Titanium Extreme
Wattie
сообщение 22.2.2008, 8:57
Пользователь №: 58 537
Прошивка: 43R
New firmware by mati77 - http://www.e2mod.com/content/view/257/26/
Morrow
сообщение 22.2.2008, 11:52
Из: Ереван, Армения
Пользователь №: 155 146
Модель телефона: Скорее всего Atrix
Прошивка: Casseopeya©
Кто-нить пробовал? - какие ощущения? Шоу-модули есть? Нету траффика, а то бы скачал для интереса!
aTsEtOn
сообщение 22.2.2008, 13:11
Из: Tambov
Пользователь №: 21 660
Прошивка: 2.3
Как и ожидалось, ничего революционного в ней нет, просто перероботка EXTREME2 от ilove3d, прошивка в двух вариантах, 2-й добавляет фичи калейдоскопа. В Credits как мы и привыкли никакого упоминания авторов Калейдоскопа smile.gif
Вот собственно и описание:
This FW is based on ROKR Extreme 2. It is dedicated to English and Spanish users (the name and language of extra applications are automatically adapted to English or Spanish language). There are two versions, the original one and other with kaledoiscope
The main advantages are:
• Incremented speed and stability
• Automatically mounts swap and ext3 when SD is inserted
• Possibility to use the telephone without the SIM card
• Skins can be loaded in SD
• The music is played smoothly. There are not annoying clips
• Correction of media player. Now it is possible to see all type of signs!!! It has also a softer displacement in the menus
• You can use the radio without earphones!!
• APMD’s that are in my favor are mounted automatically at the beginning (you should rename it to apmd)
• Synchronization with Motorola Phone Tools
• Reading of messages
• Intel Xcale tool to make real-time underclocking/overclocking
• Corrected the separator in the adressbook when it orders for last name
• Application to rename pictures with graphic menu (fotoren). It changes the name of the moto_ * picture to the following form: yyyy-mm-dd_hh.mm.ss.jpg
• Camera with zoom up to 8x
• Tap writing method improved
• Incremented volume
• The low batter annoying sound were replaced with a vibration
• ilove3d Kernel v1 (ext2 and ext3 support, multiple keypress)
• Utilities (PhoneWareManager, System Info, Intel Xscale, SD Manager, LoadSDskin, Desktop visuals, Lights control, Refresh phone, Reboot, Fotoren, LinkSYS, BootGreetings, Print screen, EFEM)
• Possibility to change the voice commands easily!!! You should put on the file "command" that is in this download, inside the folder my_favor. You can edit the “command” file whit notepad ++ (included too) and change what the man says
• Possibility to enable/disable that alarm clock sounds in all the profiles (you should put on the file "alarm" in the folder my_favor)... Important: see PS
• The brightness isn’t modified when you makes overcloking/underclocking
• Stock bootimage
• Skins: OP, Revolution, Alkali (stock)
• MotoID working and stock games
• Descompresor of rar; zip; tar; tar.gz files
• My_FAVOR automatically executes:
apmd (to make overcloking/underclocking)
myfont.ttf (to change the font of the skin)
ezx_volumetable.cfg (to modify the volume)
ui_start_up_mono.wav (to change the sound when the phone boot up)
• Solved bug of previous firmware that sometimes, in certain places, the system clock become crazy
The version with kaledoiscope adds the following functions:
• Software keylock (by C + *)
• Copy/Paste function
• Multitasking for ezx-application
• Icons in submenus
• ilaunch bar
Atention: this version removes the synchronization with Motorola Phone Tools and it`s a bit slower
Important: if in your country the mobile phone works with the 900-1800MHz 1900MHz frequencies, you should install the corresponding flex included in this download
This package contains:
• Firmware
• Motorola USB drivers 3.4 & Telnet drivers
• https://motofan.ru/soft/ РСД Lite 3.9
• Apmd Pack
• File to enable/disable alarm sound in all the profiles
• Voice commands modification kit
• Triband flex pack
Exact
сообщение 22.2.2008, 14:48
Из: Челябинск
Пользователь №: 124 412
Модель телефона: E2+L9+V3+D880
Прошивка: RSA&nonRSA
Не боялся молвы, бунтовал...
