Правка Seem В Е2, это возможно!
leskov_artem
сообщение 2.9.2006, 11:51
Пользователь №: 34 297
Модель телефона:  iPhone 3G
Прошивка: 2.1
Мануал по правке симов рокр е2
1.-First Step what you wanna do is first get Radiocom. And install it
2.-go to connections on ur cellphone and select usb net
3.- connect to pc if it doesn’t automatically find the drivers search x:/program files/common files/Motorola shared/Motorola pcs drivers or something like that and select the folder named usblan and install driver.
4.-open radiocomm and then go to setting tcpip and mlink usb lan driver
http://img315.imageshack.us/my.php?image=primerohg2.jpg
5.- here comes the tricky part
6.- In the Picture in number 1 is the offset and 2 is record number 1 so that World be seem 0032_0001
7.-Press RDELEM
8.-Below that on the DATA you will get a hex code which you should copy.
http://img322.imageshack.us/my.php?image=secondfy7.jpg
Xvi32
3rd part editing your sem. File with xvi32
9.-Open xvi32 and create new file
10.-go edit > clipboard> paste hex from clipboard
11.- there you go seem 32 ready to be edited
http://img322.imageshack.us/my.php?image=x...imerpasopr0.jpg
850 ya editado en el xiv32
12.- g oto offset 50 and then g oto tools > bit manipulating
13.- on the new tick number 0
http://img399.imageshack.us/my.php?image=850listokk4.jpg
3 er paso ya subir
14.- were almost done, now copy all that big hex code
15.- paste it on radiocomm on data where u previously took it from
16.-Now on length type as picture says
17.- STELEM and there you go you uploaded the seem to your phone
http://img399.imageshack.us/my.php?image=3...ubirseemdq7.jpg
Seems that work:
Engineering Menu works
Browser Charge before browsing on and off
850 band shows up in menu no idea if it does work but if u also seem edit seem 25 you might enable it
попробывал - работает
Ответов(1 - 35)
Darkslider
сообщение 3.9.2006, 8:12
Из: Moscow
Пользователь №: 43 239
Модель телефона: DroidMaxx
Прошивка: 4.4.4
ну,началось)
а что собственно полезного получили из этих правок?
-эт чё такое?
а инженерка такая-же?
motorap
сообщение 4.9.2006, 13:46
Пользователь №: 92 396
Модель телефона: e398+ROKR E2
Прошивка: R564_G_12.01.29P
Так что даёт провка симов !!! (она звук не добавляет?)
Puxapg_ZORGE
сообщение 15.9.2006, 7:00
Из: г. Алматы, KZ
Пользователь №: 69 098
Модель телефона: E398-->ROKR E2
Аналогично... мож кто знает как звук через динамики можна громче сделать, а то стандартный - НОЗИТ
Rider_ALT
сообщение 15.9.2006, 10:37
Пользователь №: 97 315
Прошивка: R564_G_12.00.45P
Я заметил, что пару едениц громкости можно добавит, если зайти в настройки профиля и вывести всё на максимум...
Kuz(M)и4
сообщение 22.9.2006, 12:02
Из: Россия, Тольятти
Пользователь №: 62 045
Модель телефона: Motorola
Чё уж такой звук на нём тихий, что не в терпёж его прибавить?И что всё таки из правки симов можно выжать?
4ep
сообщение 22.9.2006, 15:56
Из: Сызрань
Пользователь №: 43 886
Модель телефона: ROKR E2
Прошивка: Калейдоскоп
Rider_ALT, посмотри плз насчёт звука. Звук очень тихий.
lelvisl
сообщение 24.2.2007, 11:46
Пользователь №: 116 837
Модель телефона: Milestone & A1200
Ктонить может перевести на русский? просто я тут подумал, мож EDGE врубается через симы?
Darkslider
сообщение 24.2.2007, 14:00
Из: Moscow
Прошивка: 4.4.4
если даже так,откуда ты знаеш какой сим?
lelvisl
сообщение 24.2.2007, 15:07
Вот, человек писал
Цитата(Wattie @ Среда, 14 Февраля 2007, 17:25)
Can you extract seem 0032_0001 + the flexbit from 13R??
I think that the "SCAN" and "EDGE" functions are from seems
Вот я и задумался на этим
сообщение 24.2.2007, 15:11
Пользователь №: 55 068
Модель телефона: E398 > E1 > E2 > E6
Прошивка: >>>>>>>>>>>
Цитата(lelvisl @ Суббота, 24 Февраля 2007, 17:07)
Вот, человек писал
Можете ли вы как получить 0032_0001 + flexbit от 13R? ?
