[Milestone] Cyanogenmod, Порт от Nadlabak'a
Ratmagor
сообщение 21.11.2010, 10:50 Закрепленное сообщение!
Куратор темы
Из: Мск
Пользователь №: 59 289
Cyanogenmod4Milestone.
Домашняя страница
Google Code
Багтрекер
Информация в шапке безнадежно устарела. Пинайте старших товарищей, дабы попросились в кураторы и поддерживали тему в актуальном состоянии
CM7 RC3 (ветка Android 2.3.3)
Update.zip брать на GitHub.
GoogleApps для CM7.
Установка ниже.
Сборка от 18 апреля от f_pasha с фиксами, русским и большим количеством свободной оперативки
Релиз CM7 от goodwin_c (19 апреля)
Благодарим artanto за быстрый хостинг
Текущая версия CM7: 10.04.2011-0.08 RC4
0.08-11.04.24 7.0.1
- fix: google maps freeze on launch after repeated gmaps launches (and system reboot after that in the end, sooner or later), lock happened at the time of reading of cached maps from sdcard, fixed by:
1. revert to not moving dalvik-cache to sd-ext (it causes also other performance issues, so I'd disable it anyway), only app and app-private are moved now
2. read_ahead_kb for sdcard set to 32 (yes, I don't care about sdcard speed benchmark results, I prefer stability)
- fix: webkit text wrapping (e.g. gmail text displayed too narrow)
- fix: displayed operator name (for some European networks), forced plmn display for spdi networks
other fixes and features (status bar additions etc.)
Changelog
0.08-11.04.18b 7.0.0
- mkdir fix! http://review.cyanogenmod.com/#change,4720
0.08-11.04.18 7.0.0
- workaround to avoid frequent Gallery3D resets (seg fault in SGX library - usually coming after orientation change)
- sys.keep_app_1 and sys.keep_app_2 properties can be defined (as process names) in build.prop, to allow user to specify up to two apps to be always kept in memory (use with caution, RAM is limited!)
- possible workaround for issue 498 (black screen) - http://code.google.com/p/cyanogenmod4miles...s/detail?id=498
- slight low memory killer parameters adjustment
- sync setting fix, TextView slow scroll fix, arabic keyboard and dictionary in LatinIME
0.08-11.04.10 RC4.1
fix: kernel modules sometimes installed too late (sd-ext not mounted, overclock not applied)
possible fix: locationproxy - ConnectionPending exception (hard to reproduce - needs confirmation)
update: overclock and cpufreq_stats modules - stats freq table automatically updated
kernel module nls_utf8 added and preloaded so that iocharset=utf8 option can be used for cifs mount
fix: 2 different possible NPEs in Settings.apk
VM heap size selection list expanded
10overclock: changed default frequency table (250/400/600/800/1000)
upstream: RTL lang fixes and other updates and fixes
0.08-11.04.05 RC4
kernel modules:
ext4 (finally proper, journalling works, preloaded) - supports also ext2 and ext3 partitions
ext3, ext2 - included, not preloaded
tun (for OpenVPN, preloaded)
cifs (not preloaded, but depends on slow-work that is preloaded), CifsManager app from market can insmod cifs.ko when needed (great for playback of avi files located on windows share via wlan wink.gif
nfs (not preloaded, depends on included but not preloaded auth_rpcgss, rpcsec_gss_krb5, sunrpc, lockd)
xt_multiport (to fix some iptables issues, preloaded)
overclock (+symsearch) reworked by Skrilax_CZ (preloaded)
- 5 frequency slots enabled
- greatly simplified setting of custom frequency/vsel pairs
see /system/etc/init.d/10overclock
- 07app2ext script included in /system/etc/init.d - works via bind mount but is compatible with symlink versions. (warning - do not put more than one app2ext script in init.d as it could result in loss of apps)
- auto boot OpenRecovery (when rebooting to recovery) script added
- SD card reading performance improved (read_ahead_kb set to 2048)
- Usb.apk is now built from source, thanks to Skrilax_CZ, very nice decompilation!