MotorE1
сообщение 22.2.2008, 15:22
Мото-музыкант
Из: Казахстан, г.Алматы
Пользователь №: 126 150
Цитата(Exact @ 22.2.2008, 20:48) *
Что такое Субсиди код?
Exact
сообщение 22.2.2008, 15:30
Из: Челябинск
Subsidy код - залочился телефон, короче, как exeter'a - SUBSIDY LOCK.
// Вот г... - лоченые прошивки выкладывают
MotorE1
сообщение 22.2.2008, 15:33
Мото-музыкант
А в комплекте README есть? Выложи все текстовые файлы пожалста здесь, что пришли вместе с данной прошивкой - очень интересно
Exact
сообщение 22.2.2008, 15:50
Из: Челябинск
Вот. Те флексы, что были в комплекте - прошивал, не помогает.
Morrow
сообщение 22.2.2008, 17:54
Из: Ереван, Армения
Блин, у меня тоже самое!!!!!!!!!!!!!!!!!!
Прошился ради интереса - выскакивает "enter subsidy code" - и все! - капут!!!
Вынимаю сим карточку, тело включается нормально, как тока ее ставлю - таже хрень!!
Октатился назад на Е2_КЗ - то же фуфло! - опять код!! Прошился заводской 46П - тоже самое!!!!!!
Пробовал шить из компекта на диапазон 900 мегагерц (у нас такой, а по умолчанию 850мгц) - не шьется!!!!!! Пишет в https://motofan.ru/soft/ РСД Lite "phone is in flash mode: phone is connected". Пробовал во всех решимах - AP, BP, тело включено-отключено - все равно та же ерунда!!!!!!!!!!!!!!! Что делать-то народ????????!!!!!!!
Я этому автору все места повыдергиваю, как его там, как его ник? - он из е2мод-а? - он у меня попляшет!!!!!
Кажется, я понял, отчего этот урод закрыт - там в settings - network - search setup есть type, где должно быть GSM900, а там его нет - там тока 850/1900 и 1800. Автора винить незачем - он честно говорил в тхт файле, что эта проша не поддерживает GSM900. Для этого он там файлы оставил какие-то хреновые, чтобы ими можно было бы прошить. Но как не стараюсь, ни фига не получается. Народ, помогите!!!! Как прошить эти файлы-то??????
Народ, нашел способ прошить этого идиота - надо поставить в режим модема и надо, чтобы тело не в АП-БП режиме было, а так - включенное было просто. Тогда прошивает и в списке появляется GSM900, но все равно то же фуфло пишет!!! Ставлю эту сим-карточку на другое тело - все нормально работает. Ставлю другую карточку на мое тело - та же ерунда!!! Что делатЬ?????
Сообщение отредактировал Morrow - 22.2.2008, 18:31
MotorE1
сообщение 22.2.2008, 18:06
Мото-музыкант
Тут дело серъезное...
файл INSTALLATION.txt, который был вместе с данной прошивкой:
Installation:
1. install and open RSDLite
2. connect the telephone in modem mode
3. in case windows asks for drivers, look for them in the folder
"Motorola USB Drivers 3.4"
4. load the firmware in "Filename" box inside RSDLite (you should make click
on the 3 points button to search for "Titanium Extreme Kaledoiscope.sbf" file)
5. once your phone is detected begin the flash process with the "start" button
---------->Titanium Extreme by Mati77<----------
---------------Made in Argentina----------------
_________________________________________________________
... что-то надо править - конфиг какой-то, который отвечает за прием сети, нужно найти файл с именем типа security или Security… или на подобие
Exact, Morrow, телефон как USBNet подключить к компу можно? Он подключается, как сетевой диск?
Сообщение отредактировал MotorE1 - 22.2.2008, 18:13
Morrow
сообщение 22.2.2008, 18:53
Из: Ереван, Армения
Да, в режим USBNet подключается нормально! Даже перепрошивать можно! Я даже перепрошился на твою прошивку, после этого д...ма!. И черт меня занес ее тестировать...нафиг нужно было? - и что теперь искать в USBNet? - знаешь...помнится, я где-то-таки встречал какой-то password, по-моему где-то в bin было....может, файл whoimi?.....не помню.... Ща посмотрю.....Вы тоже, пожалуйста, помогите, чем можете! : )
Йа Санёг
сообщение 22.2.2008, 19:19
Из: вините скрываюсь от военкомата
Пользователь №: 150 157
Прошивка: Высокотехнологичная
Йо-майо тока шитьсо собрался, хорошо, что в тему заглянул, а то б тоже щас приключения разгребал.
