PP_Lrc1.5.4/PP_reader [23.09.2008update], new:pp_play_1.6 SRC&SDK
Campanula
сообщение 20.8.2008, 5:26
Пользователь №: 176 749
by:psjatqpgf[www.motoedy.cn]
pp-player plugin
This is a plug-in, with the use of motoCMD1.7.0.1
Fixed:
1: short music show little progress.
2: a blank screen and also standby to return.
Increase:
1: Allow the first from top to bottom, and the manual have the highest priority (regardless of what mode).
2: There are three modes: single, single loop, the whole cycle. # Switch
3: increase the number keys, 2 8 4 6 counterparts from top to bottom about 3 9 volume. * Or hidden.
Note:
* Just entering the end of the singles mode.
* Because the paper to find, access will be delayed.
* The MP3 will only join the list
SetWP.elf join extmgr.ini MotoCmd, choose BMP / PNG / JPG can see, but through the first set wallpaper, the screen view. And can not directly see
1. Merger documents, procedures for a merger deal with convenience.
2. Riga in the time display showing signal and electricity. And this is the same as the phone itself, not counting the voltage. Colors from red to green to the automatic transition, colors may be nausea point .......
3. Khao-screen function, improved, which may be in the normal operation of the border, but in the end and small paper did not test ....
4. Backlight control, in the text interface, the menu button is closed / open backlight. But as with the use of the Friends of the two patches under the menu ... that the use of careful, careful use of .....
5. Length of more than 20 amendments to the document can not be storage problems.
6. Can be used as a plug-in cmd.
7. In the use of the digital menu shortcuts, directly on the corresponding figure on it.
8. That opened less than 5 K's unicode format linked to the problem. (Two months ago saying this is a mistake ...)
9. Today saw the proposed zone of a message, think of a problem, Oh to be able to open the document in any format, of course, is the TXT format ~
10. That is less than 0 x21 due to the non-wrapped / Enter the text ASCII coding caused the loss (from WORD into the text in the copy of the frequent occurrence, from the pages of copy may also be a)
Interface resume ok
Do not open the file from that history disappear BUG ok
Separate document on the support ok
The final text is a single-byte coding do not show the restoration ok
Merger ok
Will be up into the main parameters of the function. ok
Time display of signals and electricity show. ok
Khao-screen problem. ok
Backlight control ok
Backlight adjustment
Jump on the document issue ok .....()
Long paper documents can not create a bookmark and history ok
The second open automatically withdraw from the ok
Bookmarks can not read the main ok
cmd link ok
Shortcuts ok
Khao screen in block border unexploded tank ok
Jump back up after the death cycle ok
Time display of signs location ok
Open less than 12 lines of text with the possibility of resuming ok
Small size of the end of documents do not show ok
Open any document ok
Patch Version:
Patch for R373_49R
Patch for L7_ACR
no Patch Version:
Прикрепленный файл ppreader_no_Patch_Version_.zip   ( 25.33 килобайт ) Кол-во скачиваний: 318
For example:
;comments
; app - elf path
; type - id|mid|uri
; id - FILE_ID as agrument to elf
; mid - Multiple FILE_ID as agrument to elf not supported
; uri - Path to file
; icon - not supported
[GIF]
app=/b/elf/MotoCmd/iv.elf
type=id
icon=0x120000CF
[ZIP]
app=/b/Elf/MotoCmd/UnZip.elf
type=id
icon=0x0
[PNG]
app=/b/elf/MotoCmd/SetWP.elf
type=id
[BMP]
type=id
[JPG]
type=id
[MP3]
app=/b/elf/MotoCmd/Music.elf
type=id
[M4A]
type=id
[AMR]
type=id
[JAR]
app=/b/elf/MotoCmd/MidTransfer.elf
type=id
[TXT]
app=/b/elf/MotoCmd/PPReader.elf
type=id
If friends want to the SRC, please PM to me!