- ADWLauncher drawer scrolling (and zoom animation) optimized to be smoother even when "allow purging of assets" memory performance option is enabled
- finally implemented "no action on plug" (it's under CyanogenMod settings>Display)
- option to disable the dock observer fixed
- fixed gingerbread key event repeating bug affecting camera when using hardware buttons
- upstream: several new RTL fixes and features, 1 important EGL fix, 3 bluetooth fixes (cherry picked), various other fixes
0.08-11.03.16 RC3
- Allow purging of asset bitmaps performance option added - to allow the system to reclaim some more RAM when needed, enabled by default
- proprietary binaries update (one step ahead of )
- etc. (sorry, I could not resist, it's so tempting smile.gif )
0.07-11.03.12 RC3
- music volume steps doubling fixed (when volume button music control is enabled)
- gps not able to be re-enabled until reboot fixed
- etc.
0.07-11.03.09 RC3
- various fixes and enhancements (e.g. Autostarts issue when theme is used fixed, jpeg neon optimization added, various framework patches etc.)
0.07-11.03.04 RC3
- EGL fix (live wallpapers etc.)
- 854x480 mp4 video playback enabled
- volume key long press playback control fixed
- new feature: notification profiles
0.07-11.03.02 RC3
- media provider and other small fixes
- Android 2.3.3, etc.
0.07-11.02.23 RC2
- 2.3 AudioEffect API works now - DSP Manager fixed (by libaudiopolicy compiled from source)
- new battery percent status bar solution
- SMS timestamp options updated, character count can be displayed sooner
- lockscreen fixes
- new advanced camera options
- etc.
0.07-11.02.18 RC1
- low memory killer parameters tweaked: mainly to prevent killing of music player when playing
- CMParts and ADW launcher default changes - keep home/sms app in memory, disabled scrolling cache
- lockscreen updates
- wlan: EAP Phase 2 settings fix
- overlay clean up (Phone.apk)
- etc.
0.07-11.02.15
- wlan: EAP fix (802.1x enterprise)
0.07-11.02.14
- various wlan connectivity issues (some N routers, wpa2, 801.x enterprise etc.) seem to be fixed (for the first time since the GOT 2.2.1 leak). Thanks for the feedback to the wifi test version
- SMS TP-Data-Coding fix (kanged from 0.04-10.12.04)
- Toggle 2G removed (the memory is precious)
- other small things, upstream sync
0.07-11.02.12
wifi test - those who are experiencing wifi issues, please test this build made from alternative wpa_supplicant6 and ti wilink sources and report, thanks.
0.07-11.02.09
- reported lightsensor range fixed
- DSPManager temporarily replaced with proprietary AudioEffects
- little clean-ups and tweaks applied, etc...
0.07-11.02.07
- now playing/album art on lockscreen etc.
0.07-11.02.06
- the previous gps and rotation vector (compass) fixes included
- fixed the disabling of the light sensor when flashlight is on
- fixed 2g/3g toggle in the settings' Power Widget
- temporary battery percentage display included (will be changed)
CyanogenMod6 обновлен 11.03.2011
Текущая версия CM6: 11.03.2011-0.08
Последние изменения:
18.03.2011 0.08-11.03.18
- proprietary files update
- various wlan connectivity issues fixed (some N routers, wpa2, 801.x enterprise etc.), as in current CM7
28.01.2011 0.07-11.01.28
- апдейт проприетарных файлов (boot.img=>kernel, modules etc from SHOLS_U2_05.26.0)
- исправлен баг с СМС (версия ОС должна быть 2.2.2, было 2.2.1 там)
- поддержка греческого LatinIME 2.3 (включая словарь)
- ext4 модуль включен (может быть использован только для ext2 - запись в журналируемые ext3/4 пока работает не корректно)
- новый отдельный BPSW update.zip(такой же как в SHOLS_U2_05.26.0/SHLA_U2_05.0C.0)
Установка:
    После того, как установлен vulnerable recovery, нужно ЗАГРУЗИТЬСЯ В РЕКАВЕРИ МОД, если телефон до этого получал официальное обновление! Дело в том, что с оф. обновлением приходит скрипт, который при загрузке откатывает подозрительный апдейт, поэтому надо загрузиться в Open Update, там войти в терминал и rm -f /system/etc/install-recovery.sh (инфа отсюда: <a href="http://android.doshaska.net/rootable" target="_blank">http://android.doshaska.net/rootable</a>
    by TheZest.
  1. Прошиваем уязвимое recovery(пункты 1-6 по ссылке).
