New FW 16r By loko_vr
PauloGSM
сообщение 20.5.2008, 16:53
Пользователь №: 172 796
Модель телефона: Motorola A1200 2Gb
Прошивка: 16r
Full specifications:
-- New feature of insersão automatic prefix of the long distance carrier.
-- Option to set the speed of the context menu.
-- Option of automatic adjustment of daylight saving.
-- RV works with flip closed.
-- Manage bluetooth with flip closed
-- Make and receive calls, viewing recent calls and contacts with flip closed.
-- 3 USB modes - Modem, USB Drive, USB Network.
-- Good battery life. (virtually the same as 24xps, 24xp30)
-- The "Phone speaker" read all messages in Portuguese.
-- Camera good with an option to automatically save and Silencio
-- Filming in the resolutions 176x144, 320x240 and 352x288
-- Pulp native "bin" reinstated with files as bash2 and VIM
-- It comes with the profiles of all network operators from Brazil
-- File "plmn.data" of 16R containing the insformações's network also live, so that's chip uses live no longer has that "problem" to appear 724-XX instead of the name of the operator in the home screen.
-- Java Heap Size changed from 4 to 5. This is get increased performance of 3D graphics in Java Apps.
-- Added support to the startup's two (startup.txt and startup1.txt)
-- Option "report delivery" enabled by default
-- Languages included: BR Portuguese, English, Spanish and French.
-- The gifs the boot and closure of the original 16R
-- Bootscreen tb was changed to the one 24xps.
-- Ringones default in the FW:
Mid
* Alert's 1, 3 and 4;
* Notification's 1, 2, 3, 4 and 5;
* Polyphonic_Alert's 1, 2 and 4;
* High_Capacity;
* Somewhat.
MP3
* Hyperactive;
* Passion.
AAC (These are new. Withdrew a monsterpack gringa, but I do not remember which!)
* Chat_alert
* E-mail 1 and 2;
* Message 1, 2 and 3.
-- All 4 of the home screen icons can be changed.
-- 3 themes of the original a1200e
-- In the file manager 3 of 7 default folders created the phone may be deleted.
-- Even in the file manager, the folders are no longer the names as "My Videos", "My Pictures", etc.. Now is "Videos", "Images", etc.. The vision was cleaner and easier viewing. Moreover, if you are on your phone, of course it is yours, do not even need to say! Rsrsrs!
-- Icons of folders and files changed. (Say goodbye to folders with flowers and hearts!)
-- New icons on the main menu.
-- The acronym GPRS "disappeared" from the Portuguese language in FW, replaced by the acronym EDGE
-- Picsel in Portuguese (New version: 1.0.16 Build 4183)
-- Opera in Portuguese (Version 8.00 Build 3172)
-- Source changed to the original FW 24xp30 that supports up to Chinese characters.
-- Font size decreased in the language en-in the following measures: (A visualiação tah better, beautiful +)
Small, 15 = p / 13
Average of 18 = p / 15
Much of 21 = p / 18
Note: flashear After your phone, you probably vai be getting a lot of messages from your carrier! If you do not know how to disable this, click here
Changes in sound:
-- New sound of initiation.
-- Sound of receiving files via bluetooth and USB connection "Device Conected.wav" was amended.
-- Sound of touch in "Tom" (Touch_Scr_Tone.wav) tb has changed.
-- Sound of closure "Hard_Key_Hold.wav" amended.
-- Sound the keyboard standard "Hard_Key_Default.wav" is silent (so the keyboard only makes noise at the time of shutdown, pq barulinho that the keyboard with time irritates !!!!)
-- Archive ezx_volumetable.cfg changed. The general volume of phone is very good, but the headphone out is great! (It is the same as the Elite)
Note: Qdo cn flashear your phone, the folders will be created tb "preload", "MyPrograms" and another now that I forgot the name, however, if you wish, you can delete them!
Applications Inclusos:
-- SmartAssistance in Portuguese.
-- Business Card reader.
-- Explorer (My Stuff, for viewing files of system)
-- Netcontrol (pra Samba, Telnet, access to the Internet by the PC, etc. ...)
-- EKonsole with native bash2
-- ILock (for blocking the "telcado" iPhone style)
Bugs:
-- Do not load the battery when plugged into the computer by USB
-- Some apps more complex as Opera Mini and MScreen, are presenting problems that FW.
NOTE: The QT apps (PKG's) that you already have installed on your memory card may not work in FW, to correct this, do the following:
-- Open the file in the folder that is CardRegistry / .system / Java with Wordpad or Metapad (not with the notebook)
-- Edit the QT apps one by one, moving the item "Attribute" from "4" (probably) to "2" and the item "Directory" which will probably have only the name of the app as a value, you have to add the full path of folder on app, ie / mmc/mmca1/.system/QTDownLoad/AppNameFolder
Link 4shared: http://www.4shared.com/account/file/482860...r_PT-BR_V1.html
FW This was based on the Portuguese language, it is necessary to implement the Russian LP!
Prior to FW on YouTube: http://www.youtube.com/watch?v=8993kYwwb9g
All rights reserved to GSMFans.com.br
____________________________________________________________________________
Sorry for the bad language, I used Google translator to translate this information.
