Новый, быстрый мод для ЕМ30, Пора бы и нашим мотофанам узнать про Imperfecto V2
Dark Lamer
сообщение 14.8.2009, 7:26
Пользователь №: 195 788
Модель телефона: Moto rokr ЖРУ30
Прошивка: ковыряю 03.06
Хочу рассказать вам про неглючный и не тормозной , что особенно важно, мод.
Собственно, зачем это нужно? много фич, активированный своп, мпкгбокс первой и второй версии одновременно, ну и еще по мелочи.
Мод основан на 04.06 прошивке. Перевожу ориинальный пост. Автор мода - Sandip 2u. Индиец .
TO START,NEED TO THANK FEW PEOPLE
1.nikhil007
2.rasputin007
3.ilove3d (the creator of mpkg box2.0)
most of the problems of imperfecto version-1 has been solved ,with the addition/modification of few features
includes all the basic features of imperfecto version-1
plus
1.mpkgbox 2.0
2.now you can install mpkg apps both on phone and memory card
3.lock anything and everything
to name
-snapshots-messages-fixed dial-autorun view-task list
-contacts-profiles-alarm clock-system info-file manager
-shortcut-phone settings-fmradio-browser-mobile internet
-calender-power-cpu speed-bluetooth-themes
-sim services-email-camera-notes-recent calls
-media finder-mpkgbox2.0-connections-new text
4.7 preinstalled mpkg apps
-snapshot (under multimedia)
-cpu speed , power , shortcut (under settings)
-system info , new text , autorun view (under office tools)
-with new text app ,you can directy create and save texts on memory card
5.swap memory (virtual memory) enabled
-need to install swap memory app on memory card
6.full java authorisation
-you need to restart your phone after you intall a java app ,to apply the chages
-the java authorisation is based on cg36 modification
-if you are not happy with it,you can always flash the cg44 modification for java authorisation developed by modders of moto.it168
7.invalid .chm check ,created by ilove3d
-it will check any invalid .chm file related to a skin
-that means to delete a skin you only need to delete it from the skins folder..
-and the next time you open themes,the unwanted skin will be completely deleted
8.all new font (you can see it in the screen shots)
-its called the "designers block"
9.much faster than the previous version of imperfecto
10.you will find out more ,when you use the flash
WHAT YOU NEED
1.RSD LITE LATEST VERSION (GOOGLE IT)
SEE HOw TO USE RSD LITE http://www.mmus.us/forum/showthread....flashing+linux
steps to flash (read the guide thrice before flashing)
1.FLASH No RSA BL (06.A9 or 06.AC depending on your present BL)
TO KNOW YOUR BOOTLOADER
-SWITCH OFF YOUR PHONE AND PRESS THRE BUTTONS TOGETHER * # AND THE POWER BUTTON (ALL THE THREE BUTTONS SHOULD BE PRESSED TOGETHER)
DOWNLOAD http://www.mmus.us/forum/downloads.php?do=cat&id=210
-AFTER YOU FLASH THIS AGAIN CHECK YOUR BOOTLOADER
-IT SHOULD SAY NO RSA
2.FLASH IMPERFECTO
3.DO A CLEAR ALL DATA (MENU/SETTINGS/PHONE SETTINGS/RESET/CLEAR ALL DATA)
-DEFAULT CODE IS 000000,SIX ZERO
4.NOW WHEN YOU CAN SEE THE HOMESCREEN GIVE IT 15 SECONDS TO BOOT PROPERLY
-THEN GO TO SETTINGS/CPU SPEED
-AND SET IT TO 532 MHz
5.AGAIN REBOOT YOUR PHONE
-GIVE IT SUFFICIENT TIME TO BOOT PROPERLY(10-15 SECONDS AFTERYOU CAN SEE THE HOMESCREEN)AND ENJOY.
Для начала хотелось бы поблагодарить нескольких людей :
1.nikhil007
2.rasputin007
3.ilove3d (Создателя MPKGbox)
В данной прошивке было решено большинство проблем первой версии мода , добавлены некоторые возможности , некоторые подверглись переработке.