  2. Ставим OpenRecovery. Отсюда. Или отсюда androidiani OR
  3. Скачиваем CyanogenMod.
  4. Закидываем файл с апдейтом в /sdcard/OpenRecovery/updates/
  5. Загружаемся в OpenRecovery.
    теперь желательно сделать nandroid backup.
  6. Делаем wipe.
  7. Выбираем пункт apply update.
  8. Делаем снова wipe.
После установки получаем ОС без маркета и прочих гугл-приложений, чтобы их установить идем на goo-inside.me, качаем Latest HDPI, закидываем к апдейту цианогена и применяем.
Если патча клавиатуры на текущую версию нет, то вместо него можно использовать ruKeyboard.
Для тех кто не ставил GOT 2.2.1, можно поставить последний доступный BPSW
Разгон
По-умолчанию, в этом моде для разгона используется файл /etc/init.d/10overclock.
Для изменения частоты нужно поменять две строчки
echo 60 > /proc/overclock/max_vsel
echo 750000 > /proc/overclock/max_rate
Первая строка отвечает за максимальное напряжение, вторая за частоту в килогерцах. Чтобы поэкспериментировать, найти оптимальное значение и при этом ничего не сломать эти строки можно вводить напрямую с консоли, при этом после перезагрузки параметры примут значения, которые записаны в файле.
Мнения по поводу данной темы, недочёты, исправления и дополнения мне в личку
Сообщение отредактировал Ratmagor - 7.6.2011, 20:17
iBarS
сообщение 17.9.2010, 15:27
Из: Кемерово
Пользователь №: 64 876
Прошивка: 2.2
Home page: http://android.doshaska.net/cm6
Статус: первый публичный альфа релиз CyanogenMod 6 for Milestone (nandroid backup)
Что работает: надеюсь все (GSM, WiFi, BlueTooth, GPS, camera & focus, video & audio recording & playback, app2sd, Adobe flash)
Custom additions to CM6: several additional dictionaries for keyboard
Update: 22.9.2010 0.01c
- includes the previously released hot fixes for APN/GPS (i5) and unwanted boot during charge only mode (i10)
- temporarily used usb_mass_storage_fix script (borrowed from Dext3r) is gone. Motorola's proprietary usbd is back accompanied with Usb.apk (re-engineered to reflect changes in 2.2 os classes and to disable the unavailable options). StorageNotifications.java (part of services.jar) adjusted to not duplicate the notifications from Usb.apk. Usb.apk together with usbd allows to suspend the usb kernel driver and the phone can enter the suspend mode now. Hopefully, the battery life will be better.
- several adjustments in init scripts (includes the check for fighting adbd sometimes launched from the first init instance)
- QuickOffice.apk included
- Street.apk removed, so you can download and install the updated version from the market
- audioflinger recompiled to not include one unnecessary static lib
Note: when adb is enabled and usb connected during boot, you will have to disconnect and reconnect the usb cable before you can mount the SD card to a computer. chmod 644 /system/etc/init.d/02adb_during_boot will disable the early adb mode and the mount will be possible immediately. Early adb is enabled by default (well, it's alpha, right?).
Only system.img has been changed and there should be no need to wipe data when you update from 0.01/0.01b, but I highly recommend to delete cache and dalvik-cache. Use OpenRecovery 1.37 or newer. Don't forget to backup your customized /system/etc/init.d/10overclock first .
Main obstacles encountered:
missing new 2.2 functions in the proprietary audio driver library libaudio taken from 2.1 system, solved by modifications to AudioFlinger.cpp (getInputFramesLost and getRenderPosition).
Известные проблемы:
- intermittent chaotic touch screen responses when connected to USB
- system will reboot when sh.bin used to run the second instance of init or the 2nd init instance itself is killed, because the original init instance will suddenly try continue the deliberately frozen init process on an already running system
To do:
- prepare and release the source for custom building (=> installation via update.zip in the future)
- clean up the mess in init scripts
- invent some better init hijack
- make some non polling usb fix (for now it's using the Dext3r's script - thanks)
- etc.
