Новый, быстрый мод для ЕМ30, Пора бы и нашим мотофанам узнать про Imperfecto V2
Dark Lamer
сообщение 14.8.2009, 7:26
Пользователь №: 195 788
Модель телефона: Moto rokr ЖРУ30
Прошивка: ковыряю 03.06
Хочу рассказать вам про неглючный и не тормозной , что особенно важно, мод.
Собственно, зачем это нужно? много фич, активированный своп, мпкгбокс первой и второй версии одновременно, ну и еще по мелочи.
Мод основан на 04.06 прошивке. Перевожу ориинальный пост. Автор мода - Sandip 2u. Индиец .
TO START,NEED TO THANK FEW PEOPLE
1.nikhil007
2.rasputin007
3.ilove3d (the creator of mpkg box2.0)
most of the problems of imperfecto version-1 has been solved ,with the addition/modification of few features
includes all the basic features of imperfecto version-1
plus
1.mpkgbox 2.0
2.now you can install mpkg apps both on phone and memory card
3.lock anything and everything
to name
-snapshots-messages-fixed dial-autorun view-task list
-contacts-profiles-alarm clock-system info-file manager
-shortcut-phone settings-fmradio-browser-mobile internet
-calender-power-cpu speed-bluetooth-themes
-sim services-email-camera-notes-recent calls
-media finder-mpkgbox2.0-connections-new text
4.7 preinstalled mpkg apps
-snapshot (under multimedia)
-cpu speed , power , shortcut (under settings)
-system info , new text , autorun view (under office tools)
-with new text app ,you can directy create and save texts on memory card
5.swap memory (virtual memory) enabled
-need to install swap memory app on memory card
6.full java authorisation
-you need to restart your phone after you intall a java app ,to apply the chages
-the java authorisation is based on cg36 modification
-if you are not happy with it,you can always flash the cg44 modification for java authorisation developed by modders of moto.it168
7.invalid .chm check ,created by ilove3d
-it will check any invalid .chm file related to a skin
-that means to delete a skin you only need to delete it from the skins folder..
-and the next time you open themes,the unwanted skin will be completely deleted
8.all new font (you can see it in the screen shots)
-its called the "designers block"
9.much faster than the previous version of imperfecto
10.you will find out more ,when you use the flash
WHAT YOU NEED
1.RSD LITE LATEST VERSION (GOOGLE IT)
SEE HOw TO USE RSD LITE http://www.mmus.us/forum/showthread....flashing+linux
steps to flash (read the guide thrice before flashing)
1.FLASH No RSA BL (06.A9 or 06.AC depending on your present BL)
TO KNOW YOUR BOOTLOADER
-SWITCH OFF YOUR PHONE AND PRESS THRE BUTTONS TOGETHER * # AND THE POWER BUTTON (ALL THE THREE BUTTONS SHOULD BE PRESSED TOGETHER)
DOWNLOAD http://www.mmus.us/forum/downloads.php?do=cat&id=210
-AFTER YOU FLASH THIS AGAIN CHECK YOUR BOOTLOADER
-IT SHOULD SAY NO RSA
2.FLASH IMPERFECTO
3.DO A CLEAR ALL DATA (MENU/SETTINGS/PHONE SETTINGS/RESET/CLEAR ALL DATA)
-DEFAULT CODE IS 000000,SIX ZERO
4.NOW WHEN YOU CAN SEE THE HOMESCREEN GIVE IT 15 SECONDS TO BOOT PROPERLY
-THEN GO TO SETTINGS/CPU SPEED
-AND SET IT TO 532 MHz
5.AGAIN REBOOT YOUR PHONE
-GIVE IT SUFFICIENT TIME TO BOOT PROPERLY(10-15 SECONDS AFTERYOU CAN SEE THE HOMESCREEN)AND ENJOY.
Для начала хотелось бы поблагодарить нескольких людей :
1.nikhil007
2.rasputin007
3.ilove3d (Создателя MPKGbox)
В данной прошивке было решено большинство проблем первой версии мода , добавлены некоторые возможности , некоторые подверглись переработке.
Добавлено
- mpkgbox 2.0
- Возможность устанавливать mgx приложения как на карту памяти, так и в телефон
- Возможность защитить паролем почти все пункты меню, мключая предустановленные MAGX приложения, среди которых числятся :
-snapshot (в Мультимедиа)
-cpu speed , power , shortcut (Располагаются в Настройках)
-system info , new text , autorun view (в Органайзере)
- Новое приложение для редактирования текстов, которое позволяет сохранять их в
память телефона и на карту.
