такое частенько бывает на "Семёрках" и "Вистах"
pes992
сообщение 19.11.2010, 11:27
Из: Кемерово
на семерке сначала ставил-не пошло,на другом компе точно такае же семерка и прошился
CurtizZ
сообщение 19.11.2010, 12:27
N!kola,
I've tested E8_Silence-7. I think there isn't special advantages.
P.S. Installed Myth 1.1 again...
P.P.S Is only one Myth is existing? I saw here "Last Myth" if I'm not mistaken...
smaylik
сообщение 16.12.2010, 14:41
Новая сборка 1.2
- Кнопка "нотка" работает
- Все скрипты теперь не русском и английском
- Изменена программа работы с темами
- Исправлен косяк с Mplayer'ом
- Мелкие исправления (конфиги и пр.)
http://depositfiles.com/files/6zegvn7mf
Сообщение отредактировал smaylik - 16.12.2010, 14:52
yomoyo
сообщение 21.12.2010, 12:25
Из: Одесса
Пользователь №: 182 416
Модель телефона: с650-l7-v3i-e8-charm
Прошивка: та всякие
так как монстр? что-то 5 дней и ни одного cry.gif поста_)
UnrealT
сообщение 22.12.2010, 9:37
MOTOUNREAL
блин, я скачал но из-за сессии нет времени заняться, прошить, посмотреть, почти к компу не подхожу(
Spitfire398
сообщение 26.12.2010, 13:40
Из: Ukraine
Пользователь №: 161 149
Модель телефона: E398, ROKR E8, DROID
Прошивка: Z-Mod E8
Радио в сборке 1.2 работает? В 1.1 не работает ... А так ОЧЕНЬ быстрый монстр, заметно.
smaylik
сообщение 26.12.2010, 19:52
У меня и в 1,1 работало, постоянно пользуюсь.
Spitfire398
сообщение 28.12.2010, 21:59
Из: Ukraine
Прошивка: Z-Mod E8
Радио не работает и в 1.2 сборке. Прошивку ставил по инструкции
smaylik
сообщение 29.12.2010, 6:25
Странно, а на других прошивках работает? Очистку данных делал? Мб при очистке ты подумал что тел. завис и батарейку выдернул? Если очистка нормально прошла могу предложить только прошить сток 13r, потом обратно эту. У меня с радио проблемы нет.
UnrealT
сообщение 29.12.2010, 7:00
MOTOUNREAL
Spitfire398, радио не запускается или шипит и ничего не говорит?
Наконец-то прошился, сегодня ночью, работает отлично, по скорости работы нормально.
Spitfire398
сообщение 2.1.2011, 23:17
Из: Ukraine
Прошивка: Z-Mod E8
Радио вообще не запускается, жму на пункт в меню "Радио" - ничего не происходит. Прошиватся нету времени, телефон нужен в рабочем состоянии 24 часа в сутки. Ставил поверх З-Мода, всё делал по инструкции. Радио вообще не использую, просто неприятен сам факт наличия подобного бага smile.gif
Sereg_K
сообщение 3.1.2011, 10:08
Мотоснайпер
Из: Жемчужина у моря
Пользователь №: 60 316
Модель телефона: ROKR E8
Прошивка: Z-Mod E8
Spitfire398,
Если бы ты был чуть повнимательнее, то обратил бы внимание на название темы "E8_silence-7, Мод на основе 13r_e". А З-Мод основан на R6713_G_71.14.1CR_A . Скорей всего, у тебя произошел конфликт кодовых групп от разных прошивок.
smaylik
сообщение 3.1.2011, 12:45
Маловероятно в прошивке все имеются все группы от 13Р (фулфлеш)
Spitfire398 может на Флешки автораны остались какие нибудь?
zerooo
сообщение 13.3.2011, 9:00
Из: Рязань
Пользователь №: 202 070
Модель телефона: c380l7l9em30zn5e8
Прошивка: разные
smaylik здравствуй а не мог бы ты выпустить еще одну свою перепакованую версию этого монстра? нравится очень скорость сижу на этом монстре но хотелось бы чтобы было софта побольше и чтобы радовало глаз smile.gif хочется чтобы скорость этого монстра и софт Final Myth smile.gif
ByJIkaH
сообщение 13.3.2011, 15:15
Пользователь №: 222 636
Модель телефона: rokr e8
Прошивка: r6713_g_71.14.1cr_a
http://depositfiles.com/files/x6mbu9djz - перезалейте монстра плиз!
smaylik
сообщение 14.3.2011, 5:29
Перезалито - http://ifolder.ru/22388164
zerooo, Извини новой версии не будет, весь функционал который в мифе можно через MgxBox организовать.
vatang
сообщение 24.3.2011, 11:25
Из: Сыкт-в-тык-кар
Пользователь №: 113 900
Модель телефона: MotoE8
Прошивка: 1CR_A
А боковую панель можно как нибудь отключить?
K()t
сообщение 24.3.2011, 11:59
Прошивка: CM
vatang, HSA панель? Да можно. Настройки > Главный экран > Стиль > Класический
igoripp
сообщение 30.6.2011, 20:29
Самый дерзкий
Из: Касимов, Муром
Пользователь №: 215 540
Модель телефона: sony ion
Главные достоинства:
1. Скорость навигации, юзаю русский язык. Был до этого у меня Змод, так вот, он медленней чем эта проша.
2. На телефоне 230 песен. Сейчас скажу в чем тут плюс: "Было у меня 210 песен, затем закинул еще 20, перезагрузил сразу же телефон. После включения, спустя 3 секунды, зашел в плеер, и начал слушать 220 песен, через 30 секунд в фонотеке появились остальные(20). Больше нет проблемы "Подождите пожалуйста, происходит обновление базы данных плеера"
3. Теперь радио само ищет название станции и сохраняет его.
4. Визуально, держит батарею дольше чем Змод.
5. Не обрабатываются прикосновения к лицевому сенсору, омега же - работает. На счет лицевой панели сенсора не знаю, плюс это или минус...
По поводу пятого пункта, это так и должно быть?
Ах, да, не выключался zCpuоверлок, пришлось в ручную это сделать.
K()t
сообщение 30.6.2011, 21:19
Прошивка: CM
igoripp, это заслуги 13r_e
aalleexxnn
сообщение 1.7.2011, 9:34
Пользователь №: 225 705
Модель телефона: ищу E8
а еще раз перезалейте пожалуйста версию 1.2
igoripp
сообщение 1.7.2011, 15:41
Самый дерзкий
Из: Касимов, Муром
aalleexxnn, ссылка рабочая!!! Будь внимателен)
sidr
сообщение 1.7.2011, 16:44
Из: Бреста
Пользователь №: 168 840
Модель телефона: Moto G 8G
Прошивка: 5.0.1
вот залил
aalleexxnn
сообщение 4.7.2011, 2:33
Размещен: 2011-03-14 08:21:14
Доступен до: 2011-04-28 19:10:46
Файл помещен в архив !!!
(Срок хранения файла истёк)
to sidr - спасибо, буду пробовать
Сообщение отредактировал aalleexxnn - 4.7.2011, 2:39
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13) · Motorola ROKR E8, EM30 · Forum
3 страниц V  1 2 3 >
Текстовая версия Сейчас: 10.9.2025, 22:52