Примечания:
- the main init scripts are located in /system/etc/rootfs
- clocking options (frequency table, vsel table and governors) can be set in /system/etc/init.d/10overclock
- google apps are already included in this one, I will change that in the future releases
- included BPSW and boot are from the 2.36 RTEU release - radio will work on European frequencies
Установка:
- use OpenRecovery to restore the downloaded system image on your phone
- if you are using Motorola's 2.1-update1 fix update, you do not need to restore the boot and BPSW, restore only the system
- data wipe/factory reset is highly recommended
Ссылки:
http://rapidshare.com/files/419591971/MM1_...alpha_0.01b.zip
http://rapidshare.com/files/420601255/MM1_...alpha_0.01c.zip
Сообщение отредактировал iBarS - 23.9.2010, 13:36
10 страниц V < 1 2 3 4 > »
Ответов(40 - 79)
John-1994
сообщение 2.10.2010, 18:13
the cake is a lie
Из: Киев , Украина .
Пользователь №: 218 960
Модель телефона: Milestone , Bitch !
Прошивка: Froyomod 2.9.3
Сейчас опробуем ...
P.S.
На нынешней кондиции ещё заметил какие-то проблемы с подсветкой , если активировать максимальный уровень , она начинает постепенно гаснуть до низкого , будто бы питания не достаточно . shok.gif
64kbiT
сообщение 2.10.2010, 18:25
Пользователь №: 204 007
Модель телефона: Milestone PCT 1ghz
Прошивка: Cyanogenmod latest
Нее, такого не замечал. у меня вечные ребуты при подключении кабеля huh1.gif
вообще ребуты часто ловлю действительно.
и да, очень важная информация. если у вас стоит данный ром, НИ В КОЕМ СЛУЧАЕ НЕ СТАВЬТЕ рековери от G.O.T, ну по крайней мере разгон через него - либо откат , либо с нуля шить потом, слетает после разгона всё (процессы отвечаюшие за мониторинг железа, отвечающие за саму "функцию телефона" и т.д, полный бизнес вообщем)
з.ы ХААА! Ребуты при подключении кабеля вылечил таким костылем - яростные многочисленные нажатия на кнопку хоум (та самая что с домиком laugh.gif ) при самом процессе подключения помогают
Сообщение отредактировал 64kbiT - 2.10.2010, 18:27
John-1994
сообщение 3.10.2010, 10:26
the cake is a lie
В общем установил я эту недоAlpha более приличным способом , вот что у меня решилось :
1. Flash так и не работает .
2. Подтормаживания прекратились . +
3. Приложения все ещё валятся , причем конкретно .
4. Камера тоже валится , причем после снятия видео практически всегда .
5. Невероятно , он Есть ! +
6. На удивление , на этот раз именно мою точку аппарат нашел , но она временами пропадает . + -
7. Как и было .
8. Пока не перезагружался . +
9. Оказывается прошивка уже имеет модуль для оверклокинга , стоково прошивка работает на 900 MHz .
В общем пока что сама прошивка не юзабельна , но в Froyo я уже успел влюбится , не считая мелких косметических мелочей , скорость действительно увеличилась , судя по бенчмарку Quadrand Standard (бенчмарк всего АО) , аппарат имеет 1338 баллов , хотя лично я именно визуального прироста скорости не заметил , ну разве что чуть-чуть .
P.S.
В общем сношу я эту сборку , и следующий 2.2 , который я хотел бы увидеть - это официальный , и на новом ядре . yesyes.gif
64kbiT
сообщение 3.10.2010, 11:21
флеш есть. его надо с маркета ставить сначала.
Ratmagor
сообщение 4.10.2010, 10:29
Куратор темы
Из: Мск
Пользуюсь уже третью неделю cyanogenmod'ом. Из минусов могу отметить:
1. Кривая работа бт-наушников (подключаются не с первого раза)
2. Периодические выпадения в Kernel Panic. (не чаще трех раз в сутки smile.gif )
3. На последней версии снова жутко жрется аккум. На 0.01с более-менее сносно. На два дня хватает.
4. После звонков с Sipdroid до меня иногда не могут дозвониться (но это случалось и на стоковой прошивке)
А так все отлично, в целом работает. Никаких крашей камеры и видео не наблюдал, вероятно, потому что пользуюсь ими ооооочень редко.
PS Wi-Fi, кстати, отключается в спящем режиме, при пробуждении подключается обратно. Может в этом и есть "плохая работа"? У меня никаких проблем с этим нет.
