E8/EM30 request to firmware creators and skinners, No More Problems With Skins And Menu
Qfish
сообщение 20.2.2011, 19:10
Пользователь №: 212 397
Модель телефона: rokr e8
Прошивка: Nik_Stallion_e8
Hi guyz! I'm posting this thread here, because me and Nikhil have and and idea and a request to the creators of all new modded firmwares and skinners.
The whole thing is, to have all skins working on all firmwares without any problems by using the same configuration for custom icons (file manager mod and mgx apps in menu)
1. File extensions in file manager
Here is optimized fm_extensions file where all unnecessary extensions like "dvd" or "exe" has been removed
and "qm" and some other were added.
IPB Image
see that they are all:
fm_extension_small | for small icon in list mode in file manager
or
fm_extension_thb | for big icon in thumbnail mode
If You are making new firmware please use this cfg.
Here are the graphics to add to iconres
IPB Image
2. Folders in file manager (Mgx, Skins, Unknows files, mmca2)
This is just a small fix of motorola's work.
I am a bit precisian and i want to show you my idea.
You decide to apply it or not but it would be good if all modders and skinners will use one standard.
**Important thing is to edit ezx_mystuffstruct.cfg when you add any folder icon
EDITED BY ME ezx_mystuffstruct.cfg FILES HERE:
(there are 2 versions, 1st is for those who don't want to have mmca2 shortcut in file manager and 2nd one is for those who want this mod)
no mmca2:
IPB Image
mmca2:
IPB Image
Icons to add:
a) Downloads and Unknown files
Reason: both folders had the same icon
Downloads folder icon stays the same
Only unknown files icon gets changed
fm_unknown_folder_small | IPB Image
fm_unknown_folder_thb | IPB Image
*don't forget to rename them before putting in your iconres
(those icons are already present in stock onyx iconres but ezx_mystuffstruct does not use them, don't
know why - motorola's fault sad.gif)
b) Skins
Reason: skins folder had the same icon as pictures folder.
fm_skins_folder_small | IPB Image
fm_skins_folder_thb | IPB Image
c) Mpkgbox folder
Reason: Mpkgbox folder had the same icon as downloads and unrecognizable files folders
We use mgx packages so why it is called mpkg ?
the real folder name stays mpkgbox but in file manager it will display as "Mgx"
fm_mgx_folder_small | IPB Image
fm_mgx_folder_thb | IPB Image
*d) mmca2
Reason: mmca2 folder used downloads folder icon (yes, there were 4 folders with the same icon in extremal situations wink.gif)
fm_mmca2_folder_small | IPB Image
fm_mmca2_foldr_thb | IPB Image
Tell me what do you think about it... it would be cool huh ?
Ответов(1 - 1)
сообщение 21.2.2011, 13:04
-----------Start translating the topic into the Russian language-----------
Привет ребята! Я создал эту тему здесь, потому что у меня и Nikhil'а есть просьба к создателям модов и скинов.
Всё это для того, чтобы все скины работали на всех прошивках без проблем с использованием пользовательских иконок. (Иконки для типов файлов в файловом менеджере, и mgx приложений в меню.)
1. Расширения файлов в файловом менеджере
Здесь оптимизирован файл fm_extensions, убраны лишние файловые ассоциации типа "*.dvd" или "*.exe".
Добавлены "*.qm" и некоторые другие.
Видим следующее:
fm_extension_small // Для маленькой иконки (для режима просмотра файлов в виде списка)
или
fm_extension_thb // Для большой иконки (для режима эскизов)
Если вы делаете свой монстрпак (мод), пожалуйста используйте этот файл конфигурации.
Графика для добавления в иконорез:
2. Папки в файловом менеджере (Mgx, Skins, неизвестные файлы, Второй раздел карты памяти (mmca2))
Это просто маленькое исправление, в работе Motorola.
Я немного привередлив и хочу чтобы Вы посмотрели мою идею, будете ли вы её применять в своих проектах или нет, это ваше дело, но было бы хорошо если бы все скинмейкеры и моддеры использовали один стандарт.
ВАЖНО чтобы вы изменяли ezx_mystuffstruct.cfg при добавлении любого значка папки
Вот отредактированный мной файл ezx_mystuffstruct.cfg:
(Есть 2 варианта, первый для тех, кому не нужна иконка mmca2 (Второй раздел карты памяти) в файловом менеджере. И второй, соответственно, кому она нужна.)
без mmca2:
c mmca2:
Добавленные иконки:
a) Загрузки и Неизвестные файлы
Причина замены: Обе папки имели одинаковые
иконки, иконка папки остаётся прежней, а иконка папки
нераспознанных файлов изменена
fm_unknown_folder_small | Изображение
fm_unknown_folder_thb | Изображение
Не забудьте переименовать их прежде чем положить в iconres.
(эти значки уже присутствуют в стоковом иконорезе скина оникс, но ezx_mystuffstruct не используется
b) Скины
Причина замены: У папки скинов был такой же значок, как и папки с фотографиями.
fm_skins_folder_small | Изображение
fm_skins_folder_thb | Изображение
c) Папка Mpkgbox
Причина замены: Эта папка имела такую же иконку как и папка "Неизвестные файлы"
Мы используем MGX пакеты, почему папка называется "Mpkgbox"?
Настоящее имя папки останется "Mpkgbox" но в файловом менеджере будет отображаться как "Mgx"
fm_mgx_folder_small | Изображение
fm_mgx_folder_thb | Изображение
*d) mmca2
Причина замены: Дублирование иконки с папкой "Загруженные файлы" (да, там 4 папки с одинаковыми иконками. Вот такая вот экстримальная ситуация wink.gif )
fm_mmca2_folder_small | Изображение
fm_mmca2_foldr_thb | Изображение
Руководство для замены иконок MGX приложений в меню будет в скором времени wink.gif
Скажите мне, что вы думаете об этом... это было бы здорово, да?
--------------End of translation--------------
Сообщение отредактировал EXL - 21.2.2011, 13:09
E8/EM30 request to firmware creators and skinners, No More Problems With Skins And Menu · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 29.7.2025, 18:31
