7 страниц V  1 2 3 > »
HeartlessMOD@V3X Version 4, Новая версия популярного монстра для V3x
KyRyL
сообщение 23.4.2008, 10:25
Из: UA
Пользователь №: 106 039
Модель телефона: Motorola RAZR V3x
Semseddin порадовал нас новой версией своего монстра для V3x HeartlessMOD@V3X
Оригиналы темы на www.hellomotorazrforum.com и на www.modmymoto.com
Изображение Изображение
От автора:
Since the third version of HeartlessMOD@V3X, Many people have asked for the new version but i decided to wait for new findings. I think that i was right to wait. To be honest, i don’t believe that this monster pack has some unique features like the previous hmod v2 and v3. However i do believe that Version 4 is the most professional, multimedia oriented, graphically unique, stable and bug free. I’ve optimized it for those who would flash and don’t need to touch anything else. I didn’t include any buggy moddings like the itunes, the flip close / open sounds and some buggy patches. I’ve also fixed all the known bugs of Version 3 and improved my nice flex. There’re noticible new adjustments like new file format for captured photos and videos, 4 mb java heap size for faster applications and 3d gaming speed, mma_ucp from skin folder for those who likes to use special skins. Since the time of version 3, i’ve improved my graphics skillz so i didn’t forget to improve the monster pack visually. The Drm of the mp is fully MotoMagX LinuX style and patched ready for itunes, Skins are well selected and unique for people with different tastes, external display skin is also very nice. Font is segou bold condensed clear type from windows vista . It looks very clear, too. Mp is based on the latest and fastest known software which is currently R252211_U_85.9B.E6P. It’s unlocked and unbranded.
SW : R252211LD_U_85.9B.E6P
Drm : MotoMagX Revision 3 by Semseddin (Разогнанный и пропатченный под иТюнс)
Шрифт : SegouBold Condensed by Semseddin LP0039 ( Special small&clear type font )
Flex : HeartlessMOD@V3X Version 4
Скины : HeartleSS by SoloRazr and Semseddin, IphoneMoto by Woody modified by SoloRazR and Semseddin, Milky, Perfection Gold by InsecureSpike ported by Semseddin, Phenomenon by Semseddin, Windows Vista by Cloud Strife, All external skins by J4ZZ from his IJ4ZZ skin.
СПИСОК ПРИМЕНЁННЫХ ПАТЧЕЙ (всего 24):
1. 4 MB heap в java
2. Новый формат имени картинок и видео, сделанных камерой (вместо DD-MM-YY_HHMM - YYYY-MM-DD_HHMM)
3. Смена mma_ucp вместе со скином.
4. Доступ к скрытым симам..
5. Патч для доступа к ФС без запросов + установка корлетов v1.1
6. Изменение атрибутов из явы
7. Неудаление списков звонков при смене SIM-карт.
8. Теперь красная кнопка при проигрывании будильника отключает его до следующего дня
9. Включение/выключение фонарика на двойное нажатие C
10. Мелодия SMS независимо от мелодии контакта
11. Работа java-приложений с подключенным USB-кабелем
12. Корелеты в списке ява приложений
13. Теперь при создании будильника по дефолту стоит громкость 7
14. Изменение времени повторного срабатывания Будильника
15. Время и название будильника
16. Изменение времени aвтоматического повторного набора на 7 секунд
17. Не издаётся звук при севшей батарее
18. Предупреждение о установке неподписанных приложений отключено
19. Отчёт о доставке смс по-умолчанию!
20. Время работы ВlueТooth 10 минут
21. Зарядка от USB вместо Анимации
22. Следующий трек или повтор в плеере!
23. 250% zoom в картинках
24. Корелет из фона вместо пункта Активации.
ФИЧИ:
* Index scrolling enabled - ?
* Порядок меню был изменен для лучшей навигации
* Поиск по Справочнику улучшен
* Сортировка музыки и картинок в алфавитном порядке
* Задействован Quad band (дополнительная частота - 850MHz) - ?
* Решена проблема перезгрузки Java
* Самый сильный уровень сигнала на E6P
* Звук увеличен на 4 уровня, без искажений. Повышен звук ушного динамика и проводной гарнитуры
* Улучшено качество фото и видео
* Добавлен 4x zoom, и "ночной режим" в видеокамеру
* Безлимитная запись видео на флеш карту
* Добавлена Пауза при записи видео
* Для фото добавлены эффекты синий, красный и зеленый, негатив и золотой
* Предварительный просмотр видео перед сохранением
* До 1 Мб посылаемого видео через MMS
* Добавлен счетчик при воспроизведении аудио/видео
* Запись видео в формате mp4
* пункт "Масштаб" в Основных настройках
* "Послать видео" в меню сообщений
* Установлен плеер DAP 5.1.9
* Поддержка EMS с большими стильными смайлами
* Меню "Послать открытку" в сообщениях
* Отображение всех входящих/исходящих звонков от одного абонента
* Включена загрузка приложений
* Функция Obeymoto (Голосовое управление) с американским вариантом английского
* Совместимый и оптимизированный mma
* Добавлены местные вэб-сессии
* Больше никаких "На;" в сообщениях
* Выключен юникод
* В памяти телефона хранится 500 SMS
* Подсветка дисплея 5 / 10 / 20 секунд
* Удалено ненужное видео
* Стиль звонка не меняется при зарядке или подключении к компу
* Клавиши быстрого набора от 1 до 9
* Голосовая почта на кнопке "1"
* Блокировка клавиатуры
* 60 входящих/исходящих
* Изменены картинки и мелодии на включение/выключение телефона
* В браузере добавлено сообщение о дополнительной плате
* Изменена заставка при входе в JAVA
И многое другое...