Сообщение отредактировал Ratmagor - 4.10.2010, 10:31
John-1994
сообщение 4.10.2010, 11:47
the cake is a lie
Близко , но нет , у меня с Wi-Fi проблемы заключались в том , что находились не все точки , порой было так , что мою , от которой я находился за 3 метра аппарат не видел , но зато соседскую на два этажа выше даже видел .
GPS - в ответственный момент ну очень долго искал сеть , нашел только через минут 20 , до этого я ориентировался по Wi-Fi и GSM вышкам . Когда уже нашло , стоит усыпить девайс и снова разбудить , как местоположение снова не определяется "сразу" , я тогда прямо на улице перешился обратно на стандартную ... yesyes.gif
64kbiT
сообщение 4.10.2010, 18:26
уфффф, при подключении юсб для передачи данных ухожу в ребут сразу. как решить?
XVilka
сообщение 5.10.2010, 6:16
Пользователь №: 109 689
Прошивка: CM10
Вот тут можно высказать пожелания и обратную связь nadlabak-у http://forum.droid-developers.org/viewforum.php?id=16
Ratmagor
сообщение 5.10.2010, 8:02
Куратор темы
Из: Мск
Цитата(Silent_Bob @ 5.10.2010, 5:21) *
Всё там прекрасно распаковывается ...
ps.gif Перекладываю оригинал и *.tar.gz ...
Спасибо, зип, правда не открывается. У меня проблемы, вероятно. :3
64kbiT
сообщение 5.10.2010, 8:15
поставил клавы, которые выложил боб, на цианоген. хард клава должна же работать ? так всё хорошо, но при попытке сменить язык (EN|РУ) он не меняется, и уходит в ребут через 5 (!) секунд, не сразу.
Сообщение отредактировал 64kbiT - 5.10.2010, 8:15
iBarS
сообщение 9.10.2010, 5:30
Из: Кемерово
Прошивка: 2.2
Update:
06.10.2010 0.02-10.10.06
- media playback - for the local media playback, opencore instead of stagefright player will be used. Please note that it will lower your Quadrant score. Quadrant seems to be unable to test the h264 at all when stagefright is used - it considers the h264 test done immediately, while when opencore is used, the test is actually carried. Therefore, the simple change of the property media.stagefright.enable-player=true will double your score. But it has no connection to the real world. Actually, the h264 playback by the stagefright player has slightly higher CPU demand than opencore h264 playback (and both are using the same TI OMX libraries that do the actual h264 decoding on the hw DSP). If you don't care about the real performance but only about the benchmark results, you can change the media.stagefright.enable-player property back to true in /system/build.prop.
This change fixes the short audio sample playback, aac incompatibilities and possibly other media issues too.
addition: quote from mail from the Quadrant developer - I have not determined why Stagefright produces much higher values yet. Perhaps this is caused by hardware acceleration or some compatibility issues. Either way, it will take some time to investigate this problem and design a proper solution.
- Camera - the recent CyanogenMod changes have been reverted and the zoom support corrected. The continuous autofocus mode introduced recently by Cyanogen seems to not suit well our current camera implementation.
- kernel tuning script added to init.d. The scheduling/memory tweaks are enabled, the network tweaks commented out by default. You can change it to your liking by editing of the /etc/init.d/11kernel_tuning script.
- another AGPS change - back to the Motorola way. After this update.zip installation, please delete manually the file /data/location/location.cfg and edit your APN setting to delete the supl from the APN type (I will change the default APN settings directly in the build later). Then reboot.
- Toggle 2G/3G app is included for saving the battery, set it to switch to 2G automatically whenever the 3G is not actually needed.
Update:
07.10.2010 0.02-10.10.07
- simple nightly build reflecting the recent commits to the CyanogenMod source tree
+ fix of the Toggle 2G/3G app signature, kernel tuning script updated
Сообщение отредактировал iBarS - 9.10.2010, 5:45
John-1994
сообщение 10.10.2010, 21:03
the cake is a lie
Парни , пользователи Сайонджена , очень прошу выдрать .Apk программы-эквалайзера , мне она при тестировании прошивки очень понравилась , но найти установку после сноса так потом и не смог . Буду очень благодарен . wink.gif
iBarS
сообщение 11.10.2010, 11:52
Из: Кемерово
Прошивка: 2.2
Update:
11.10.2010 0.02-10.10.11
- tcmd replaced with new patched version (I suspect that it was contributing to the BP panics, but it needs much more testing), usbd replaced
- back to sh init hijack, now finally stable thanks to the 2nd-init (many thanks to Skrilax_CZ, great job!). No more multiple init instances - much cleaner solution to defeat the signed boot.img obstruction on the init level at least.
