mma_ucp and skin icons
SocaSlvr
сообщение 18.9.2008, 21:18
Пользователь №: 158 313
Модель телефона: E8, L7, K1, V3
I have seen the guides on how to get the icons located in the drm to be redirected to the skin (itunes, usb settings, voice dial etc.).
The guide uses mma advance editor where you modify the item and use certain "codes" to redirect to certain unused icons in the skin.
My question is how do i get these "codes" that are entered for certain icons located in the skin.
I would like to know how to generate/calculate what "code" must be used for any icon located in the skin.
Do you get what I'm trying to say?
For example i would like to get the code for the list icon for motomixer (808.gif) located in the skin.
The code is 552
What must i do to get the code? This is just an example, but i would like to find out how to do this for any icon located in the skin.
Hope someone can help me with this!
Thanks in advance
Сообщение отредактировал johndoelaser - 18.9.2008, 21:21
Ответов(1 - 6)
vetal_13
сообщение 19.9.2008, 8:02
EverFree
Из: Апрелевка
Пользователь №: 118 290
Модель телефона: C380, Lenovo A820
Прошивка: MotoKDE, LifeStyle
The code is 552
552 - is the number of DRM icon and that is all
552.gif is a file not a code.
I made an english version of manual, hope this will help you to understand how it works.
The only thing you need is the list of DRM - icons with their numbers.
Прикрепленный файл FullSkin_manual_v1.3_eng.rar   ( 38.73 килобайт ) Кол-во скачиваний: 135
SocaSlvr
сообщение 19.9.2008, 22:03
Yes it is a code
Its the code used for rerouting the icon to be take from the skin
Look here
IPB Image
By the way
That rar has an error (corrupt)
Сообщение отредактировал johndoelaser - 19.9.2008, 22:05
elvis
сообщение 19.9.2008, 23:05
Пользователь №: 162 964
Модель телефона: e770_V3X
Прошивка: 85.9b.E1P
there are some problems on the motofan, but you can download all files with DOWNLOAD MASTER(for example)
Сообщение отредактировал elvis - 19.9.2008, 23:05
SocaSlvr
сообщение 20.9.2008, 0:13
QUOTE(elvis @ 19.9.2008, 19:05) *
how to do that
vetal_13
сообщение 20.9.2008, 20:05
EverFree
Из: Апрелевка
mma_ucp contains the information about menu items and icons linked to each one, configuring mma_ucp you may change the links.
Look here
If menu item has own icon (some of them do not) the simple operation takes place:
The item has graphical element (552 (default) that means taken from DRM); if proper element is available in skin then display skin element (808); else display default one.
mma_ucp is like a "table" containing items' names and icons' numbers; open mma_ucp in MMA_Advanced_Editor, pick any item you want, right-click on it, and find out what ICON NUMBERS (either from skin or from DRM) corresponds the selected item.
Numbers of skin icons available in Skinner4Moto
Numbers of DRM icons available in ShxCodec
Google it to download, or visit MotoFan.Ru "Download" page.
SocaSlvr
сообщение 20.9.2008, 21:56
QUOTE(vetal_13 @ 20.9.2008, 16:05) *
Look here
That clarifies everything for me now.
Thanks a lot for the explanation.
I already know how to edit skin gifs and drm(cg15) gifs
So now i understand thanks to you and
Thanks again
mma_ucp and skin icons · For English speaking members · Forum
Причина закрытия (Dark Beat 26-09-2008): Done
Текстовая версия Сейчас: 12.7.2025, 14:11
Форум живёт: 8080 дней