Сообщение отредактировал Campanula - 23.9.2008, 2:20
Campanula   PP_Lrc1.5.4/PP_reader [23.09.2008update]   20.8.2008, 5:26
Alemurillo·   *Edit: To run ppp.elf edit extmgr.ini and eliminat...   20.8.2008, 15:23
Campanula   Last1Left The SRC to you   22.8.2008, 7:04
Campanula   ppreader_t8 Fixed: 1: relevance to open a single ...   24.8.2008, 1:39
friend 1   ppreader не работает на Л7е :( Неотображает русс...   24.8.2008, 11:58
RuslanchiK   И не должен.   25.8.2008, 8:40
Last1Left   PPReader in english( i'm not sure if the trans...   27.8.2008, 18:09
RuslanchiK   Last1Left - Great Job! Thanx! 2all - whe...   28.8.2008, 9:56
Campanula   30.08.08 pp_player_1.5 + + With pp_player, the #...   30.8.2008, 4:52
croccio   everyone can port the patc of pplayer and ppreader...   30.8.2008, 7:54
G-XaD   this is not a plugins for MotoCMD!   30.8.2008, 8:03
Campanula   this is not a plugins for MotoCMD! Which ?   30.8.2008, 8:19
croccio   with ppplayer i can't open *.mp3 files! wi...   31.8.2008, 12:07
friend 1   А картинки в мотокмд должны открываться или посыла...   31.8.2008, 18:56
VEX   friend 1 посылать как фоновой рисунок на рабочий с...   31.8.2008, 19:05
Last1Left   pp_player v1.5.4 in english: -archives contain: -...   1.9.2008, 18:49
newbieholic   Why after update libgen 4.0 for working iv.elf my ...   4.9.2008, 3:01
Nixxell   Кто знает зачем патч gb2uc.fpa ???   4.9.2008, 3:41
DDA-E398   Может кто-нибудь по-русски объяснить как установит...   4.9.2008, 5:09
RuslanchiK   Может кто-нибудь по-русски объяснить как установи...   4.9.2008, 7:07
Campanula   Very Good!   4.9.2008, 7:15
blak_alex   при запуске PPReader постоянный ребут либа новая 4...   4.9.2008, 12:49
RuslanchiK   blak_alex, Читать не судьба???? ЕГО НЕ НАДО ЗАПУС...   4.9.2008, 13:03
blak_alex   blak_alex, Читать не судьба???? ЕГО НЕ НАДО ЗАПУ...   4.9.2008, 13:24
simba4   some functions needs to be added in the lib __rt...   4.9.2008, 13:27
croccio   i apply the patch and woth new version i can't...   4.9.2008, 14:39
Мачо   Memclr не добавляйте тюнс глючить будет.. В т...   4.9.2008, 15:30
DDA-E398   я применил автопатчер к эльфу и всёравно ребут   5.9.2008, 20:57
Last1Left   pp_player v1.5.4 black walkman mod by me, english ...   8.9.2008, 10:19
RuslanchiK   Last1Left, black_walkman_no_patch - reboot :(   8.9.2008, 11:54
Campanula   Last1Left, black_walkman_no_patch - reboot :( ...   8.9.2008, 12:12
newbieholic   @campanula, Is there any program for edit or make ...   9.9.2008, 7:17
Last1Left   @campanula, Is there any program for edit or make...   9.9.2008, 11:45
Hellscream   выложите кто-нибудь эти эльфы на сторонние хостинг...   10.9.2008, 3:52
VEX   Campanula you elf pp-player conflict with elf date...   21.9.2008, 8:36
Campanula   Campanula you elf pp-player conflict with elf dat...   21.9.2008, 8:47
VEX   English Version: This is exactly the English ver...   22.9.2008, 12:59
Campanula   This is exactly the English version? I have for s...   23.9.2008, 2:17
Last1Left   pp_player v1.6 ENG walkman   25.9.2008, 10:58
croccio   CAN U GIVE ME THE PATCH L1L FOR L7 ACR_RB?   25.9.2008, 11:11
Alesha_Pl   Last1Left, да что же такое китайский pp_player no...   25.9.2008, 11:35
Last1Left   pp_player walkman v1.6.5 --some bugs fixed --added...   25.9.2008, 15:11
GALL   Last1Left, my phone is frozen with pp_player walkm...   25.9.2008, 16:26
VEX   [b]Last1Left, английский вешает телефон? Что за ...   25.9.2008, 19:12
GALL   VEX, эльф Date выгружен.   26.9.2008, 3:04
Alesha_Pl   VEX, поясняю. Да у меня запущен эльф дэйт. При это...   26.9.2008, 5:44
blak_alex   Last1Left ожидается ли выход PP_reader с отображен...   29.9.2008, 11:19
bbeepopov   А как заставить PP player играть несколько песен? ...   8.1.2009, 19:23
VEX   bbeepopov, на # переключение режима воспроизведени...   8.1.2009, 20:32
bbeepopov   Не, это понятно, я имел ввиду списки воспроизведен...   9.1.2009, 13:06
VEX   bbeepopov,нет.   9.1.2009, 18:08
twisted 747   Выйдет ли ppreader с кирилицей? Есть какой-нибуть ...   12.4.2009, 12:45
Fenja   Сомневаюсь :) Плугин смотреть в теме: ELFs by ...   12.4.2009, 13:04
PP_Lrc1.5.4/PP_reader [23.09.2008update], new:pp_play_1.6 SRC&SDK · Эльфы, их разработка и портирование · Forum
Текстовая версия Сейчас: 13.7.2025, 19:48
Форум живёт: 8081 дней