Добавлено
- mpkgbox 2.0
- Возможность устанавливать mgx приложения как на карту памяти, так и в телефон
- Возможность защитить паролем почти все пункты меню, мключая предустановленные MAGX приложения, среди которых числятся :
-snapshot (в Мультимедиа)
-cpu speed , power , shortcut (Располагаются в Настройках)
-system info , new text , autorun view (в Органайзере)
- Новое приложение для редактирования текстов, которое позволяет сохранять их в
память телефона и на карту.
- Активирован Swap, нужно установить приложение для него на карту памяти.
- Выдача полных прав для Java , для полного примененя изменения прав , нужно перезагрузить телефон после установки приложения. Примененный метод выдачи прав оновывается на модификации CG36. Но если кто-то недоволен, то он может прошить СG44 от моддеров с Moto.it168 для этих же целей.
- Проверка для неправильных файлов *.chm (за авторством ilove3d)
Что она делает?
Проверяет *.chm файл темы. И если найдет файл с ошибками , то Вам останется только удалить скин из папки skins. В результате, когда Вы откроете темы в следующий раз, то этот скин вы уже не найдете.
- новый шрифт (шрифт классный, прямо супер, но русскоязычным пользователям придется его заменить - нет кириллицы)
- Ну и , наконец, этот мод действительно быстр.
Список изменений неполный, при желании вы сможете найти и другие отличия от стандартной прошивки и от предыдущей версии мода.
Как прошить?
Как обычно. Шьете NoRSA бут , а затем прошиваете сам мод, который можно взять по адресу http://www.megaupload.com/?d=DPFAMXOV (не перезаливал, ибо не спрашивал согласия автора)
после сделать Delete all data , установить лэнгпак по вкусу и радоваться.
Переводил я (Dark Lamer), вручную, никаких "Google переводов"
Картинки ,пожалуй, добавлю потом. Однако, ничего такого в них нет.
Сообщение отредактировал Dark Lamer - 19.8.2009, 19:18
BlackDeath
сообщение 14.8.2009, 11:16
Пользователь №: 197 521
Модель телефона: c380, V3i, EM30
Прошивка: 06R_C
Dark Lamer,
как успехи с ленгом или русским вводом?
Dark Lamer
сообщение 14.8.2009, 11:24
пока не пробовал. вечером подмонтирую раскладку и сменю шрифт, вот и все.
Самое смешное, что русский язык мне в телефоне нужен только для справочника.
Сообщение отредактировал Dark Lamer - 14.8.2009, 11:25
Dark Lamer
сообщение 14.8.2009, 11:58
сначала дате загрузиться 20 секугд ему после включения, зайди, выйди из меню. после будет круто. если же скорость не устраивает, мо можешь разогнать, там CPUspeed в настройках, выставишь 532 мгц, только когда будешь в интернете долго сидеть, понизь обратно частоту.
Сообщение отредактировал stigr - 15.8.2009, 5:54
apple97
сообщение 14.8.2009, 12:24
Пользователь №: 111 729
Модель телефона: MotoRIZR Z8
кстати столкнулся с проблемой невозможности удаления номеров моторолы там их 4 штуки
Virgilij
сообщение 14.8.2009, 13:32
Уруру
Из: Убервальд
Пользователь №: 163 908
Прошивка: PearlMod
Цитата(Dark Lamer @ 14.8.2009, 16:19) *
шрифт сохранить нельзя, в нем нет кириллицы, блин.
Добавте в шрифт русские символы, в проге Font Creator это не сложно сделать, времени уйдёт пол часа максимум. Правда кое какие буквы прийдётся рисовать в ручную, но это там тоже не сложно сделать))
Zach
сообщение 14.8.2009, 16:09
Пользователь №: 192 367
Модель телефона: ROKR E8
А эсли втулить просто левый ленг который был раньше гдето выложен на сайте ???
Dark Lamer
сообщение 14.8.2009, 16:15
я попробую, но не исключены тормоза. хотя не должно. В общем буду добровольцем.
5 минут и будет отчет.
Добавлено позже (14.8.2009, 16:22):
2 минуты полет нормальный. Прошивал турбленг свой.
Абсолютно не понимаю, про какие тормоза говорится.