- latest CM commits included
- fallback supl server enabled in /etc/location.cfg
- slightly higher vsel for lower frequencies in /etc/init.d/10overclock
iBarS
сообщение 16.10.2010, 2:00
Из: Кемерово
Прошивка: 2.2
Он просто написал, что тестит см6 на 32 ядре (froyo). Он не выкладывал еще..
M.org
сообщение 17.10.2010, 8:47
Просто Зверь
Пользователь №: 879
Модель телефона: HTC One M8+Moto 360 2nd
Прошивка: GPE
Гм, а как же "невозможность изменить ядро" на мылстоне?
iBarS
сообщение 17.10.2010, 10:04
Из: Кемерово
Прошивка: 2.2
Дык так и есть. Просто утек билд froyo для майлстоуна..
Илья Дорошенко
сообщение 18.10.2010, 11:54
Из: под славным Тольятти
Пользователь №: 149 988
Прошивка: Самопал
Fgfnbz
народ уже давно юзает альфа версию фройо от моторолы... на новом ядре...
iBarS
сообщение 18.10.2010, 12:04
Из: Кемерово
Прошивка: 2.2
Цитата(John-1994 @ 18.10.2010, 18:35) *
С чего бы это вдруг ?
Просто по идее именно установка новой прошивки должна сопровождатся соответствующим сертификатом или ключом . А те перепрошики , которые вы делаете - это далеко не перепрошивка , вы просто восстанавливаете файлы системы из бекапа , ядро ОС остается на месте . wink.gif
Это мне было? Сайты то читайте.. Пожалуйста Android 2.2.1 для мотора, на 32 ядре
Илья Дорошенко
сообщение 20.10.2010, 7:05
Прошивка: Самопал
Fgfnbz
ГОТ нее склепал сборку!!! они только дофиксили то что мотор еще фиксит!!!
John-1994
сообщение 14.11.2010, 14:55
the cake is a lie
Кстати , а никто не сталкивался с проблемой того , что в idle режиме аппарат хряцает невероятное количество энергии ?
И делает это не какая-то сторонняя программа , а сам режим ожидания . Полного заряда при полном неиспользовании аппарата хватает на 2 дня . dwarf.gif
Ratmagor
сообщение 17.11.2010, 22:35
Куратор темы
Из: Мск
Обновись на последний циан. Баг с аккумом пофиксили. Теперь заряда хватает на 2-2.5 дня.
Asmodey777
сообщение 19.11.2010, 9:29
Пользователь №: 157 350
Прошивка: Cyanogenmod 6
а у кого сколько показывает Linpack на 1000Мгц? GOT_RTEU_2_2_1FULL с последним Цианогеном 0.04-10.11.16-cm-6.1.0-RC4
у меня
MFLOPS: 15,35
Time: 5.46
Norm Res: 5.68
Просто интересно,
мне кажется маловато у меня.
Потому как по топ на 1000Мгц дройды и вехи у всех MFLOPS больше 20, а некоторые больше 30.
John-1994
сообщение 19.11.2010, 13:09
the cake is a lie
Я использую Quadrant Benchmark , и общий показатель у меня самый высокий среди 2.1 устройств и 2.2 Nexus One . По сравнению в 2.1 , огромное количество баллов набирается из-за колоссального прироста при вычислениях на CPU , так что если остальные устройства тоже прогнать через 2.2 , то Milestone окажется примерно между Galaxy S и Desire/Nexus и остальными , которые аппаратно слабее её .
P.S.
Частота 1000 MHz(56 vsel) , для меня это стандарт спустя две недели от покупки .
lelvisl
сообщение 20.11.2010, 22:28
Пользователь №: 116 837
Модель телефона: Milestone & A1200
Сообщение отредактировал lelvisl - 20.11.2010, 22:28
disparo
сообщение 26.11.2010, 14:20
Пользователь №: 69 517
Модель телефона: MILESTONE
Я поставил, через полдня откатился обратно на стоковую прошивку по причине того, что телефон начал греться в руке как утюг, даже выгрузка оверклочного модуля не спасает.