РЕКОМЕНДАЦИИ:
* Прошивать программой MotoKup02
* Перед прошивкой полностью зарядите батарею!
* Перед прошивкой делайте бэкап телефона, на случай того если что-то пойдет не так
* Перед пршивкой сохраните свои вэб-сесси (файл WebSession на диске a/), чтоб потом не настраивать их снова
* Чтоб не потерять свои сообщения, перед прошивкой - сохраните содержимое папки a/mobile/msgdb, а после прошивки восстановите.
* В монстре выключен юникод, не забудте включить его в программе P2KToolsVS или Uni moto
* Лэнгпак 0036 с русским iTAP - скачать
СКАЧАТЬ:
На бут 0.6.71 -» webfile.ru; 4shared.com; ifolder.ru;
На бут 0.6.81 / 0.6.82 -» webfile.ru; 4shared.com; rapidshare.com;
На бут 0.6.83 / 0.6.84 -» webfile.ru; 4shared.com;
Сообщение отредактировал KyRyL - 24.4.2008, 21:50
pk92
сообщение 23.4.2008, 13:06
Пользователь №: 95 803
Модель телефона: Xt5
попрошу перевести на русский все фичи и настроики нечё не понятно чё в монстре
citroen
сообщение 23.4.2008, 21:00
MotoAuto
Из: Minsk, Belarus
Пользователь №: 95 640
Да хочу добавить ув.semseddin не добавил в монстр корелеты( iTuns и VirtualCorelet) так как посчитал их глючными. Вы можете сами их установить взяв полностью рабочие из этой темы !New! Monstr for V3x - LifeTec by citroen
Ilya_GC
сообщение 24.4.2008, 11:29
Пользователь №: 170 313
Модель телефона: milestone, RAZR
Прошивка: CM 7 Roadracer
Мне нравится! Скины отличные!!
KyRyL
сообщение 24.4.2008, 15:56
Из: UA
Отличия от HeartlessMOD@V3X Version 3:
1. Профиксены баги
2. Добавлен патч "Новый формат имени картинок и видео, сделанных камерой"
3. Добавлен патч "Смена mma_ucp вместе со скином"
4. Добавлен патч "4 MB heap в java"
5. Много качественных авторских скинов, разогнанный, пропатченный Drm.
6. Заменены заставки на вкл./выкл. и заставка явы
7. Убраны звуки на открытие / закрытие флипа.
8. УБРАН иТЮНС!
А тюнс убрали из-за конфликта с патчем на 4мб хипа...
При выходе из явы телефон уходит в ребут...
Вы можете поставить итюнс самостоятельно, но придётся выгружать его при каждом запуске явы...
И наоборот - закрывать свёрнутую яву при запуске корелетов... Иначе будет ребут!
ВОТ архив от автора с иТюнсом, мма и инструкцией по установке всего этого
Сообщение отредактировал KyRyL - 24.4.2008, 22:15
Ilya_GC
сообщение 24.4.2008, 17:12
Что значит в меню "основная настройка" пункт "анимация" ???? Метки в монстре отсутствуют? если нет, то как их ставить ? И что значит "Смена mma_ucp вместе со скином" ?
KyRyL
сообщение 24.4.2008, 17:20
Из: UA
Значица в основных настройках активирован пункт "анимация", но благодаря патчу "Зарядка от USB вместо Анимации" он включает / выключает зарядку от юсби кабеля
это патч такой:
Смена MMA_UCP вместе со скином, MMA_UCP кидать в папку со скином, дефолтный MMA_UCP находится на прежнем месте в папке SYSTEM. После применения патча сразу же заменить дефолтный mma_ucp на другой!
P.S. Так же для портеров в архиве с патчем лежит исходник, для более лёгкого портирования
Сообщение отредактировал KyRyL - 24.4.2008, 21:33
Ilya_GC
сообщение 24.4.2008, 19:12
Всё таки есть метки или нет?
citroen
сообщение 24.4.2008, 19:55
MotoAuto
Из: Minsk, Belarus
Ну так попробуй.Если активировано то должна быть кнопка "Меню" пробуй браузер или "видео-вызов" если вместо этих пунктов открываеться меню.Значит метки активированы. Потом зажми на любом пункте и смотри потом...
Насчет пункта "Анимация". Да действительно как сказал KyRyL это нужно для патча "Зарядка по USB". Но теперь с этой темы скачай файл dnp.prf Патчи V3x на R252211LD_U_85.9B.E6P и залить его a/mobile и тогда вмесе с патчем замениться некоторые названия пунктов.
MObi Dick
сообщение 24.4.2008, 20:01
Из: Донецкая обл., Украина
Пользователь №: 62 406
Модель телефона: v3x
Прошивка: самая лучшая
Может кто-нибудь перезалить монстра для 0.6.82 на другой обменник??? с этих у меня ваще не качает!
С меня +1,5
HeartlessMOD@V3X Version 4, Новая версия популярного монстра для V3x · Кастомные прошивки для Motorola 3G · Forum
Текстовая версия Сейчас: 26.5.2024, 21:20