- Активирован Swap, нужно установить приложение для него на карту памяти.
- Выдача полных прав для Java , для полного примененя изменения прав , нужно перезагрузить телефон после установки приложения. Примененный метод выдачи прав оновывается на модификации CG36. Но если кто-то недоволен, то он может прошить СG44 от моддеров с Moto.it168 для этих же целей.
- Проверка для неправильных файлов *.chm (за авторством ilove3d)
Что она делает?
Проверяет *.chm файл темы. И если найдет файл с ошибками , то Вам останется только удалить скин из папки skins. В результате, когда Вы откроете темы в следующий раз, то этот скин вы уже не найдете.
- новый шрифт (шрифт классный, прямо супер, но русскоязычным пользователям придется его заменить - нет кириллицы)
- Ну и , наконец, этот мод действительно быстр.
Список изменений неполный, при желании вы сможете найти и другие отличия от стандартной прошивки и от предыдущей версии мода.
Как прошить?
Как обычно. Шьете NoRSA бут , а затем прошиваете сам мод, который можно взять по адресу http://www.megaupload.com/?d=DPFAMXOV (не перезаливал, ибо не спрашивал согласия автора)
после сделать Delete all data , установить лэнгпак по вкусу и радоваться.
Переводил я (Dark Lamer), вручную, никаких "Google переводов"
Картинки ,пожалуй, добавлю потом. Однако, ничего такого в них нет.
Сообщение отредактировал Dark Lamer - 19.8.2009, 19:18
Dark Lamer   Новый, быстрый мод для ЕМ30   14.8.2009, 7:26
BlackDeath   Dark Lamer, как успехи с ленгом или русским вводо...   14.8.2009, 11:16
Dark Lamer   пока не пробовал. вечером подмонтирую раскладку и ...   14.8.2009, 11:24
Dark Lamer   сначала дате загрузиться 20 секугд ему после включ...   14.8.2009, 11:58
apple97   кстати столкнулся с проблемой невозможности удален...   14.8.2009, 12:24
Zach   А эсли втулить просто левый ленг который был раньш...   14.8.2009, 16:09
Dark Lamer   я попробую, но не исключены тормоза. хотя не должн...   14.8.2009, 16:15
BlackDeath   Я кстати пробывал твой ленг когда у меня стоял это...   14.8.2009, 20:38
Offset   Что за чат? Сережа, что ты тут по слову в посте пи...   14.8.2009, 21:06
Dark Lamer   Итак, 2 день , полет нормальный , впечатления поло...   15.8.2009, 15:02
BlackDeath   Dark Lamer, Нормальный полет теперь с турболенгом...   16.8.2009, 8:28
Dark Lamer   https://forum.motofan.ru/index.php?act=Attach&t...   16.8.2009, 8:41
UserRokr   Dark Lamer, ну как дела с модом? он быстрей чем м...   17.8.2009, 13:52
Dark Lamer   Хорошо пока Не видел последнюю версию мода ча...   17.8.2009, 16:07
UserRokr   ох да....поставил....по началу как то не привычно ...   17.8.2009, 20:00
Dark Lamer   Всмысле непривычно?   17.8.2009, 20:09
timtimer   Что-то много всего нужно сделать непонятно для чег...   17.8.2009, 20:34
Dark Lamer   завтра будет цельный . это раз. 2 - мне не нравил...   17.8.2009, 20:41
timtimer   >желающие могут поставить и посмотреть. Все над...   19.8.2009, 19:02
Dark Lamer   выложен нормальный вариант.   19.8.2009, 19:13
j-dante   скачал мод установил основан не на 04.06 а на 03.0...   19.8.2009, 22:17
dvrts   Выложи гибрид плз..   20.8.2009, 5:29
Dark Lamer   нужно просто прошить ноу рса для своей версии бута...   20.8.2009, 7:27
aer   Результаты Jbenchmarka2 можно   20.8.2009, 9:10
Kurban   А у меня с этим модом mpkgbox 2 перезагружает теле...   20.8.2009, 9:37
Dark Lamer   возможно перед тем как ставить, нужно поставить чи...   20.8.2009, 10:19