Я думаю, что "SCAN" и "EDGE" от функции представляется
lelvisl
сообщение 24.2.2007, 15:23
4473, угу вот именно, возможно эти функции просто врубаются/вырубается через симы. Тока мне бы вьехать, как их реддактироватьblush1.gif. Переведите ктоить первый пост, очень прошу
сообщение 24.2.2007, 15:27
Переводчик называется!
http://www.google.ru/language_tools
Там можно и страници переводить smile.gif правда кривовато получатся sad.gif
1.-7 Первый шаг - то, что вам нужно сделать - это прежде всего посмотрим Radiocom. И установить его концепция - идти к нему на сотовый телефон Наш usb-интерфейс и выбрать чистые 3 .- подключения к компьютеру, если он не автоматически найти драйверы поисковых х : / файлы / общие файлы / разделяют Motorola / Motorola шт драйверов или что-то вроде того, и выбрать папку с именем usblan и установите драйвер. 4.-11.8 radiocomm открывать и открывать для установления и двоеточиями mlink usb-интерфейс Лен водитель http://img315.imageshack.us/my.php?image=primerohg2.jpg 5 .- здесь идет сложная часть 6 .- В число фотографий в 1 и 2 компенсировать является рекордным числом 1, с тем чтобы Всемирная бы себе Многие 0032_0001 7.-14 RDELEM - пресс производительностью Ниже - о том, что данные вы можете получить шестнадцатеричный код, который вы будете копировать. http://img322.imageshack.us/my.php?image=secondfy7.jpg Xvi32 3-м часть редактировать Ваши семинары. Файл с xvi32 ночь - Открыть xvi32 и создайте новый файл рады - идти править> буфер> вставьте шестигранный из буфера обмена 11 .- там вы пойти показаться 32 готов быть отредактированы http://img322.imageshack.us/my.php?image=x...imerpasopr0.jpg 850 ya editado странице эль xiv32 г .- 12 ´ 50 и компенсируются Затем запускается г инструменты> 13 бит манипулирования .- о новых галочку рядом http://img399.imageshack.us/my.php?image=850listokk4.jpg 0 3 er subir ya paso 14 .- были почти у цели, н ов и скопировать все, что крупные шестнадцатиричный код 15 .- вставьте его на radiocomm данные о которых ранее у отнял от 16.-30.03.2006 - Теперь о продолжительности рода, как картина, - говорит .- 17 STELEM и там вы ходите вы загрузили похоже на телефон http://img399.imageshack.us/my.php?image=3...ubirseemdq7.jpg Выглядит эта работа : E ngineering Меню Браузер работает обязанности до просмотра и выключаться в диапазоне 850 появится в меню нет идеи, если она ы работу, но если у того, как править, как 25 вы можете позволить ему
lelvisl
сообщение 24.2.2007, 15:32
4473, им я уже перевёл, и нифига не понял sad.gif , но усё равно пасиб. нечитабельно...
FLAME NEON
сообщение 24.2.2007, 15:33
Из: Москва г.Зеленоград
Пользователь №: 56 846
Модель телефона: ROKR E2, MING A1200
Допустим я солью, и симы и Flexbit с 13 проши, дальше то что?
lelvisl
сообщение 24.2.2007, 15:35
FLAME NEON, не все симы, а только 0032_0001 . Первый вариант - тупо запихнуть их в новую прошу. Если не получится, то ковырять далее.
Но пока нада проверить первый вариант
FLAME NEON
сообщение 24.2.2007, 15:45
lelvisl, Ок первый пост это с е2mod.com один из старых мануалов, я ещё тада пробывал всё получилось, тада щас попробую из 13-ой вытянуть и в 45-ую вставить, результата жди гдето через час. Будеш ждать, а то если нет то я и шиться то небуду
lelvisl
сообщение 24.2.2007, 16:20
FLAME NEON, жду с нетерпением!!!! Если получится, то залей файлы и мануал по упихиванию в прошу!
FLAME NEON
сообщение 24.2.2007, 17:17
Слил с 13-ой симы, но батарейка на исходах, придётся подождать пока зарядиться а тока потом шить на 45-ую и впихивать. как тока будут результаты отпишусь.
Criz@liS
сообщение 24.2.2007, 23:35
Из: Планета The Мля
Пользователь №: 62 989
Прошивка: 14.3
WTF?!