Сообщение отредактировал Dark Lamer - 14.8.2009, 16:25
BlackDeath
сообщение 14.8.2009, 20:38
Прошивка: 06R_C
Я кстати пробывал твой ленг когда у меня стоял этот мод, но тел в буте с ошибочкой висел
Offset
сообщение 14.8.2009, 21:06
Leo
Пользователь №: 126 712
Прошивка: 2BR
Что за чат? Сережа, что ты тут по слову в посте пишишь? Будет баловаться - будешь наказан.
Dark Lamer
сообщение 15.8.2009, 15:02
Итак, 2 день , полет нормальный , впечатления положительные. Немного медленно загружаются (секунда) приложения типа смс и прочего, но в остальном все хорошо.
BlackDeath
сообщение 16.8.2009, 8:28
Прошивка: 06R_C
Dark Lamer,
Нормальный полет теперь с турболенгом?
Добавлено позже (16.8.2009, 8:30):
Если да, прошу выложить ленг
Dark Lamer
сообщение 16.8.2009, 8:41
https://forum.motofan.ru/index.php?act=Attach&type=post&id=201839
Вот нужный турболенг.
UserRokr
сообщение 17.8.2009, 13:52
Пользователь №: 191 287
Модель телефона: em30 & milestone
Dark Lamer,
ну как дела с модом?
он быстрей чем мод Чачи?
что тебе больше нравица?
стоить ставить?
Dark Lamer
сообщение 17.8.2009, 16:07
Хорошо пока
Не видел последнюю версию мода чачи, точно не могу сказать. Наверное так же или чуть быстрее.
Мне нравица больше поставить сток, вынести рокбокс, мплеер, зтаскмен, еще пару софтин в меню, поставить патченую СГ от китайских друзей для полных прав явы, сделать многозадачность, сделать своп. biggrin.gif
Стоит ставить , если делать все под себя влом.
Сообщение отредактировал Dark Lamer - 17.8.2009, 16:08
UserRokr
сообщение 17.8.2009, 20:00
ох да....поставил....по началу как то не привычно даж)
а терь вродь привык...ниче мод...
Dark Lamer
сообщение 17.8.2009, 20:09
Всмысле непривычно?
timtimer
сообщение 17.8.2009, 20:34
Пользователь №: 193 906
Модель телефона: EM30
Прошивка: R6716_G_71.04.06R_C
Что-то много всего нужно сделать непонятно для чего - можете четко изложить что в этом моде лучше по сравнению с мод "Perfect". Понимаю что офтоп -но тема не раскрыта.... С перфектом хот ьвсе просто -прошил один файл - и радуешься
Dark Lamer
сообщение 17.8.2009, 20:41
завтра будет цельный . это раз.
2 - мне не нравился перфект еще в изначальных версиях, потому выложил альтернативу. желающие могут поставить и посмотреть. Нежелающие - пройти мимо.
timtimer
сообщение 19.8.2009, 19:02
Все надо попробовать, я надеюсь человек риально забыл накатить НоРСА бут. Когда ожидать кумулятивный мод - без патчей... и т.д?
Dark Lamer
сообщение 19.8.2009, 19:13
выложен нормальный вариант.
j-dante
сообщение 19.8.2009, 22:17
Пользователь №: 204 794
Модель телефона: ROKR EM30
скачал мод установил основан не на 04.06 а на 03.06 если шить на бут 06.АС получите труп.
У меня после скачка напряжения на зарядке тело выдало Err:A5,62,4E,01,24 собрал гибридный бут из 06.АС и 06.А9 norsa и вшил затем вшил мод, после чистый 06.А9 norsa и update мод и тело ожило. В целом мод очень удачный мне понравился. Рекомендую всем! Но прежде чем шить наберите на своем теле *#9999# и шейте согласно мануала к вашему софту.
dvrts
сообщение 20.8.2009, 5:29
Из: Lviv
Пользователь №: 162 099
Выложи гибрид плз..
