|Z3 MP| "STaRLighT 47" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA !
сообщение 13.3.2008, 13:18
Сам не тестил (поэтому делайте бекапы в том числе и PDS !!) нашел на
http://www.modmymoto.com/forums/showthread.php?t=73711 . Для тех кому скучно
Прикрепленное изображение + Прикрепленное изображение
Specifications
* Based on ODR Firmware
* Boot loader: A.C0 [DUAL BOOT]
* Flex : Starlight Flex
Features
* Custom Langpack
* Custom Boot Screen
* Custom Wakeup/Shutdown
* Custom Camera Sound
* Music On The Go [Slider Tones]
* Jump To File In Sounds Method
* 11 Funlights With Full LCD Support
* XClear DRM
* 3x4 Menu
* Dedicated Music Button(Pressing Browser Key Jumpes Into Sounds),
* Mp4 Rec
* Sim Not Required for access
* Dash On Numbers
* High Quality Voice Clarity
* Picture Grid View
* Hold # To Switch B/W Ringstyles
* Hold 1 For Voice Menu
* Can Store Up To 300+ SMS
* Custom Delayed Tone
* Talking phone feature
* Volume hacks >earpiece, speaker phone & mic gain
* Increased Volume
* 10X Speedier Than Normal RIZR ,
* Can Enable Full Access To JAVA APPS [ Using Motomidman]
* Lot More Ringtones & Wallpapers
UPDATES
1. Fast access photo from video camera
2. Access system files
3. Alarm clock name and time
4. Funlights Re editted
5. Alarm clock enable\disable on the right button instead exit
6. Bluetooth visible 15min
7. Default video resolution 352x288
8. Removed DRM protection
9. Increase java heap size to 2MB
10. Start corelets from iTunes icon form menu (required to edit mma_ucp and add iTunes)
11. Java Black Splashscreen
12. File access from java
13. Java works with usb cable
14. Access menu from everywhere press *
15. New date format dd.mm.yyyy
18. SMS\MMS ringtone
19. Usb charge instead animation
20. Set default webssesion on green button
21. zoom 200% and 250% instead 50% and 75% [Need dnp edit to show its 200%]
22.Camera tones Re editted
23.Delayed answer Re editted
24.Full access to every java applications fixed
Skins
* Sexy 7+
* Auda 7+
* Azure's Edge 7+
* Pink Addicted 9+
* Sky Sex 8+
* Walkman W880
* Walkman Black Pre 7
* Walkman Lord
Java Apps
* Winamp
* iTunes [Not Corelet]
* Bonus Apps
Thanks to:
Modmymoto & All The Motomodding Communities, All The Skinners
NOTES : STARLIGHT MP COMES WITH DUALBOOT & Is RSA REMOVED, DETAILED INSTRUCTIONS ARE GIVEN INSIDE, IT IS STRICTLYRECOMMENDED TO READ&FOLLOW EVERY STEPS AS INSTRUCTED!
-: Due to custom backdrops on music player, it is recommended that play videos at FULLSCREEN/ use walkman series skins.
ALL THE BEST FROM X&K
A TEAM WORK BY XCLEAR & KINGS
COPYRIGHT PROTECTED (C)
DOWNLOAD -
при прошитии рекомендую снять галочку с прошития ленгпака
т.к. скорее всего нерусский стоит.
ссылка для скачивания ==>>>
|Z3 MP| "STaRLighT 47" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA ! · Кастомные прошивки для Motorola RIZR Z3, KRZR K1, W490, W510, ROKR W6, SLVR L7e, L7i, L7x, L71, L72, L9 · Forum
> Быстрый ответ
Текстовая версия Сейчас: 11.8.2025, 10:20
Форум живёт: 8110 дней