Ребята есть пара замечаний:
1) Харош флудить, разговор типа "ты как там, скоро?" - "да-да, я уже почти закончил" оставляйте при себе! Форум должен нести информативность! И должна быть польза с постов. Я пользы не получил от прочтения вашей писанины. На крайняк есть ЛС или аська.
2) Если тупо вынуть симм из 13 и вставить в 45 - нефига не будет ежа! Думайте головой! mad.gif
lelvisl
сообщение 28.2.2007, 16:45
FLAME NEON, ну и куда мы пропали???
Кто-нибудь скинте 0032_0001 и flexbit от 13R, прошу очень!
Scottish
сообщение 1.3.2007, 3:09
Из: Тюмень
Пользователь №: 76 446
Модель телефона: Rokr E2
Прошивка: 4AP
lelvisl если ты внимательно посмотришь на 13R, то поймешь что в ней Flex нет и все симы и Flex остаются от предыдущей прошивки которая стояла до прошивки на 13R поэтому все симы что тебе сольют будут от той прошивки которая была ранее на телефоне!
из 13R ты можешь выудить только Flex_bit файл настройки работы Flex.
Darkslider
сообщение 1.3.2007, 7:06
Из: Moscow
Прошивка: 4.4.4
кстати,в 13R есть ёж то?он должен быть в 13P по идеи
Xronos
сообщение 1.3.2007, 12:19
Пользователь №: 57 881
Прошивка: 4A
Нет его в 13R. На этой страничке - http://moto.it168.com/viewthread.php?tid=6...;extra=page%3D1 - присмотритесь - у I love 3D именно та прошивка, которую все и искали и где все есть - и EDGE и много другого, заметтьте, скин стоит другой.....
uxobryux
сообщение 1.3.2007, 12:28
Из: Мск
Пользователь №: 52 068
Мне кажется что это фейк. Там написано QuadBand 3G. Откуда 3G то??? Е2 не поддерживает ни видеотелефонию ни WCDMA ни HSDPA и вообще ничего из 3G.
И с чего ты взял что это именно та прошивка?
lelvisl
сообщение 1.3.2007, 16:18
.01 говорил, что он ежа видел... Нада его спросить
Darkslider
сообщение 1.3.2007, 17:04
Из: Moscow
Прошивка: 4.4.4
выложите сюда скрины,а то чёт я там не увидел,по китайски не ферштейн
мне wattie в аське подметил,что прошивка была 13P,а мы нашли 13R
Xronos
сообщение 2.3.2007, 5:43
Прошивка: 4A
Вот картинка
Nuvolari
сообщение 2.3.2007, 12:34
Из: Нижний Новгород
Пользователь №: 97 162
Модель телефона: Milestone+Z8+ZN5+VE66
Да это все фигня. Я находил файлик laugh.gif Там можно и прошивку обозвать как угодно и название дипазона хоть 4G написать. Причем файл помоему просто можно изменить, даже монтирование не требуется smile.gif)
Xronos
сообщение 2.3.2007, 12:37
Прошивка: 4A
Ну скажи, где такой файлик находится... Будет очень интересно узнать.
Nuvolari
сообщение 2.3.2007, 12:42
Из: Нижний Новгород
Сказать где он не могу. нашел его чисто случаянно. Не помню где, но я точно помню что менял название прошивки АР там было by ilove3d а я сделал by Nuvolari, с телефона смотрел, все ок
Сумерок
сообщение 4.3.2007, 11:34
Из: Budva
Пользователь №: 98 437
Модель телефона: Nokia E52
Прошивка: latest
Да, я тоже находил, стер ilove3d, оставлял только название =)
Vinil_37
сообщение 5.3.2007, 8:28
Пользователь №: 38 166
Прошивка: R564_G_12.01.46P
Смотри Активация Edge на Rokr E2!
lelvisl
сообщение 5.3.2007, 15:07
Vinil_37, умник плин, его тогда небыло. Кстати, вруибили через симы
Will Rock
сообщение 5.3.2007, 17:35
Из: Тамбов
Пользователь №: 86 066
Модель телефона: ZN5/iPhone
biggrin.gif +1
frukT
сообщение 9.3.2007, 21:45
Пользователь №: 55 517
Модель телефона: E2
Прошивка: 38P...
может через симы возможно перезначение клавишь?
Правка Seem В Е2, это возможно! · Motorola ROKR E2, A910, A910i, E895 · Forum
Текстовая версия Сейчас: 13.9.2025, 20:30