Dark Lamer
сообщение 20.8.2009, 7:27
нужно просто прошить ноу рса для своей версии бута.
aer
сообщение 20.8.2009, 9:10
Пользователь №: 200 517
Модель телефона: Motorokr em 30
Результаты Jbenchmarka2 можно
Kurban
сообщение 20.8.2009, 9:37
Пользователь №: 194 341
Прошивка: MOD от Chacha_Ivanov
А у меня с этим модом mpkgbox 2 перезагружает телефон
Dark Lamer
сообщение 20.8.2009, 10:19
возможно перед тем как ставить, нужно поставить чистую стоковую прошивку.
Bender686
сообщение 22.8.2009, 10:24
Из: Ижевск
Пользователь №: 187 455
Модель телефона: ROKR EM-30
не знаю чего там нашлось быстродейственного но после недели пользования, поставил снова мод pefect. Куда лучше этого
UserRokr
сообщение 22.8.2009, 16:17
Аналогично.мод с разгоном проца по быстродействию сравним с модом от Чачи без разгона...
BlackDeath
сообщение 27.8.2009, 4:28
Прошивка: 06R_C
Dark Lamer, как на Imperfecto HSA вкатать? не пробовал ставить?
UserRokr
сообщение 27.8.2009, 4:57
хотя я наверно переоценил мод от Чачи...
они немного отличаюца по производительности...один быстрее делает одно другой другое
хотя с рагоном проца этот мод вроде как шустрей....
ща еще раз вернусь на него...
тут хоть пути нормальные (пример работают проги Транспарент,МенюЕдитор - вторая особо важна..)
плохо только МПГбокс 2,0 лимитид стоит...
UserRokr
сообщение 27.8.2009, 11:42
че то у меня не получаеца засунуть таскмена на зеленую кнопку ((((( sad.gif sad.gif sad.gif sad.gif sad.gif
оч оч интересный мод =))))
Добавлено позже (27.8.2009, 15:59):
кто нить может обьяснить в чем дело?
Сообщение отредактировал stigr - 27.8.2009, 16:46
Dark Lamer
сообщение 27.8.2009, 15:57
видимо надо пользоваться авторанами.
Pyth_ON!
сообщение 27.8.2009, 17:26
MOTOMAGXX0r
Пользователь №: 198 680
Модель телефона: ROKR EM30/PEARL VE66
Прошивка: R6716_G_71.01.02R_B
Лично у меня на стоковой проше удалось прицепить на зеленую клавишу менеджер задач только добавив маунт в medld.conf, до этого пытался использовать авторан но видимо телефон не успевал промаунтить SysRegistry (autorun.txt грузится на много позднее чем medld.conf ибо его обрабатывает init.sh, который запускается из medld.conf) и загружал оригинал smile.gif
UserRokr
сообщение 28.8.2009, 4:08
Нифига не получается....бред какой то.... 2 3 строчку из медла маунтит...а другие нет...
______________
попробуй код ручками вбить, а не копировать или если копируешь, то с рабочего файла. Я уже несколько раз заметил, копируешь код с сайта, вставляешь, сохраняешь - бяка. Стираешь, набираешь тот же код ручками - всё ок. Чё так не знаю.
Сообщение отредактировал stigr - 28.8.2009, 6:22
Dark Lamer
сообщение 28.8.2009, 6:21
сисрегистри помойму и по авторану можно маунтить
UserRokr
сообщение 28.8.2009, 10:08
ща попробую...
Добавлено позже (28.8.2009, 13:21):
через авторан все встало...а медл полностью сам писал..
dvrts
сообщение 4.9.2009, 11:09
Из: Lviv
перезалить можете? в формате tar
dvrts
сообщение 7.9.2009, 17:38
Из: Lviv
разрешите напомнить о своей настойчивой просьбе
с меня пиво плюсы
mPhoneR
сообщение 13.9.2009, 12:42
Из: 42RUS
Пользователь №: 194 388
Модель телефона: E2\LG GT540
Прошивка: mUbuntu\2.2.2
Mood downloading...
Вышла третья версия, ознакомиться можно здесь
Кто-нибудь уже заюзал?
Новый, быстрый мод для ЕМ30, Пора бы и нашим мотофанам узнать про Imperfecto V2 · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 28.7.2025, 5:34
Форум живёт: 8096 дней