Bender686   не знаю чего там нашлось быстродейственного но пос...   22.8.2009, 10:24
UserRokr   Аналогично.мод с разгоном проца по быстродействию ...   22.8.2009, 16:17
UserRokr   Аналогично.мод с разгоном проца по быстродействию...   27.8.2009, 4:57
BlackDeath   Dark Lamer, как на Imperfecto HSA вкатать? не про...   27.8.2009, 4:28
UserRokr   че то у меня не получаеца засунуть таскмена на зел...   27.8.2009, 11:42
Dark Lamer   видимо надо пользоваться авторанами.   27.8.2009, 15:57
Pyth_ON!   Лично у меня на стоковой проше удалось прицепить н...   27.8.2009, 17:26
UserRokr   Нифига не получается....бред какой то.... 2 3 стро...   28.8.2009, 4:08
Dark Lamer   сисрегистри помойму и по авторану можно маунтить   28.8.2009, 6:21
UserRokr   ща попробую... Добавлено позже (28.8.2009, 13:21)...   28.8.2009, 10:08
dvrts   перезалить можете? в формате tar   4.9.2009, 11:09
dvrts   разрешите напомнить о своей настойчивой просьбе с...   7.9.2009, 17:38
mPhoneR   Вышла третья версия, ознакомиться можно здесь Кто-...   13.9.2009, 12:42
Yonodmc   Я уже почти неделю юзаю... В целом полет нормальны...   13.9.2009, 15:39
FrikerOla   Сегодня тоже обновился до Imperfecto_V.3.0_Happy_B...   13.9.2009, 19:06
Yonodmc   Сам был в шоке! После пёрфекта ощущения не пер...   13.9.2009, 19:11
mPhoneR   Это с турболенгом летает или со стандартным ленгом...   14.9.2009, 1:03
FrikerOla   Это с турболенгом летает или со стандартным ленго...   14.9.2009, 4:04
Yonodmc   Я с турболэнгом юзаю... С простым не пробовал...   14.9.2009, 3:03
slava2007   люди а можете дать ссылку на то как установить рус...   15.9.2009, 12:24
mPhoneR   slava2007, Как прошить Linux телефон Все, что нап...   15.9.2009, 13:16
Ёжищще   подскажите, у меня вот сейчас перфект мод, если я...   15.9.2009, 16:28
Миша77   дай те ссылку ктонибуть на этот монстр.   15.9.2009, 17:35
Ёжищще   http://www.megaupload.com/?d=1ZV457G8   15.9.2009, 17:47
Wazid   После установки заменил папку Rockbox на карте пам...   16.9.2009, 7:12
UserRokr   хм....полный сброс настроек (удаление всех данных ...   16.9.2009, 7:51
klaraivanovna   UserRokr, нужно флекс бит править во вторых есть ...   16.9.2009, 9:10
UserRokr   есть Добавлено позже (16.9.2009, 12:57): klaraiva...   16.9.2009, 9:55
e_n_d_   люди переложите пожалуйста монстра на другой обмен...   16.9.2009, 11:15
dvrts   e_n_d_, я тоже прошу. Догадайся о результате   16.9.2009, 11:43
-=M!B=-   e_n_d_, dvrts, http://depositfiles.com/files/8dbkx...   16.9.2009, 13:07
e_n_d_   e_n_d_, dvrts, http://depositfiles.com/files/8dbk...   17.9.2009, 13:28
dvrts   Это чудо на 04 или 03?   28.9.2009, 1:44
mPhoneR   На 03.06   28.9.2009, 2:20
dvrts   окей. что со мной будет если поставлю на 04?   28.9.2009, 5:20
mPhoneR   Смотри выше. Где написано про тормоза и глюки.   28.9.2009, 5:33
dvrts   да, я знаю что Perfect прекрасен   28.9.2009, 5:39
alxey   при чем тут перфект? это тема про imperfekto   28.9.2009, 5:44
dvrts   при том, что imperfecto [вырезан мат]   28.9.2009, 6:01
alxey   Я ставил и второй и третий и 3.1 и все было нормал...   28.9.2009, 6:24
Миша77   ни че не будит. я ставил и на 03 и 04 разницы не ...   28.9.2009, 10:20
dvrts   Миша77, хоть кто-то утешил   28.9.2009, 19:41
Новый, быстрый мод для ЕМ30, Пора бы и нашим мотофанам узнать про Imperfecto V2 · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 14.7.2025, 23:23
Форум живёт: 8082 дней