Sanhcous_MR-Edition
сообщение 22.2.2008, 19:23
Из: Ростов - на - Дону
Пользователь №: 118 720
Модель телефона: Motorola ZN5
Прошивка: Motomagx 6.3
у меня проблемка прошился данным монстром все нормально работает в прнципе устраивает все все ок вот только теперь в режим BP части прошивки войти не могу что делать кто что подскажет???
Morrow
сообщение 22.2.2008, 19:28
Из: Ереван, Армения
Блин, раньше писал "enter subsidy lock" и поля давал для ввода. Пару раз я ввел. Теперь и это не дает, пишет об ошибке, что мол, тока могу emergency call делаты и все - не дает это поле для ввода цифр!!!! Хелп!!!!!!!!!!!!!!!!!!! : )
Exact
сообщение 22.2.2008, 19:39
Из: Челябинск
я не могу BP даже залить, выводит вот что:
Читал отмазы и решения проблемы от автора тут: http://motohell.com/index.php?topic=2186.15
Сейчас тел заряжу > Esco47P_RU > BP какой-нить > дальше посмотрим...
p.s. Не шейте этот монстр, если не хотите проблем!
Сообщение отредактировал Exact - 22.2.2008, 19:57
Morrow
сообщение 22.2.2008, 19:54
Из: Ереван, Армения
Читал отмазы и решения проблемы от автора тут: [url=http://motohell.com/index.php?topic=2186.15]http://motohell.com/index.php?topic=2186.15[url]
Тот урод автор и сам не знает, что делать! Не работает его BP!! У меня есть операторский BP, тока не знаю, как их заливать!! - кто-нить может проконсультировать? - надо зайти в бут мод (зеленная кнопка + голосовая) и потом в https://motofan.ru/soft/ РСД lite указать этот флаш файл да??
ЗЫ: На этом печально сообщении я стал Мастер-ом! : )
ЗЫ: Хоть одно утешение - на этом печально сообщении я стал Мастер-ом! : )))
К тому же, я кое-что не пониммаю: мы же прошивали АП часть! - причем тут БП??? Зачем его заново прошивать?
Действительно - не шейтесь! - Телефоны убьете!!!
Сообщение отредактировал Morrow - 22.2.2008, 20:10
Йа Санёг
сообщение 22.2.2008, 20:19
А потом через секунд 5 нажать еще раз на голосовой набор, перейдешь во 2-й бут режим, через него БП и шьетсо.
Morrow
сообщение 22.2.2008, 20:25
Из: Ереван, Армения
Ну как, есть что-то новое у тебя???
м-да... Titanium Extreme....действительно, extreme - телефоны попадают в экстремальное состояние!!!
Добавлено позже (23.2.2008, 0:31):
АУ меня их там очень много, этих файлов (46P): Barbados_Martinique_production_Eraser.shx, GSZMTRAMABRLA041.hs, GSZMTRRTLBRLA041.hs, GSZMTRTLMBRLA041.hs, R564_G_12.00.21P_gsm_sumatra_mbm_flash.sbf, R564_G_12.00.46P_flash_dev_rom.shx, R564_G_12.00.46P_gsm_sumatra_flash.sbf, R564_G_12.00.46P_gsm_sumatra_LANG002DE.sbf, Sumatra_Default_Phasing_Data_13R.nvm. Каким из них прошивать-то? Этим? - R564_G_12.00.46P_flash_dev_rom.shx ?
Exact
сообщение 22.2.2008, 20:34
Из: Челябинск
Вот этот способ: Заблокировался е2, не работает (Пост #20).
Телефон еще не зарядил...
Поле ответа - пустое там.
Сообщение отредактировал Exact - 22.2.2008, 20:34
eXeTeR
сообщение 22.2.2008, 20:56
Пользователь №: 123 801
Я в своей теме написал и ответил, я свое тело поднял, читайте тему "Заблокировался е2".