Ratmagor
сообщение 26.11.2010, 14:30
Куратор темы
Из: Мск
У меня греется не сильнее чем на стоковой, не знаю с чем связано. Я пользуюсь на 750Мгц/45vsel.
disparo
сообщение 30.11.2010, 15:05
Свежий патсн под хардклаву:
http://4pda.ru/forum/index.php?showtopic=1...t&p=5789115
Работает на версии CM RC5 от 29-го ноября - проверял.
John-1994
сообщение 2.12.2010, 12:59
the cake is a lie
Disparo , не знаешь как убить значок на панели уведомлений ?
P.S.
Последние обновления меня невероятно порадовали . Господа , считайте 2.2 для Milestone уже здесь !
Последняя версия очень шустрая , не имеет ни одного замеченного мною ранее бага , USB Tether после мелкого шаманства работает , Google Apps тоже можно установить .
Ratmagor
сообщение 4.12.2010, 1:21
Куратор темы
Из: Мск
Самое главное - не забывать перегружаться после зарядки. Иначе оно в сон не уходит.
disparo
сообщение 6.12.2010, 8:30
Какой значок? Панель управления питанием GPS, WiFi и Bluetooth? Других посторонних значков у меня там не было.
Да, RC5 не перестает радовать! Есть небольшой глюк с ВиФи - он не всегда видит мою домашнюю точку, кажется, его поправили в выпуске от 4.12, но пока нет клавиатурного фикса, апгрейдиться не буду.
John-1994
сообщение 7.12.2010, 17:54
the cake is a lie
Значок патча для клавиатуры с предыдущей страницы .
При выдвинутой клавиатуре на notofication bar появляется значок низкого разрешения , изображающий флаги РФ или США , то есть нынешнюю раскладку клавиатуры . В принципе такой значок очень полезен , но разрешение изображения просто вырывает глаза . blind.gif
Добавлено позже (7.12.2010, 21:24):
Ахтунг !
Патч для аппаратной клавиатуры , который на предыдущей странице выложил Disparo с версией Cyanogen 04-го декабря НЕ РАБОТАЕТ , после установки получаете вечный ребут . rtfm.gif
Сообщение отредактировал John-1994 - 7.12.2010, 19:30
Ratmagor
сообщение 8.12.2010, 20:04
Куратор темы
Из: Мск
Ахтунг !
Совместимость патчей от версии к версии — это исключение, а не правило. Перед обновлением, патчами и т.п. делаем бэкапы.
sibkor
сообщение 10.12.2010, 7:03
Пользователь №: 219 059
Прошивка: 2.3.2 Cyanogenmod7
Поставил циан,перестал работать 3g и edge,перепрошиваюсь на оф. прошивку не помогло,ПОМОГИТЕ
Ratmagor
сообщение 10.12.2010, 11:19
Куратор темы
Из: Мск
Ни разу не сталкивался с подобным. Аппарат российский? Попробуй сделать вайп и поставить официальную через RSDlite.
Сообщение отредактировал Ratmagor - 10.12.2010, 11:20
sibkor
сообщение 10.12.2010, 21:30
Да телефон российский,значек edge или 3g горит,а инета нет
John-1994
сообщение 10.12.2010, 21:55
the cake is a lie
APN настроен ?
sibkor
сообщение 11.12.2010, 8:43
Цитата(John-1994 @ 10.12.2010, 21:50) *
APN настроен ?
Да настроен
Добавлено позже (11.12.2010, 8:44):
Сделал вайп,инет заработал.Спасибо
Vinndimon
сообщение 12.12.2010, 10:13
Из: Москау
Пользователь №: 192 549
Модель телефона: Photon, Milestone, EM30
Прошивка: CM10, CM7, RSP
Ссылка на OpenRecovery не работает.
Ratmagor
сообщение 12.12.2010, 15:13
Куратор темы
Из: Мск
Обновил закрепленный пост. Вышла новая версия цианогенмода.
[Milestone] Cyanogenmod, Порт от Nadlabak'a · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 29.7.2025, 22:43