PauloGSM   New FW 16r By loko_vr   20.5.2008, 16:53
tmp_do   it is mod? do you have FULL original firmware? До...   20.5.2008, 18:13
Barbaro   O Sr é um fanfarrão Sr Paulo GSM hehehe ...   20.5.2008, 20:19
PauloGSM   O Sr é um fanfarrão Sr Paulo GSM hehehe...   21.5.2008, 10:48
Barbaro   sorry BenLaden I tried to write in Russian transl...   20.5.2008, 21:37
leevgenij   Мужики так на каком она буте?   22.5.2008, 17:05
Silent_Bob   Если я её прошью, я смогу откатиться обратно ???   12.6.2008, 15:19
CatSoup   Фиг бы их знал на каком. Эх, мож заглянут скажут. ...   12.6.2008, 17:25
Silent_Bob   Насколько я понял это прошивка "C2" сери...   13.6.2008, 1:24
Silent_Bob   Народ вы мне скажите pls : можно с неё откатится б...   18.6.2008, 16:43
leevgenij   =Хотелось бы попробывать этто чудо, но боязно   19.6.2008, 13:36
Bonzic   прошил поверх F5 !! кнопка голоса работает...   19.6.2008, 17:46
Silent_Bob   прошил поверх F5 !! кнопка голоса работае...   20.6.2008, 12:51
Silent_Bob   Есть новее версия http://www.4shared.com/file/5156...   19.6.2008, 19:03
tmp_do   нивкурю, BP там какой версии? какой флекс? кто пос...   19.6.2008, 19:42
_Bolik_   разобрал EZXcodec`ом...... ap_version.txt R53...   19.6.2008, 20:08
tmp_do   спасибо. 532C2...нафиг надо...   20.6.2008, 3:43
Silent_Bob   едж та на ней пахать будет ??? :shuffle:   20.6.2008, 5:23
leevgenij   Ну и как ощущения на первый взгляд?   20.6.2008, 14:31
Silent_Bob   Всё здорово но смски па русски не шлёт ... ((( В ...   20.6.2008, 14:46
Silent_Bob   #!/bin/sh if [ -f /ezx_user/autorun/icon/...   20.6.2008, 22:13
Silent_Bob   Щас прошился Perfectron_Amin_16R_Híbrida ... ...   21.6.2008, 1:42
leevgenij   А где саму прошу взять?   21.6.2008, 12:17
Silent_Bob   Тут http://www.4shared.com/file/51409639/f881d......   21.6.2008, 12:29
leevgenij   Подскажи куда iconrez сувать чтоб клава русиш была   21.6.2008, 16:33
Silent_Bob   #!/bin/sh if [ -f /ezx_user/autorun/icon/...   21.6.2008, 16:40
leevgenij   Спасибо за разяснение а вообще стоит попробывать и...   21.6.2008, 16:44
Silent_Bob   Еслиб смски по русски отправляло - былоб шикарно -...   21.6.2008, 17:56
leevgenij   Бобыч скинь пожалуйста свой авторан а что то не хо...   21.6.2008, 18:24
Silent_Bob   Уже два раза выкладывал ... Тут... /ezx_user/a...   21.6.2008, 18:46
Cent   А как насчет тупняка при входящем звонке?? есть та...   23.6.2008, 2:33
leevgenij   Практически нет Бобыч что то буквы печатаются ру...   25.6.2008, 13:44
Silent_Bob   iconres.ezx - это подмонтировал ??? iconres.ezx.g...   25.6.2008, 15:58
leevgenij   iconres.ezx - это подмонтировал ??? Подмонтиро...   25.6.2008, 16:05
Silent_Bob   Kлава как выглядит (screenshot) ??? Добавлено поз...   25.6.2008, 16:06
leevgenij   Добавлено позже (25.6.2008, 20:27): Во как   25.6.2008, 16:21
Silent_Bob   Не отображается картинка - но судя по описанию - к...   25.6.2008, 17:18
leevgenij   Da   25.6.2008, 17:36
Silent_Bob   Выбирай стандартную тему ... Добавлено позже (25....   25.6.2008, 18:25
leevgenij   Напиши пожалуйста как засунуть в ...\icon А ч...   26.6.2008, 12:56
Silent_Bob   Подмонтировать вместо ... Не ставил ... Altera...   26.6.2008, 16:47
leevgenij   silent napishi kod kak v konsoli perenesti s karty...   26.6.2008, 18:17
Silent_Bob   #!/bin/sh if [ -f /ezx_user/autorun/icon/...   27.6.2008, 0:32
leevgenij   Как файл авторана должен обзываться? Уже только на...   28.6.2008, 13:39
Silent_Bob   startup.txt   28.6.2008, 13:59
leevgenij   startup.txt Спасибо за терпение все пошло но сам...   28.6.2008, 14:35
Silent_Bob   Проверь смски в новой версии ... Русиш сделать сл...   29.6.2008, 3:38
leevgenij   Не неотправляет, хотя для меня этот пункт абсолютн...   29.6.2008, 15:15
Silent_Bob   :shades: iconres для 2.5 ...   29.6.2008, 20:43
leevgenij   Так что смс по русски будет?   30.6.2008, 3:01
Текстовая версия Сейчас: 30.7.2025, 20:06
Форум живёт: 8098 дней