Сообщение отредактировал PItBuLL - 20.6.2009, 7:51
Exact
сообщение 22.2.2008, 20:58
Из: Челябинск
Я имею в виду этот способ.
Morrow
сообщение 22.2.2008, 21:25
Из: Ереван, Армения
Что делать-то блин??????????????? Как поступить??? - в нашем е....м городе ни одного специалиста нету по этому телу!!! Может, в Моторолу письмо написать????????
ЗЫ: Уже 3 часа ночи! Не спится! Написал письмо Мотороле - посмотрим, что они скажут. Кстати, когда заходишь в рсд под BP пишет номера IMEI: может их стоит попробовать? На сайте Моторолы прочитал, что тело от 12 до 24 часов сбрасывает код и его снова можно набирать. Будет ждать и пробовать набрать там IMEI..... : ) Всем гуд найт! : )
ЗЫЫ. Получил ответ от Моторолы - они действительно идиоты! - Вот что они написали:
Dear Mr Ayvazyan
Thank you again for your email dated 23 February 2008.
Your email has reached Motorola Singapore Office.
Your handset may be locked by the original network provider. If the network provider s name displayed on your handset when you switched it on is different from your mobile subscription company, you will need to contact the network provider, which in your case would be the network provider from America. You will need to provide the IMEI number when calling the network provider and they will provide you with the subsidy code to unlock the handset.
This is an added built-in security for the network provider. Once you have obtained the subsidy code, you may need to wait between 6  12 hours for the phone to reset itself and allow you to enter the code once again. You can also leave the handset turned on with the SIM card from the different network provider overnight, and by then the phone should be ready to allow them to re-enter the code once again.
Yours sincerely
Casey
Motorola Customer Service
Какой на фиг нетворк провайдер и какая на фиг Америка? - я же им человеческим языком написал, что у меня ДО перепрошивки все было ок, а после уже этот код появился!.
Сообщение отредактировал Morrow - 23.2.2008, 9:09
Wattie
сообщение 23.2.2008, 12:01
Прошивка: 43R
You can use any unlock software if your phone is locked
DDSH
сообщение 23.2.2008, 12:04
Пользователь №: 94 741
Wattie,
ага, вовремя сказал.
tigo
сообщение 23.2.2008, 13:50
Пользователь №: 150 839
Модель телефона: motorola rokr e2
Прошивка: 46
А простого решения проблемы разлочки нет? а то я как то упустил всё развитие событий, но регулярно обновлял прошивки ))
Morrow
сообщение 23.2.2008, 15:13
Из: Ереван, Армения
And where i can download such software? Can you give me a direct link?
Значит так... пошарил сегодня весь город, но ничего путного не нашел. Вдруг случайно вспомнил, что чел из нашего здания занимается разблокировкой телов. Позвонил ему. Он сказал, что сделает без проблем, только воторник. Так что надежда хоть какая есть. Буду ждать вторника и отпишусь тут, как и что.
Походу хотел попросить модеров пометить эту тему как опасную для жизни тела! : )
DDSH
сообщение 23.2.2008, 15:37
Problem Fix:
1. Test Point for Motorola Rokr E2
2. Go to URL: http://www.got.bz/got/main.php?section=clients
3. Download it: GOT Moto.
4. To Buy GOT Moto from 1-day Access.
Quote
1 day server access: 2.99€
5. Run GOT Moto & unlock!
(-) Mati77
Morrow
сообщение 23.2.2008, 19:21
Из: Ереван, Армения
Спасибо, DDSH!!
Млин, это прога платная да? : ((( Жаль..... В крайнем случае арендую ее на день и заплачу - ведь тело-то лечить надо!
Алелуйя! Сегодня мой Е2 воскрес! Спасибо знакомому челу, которому отдал! Как всегда - test point и перепрошивка!! Е2 бессмертен!
Сообщение отредактировал Morrow - 29.2.2008, 10:44
Titanium Extreme · Motorola ROKR E2, A910, A910i, E895 · Forum
Текстовая версия Сейчас: 14.8.2025, 15:36
Форум живёт: 8113 дней
